Wulf Vengis Posted March 7, 2022 Share Posted March 7, 2022 "Apocalyptic explosion!" Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5802477 Share on other sites More sharing options...
Blackadder Posted March 8, 2022 Author Share Posted March 8, 2022 Weapons Mounted; Temporarily to be sure but as a dry run it seems they hang admirably. https://i.imgur.com/V9eMciC.jpg The Gatling is quite a bit heavier that the plasm Blaster but not enough to unbalance the mounting. https://i.imgur.com/3S8QYUR.jpg A problem revealed itself on this first application; namely there does not seem room for the ammo drum in the gantry. :bleep: https://i.imgur.com/6X9GnQq.jpg Also my idea for an ammo belt in the lower body of the titan doesn't seem likely at this time without a major revamp of the magazine position.... :violin: https://i.imgur.com/D6HdcL3.jpg Sagentus, Zebulon, T0MMY and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5802860 Share on other sites More sharing options...
YoungWolf7 Posted March 8, 2022 Share Posted March 8, 2022 I'm sure you can solve it. It's a thing of glory as-is! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5802895 Share on other sites More sharing options...
AlexCrute Posted March 9, 2022 Share Posted March 9, 2022 If even the parochial and backward adeptus astartes can afford teleporters for their puny terminator excursions on to space hulks surely the cannon can teleport ammo direct from production line to firing chamber. Jus' sayin'. Brother Carpenter 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5803009 Share on other sites More sharing options...
Brother Carpenter Posted March 10, 2022 Share Posted March 10, 2022 Hmm, Do I see a drum magazine on the gun in the near future? Would bulk out the rear of the gun somewhat Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5803567 Share on other sites More sharing options...
Blackadder Posted March 24, 2022 Author Share Posted March 24, 2022 Gatling Gun Rear Subsection For those who wish to follow along through each modicum of construction I present the following. It may be noted that there is significant relief in the substructure of this section of the construct. https://i.imgur.com/p6WFzIP.jpg I found that the mounting bracket of the arm was too delicate looking for the mass of the gun so I doubled the thickness of the mounting yoke. I used 10/24 countersunk screws and blind nuts to make the universal mountings of the arm. This way I can achieve almost a full range of motion for the weapon. https://i.imgur.com/FGHOmRV.jpg I much prefer the intricacies of the drum style yoke to the bracket style yoke of the original 3D image. Adapting the magazine aft section to the increased caliber of the barrels resulted in a few compromises in the overall appearances of the mounting system. https://i.imgur.com/zTckkrr.jpg I probably could have done without the forward sight but I kept it for its aesthetic value. Likewise the bulging midsection of the loader. Now that I have fulfilled the need for displaying the inner structure I can proceed with applying the surface sheathing and detail. Majkhel, firestorm40k, Brother Chaplain Ryld and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5807398 Share on other sites More sharing options...
Sgt. Blank Posted March 26, 2022 Share Posted March 26, 2022 Seeing the weapons mounted, this thing looks amazing. The details on the gatling front section are great, looking forward to seeing the back come together. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5808315 Share on other sites More sharing options...
Brother Carpenter Posted March 26, 2022 Share Posted March 26, 2022 Almost time to paint. Im assumimg you stocked up on spraycans boltgun metal? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5808412 Share on other sites More sharing options...
Mud Duck Posted March 30, 2022 Share Posted March 30, 2022 Question. If you plan on having a exterior ammunition belt,are you going to have a second return one? If memory serves the Gatling Mega Bolter has a return as it helps in retaining the balance of the Titan, and keeping it from raining hundreds of shell casing on supporting troops. I could see using the same reasons (more so) here. Plus, is the plan to have the magazine hanging in the same place as your reference? I could see it in line with the center line and behind the chamber, last thing on your structure. I guess what I'm seeing in my minds eye is as the Titan is in it's berth, a gantry crane comes behind the Titan with a giant four fingered hand, grips the magazine giving it a quarter counter-clockwise twist, removing it to a ground vechile which transports it to the ammo bunker for reloading, as a second magazine is moved in for replacement. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5809737 Share on other sites More sharing options...
Blackadder Posted April 6, 2022 Author Share Posted April 6, 2022 (edited) Utility or Glitz: I've come to a crossroads regarding the magazine. Do I go for the more utilitarian magazine belt drawn from the hull if the titan or the ruddy great ammo drum mounted under the recoil/loader aft end of the gun. To me the drum offers a small number of rounds compared to the in hull magazine plus it will hang very low on what is already a massive construction compared to the elegant Plasma Blaster and even the multi barreled Quake Cannon. Regardless the infeed ports on the sides of the loader needs to be manufactured and positioned. The components shown above. The layout of the position drawn in which will be aligned with the drum and the hull positions. The ports roughed in. And the roughed in chambers. Edited April 6, 2022 by Blackadder Grotsmasha and Brother Lunkhead 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5812950 Share on other sites More sharing options...
Blackadder Posted April 7, 2022 Author Share Posted April 7, 2022 Okay so I opted for the in hull magazine. The clincher was that the ammo belt port lines up perfectly with the hull section that I designated for the belt egress, no lie, it lined up perfectly. Ha! Seen here directly above the loading port. The large blank area is where the belt will be situated. A much better use than proposed in the original concept 3D art. Cheers! Radiation, Brother Chaplain Ryld, Focslain and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5813133 Share on other sites More sharing options...
Majkhel Posted April 7, 2022 Share Posted April 7, 2022 A good call in my humble opinion. All the better it lined up as it will reduce your effort a bit Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5813140 Share on other sites More sharing options...
Blackadder Posted April 25, 2022 Author Share Posted April 25, 2022 Ammo Belt: After a few bad starts I finally went back to my original plan of how to create this structure. Also I decided to commit to an onboard round magazine rather than the drum attached to the weapon. https://i.imgur.com/X0SKDLq.jpg The reason is twofold. 1 The Ammo drum is too bulky to attach to the loading housing and would look ludicrous. 2 Plus the drum would be too small to store a significant number of rounds. The hull would be a better option. Maintaining flexibility was also a challenge which necessitated splitting the rounds on the ammo belt strip. Since the belt is merely for show I can make this presumption. It took me two weeks to come up with a viable plan and I haven't even applied the details; Whew! Doghouse, Dr_Ruminahui, YoungWolf7 and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5819395 Share on other sites More sharing options...
Blackadder Posted May 30, 2022 Author Share Posted May 30, 2022 I broke my foot a couple of weeks ago and I haven't had the ambition to proceed with the project for a while. I've been itching to get back to it over the Past two days so expect an update soon. EB Augustus b'Raass, LameBeard, Majkhel and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5834208 Share on other sites More sharing options...
LameBeard Posted May 30, 2022 Share Posted May 30, 2022 Sorry the like was for you getting back to the project, not for breaking your foot. I hope you make a speedy recovery. Marshal Mittens 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5834320 Share on other sites More sharing options...
Sgt. Blank Posted May 31, 2022 Share Posted May 31, 2022 Sorry to hear about the injury, imagine thats a super frustrating recovery on top of the injury itself. Hope you have a swift recovery. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5834356 Share on other sites More sharing options...
Blackadder Posted August 4, 2022 Author Share Posted August 4, 2022 Back in the Saddle Again After being laid up with yet another bout with Covid, the worst one yet, these past few days have seen me in a flurry of industry where I managed to add quite a bit of detail to the upper works. This first images of the superstructure shows the angular shaped stained glass window frames that decorate the bastions in groups or threes; https://i.imgur.com/xMufwQy.jpg I made dozens of these basic decorations and they are used throughout the model in various sizes. Each one will ultimately be embellished with cut out paper 40k stained glass themes. https://i.imgur.com/YDoLBcY.jpg I may or may not cut these out and install lighting behind the frames but that is far down the road from where I am today. The next images show the gatling blaster mounted once again with the rear position of the gun mechanism lined up with the hull magazine. Amazingly it lines up with the proposed belt chain of projectiles even though I had not initially planned for this. https://i.imgur.com/UAqWxzp.jpg https://i.imgur.com/tx26jkL.jpg And another view for clarity.... https://i.imgur.com/wSZEzAV.jpg Dr_Ruminahui, CaptainFrederickson, Majkhel and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5853691 Share on other sites More sharing options...
Naryn Posted August 4, 2022 Share Posted August 4, 2022 Love it, that's very clean how well it lines up! Sorry to head about your COVID diagnosis but happy that you're feeling well enough to hobby and post Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5853702 Share on other sites More sharing options...
Majkhel Posted August 5, 2022 Share Posted August 5, 2022 Good job! The structure is immediately gaining depth and gravitas with those Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5853938 Share on other sites More sharing options...
Blackadder Posted August 5, 2022 Author Share Posted August 5, 2022 Thanks for the replies, Bastion Base Detail Yeah I know; it looks like a step backwards but it took me a couple of days installing these stained glass window frames and the details thus far. But now I can install the finer detail items such as layered armour, skulls and Aquilae, corner angles and tchotchkes. You'll see where I am going with this.. https://i.imgur.com/twsCGYl.jpg I've already decided I need to make two more building structures, rectories if you will' between the front and rear bastions which will really make the interior of the superstructure really POP! https://i.imgur.com/OTa0XJJ.jpg But right now I am excited about how will these components have come out. https://i.imgur.com/bY9Obu9.jpg Naturally these will not be stacked like these but instead will serve as the corner bases for the superstructure. I just thought it would be amusing to show them off before I install the really fun details. Cactus, Lord Raven 19, Brother Lunkhead and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5854199 Share on other sites More sharing options...
Blackadder Posted August 16, 2022 Author Share Posted August 16, 2022 (edited) Ye Gods, Has It Been That Long! Over the past six years and four months since I started this project I've been repeatedly asked, What colour am I going to paint this beasty. Well I've finally found a colour scheme I think will be befitting this endeavor. It combines the understated mechanical appearance of a Lucius Pattern Emperor Titan with the garish opulence of the upper works. The concept is credited to Joazzz2, the original 3D designer of the images I follow. https://i.imgur.com/S2KmceV.png You can see I quite a bit of detailing still to do on the upper works before I commit to painting. And the four spires on the superstructure will be "Vengeance Weapons Batteries" for aerial defense. Edited August 16, 2022 by Blackadder Mostwanted, Majkhel, YoungWolf7 and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5857772 Share on other sites More sharing options...
Mostwanted Posted August 17, 2022 Share Posted August 17, 2022 I can't believe it's been over 6 years! Where has the time gone! Glad to see your still working on this and really can't wait to see it finished. Keep up the great work! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5858095 Share on other sites More sharing options...
dieusurterre Posted August 21, 2022 Share Posted August 21, 2022 Since CMON finally died, I'm joining here to keep an eye on the progress! Good to see you're back at it :) How's the foot? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5859136 Share on other sites More sharing options...
Blackadder Posted August 30, 2022 Author Share Posted August 30, 2022 I just posted on Cool Mini. It's a bit of a hassle but the finally let me in... Are We Having Fun Yet! It took me the better part of a week but I finally have 22 cathedral style window frames for my buttresses. Basilica Adminstratum https://i.imgur.com/7DCwNlo.jpg I cut them out from the panels of couple Basilica Adminstratum kits I had lying about. https://i.imgur.com/tiCkgUP.jpg Cripes! Blackadder Do you know what those kits are worth? Yeah, in point of fact I just purchased one on ebay for a hundred bucks free shipping ( I still need more windows and door panels.) https://i.imgur.com/5tQiZge.jpg But "In for a penny, in for a pound." I always say. It's only money. https://i.imgur.com/STHfTYG.jpg So, was it worth it? Zebulon, Jolemai, Master Toddius and 8 others 10 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5862012 Share on other sites More sharing options...
Majkhel Posted August 30, 2022 Share Posted August 30, 2022 Considering the alternative, I'd say: definitely worth it! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/44/#findComment-5862069 Share on other sites More sharing options...
