malika666 Posted November 12, 2017 Author Share Posted November 12, 2017 Painted up ordnance by the talented OSJClatchfords: http://www.forum.specialist-arms.com/index.php?topic=8492.msg75529#msg75529 Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-4930136 Share on other sites More sharing options...
malika666 Posted January 25, 2018 Author Share Posted January 25, 2018 Need some extra pistols for games like Necromunda? Available here: http://shpws.me/PsOY deathspectersgt7 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-4993595 Share on other sites More sharing options...
malika666 Posted March 8, 2018 Author Share Posted March 8, 2018 In the meantime, I've started working on something more body-horror... Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5028095 Share on other sites More sharing options...
malika666 Posted April 22, 2018 Author Share Posted April 22, 2018 Been working on some smaller mercantile ships that will most likely be released on a single sprue. Each craft is about 20mm long. Curious to hear your feedback before shipping this one off for production. (Novan Elites Panthera Heavy Frigate added for scale) Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5062704 Share on other sites More sharing options...
Naryn Posted April 23, 2018 Share Posted April 23, 2018 Love those ships. They’re reminiscent of other series’ civilin ships, but with a distinct look that’s very much your style. Super impressive! malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5062937 Share on other sites More sharing options...
malika666 Posted May 5, 2018 Author Share Posted May 5, 2018 Browsed through NASA's database and found a relatively high-res asteroid, so I thought: lets try to make a Novan mining station. I imagine that most mining would be done on asteroids, basically strap a whole bunch of engines on them and then suck it dry. I'm running into a couple of issues though:1) NASA doesn't have many different high-res asteroids files, most are pretty low resolution and just look like blobs.2) These will be pricy to produce since they are basically massive chunks of material that need to be printed, as solid models they'd also be rather heavy, unless you go for resin.3) One of the fun things with asteroid stations and such is the modelling itself. A sollution is to make a modelling kit. There are many ways you can make easy asteroids as seen and . But a small baggy of 'station bits' could really add a bit of character. So various thrusters, turrets, buildings/towers, landing bays, docking stations, etc.Your thoughts? ElDuderino 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5073435 Share on other sites More sharing options...
malika666 Posted May 20, 2018 Author Share Posted May 20, 2018 Rampager Light Tank I've designed for Vanguard Miniatures is out! Tainted Rampager Light Tanks - £10.00 Quote Each Rampager set consists of 4 x multi-part Rampager tank models.Model diameter approx, 18mm. 25mm plastic bases not included. http://vanguardminiatures.co.uk/shop/tainted-rampager-light-tanks/ Bjorn Firewalker and ElDuderino 2 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5086529 Share on other sites More sharing options...
Bjorn Firewalker Posted May 20, 2018 Share Posted May 20, 2018 The Rampager looks cool, but how does the crew enter/exit the vehicle? Does an abominable (artificial) intelligence control it? A bound Daemon? Are the crewmen sealed within, doomed to wither away inside the Rampager if they don't die in battle? Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5086610 Share on other sites More sharing options...
malika666 Posted May 21, 2018 Author Share Posted May 21, 2018 I was thinking of various possibilities, either some sort of corrupted AI or some sort of biomechanical system, so basically (human) brains, nerves etc. plugged directly into the machine. Basically turning the whole vehicle into an armoured body. The hatches on the sides (on the sponsons) allow for mechanics and such to go inside the thing for repairs and what not. Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5087232 Share on other sites More sharing options...
malika666 Posted May 29, 2018 Author Share Posted May 29, 2018 New releases! First up: Tainted Fighters! Tainted Hecate Interceptor - £7.00 Quote Tainted Hecate InterceptorManouverable and well armed, Tainted Interceptors are powered by nuclear cells, such that even in death their pilots may bring woe. Sets contains 2 x Hecate Interceptors and 2 x plastic flight stands. Length: 5.6cm https://vanguardminiatures.co.uk/shop/tainted-hecate-interceptor/ Tainted Charon Fighter - £7.00 Quote Tainted Charon Ground Attack FighterA variant of the Hecate interceptor the Charon has been designed as a light ground attack aircraft capable of rapid response and with a surprising amount of firepower for it’s size. Set contains 2 x Charon fighters and 2 x plastic flight bases. Length: 5.6cm https://vanguardminiatures.co.uk/shop/tainted-charon-fighter/ Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5093144 Share on other sites More sharing options...
malika666 Posted August 18, 2018 Author Share Posted August 18, 2018 So this just happened... Novan Elites Spiculum Heavy Fighter - £7.00 Quote The Spiculum like most Elites aircraft can function perfectly fine within the vacuum of space, but has been specifically optimised to operate in the ground support roll providing precision strike capability against enemy armoured targets and infantry concentrations.Set contains: 2 x Spiculum heavy fighters 2 x rocket clusters https://vanguardminiatures.co.uk/shop/novan-elites-spiculum-heavy-fighter/ Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5147397 Share on other sites More sharing options...
malika666 Posted August 24, 2018 Author Share Posted August 24, 2018 The System Ships are as good to go, any final feedback before I ship them off for printing? Focslain 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5152812 Share on other sites More sharing options...
malika666 Posted August 28, 2018 Author Share Posted August 28, 2018 A few tiny details here and there changed, will look into it one more time later this week and then it's ready for submission: Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5155305 Share on other sites More sharing options...
Subtle Discord Posted August 28, 2018 Share Posted August 28, 2018 I find I'm usually struggling a little bit to find the right balance when trying to detail things while 3D modeling; I want the right amount of details but I don't want to overdo it and that's at 28mm heroic scale. I can only imagine how tricky it can be at epic scale. Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5155316 Share on other sites More sharing options...
malika666 Posted August 28, 2018 Author Share Posted August 28, 2018 At ship scale it's a bit easier again, but indeed at 6mm and 3mm scales there's only so far you can go. Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5155339 Share on other sites More sharing options...
malika666 Posted September 12, 2018 Author Share Posted September 12, 2018 Feedback needed. I'm about to submit these for printing, just need to know if the missile pods should be pointing straight forward (Elites on top) or slightly up (Elites on the bottom). Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5165358 Share on other sites More sharing options...
Bjorn Firewalker Posted September 12, 2018 Share Posted September 12, 2018 Why not have both models of Terminators, those with direct fire missile launchers as well as those with indirect fire (elevated) launchers? Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5165383 Share on other sites More sharing options...
Lynnean Posted September 12, 2018 Share Posted September 12, 2018 I'd use the slightly up, firing at an arc seems more fitting for the scale of battles.Love your stuff! Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5165387 Share on other sites More sharing options...
malika666 Posted September 12, 2018 Author Share Posted September 12, 2018 On 9/12/2018 at 7:04 AM, Bjorn Firewalker said: Why not have both models of Terminators, those with direct fire missile launchers as well as those with indirect fire (elevated) launchers?The thing is that for the 6mm models I won't wanna do a 10 man sprue, mainly because it would simply be copying the poses but then with the missile launchers at a different angle, you'd get a bit of an uncanny valley thing. Also, it would increase the production costs greatly. However, in 3mm this might not be a far-fetched idea to do... Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5165397 Share on other sites More sharing options...
malika666 Posted October 23, 2018 Author Share Posted October 23, 2018 Started working on a sort of grimdark/gothic version of Tatooine, your thoughts? Lord Raven 19 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5178264 Share on other sites More sharing options...
Bjorn Firewalker Posted October 23, 2018 Share Posted October 23, 2018 The buildings look good. malika666 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5178629 Share on other sites More sharing options...
malika666 Posted November 28, 2018 Author Share Posted November 28, 2018 Thanks Craig Fenion for the rendering! Lasuria 1 Back to top Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5202117 Share on other sites More sharing options...
Bjorn Firewalker Posted November 30, 2018 Share Posted November 30, 2018 On 11/28/2018 at 6:15 PM, malika666 said: Thanks Craig Fenion for the rendering! No offence intended towards your friend, but why doesn't this ship have gun turrets to defend her underside? Void warfare is 3-dimensional, as Star Trek II: The Wrath of Khan demonstrates. Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5203555 Share on other sites More sharing options...
malika666 Posted December 1, 2018 Author Share Posted December 1, 2018 On 11/30/2018 at 7:31 PM, Bjorn Firewalker said: On 11/28/2018 at 6:15 PM, malika666 said: Thanks Craig Fenion for the rendering! No offence intended towards your friend, but why doesn't this ship have gun turrets to defend her underside? Void warfare is 3-dimensional, as Star Trek II: The Wrath of Khan demonstrates. Rule of cool: http://4.bp.blogspot.com/-tM6Fa6vng_w/UlwV0BKU9OI/AAAAAAAAAJM/ctUSXdvg72s/s1600/Imperial+Guard.jpg Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5203919 Share on other sites More sharing options...
malika666 Posted October 18, 2019 Author Share Posted October 18, 2019 Beginning of a possible new project? Link to comment https://bolterandchainsword.com/topic/308829-malikas-3d-design-extravaganza/page/5/#findComment-5410040 Share on other sites More sharing options...
