Jolemai Posted October 16, 2014 Share Posted October 16, 2014 Thanks baz Work has started on the Baneblade. Not much to look at so far but the sponsons are built. So much going on at the same time http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0648_zps18dee499.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0649_zpse72b4631.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0650_zpsbdfb1d46.jpg If you want to know how I went about with the magnetised weapons (special thanks to Sox for the idea of magnetising the lascannon turrets ) then please be patient as I am working on a tutorial which will go live, hopefully, by the start of next month Are you undercoating on the sprue? walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3834923 Share on other sites More sharing options...
WarriorFish Posted October 16, 2014 Share Posted October 16, 2014 Good stuff! I am eager to see this tutorial but first I should really prepare for Big Guns ;) Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3834950 Share on other sites More sharing options...
elmo Posted October 16, 2014 Author Share Posted October 16, 2014 Are you undercoating on the sprue? I tend to build sub assemblies then spray them, shade and detail then fit them all together and weather last. Vash and CoffeeGrunt 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3835042 Share on other sites More sharing options...
elmo Posted October 17, 2014 Author Share Posted October 17, 2014 Planning far ahead again... I was pottering around in my workshop/shed doing some cleanup after a DIY job and found an old football table base. It is 5-6mm thick fibreboard and it got me thinking... When I get around to building up my HW teams I want them to be based so as to be able to remove one of the models as a wound marker. One thing lead to another and these where the result :) The discs are a little over 60mm (nearest size of cutter I had) with a 26mm diameter recess drilled out to a depth to fit the standard 25mm plastic base. They have just been painted with a watered down PVA and when dry will get a spray of black primer. I only made 9 to start off with but I have enough fibre board for at least another 9 :) If anyone is interested in making their own you will need one of these: Lighting Holesaw, 65mm Diameter and one of these: Kitchen Cupboard Door Hinge Hole Cutter Drill 25/26mm diameter and naturally a drill with a drill stand CoffeeGrunt, WarriorFish, CommissarZac and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3836341 Share on other sites More sharing options...
WarriorFish Posted October 17, 2014 Share Posted October 17, 2014 Cool that's a good use of old materials, now you've just got to model some HWTs up ;) walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3836368 Share on other sites More sharing options...
elmo Posted October 19, 2014 Author Share Posted October 19, 2014 I have made myself a promise as I now have 4 projects on the go at the same time... 1. Finish off the 10 x snap fit figures (this week) 2. Build 9 x HW teams on the bases I have made (assemble ready for spraying next weekend - ML, Mortars, Lascannons/Heavy Bolters) 3. Finish off the Sentinel I just could not resist opening in the last couple of days (this week - if time allows) 4. Then concentrate on the Baneblade (I need to clear some space on the painting table first!) Lets see how single minded I can be Oh look - shiny thing - distracted!!! WarriorFish, Cod, Kierdale and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3838025 Share on other sites More sharing options...
Vash Posted October 19, 2014 Share Posted October 19, 2014 Sounds like a lot on your table. Good luck and keep us updated! CoffeeGrunt 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3838083 Share on other sites More sharing options...
elmo Posted October 19, 2014 Author Share Posted October 19, 2014 Thanks Vash - will do. There always seems to be more to do. It will never end ;) walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3838268 Share on other sites More sharing options...
WarriorFish Posted October 19, 2014 Share Posted October 19, 2014 My list of things has increased today, when will we learn? You know what they say, better to be busy than bored and what better thing to be busy with than 40k? We'll need regular updates of course to check that you're still working hard :P CoffeeGrunt, captain sox and elmo 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3838277 Share on other sites More sharing options...
Kierdale Posted October 20, 2014 Share Posted October 20, 2014 Great work on those bases! Looking forward to seeing the Sentinel particularly. elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3838989 Share on other sites More sharing options...
elmo Posted October 20, 2014 Author Share Posted October 20, 2014 I'll try not to dissapoint ;) Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3839005 Share on other sites More sharing options...
WarriorFish Posted October 20, 2014 Share Posted October 20, 2014 We expect no less - a Commissar always chooses death before dishonour! :P elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3839014 Share on other sites More sharing options...
elmo Posted October 24, 2014 Author Share Posted October 24, 2014 I have made myself a promise as I now have 4 projects on the go at the same time... 1. Finish off the 10 x snap fit figures (this week) 2. Build 9 x HW teams on the bases I have made (assemble ready for spraying next weekend - ML, Mortars, Lascannons/Heavy Bolters) 3. Finish off the Sentinel I just could not resist opening in the last couple of days (this week - if time allows) 4. Then concentrate on the Baneblade (I need to clear some space on the painting table first!) Lets see how single minded I can be Oh look - shiny thing - distracted!!! 1. Completed - no squad markings yet till I work out where they are going. http://fc00.deviantart.net/fs71/f/2014/297/a/b/troop_reinforcements_by_elmo9141-d83yy4w.jpg 2. 3 x Missile teams are ready for spraying 3. Sentinel is magnetised and about 2 painting days short of being complete http://fc05.deviantart.net/fs70/f/2014/297/4/f/wip___magnetised_sentinel_by_elmo9141-d83yyqw.jpg 4. no progress :( WarriorFish, walter h and CoffeeGrunt 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843149 Share on other sites More sharing options...
WarriorFish Posted October 24, 2014 Share Posted October 24, 2014 Excellent progress, they look great as ever. Now I want to get some more Sentinels - maybe something for Christmas? :P How fiddly was the magnetising as it's a compact kit? elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843197 Share on other sites More sharing options...
elmo Posted October 24, 2014 Author Share Posted October 24, 2014 The weapons where no more difficult than the chimera, the roll bars where a complete ... You need a steady hand and a slow drill but it was worth it :) The tutorial is now live for all interested Guardsmen WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843231 Share on other sites More sharing options...
WarriorFish Posted October 24, 2014 Share Posted October 24, 2014 I've done some fine drilling by hand before, so if I can do it everyone can - patience is a virtue though :P Good job Elmo, the magnetising tutorial goes from strength to strength - I hope we can see some more magnetising efforts from comrades in the future :D elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843237 Share on other sites More sharing options...
elmo Posted October 24, 2014 Author Share Posted October 24, 2014 I had best see some of the Guardsmen putting these tutorials to good use in the upcoming "Big Guns" or a certain Commissar's bolt gun may have to come into force.. Morale officer and all that don'cha know ;) I really enjoy the thought process behind the magnetisation, especially when I am forced to think a little laterally like with the scout roll cage and the Landraider Ares. A challenge and fun to boot :) The Baneblade will be my greatest challenge so far... Will it fight against being magnetised? Will it win? This Commissar will not back from his duty! On a side note - think of the chaos I am causing to the bitz sites... I never have any left over :) WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843249 Share on other sites More sharing options...
captain sox Posted October 24, 2014 Share Posted October 24, 2014 (edited) I've been away for a bit, sadly only lurking in the background. Work and real life have taken up so much time. I have done some modelling, but no painting sadly. Elmo, you are a master! Your models are spectacular! I'm looking forward to seeing your Baneblade. Do you by chance use weathering powder for the dirt/dusty effect? I'm doing a desert camo scheme too, though somewhat radical and would love to know your secret! I think we need to expedite this "Big Guns" contest... I'm itching to paint my Hellhammer! Fantastic work and oh so inspirational my friend! Edited October 24, 2014 by captain sox elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843269 Share on other sites More sharing options...
elmo Posted October 24, 2014 Author Share Posted October 24, 2014 Thanks Sox :) I have invested in some Tamiya weathering powder but only use it for the soot effect at the moment. My mud/dust is done using a sponge and the following colours in progressively lighter coats... Bestial Brown, Graveyard Earth then Bleached Bone. My normal mud for the DA is taken a step darker with Scorched Brown, Bestial Brown then Graveyard Earth - it all depends if you want European mud or Desert dust ;) The Big Guns best not start too soon as my 8 in 1 Baneblade has not made much assembly progress due to other shiny toys (yes I am talking to you Mr. Sentinel!) :( Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843281 Share on other sites More sharing options...
captain sox Posted October 24, 2014 Share Posted October 24, 2014 Cant wait to see it!! Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3843510 Share on other sites More sharing options...
elmo Posted October 26, 2014 Author Share Posted October 26, 2014 +++ Message from the Commissariat +++ Imperial Guardsmen! Recently the glorious 711th CCAB, during a minor skirmish on an insignificant rock captured human turncoats calling themselves Gue'Vesa. These so called Tau human helpers have now renounced their allegiance to the blueskins and have rejoined the Emperors holy armies. A decree of decimation has been declared by the Commissariat and once the punishment has been carried out, they will be absorbed into the 711th as battlefield replacements. Have no fear Guardsmen, the Commissars will be closely observing these turncoats and on the first infringement they will be harshly dealt with. The Emperor Protects +++ Message ends +++ I made these Gue'Vesa during the 4th Ed, when they where an approved addition to Tau forces. Unfortunately they have been languishing at the rear of my shelf, unused and unloved for a couple of years so with my IG collection steadily increasing and with replacement Fire Warriors, now is the time to strip them and re-purpose them to serve the Emperor. The Simple Green awaits... http://i814.photobucket.com/albums/zz66/jonbrooks_photo/PA260001_zpsbac32af6.jpg Kierdale, walter h and CoffeeGrunt 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3844484 Share on other sites More sharing options...
WarriorFish Posted October 26, 2014 Share Posted October 26, 2014 A glorious death in the service of His armies is more than they deserve! Once more the beneficence of the commissariat knows no bounds :P elmo and Kierdale 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3844625 Share on other sites More sharing options...
CoffeeGrunt Posted October 26, 2014 Share Posted October 26, 2014 No, not the Gue'vesa, pleeease! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3844639 Share on other sites More sharing options...
Marshal Argos Posted October 26, 2014 Share Posted October 26, 2014 I think your Sgt. lost is arm.. a warning from the commissariat perhaps? Shall you do these up in the same camo as the rest of your troops, or leave some sort of marking on them showing that they were once traitors that have rejoined the light? Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3844774 Share on other sites More sharing options...
elmo Posted October 26, 2014 Author Share Posted October 26, 2014 No, not the Gue'vesa, pleeease! Yesssss... Till GW bring back Gue'vesa ;) I think your Sgt. lost is arm.. a warning from the commissariat perhaps? Shall you do these up in the same camo as the rest of your troops, or leave some sort of marking on them showing that they were once traitors that have rejoined the light? The arm dropped off just as I was moving them.. Could be a sign :) They will be painted up just the same as the others. The change of allegiance is just a bit of fun. It was more to do with the models where never used and it seemed a waste. Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/14/#findComment-3844798 Share on other sites More sharing options...
