OliverRaffle Posted June 3, 2013 Share Posted June 3, 2013 Great work on the termies . Looking very menacing with their energy crackling hammers. I love the effect, how did you do it? (I'd like to steal it.. :) ) Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3386164 Share on other sites More sharing options...
Artemid Posted June 3, 2013 Author Share Posted June 3, 2013 Great work on the termies . Looking very menacing with their energy crackling hammers. I love the effect, how did you do it? (I'd like to steal it.. ) Thanks! It's pretty easy, actually: 1) Paint the hammer like normal (here, Boltgun Metal/Leadbelcher, washed with Nuln Oil, Dwarf Bronze for details) 2) Paint your lightning crackles with a dark blue. I'm using Vallejo Game Color Imperial Blue - probably Regal Blue for GW. These lines can be fatter because you'll go over them later. 3) Go over your crackles with Ultrasmurfs blue. Try stay inside the dark blue base a bit so you can still see a bit of the edge. 4) Go over the crackles again with more careful applications of straight white. This is the pass that really makes them pop, but it helps a lot to keep the white lines thinner so you can really see the blue behind it. That's it! If you want to get fancy you can blend the colors up, add more stages, glaze the thing afterwords, etcetc. You could easily switch colors too, it's just dark color/light color/white getting successively thinner - but it's very time efficient for the impact I think :) Big fan of your previous DW here so can't wait to see more progress on these guys. Best of luck with your vow. Cheers I Thanks I! I'm really debating trying out some weathering this go around - paint on some gashes and holes, maybe (maybe!) do some sponging, and I have FW weathering powders in the mail. Only, I'm not sure that painted damage would look that great with the heavily drybrushed armor that already looks very textured, unlike painting damage onto flatter or blended colors. Thoughts, anyone? The quartered scheme for the successor chapter is awesome! Thanks man! When I finish up these Termis I want to go back and finish those guys up. And I think I really want to use the new FW Praetor kit to make their Chapter Master because the model is that good, even though it's not what I'd been thinking I'd do for him. Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3386545 Share on other sites More sharing options...
Bryan Blaire Posted June 3, 2013 Share Posted June 3, 2013 Artemid, those new DW look boss! The chain-fist guy looks ready to tear some bad boys (:ph34r: Fallen :ph34r:) up one side and down the other. As far as the battle damage, I think if you stick to sponged damage it might look better with the texture already from the dry-brushing. Plus, if you vary your sponge type, you might stil get a couple of larger damage spots to paint 3D style to look like chunks taken out of the armor, etc. To make it show up on the white, you could probably get away either metallic or brown, but grey might fade in too much and black would probably be too stark. Looking forward to seeing what you come up with and that Praetor sounds awesome! Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3386609 Share on other sites More sharing options...
Artemid Posted June 7, 2013 Author Share Posted June 7, 2013 Thanks a ton Bryan! That means a good deal coming from someone of your caliber Good call on the sponging. I could go with Scorched Brown, or possibly Charadon Granite given how a tiny bit of overspill from basing the Sgt's bunny ears looks. Took a break from blocking in basecoats and did up the Sgt's power sword in a new style, following valhouth's excellent guide: http://i.imgur.com/A02OxXA.jpg?1 http://i.imgur.com/Wp6qXPI.jpg?1 Pretty good for a first go I think! I actually like the back side better because more of the basecoat is showing through, so it's a little higher contrast. I'd like to go back and redo all the rest of my non-Heavenfall blades this way I think. Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3389812 Share on other sites More sharing options...
Artemid Posted June 10, 2013 Author Share Posted June 10, 2013 http://i.imgur.com/raAvmXS.jpg Progress off the last few days of sitting down with brushes and pro StarCraft 2 :D Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3391192 Share on other sites More sharing options...
Gillyfish Posted June 10, 2013 Share Posted June 10, 2013 They look to be very impressive Artemid - congratulations! Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3391222 Share on other sites More sharing options...
Isiah Posted June 10, 2013 Share Posted June 10, 2013 Nice power sword there Artemid :tu: Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3391352 Share on other sites More sharing options...
Artemid Posted June 28, 2013 Author Share Posted June 28, 2013 Thanks! This is where they are now. They're basically done, although I should probably get some weapon highlights on, and I'd really like some thoughts about weathering options or if I should at all (I know that sponge has been suggested). http://i.imgur.com/VPVWags.jpg Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3402751 Share on other sites More sharing options...
Interrogator Stobz Posted June 28, 2013 Share Posted June 28, 2013 Looking great Artemid, I don't think your style needs weathering, it already has plenty of visual depth. Nice work :tu: Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3402760 Share on other sites More sharing options...
Artemid Posted June 28, 2013 Author Share Posted June 28, 2013 Looking great Artemid, I don't think your style needs weathering, it already has plenty of visual depth. Nice work Yay compliments from Stobz! That is a pretty good point about depth. I can always go back and add stuff later too, so I'll try to knock the bases out soon since I need to build them. Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3403143 Share on other sites More sharing options...
elmo Posted June 28, 2013 Share Posted June 28, 2013 Very nice work - I am lovin the almost stone effect armour rather than the usual bone. Very effective ;) Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3403176 Share on other sites More sharing options...
Artemid Posted June 29, 2013 Author Share Posted June 29, 2013 Thanks Elmo! Very encouraging to hear it from you guys! Starting on bases. Adding a bit more rubble-flair than normal for me: http://i.imgur.com/0GBwcA1.jpg Eventually I might even graduate to cork! Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3403711 Share on other sites More sharing options...
Artemid Posted June 30, 2013 Author Share Posted June 30, 2013 Vow complete! http://i.imgur.com/LB7wmXq.jpg?1 Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3404313 Share on other sites More sharing options...
Artemid Posted July 3, 2013 Author Share Posted July 3, 2013 Up next (I think), I steal Cactus' awesome Deathwing Knights conversion: http://i.imgur.com/GxFuRKd.jpg Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3406166 Share on other sites More sharing options...
Cactus Posted July 5, 2013 Share Posted July 5, 2013 Excellent, I've been itching to see how others tackle the same project. Slicing the forearms off the shields is chore, isn't it? Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3407329 Share on other sites More sharing options...
Artemid Posted July 5, 2013 Author Share Posted July 5, 2013 Excellent, I've been itching to see how others tackle the same project. Slicing the forearms off the shields is chore, isn't it? Yeahhh I just attacked the arms with my super sharp snippers and cleaned it out some with my xacto. I have yet to decide how rigorous I will be about joining forearm and shield. I get really lazy about actually using GS, so I may file down the outside of the forearm instead. We shall see how posing goes :D Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3407387 Share on other sites More sharing options...
Artemid Posted August 5, 2013 Author Share Posted August 5, 2013 Mocking up Chapter Master Machiu Troyan of the Angels Ardent for Grot's challenge. Have the Sverin Loth kit on the way, hopefully will be grabbing a helmet and maybe a torso from it. Shoulder pads are not set but I think are close. Did a whole bunch of work to the hammer to make it look more correct to me.. and then I realized I should have just used a GK hammer and arms set. Oh well. Thoughts on the forearm pad to hide the mangled Angelus Bolter? http://i.imgur.com/ou3BCxil.jpg http://i.imgur.com/xfb5lbZl.jpg http://i.imgur.com/QyfkdRNl.jpg http://i.imgur.com/hA7AJxXl.jpg http://i.imgur.com/4Bs5YQKl.jpg Link to comment https://bolterandchainsword.com/topic/257304-da-1st-4th-angels-ardent-capn-kitbash/page/3/#findComment-3412557 Share on other sites More sharing options...
