Marshal Mattias Posted February 26, 2017 Share Posted February 26, 2017 That is one purposeful pose! Really awesome striding look. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667033 Share on other sites More sharing options...
Ciler Posted February 27, 2017 Share Posted February 27, 2017 I have no experience magnetising resin, but with due consideration to how fragile the material is compared to plastic, I'd magnetise at the shoulder. You'd have to find a stock of corresponding (Mk IV ?) arms though. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667284 Share on other sites More sharing options...
Marshal_Roujakis Posted February 27, 2017 Share Posted February 27, 2017 You might need to either drill deep into the resin to get the magnet to fit, or cut the magnet into two pieces, which would help in lining them up in general... regardless, if you're going to put a heavier object on his wrist, chances are that if the fit of the magnet isn't snug enough, it'll just fall off... I should know, I tried... If you're going for a wrist attachment, then I would suggest that the arm be posed higher so that the wrist magnets and the weapon will be on an angle and friction will do majority of the work to ensure that the weapon won't fall off... if you go for Shoulder Magnets though, then prepare a lot of shoulder pads, but you could modify the models full pose as well if you go with the shoulders instead of the wrist... Either case, good luck, and great model :) Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667307 Share on other sites More sharing options...
Ciler Posted February 27, 2017 Share Posted February 27, 2017 I would strongly advise against cutting magnets. They are sold with a protective (usually shiny) finish that helps enhance durability. The inside of a magnet is actually quite brittle and repeated snapping and unsnapping of an unprotected magnet tends to damage it. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667328 Share on other sites More sharing options...
Marshal Mattias Posted February 27, 2017 Share Posted February 27, 2017 It's also a little dangerous :P I magnetised the shoulder of the EC in resin, and it supports his outstretched sword arm easily. Wrist is hard enough to get tight in plastic, resin will be very tricky. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667350 Share on other sites More sharing options...
Acebaur Posted February 27, 2017 Author Share Posted February 27, 2017 I'm actually not worried about the actual process of putting the magnets in. I have lots of experience with that with both resin and plastic and doing both wrists and shoulders. I guess my dilemma was more of a where do I choose to do it. If I go with the wrist the pose is more static, but also more stable. If I go at the shoulder it can be more dynamic but also more prone to being knocked out of the position I want it to be in to look cool. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667392 Share on other sites More sharing options...
Ciler Posted February 27, 2017 Share Posted February 27, 2017 Well then go for the wrist, in my opinion, your pose there is really awesome and deserves to be soldily in place. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4667434 Share on other sites More sharing options...
Marshal Mattias Posted February 27, 2017 Share Posted February 27, 2017 ^^what he said. Do it. B) Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4668115 Share on other sites More sharing options...
Honda Posted February 28, 2017 Share Posted February 28, 2017 I really like the pose and agree with the "wrist" option. I do think that the hammer should be pointing "out" vs. the "in" you currently have it displayed. Not sure if that would affect the magnetization or not. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4668155 Share on other sites More sharing options...
Acebaur Posted February 28, 2017 Author Share Posted February 28, 2017 On 2/28/2017 at 12:37 AM, Honda said: I really like the pose and agree with the "wrist" option. I do think that the hammer should be pointing "out" vs. the "in" you currently have it displayed. Not sure if that would affect the magnetization or not. Not really, the magnet will allow it to swing around pretty easily, the trick is that the wrist guard that covers part of the hand makes turning the hand tricky as too much rotation and it looks weird. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4668187 Share on other sites More sharing options...
Acebaur Posted March 1, 2017 Author Share Posted March 1, 2017 And the Thunder Hammer is ready http://i85.photobucket.com/albums/k48/Acebaur/40K/Marshal%20Ramius/tj5Txoh_zpsskvoopzm.jpg Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4669073 Share on other sites More sharing options...
Ciler Posted March 1, 2017 Share Posted March 1, 2017 Where does the blank shoulder pad come from ? Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4669760 Share on other sites More sharing options...
Acebaur Posted March 1, 2017 Author Share Posted March 1, 2017 It's from the same command kit. I'm not 100% sure I'm going to use it for him yet though. Being a Marshal he might need some more bling. :lol: Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4669857 Share on other sites More sharing options...
Acebaur Posted March 1, 2017 Author Share Posted March 1, 2017 So here's another option I came up with for how the shield is positioned. Thoughts? Also the TH is fully magnetized now as you can see. http://i.imgur.com/uu4X5cv.jpg?3 Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4670066 Share on other sites More sharing options...
Ciler Posted March 2, 2017 Share Posted March 2, 2017 Both are good. My only concern with the later one is that it looks like he's dragging the shield (but maybe that's just for convenience and once glued it'll be off the ground). Incidentally, is that the shield from the BA termie box ? Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4670336 Share on other sites More sharing options...
Sagentus Posted March 2, 2017 Share Posted March 2, 2017 personally i prefer the second pose ... really liking this thread, keep up the good work :) Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4670437 Share on other sites More sharing options...
Marshal Mattias Posted March 2, 2017 Share Posted March 2, 2017 Yeah, the second version makes him look even more like he is just ballin' his way across the battlefield towards some yella-bellied chaos 'champion' while ignoring all the whizzing gunfire etc. Cool guys don't look back at explosions ;) :lol: Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4670485 Share on other sites More sharing options...
Acebaur Posted March 4, 2017 Author Share Posted March 4, 2017 Alright here is an altered version with the shield held up higher. Let me know if you guys think its better. Also note the cloak, I love how it looks but it limits the placement of the hammer, so that may be something I have to toy with. http://i.imgur.com/2SzxKsr.jpg?1 http://i.imgur.com/esBw5iC.jpg?1 Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4672462 Share on other sites More sharing options...
Ciler Posted March 4, 2017 Share Posted March 4, 2017 Definitely better in my opinion. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4672600 Share on other sites More sharing options...
Psykic_scribe Posted March 4, 2017 Share Posted March 4, 2017 Cloak is good - please keep it. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4673125 Share on other sites More sharing options...
Marshal Mattias Posted March 5, 2017 Share Posted March 5, 2017 Cloak is great. I don't see the same swagger though - the shield is a touch too high maybe. I think the crucial thing was the way he was holding it almost behind him to start with, it created a nice opposite motion to the extended hammer arm and that's where a lot of the movement came from. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4673755 Share on other sites More sharing options...
Acebaur Posted March 5, 2017 Author Share Posted March 5, 2017 Do you guys like it better than the first arm where he's carrying it in a more traditional way? Also Ciler the shield is from the basic TDA box, I believe it's the Sgt one. I plan to wrap some chains around it Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4673813 Share on other sites More sharing options...
Lippy Posted March 6, 2017 Share Posted March 6, 2017 I love it. He looks real menacing. I prefer the second pose and think he looks like hes swinging the shield to help provide more lift to his hammer. Will look out for him when hes painted up! Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4674537 Share on other sites More sharing options...
Sagentus Posted March 6, 2017 Share Posted March 6, 2017 I prefer the second pose personally. I also think you might need to dip his head forward ever so slightly Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4674576 Share on other sites More sharing options...
Firepower Posted March 11, 2017 Share Posted March 11, 2017 Have you considered turning the head to his left? Could make for an interesting 'You just got shield bashed!' pose rather than the purposeful stride, which seems a bit awkward to me right now. Although I think it may not be possible to pull off that suggestion, seeing as he seems to have a limited space to rotate that big noggin of his. Link to comment https://bolterandchainsword.com/topic/288402-the-jericho-crusade-sword-brethren-cometh/page/17/#findComment-4680927 Share on other sites More sharing options...
