For me it's not prefaced with the normal "you may choose"/"your choice of" etc and then when you follow the line you reach the the "gain" part, and immediately gain the rule with no choice in the matter at that exact moment, then move on to the "or" part. When a unit/model gains a rule you don't have a choice to ignore it unless specified.
Edited by Nusquam
The RAW let you pick a USR even if you have a legion with LA rules. I'm not a native English speaker but I can't find anything hinting the other way.
RAI, this is like the legion without rules where you choose a USR for your army. Once you get rules, can you go back? Not that I know.
But given the fact that you don't have to pick the same USR that your army, my RAI interpretation was maybe off.
Edit : "selected" kinda imply a choice, no?
Edited by Gyem
I don't see any issue w
Sorry I'm just not following your logic.
The "or" in that sentance gives you that specification. The issue is your reading the first part of the sentance as if it's a whole sentance. If I was to offer you $100 or $1000, you are not restricted to only taking the $100, because I didn't preface the sentance with "you may choose/or your choice of". The "or" in the sentance literally means, you have the choice of the fist or the second of the offered products, items, rules, etc. There is no need to add other words, because that is what it means.
There is no logic to follow, the rules as written are crystal clear.  If we want to discuss RAW vs RAI, that's an entirely different manner, except in this case there is no language ambiguity to seize on for the RAI side of the argument, so it would have to be complete conjecture.
The unlisted legion rule, which it seems is what people are referring to, is written entirely different:
"If you are using this army list to represent a Legion which does not yet have its own unique Legiones Astartes rule, you may instead add either the Stubborn or Furious Charge special rule to the standard provisions of this rule in the interim."
Edited by Terminus
One of my prime reasons for nearly always taking a leviathan in a pod these days, facing too many 3 gun medusa batteries guarded by 24 crew in milita&cults lists, or phosphex rapier battieres in marine lists and a leviathan with bombard/phosphex just nopes that off the board.
If course, since the artillery pieces have 2 wounds, it won't actually remove any of them, and you would have to kill all of the crew to silence the unit. That's hard to do with a single 5" template. Phosphex discharger can help, but it needs 6s to wound.
Poisoned 3+ on Phosphex thinks otherwise.
Register a new account
Sign in
