Dantay VI Posted May 4, 2018 Share Posted May 4, 2018 (edited) I assume the left is the original and the right is the one which you have modified? Difficult to tell without seeing the rest of the titan built up on the legs Going back to an older picture, while I like the stance od th legs, unless there is a ball joint of some type, the angle of the legs on the straight lengths (hips?) looks a little off to me. Maybe extend the pelvis down slightly and fit the hips? at a slight angle to make it look more natural. Maybe a ridged covering over the sections coming out to disguise the lack of ball joint if you did not wish to put one in. A bit like the Cerastus Knight pelvic area? Hidden Content 20170616_201305 by Danny Taylor, on Flickr 20170616_214507 by Danny Taylor, on Flickr Edited May 4, 2018 by Dantay VI Master Toddius 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5072085 Share on other sites More sharing options...
Blackadder Posted May 5, 2018 Author Share Posted May 5, 2018 The New Helsreach Chapter 11 Has revealed a heretofore unknown area of detail under the greave skirt ( Yeah I know what I've said.) https://i.imgur.com/mi7Tgk1.jpg Anyway I knew there were actuators there but I fought the temptation to make the toes movable as the effort I put into movable toes on my Warlord was pretty much for nothing. I rarely pose it with the toes flexed. Another tidbit of detail is the corner spires have pointy bits on both ends. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5073632 Share on other sites More sharing options...
TURBULENCE Posted May 6, 2018 Share Posted May 6, 2018 Knowing you those details will be recreated in a believable manner that is lacking in most Titan builds. Though I can see why you would want to avoid articulation in the foot. It is a lot of extra work for very little reason. But then this project is madness, and just about the most amazing thing I've ever seen, so who knows what to expect from you at this point. I'll be looking forward to your next update Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5073685 Share on other sites More sharing options...
Blackadder Posted May 10, 2018 Author Share Posted May 10, 2018 Details Details: The Devil is in the details. Since I found out last week courtesy of HelsReach 11 that the corner spires are pointy on both ends; Egad!!!!! I've come up with a way (I think) to make the legs pose-able to a degree. The image in my last post shows internal cylinders that while I know they had to be there. None the less; it is nice to have verification. https://i.imgur.com/0ZezakH.jpg I've also worked on the Upper leg housing and made the foot pad ankle gimbal system a reality that I believe will be strong enough to support the 10 kilos of mass this model will ultimately have. https://i.imgur.com/dI41YB6.jpg It took a bit of scrambling to make up for that deficit............ https://i.imgur.com/GYfmdur.jpg Right now I am just toying with the components to see what can be done.... I may have to scrap the idea of the internal mop handle for a more utilitarian center column. https://i.imgur.com/HTPFpjl.jpg Which would be a pity but I'm not exactly wedded to the idea; one of the benefits of designing on the fly. Sgt. Blank, DuskRaider, Sagentus and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5077816 Share on other sites More sharing options...
Sagentus Posted May 10, 2018 Share Posted May 10, 2018 Just jaw dropping work, just mind boggling detail ... always great to see progress on this behemoth of a build/project Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5077900 Share on other sites More sharing options...
Blackadder Posted May 12, 2018 Author Share Posted May 12, 2018 Zounds! I hate to toot my own horn but this actually worked out as a surprise to even me. https://i.imgur.com/GutkRnb.jpg The above view is of the internal structure where I hope to be able to house twenty to forty troop harnesses and still have room for the stabilizing cylinders https://i.imgur.com/Iaisvly.jpg The view above is of the rear disembarkment doors which I feel are much more practical that front mounted doors as it give the troops the ability to form up before confronting their adversaries. Not in the best Imperial tradition I know but definitely saner. https://i.imgur.com/1JzNvHK.jpg The friction gimbel works as designed and I am hoping with the 20 odd pounds of Emperor Titan they will provide the requisite stability. The stabilizers may offer assistance there. https://i.imgur.com/LS5xiMs.jpg Front clearance also seems adequate when assuming the classic combat pose. https://i.imgur.com/VIXWH91.jpg and with the second and third tiers in place we begin to see the entire leg become a reality. Finally the interior structure that will house the troops. https://i.imgur.com/n1EB95i.jpg This structure will slide out of the greave to reveal the inner transport chamber and the mechanical walking devices/components. I'm going to be hard pressed finding room for all that needs to be here and still have room for activation. Master Toddius 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5079709 Share on other sites More sharing options...
Blackadder Posted May 14, 2018 Author Share Posted May 14, 2018 First Time Assembled: I worked yesterday evening into the early morning hours to assemble the working joints of both legs albeit with temporary diameter screws 6-32 until I found out if the design is viable. And it WAS! https://i.imgur.com/fXNC3DN.jpg In the basic pose, legs straight, the inner side toes had just the right amount of clearance between the greaves at the most minimum width adjustment of the pelvic block. I had made allowances for up to an inch per leg but it wasn't needed. If the model could actually walk, the inner toes would clear each other with each step. https://i.imgur.com/NTpVqrQ.jpg Next I adjusted the pose with one foot forward as if stepping out. The adjustment was made gingerly as all the friction axles aren't in place yet so the knee joints and hip sockets are rather stiff in appearance, The dual axle hip sockets worked as planned, allowing the legs to be placed one behind the other as would be necessary if this contraption could walk as a true biped instead of a baby's rocking waddle which would look comical on a battlefield. https://i.imgur.com/s8E7T0S.jpg Again the limited range of motion due to the small temporary hardware limited the viability of the pose. With the right diameter hardware the poses will have a more fluid appearance. Finally the spraddle legged Classic Titan Pose. https://i.imgur.com/FbjPGwI.jpg Again made viable by the dual axle hip joints is thankfully a reality...... https://i.imgur.com/F6p0kQx.jpg In the Immortal words of Dr Strangelove; "Mien Fuhrer! I CAN WALK!" MARTINI TIME! Spinsanity, Grotsmasha, Dreagher and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5081451 Share on other sites More sharing options...
Sagentus Posted May 14, 2018 Share Posted May 14, 2018 Just absolutely jaw dropping! The legs look perfect! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5081478 Share on other sites More sharing options...
Stercus Posted May 14, 2018 Share Posted May 14, 2018 Holy snot Blackadder, that thing is starting to look terrifyingly good. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5081581 Share on other sites More sharing options...
Dantay VI Posted May 15, 2018 Share Posted May 15, 2018 Wonderful work... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5081762 Share on other sites More sharing options...
Sgt. Blank Posted May 15, 2018 Share Posted May 15, 2018 Wow! The legs are coming together amazingly. I think the decision to shorten them looks correct and the range of motion for something this big and detailed is almost unbelievable. In particular the execution of the pyramid spires on the legs and shoulders ties it all together so we Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5082029 Share on other sites More sharing options...
Pearson73 Posted May 15, 2018 Share Posted May 15, 2018 Really impressive work, as per. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5082364 Share on other sites More sharing options...
Blackadder Posted May 17, 2018 Author Share Posted May 17, 2018 (edited) Thanks for all the replies, In No Particular Order: Yesterday I replaced the temporary 6-32 hardware with 10-32 screws and this morning I beefed up the third tier to receive the full 10 kilos of weight it must endure for decades at the least. This little top hat style construction bears easily twice that even without reinforcement so I'm certain even with the top hamper it will serve. So in no particular order here's my assembly: https://i.imgur.com/0Ict0U8.jpg Everything looks rather slapdash and crude at this stage https://i.imgur.com/PChstET.jpg The excess framing needs to be cut down now that it is no longer needed https://i.imgur.com/ppzYPg9.jpg and the axle sleeves for the knee and 'medial hamstring tendon' actuator (For want of a technical term) need to be pared down and encased. https://i.imgur.com/TYj85h3.jpg I'm rather surprised at the interior of the second tier not needing further bracing but I'll add some anyway now that I have a good idea of the direction I'll be pursuing finishing up the articulation mechanisms. Edited May 17, 2018 by Blackadder Subtle Discord, DuskRaider and Grotsmasha 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5084404 Share on other sites More sharing options...
Blackadder Posted May 20, 2018 Author Share Posted May 20, 2018 Exhausted: I'm going to leave you with these two images because I just too mentally exhausted to go any further. https://i.imgur.com/rZMoOtE.jpg Tomorrow we'll see Imperius Rex make his debut. https://i.imgur.com/siTdIJk.jpg Wedded as it were to his lower parts. Ha! And hopefully standing on his own. Sgt. Blank, Subtle Discord, Grotsmasha and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086318 Share on other sites More sharing options...
Subtle Discord Posted May 20, 2018 Share Posted May 20, 2018 It stands! Glorious. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086320 Share on other sites More sharing options...
Naryn Posted May 20, 2018 Share Posted May 20, 2018 Absolutely stellar work. It’s exciting to see it coming together! This is a big step, no pun intended. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086404 Share on other sites More sharing options...
Canadian_F_H Posted May 20, 2018 Share Posted May 20, 2018 Oh my god emperor! Soon? This is such an awesome moment of tension! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086514 Share on other sites More sharing options...
Blackadder Posted May 20, 2018 Author Share Posted May 20, 2018 (edited) OMO: Oh My Omnissiah! After a bit over a year it is beyond gratifying to sit in front of this construction and gingerly assemble the dozens of components that make up Imperius Rex (Not it's name but what came to me yesterday evening when assembling the legs. "First you have to vacuum the floor and dust the furniture" was my better half's injuncture when I proposed to display this creation on the rug in front of the TV. (lest it be damaged if it topples over) My primary concern was ameliorated when it stood without the aid of something to lean against. https://i.imgur.com/ErYsfTT.jpg This first image is from ground level and appears a bit empty of detail which will be remedied in the coming months. https://i.imgur.com/iNud7xb.jpg The full on front view is more satisfactory. The proportions look right on to my eye. https://i.imgur.com/iE5VzZ1.jpg Now that the stability of the model is not in question I'll reassemble it on the console fronting my desk and assemble the rear components as well. https://i.imgur.com/p3mfbE0.jpg Finally; a 3 foot scale to show the height thus far. Whew! Edited May 20, 2018 by Blackadder DuskRaider, Khornestar, Pearson73 and 13 others 16 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086531 Share on other sites More sharing options...
Dantay VI Posted May 20, 2018 Share Posted May 20, 2018 Bloody hell that is marvellous... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086538 Share on other sites More sharing options...
Doghouse Posted May 20, 2018 Share Posted May 20, 2018 Fantastic stuff, I think two of those back to back could form their own gaming table. Aramis K 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086543 Share on other sites More sharing options...
Grotsmasha Posted May 20, 2018 Share Posted May 20, 2018 :cuss me..... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086584 Share on other sites More sharing options...
Pearson73 Posted May 20, 2018 Share Posted May 20, 2018 Great Scott, quite the marvel you've engineered there. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086596 Share on other sites More sharing options...
Bjorn Firewalker Posted May 20, 2018 Share Posted May 20, 2018 Most impressive, even without its citadel. Hopefully, the legs, back, and various joints are sturdy enough to bear the citadel's weight when you mount it. Will you use a transparent plastic back brace or clutches to support the citadel's weight when it's built? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086604 Share on other sites More sharing options...
Subtle Discord Posted May 20, 2018 Share Posted May 20, 2018 It's not even close to finished and it already had me at a loss for the right words. *Subtle mashes his face on the keyboard* ncfdvx hgbvnzxfs! There, that's the best I can come up with. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086651 Share on other sites More sharing options...
Stercus Posted May 20, 2018 Share Posted May 20, 2018 My goodness. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/20/#findComment-5086661 Share on other sites More sharing options...
