Shovellovin Posted August 3, 2018 Share Posted August 3, 2018 I use micro sol and micro set on decals that I bought from chapter customizer. The products work just fine. Yes, I am going to try inkjet paper. I could get access to a laserjet printer at work, but as it is a communal printer, always scared somebody will print their work stuff on my expensive paper Will give it a test, cheers. If too strong can the microsol/set be diluted down, or is it best just to use it for smoothing the decal out only? Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5137529 Share on other sites More sharing options...
LutherMax Posted August 4, 2018 Author Share Posted August 4, 2018 Congrats with featuring on Warhammer Community! They are a thing of beauty Well deserved Luther. It's always a pleasure to see your finished models - although it does make me feel somewhat inadequate in my own efforts... WELL DESERVED appearance on Warhammer Community! I saw your feature on the Warhammer Community site and then was told your a frater! Really stunning work and I love your Shrike conversion. Thanks guys!! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5137901 Share on other sites More sharing options...
LutherMax Posted August 5, 2018 Author Share Posted August 5, 2018 Next up some plasma Inceptors... Bjorn Firewalker, Dosjetka, The Yak and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5138439 Share on other sites More sharing options...
thewarriorhunter Posted August 5, 2018 Share Posted August 5, 2018 The yellow on your shoulder pads is so vibrantly muted... if that makes any sense at all. Really helps the models to pop. Honda and LutherMax 2 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5138587 Share on other sites More sharing options...
Bjorn Firewalker Posted August 5, 2018 Share Posted August 5, 2018 Well done. However, I think more models should lean forwards, as if diving into battle. I understand your models lean back to dodge enemy shots, but it also looks like they're falling back, i.e., withdrawing from battle. People (including myself) often mistake such reactive behavior as passive, even submissive behavior- not traits you want associated with one's own army. Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5138703 Share on other sites More sharing options...
Mostwanted Posted August 5, 2018 Share Posted August 5, 2018 How are you painting at such a high standard and knocking models out at a pretty quick rate? I'm very impressed! It's taking me ages to get through just one tactical squad! If you have time could you run through your techniques for the inside of the jump pack vents and the colours used please? Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5138862 Share on other sites More sharing options...
LutherMax Posted August 5, 2018 Author Share Posted August 5, 2018 Thanks for the comments and congrats! Well done. However, I think more models should lean forwards, as if diving into battle. I understand your models lean back to dodge enemy shots, but it also looks like they're falling back, i.e., withdrawing from battle. People (including myself) often mistake such reactive behavior as passive, even submissive behavior- not traits you want associated with one's own army. That’s not the feeling I get from them. The models are pretty much mono-pose from the kit, and I thought this angle made them look like they’re aiming down slightly at targets in front of them. If they were tilted forwards they’d be shooting pretty much straight down at the ground! How are you painting at such a high standard and knocking models out at a pretty quick rate? I'm very impressed! It's taking me ages to get through just one tactical squad! If you have time could you run through your techniques for the inside of the jump pack vents and the colours used please? I tend to spend a day airbrushing a whole bunch of models at once. From that point a unit can usually be done in two or three sessions so I can crack them out pretty quick. For the thrusters I base coated them Vallejo Model Air Light Sea Blue, then sprayed White right in the centre and French Blue around the edges. Then some white edge highlights on the little ridges inside. Here’s a closeup I took on my phone: Carrick and thewarriorhunter 2 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5138903 Share on other sites More sharing options...
Bjorn Firewalker Posted August 6, 2018 Share Posted August 6, 2018 Well done. However, I think more models should lean forwards, as if diving into battle. I understand your models lean back to dodge enemy shots, but it also looks like they're falling back, i.e., withdrawing from battle. People (including myself) often mistake such reactive behavior as passive, even submissive behavior- not traits you want associated with one's own army.That’s not the feeling I get from them. The models are pretty much mono-pose from the kit, and I thought this angle made them look like they’re aiming down slightly at targets in front of them. If they were tilted forwards they’d be shooting pretty much straight down at the ground!Are the shoulders fixed in place? No way for you to mount the arms (and the guns those hands hold) parallel to the torso? What a fecal design for the models. Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139019 Share on other sites More sharing options...
LutherMax Posted August 6, 2018 Author Share Posted August 6, 2018 Well done. However, I think more models should lean forwards, as if diving into battle. I understand your models lean back to dodge enemy shots, but it also looks like they're falling back, i.e., withdrawing from battle. People (including myself) often mistake such reactive behavior as passive, even submissive behavior- not traits you want associated with one's own army.That’s not the feeling I get from them. The models are pretty much mono-pose from the kit, and I thought this angle made them look like they’re aiming down slightly at targets in front of them. If they were tilted forwards they’d be shooting pretty much straight down at the ground! Are the shoulders fixed in place? No way for you to mount the arms (and the guns those hands hold) parallel to the torso? What a fecal design for the models. From memory (I actually built these months ago!), the arms and torso have those shaped nubs on them that want to force them into a fixed position. Probably because of the cabling that connects to the back of the torso. The impression I get from the pose is that they're balanced between the weight of their packs (causing them to lean back) and the thrust being generated (pushing them forward). I have them mounted on brass rod which I've bent, and could easily bend more to have them angled further forward, but mine look pretty much the same angle as the ones shown on e.g. the Games Workshop website. I must admit, these are not my favourite Primaris models. I'm not super keen on the Aggressors or the Repulsor either but they have all been super fun to paint! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139203 Share on other sites More sharing options...
Mostwanted Posted August 6, 2018 Share Posted August 6, 2018 (edited) Thanks for the info on how you paint the thrusters, I will give that a go. I personally think your Inceptors are well positioned. To me they look like they are coming in to land feet first on something/someone while getting shots off. Edited August 6, 2018 by Mostwanted LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139216 Share on other sites More sharing options...
golfdeltafoxtrot Posted August 6, 2018 Share Posted August 6, 2018 (edited) The glow from the jump pack thrusters is outstanding. Congrats on your WarCom appearance and your ETL Artificer badge, both very much deserved. Edited August 6, 2018 by golfdeltafoxtrot LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139225 Share on other sites More sharing options...
thewarriorhunter Posted August 6, 2018 Share Posted August 6, 2018 The arms of the inceptors (at least from the Dark Imperium box) are mounted on shaped pegs for fixed positions. I however have a magnet problem and promptly cut the posts off. My thought was to eventually buy plasma arms so I could run either without buying a whole new box. You could also just cut the posts and glue the arms in whatever position you want to. My painting is no where near Luther's quality but in this is my inceptor album where you can see different arm positions. Bonus with the magnets is they get slightly more compact when storing in foam for travel. https://imgur.com/a/nTTBE Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139357 Share on other sites More sharing options...
LutherMax Posted August 6, 2018 Author Share Posted August 6, 2018 The arms of the inceptors (at least from the Dark Imperium box) are mounted on shaped pegs for fixed positions. I however have a magnet problem and promptly cut the posts off. My thought was to eventually buy plasma arms so I could run either without buying a whole new box. You could also just cut the posts and glue the arms in whatever position you want to. My painting is no where near Luther's quality but in this is my inceptor album where you can see different arm positions. Bonus with the magnets is they get slightly more compact when storing in foam for travel. https://imgur.com/a/nTTBE Thanks for the info – that's good to know! If I do more of these it would be pretty boring to have them in the same poses! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5139737 Share on other sites More sharing options...
LutherMax Posted August 11, 2018 Author Share Posted August 11, 2018 (edited) I loved this model when I first saw it, but I felt my buddy Legofingerz improved it even further with his excellent conversion, so I did what all good artists do when they see a great idea. I stole it. Edited August 11, 2018 by LutherMax binary, That Guy Matt, Dosjetka and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5142918 Share on other sites More sharing options...
Bjorn Firewalker Posted August 11, 2018 Share Posted August 11, 2018 Excellent work on the Chaplain. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5142930 Share on other sites More sharing options...
Brother Desultor Posted August 12, 2018 Share Posted August 12, 2018 Perfect. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143095 Share on other sites More sharing options...
Quixus Posted August 12, 2018 Share Posted August 12, 2018 Perfect. A proper crozius looks so much more fitting than the pimp cane. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143109 Share on other sites More sharing options...
LutherMax Posted August 12, 2018 Author Share Posted August 12, 2018 Thanks very much guys! Hot on the Chappie's heals, here's the Apothecary... Bryan Blaire, GrandMagnus, Corporal_Chaos and 11 others 14 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143224 Share on other sites More sharing options...
Brother Desultor Posted August 12, 2018 Share Posted August 12, 2018 Oh stop it. I’ve run out of superlatives.... Quixus and LutherMax 2 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143276 Share on other sites More sharing options...
LutherMax Posted August 12, 2018 Author Share Posted August 12, 2018 Oh stop it. I’ve run out of superlatives.... xD Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143286 Share on other sites More sharing options...
binary Posted August 12, 2018 Share Posted August 12, 2018 Man I've just been through all 29 pages and I have to say this is just so freakin' awesome. Nice to see some love for one of the lesser known chapters, and your airbrush skill is just mind blowing. Any tips for someone just starting out with one? Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143461 Share on other sites More sharing options...
LutherMax Posted August 12, 2018 Author Share Posted August 12, 2018 Man I've just been through all 29 pages and I have to say this is just so freakin' awesome. Nice to see some love for one of the lesser known chapters, and your airbrush skill is just mind blowing. Any tips for someone just starting out with one? Thanks man! I learned how to airbrush minis watching YouTube videos: Awesomepaintjob, Buypainted, Robpaintsmodels, Dr Faust. All highly recommended! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143571 Share on other sites More sharing options...
Bjorn Firewalker Posted August 12, 2018 Share Posted August 12, 2018 The Primaris Apothecary looks great! LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5143674 Share on other sites More sharing options...
hushrong Posted August 13, 2018 Share Posted August 13, 2018 Awesome, awesome, awesome! The chaplan is sweet and permanently borrowing ideas from other hobbyist is a time honored tradition :) The apothecary is also a stunner but the sculpt always seems weird that he is stepping on a battle brothers corpse. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5144111 Share on other sites More sharing options...
The Yak Posted August 13, 2018 Share Posted August 13, 2018 Serious Raptor Porn!!!! Thanks Brother. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/29/#findComment-5144182 Share on other sites More sharing options...
