Sagentus's Khorne army - Contemptor Dread and DA
Sagentus
  • 2 weeks later...
Managed to get some more of the drake done over the weekend
1) Firstly i painted the base colours:
Red - Mephiston spray
Gold - mournfang brown then runelord brass
Metal - Leadbelcher
2) Then wash with nuln oil
3) Now I pooled nuln oil in the middle of each segment (i did this twice to ensure i got a deep black),
then i went round the edges with mephiston red
4) I then worked out the highest part of each segment and highlighted with wildrider reds
Once that is done its a case of highlighting the gold/metal and general tidying up. got 1 out of 4 wings to stage 4 and
the rest including the claw arms at stage 3.
Whilst I was waiting for washes I started one of my cultists
Bit more tidying up, final highlights and paint the hair/eyes and he's done. then 9 more to paint lol.
NICE! The amount of work for each panel of the heldrake seems like a lot but it is well worth it!
The cultist also looks off to a great start. Looking forward to the rest of his ragged band destined for the meat grinder.
@Hushrong - cheers mate, i hope to have it done soonish. It has been quite a journey painting it. Then ill get the ragged crew of cultists painted asap.
@eld - tbh the painting of the trim took about 3 hours in total because i had to paint it brown first. It is quite a lot of trim to paint but the way ive done it meant i didnt have to be to precise
  • 2 weeks later...
  • 4 weeks later...
Been a while since i posted anything. Hobby time has been very scarce on the run up to xmas. Made a little headway on the cultists (will get a pic of them asap). Also today i had 10 mins spare and started this:
Still very early stages, but its got the general shape
  • 3 weeks later...
Got the new first strike over xmas and have had a play with the new nurgle models. The blight launcher arm is impossible to change without destroying it so changed the angle of the head a bit
With the second i thought id go for a different head and back pack
With the champ i aim to swap out the pf, but i realised that the arms of the new dg are massive compaired to the normal csm, so im going to have to get a PM kit or con the dark imperium set out of the miss' for my bday in jan lol
  • 2 weeks later...
Been messing around making some HB havocs. I only have 3 HBs atm, will have to see if i can get a 4th off ebay
Was also starting work on my 2nd bez squad. Here is the champ
The PF is a BT one which i have calved out the BT insignia and covered with GS to make a khorne symbol. I will also get rid of the DA symbol on his helmet. Still very early wip.
Edit:After looking at these pics i think ill tilt the body forwards a bit more to show a bit more momentum in his charge :-)
@bio - cheers mate. Yeh defo going to angle him forward a bit, had to use a new set of legs and torso because I had already glued these together about 5 years ago and they wont break apart lol.
@Nem - You sir are a life saver. If i can return the favour I will :)
@Nem - Thanks mate, just goes to show even with old kits they can be made to look decent with a bit of work/kitbashing. Thank you again for the HB, cant wait for it to arrive and get a 4th HB to my havoc squad :)
@ DR - cheers mate, I realised that the pic of the PF didnt come out so reuploaded it. Now you can see the Khorne Icon on the PF! :D
Looks a lot better bud. For my Zerkers I was worried the pose would mean they’d break off the base quite easily so I ran a wire through the base into the trailing leg. I made a loop on the bottom of the base as an anchor type deal. Just a suggestion. :)
The Khorne icon looks cool on the PF as well :tu:
