FollowerofDG Posted August 30, 2022 Share Posted August 30, 2022 TOTALLY WORTH IT!!!! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5862082 Share on other sites More sharing options...
Naryn Posted August 30, 2022 Share Posted August 30, 2022 Looks great, those fit perfectly! I love the addition of some 40k bits to this beautiful insanity. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5862088 Share on other sites More sharing options...
Grotsmasha Posted August 31, 2022 Share Posted August 31, 2022 Â It was worth it Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5862105 Share on other sites More sharing options...
Blackadder Posted September 12, 2022 Author Share Posted September 12, 2022 (edited) Thanks for the replies... Octagons... That Feeling You Get When Things Go Awry  It was a matter of disappointment when I found the turrets were hexagonal and would not fit the upper bastion assemblies.  Ultimately I had to make my own...  https://i.imgur.com/i7Ahp5P.jpg  Fortunately I could still use the guns.  https://i.imgur.com/laagsbC.jpg  The upper works of one of the four corner bastions.  https://i.imgur.com/DapA7Uo.jpg  And some ideas of how to flesh out the basic structure..  https://i.imgur.com/lU9C8RC.jpg https://i.imgur.com/ntsTWdO.jpg     Edited September 12, 2022 by Blackadder Mithrilforge, Grotsmasha, Zebulon and 15 others 18 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5865836 Share on other sites More sharing options...
Naryn Posted September 12, 2022 Share Posted September 12, 2022 Simply glorious. Attention to detail at every step. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5865881 Share on other sites More sharing options...
Mud Duck Posted September 13, 2022 Share Posted September 13, 2022 I like where you're going with the statues, but that's a lot of blank space between and above them. I would propose, and this is based on finding and ability to procure them, a single statue on each side that is the height of the square area in the center; Each one of a different (loyalist) Primarch? So if anyone has a 3d printer and some free time? That or I propose a 'Get the Adder a printer, so he can make this stuff cooler' fund. I've got $20 to start it off right here! If failing that, I would propose a bas relief between the statues. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5866018 Share on other sites More sharing options...
Blackadder Posted September 19, 2022 Author Share Posted September 19, 2022 On 9/12/2022 at 8:11 PM, Mud Duck said: I like where you're going with the statues, but that's a lot of blank space between and above them. I would propose, and this is based on finding and ability to procure them, a single statue on each side that is the height of the square area in the center; Each one of a different (loyalist) Primarch? So if anyone has a 3d printer and some free time? That or I propose a 'Get the Adder a printer, so he can make this stuff cooler' fund. I've got $20 to start it off right here! If failing that, I would propose a bas relief between the statues. 3D printer, my son has one of those. But I consider that cheating. Bad enough I am kit bashing but hey, GW/FW does that all the time. Khornestar and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5867757 Share on other sites More sharing options...
Mud Duck Posted September 19, 2022 Share Posted September 19, 2022 7 hours ago, Blackadder said: 3D printer, my son has one of those. But I consider that cheating. Bad enough I am kit bashing but hey, GW/FW does that all the time. Cheating? Nah. It's an alternate method of construction. Plus, it would save you money from having to buy more wall kits for the windows. But either way this beast is a beauty, in both form and function. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5867860 Share on other sites More sharing options...
Blackadder Posted September 20, 2022 Author Share Posted September 20, 2022 Thanks for the reply. Â I've got dozens of kits (bitz) lying about I can use for sources and I can mold doors etc. for whatever I want. Even a SOTA printer which my son has would take too long to print out what I need. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5867933 Share on other sites More sharing options...
Cactus Posted September 20, 2022 Share Posted September 20, 2022 My first thought on the blank space between the statues was a tall window, because it's gothic innit? My second thought was some industrial/mechanical greebling (pipes and fans and such), but still in a vertical orientation to maintain the gothic form. Did those 40k walls come with any useful flooring? It's an astounding build and I enjoy every update. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5868014 Share on other sites More sharing options...
Wulf Vengis Posted September 29, 2022 Share Posted September 29, 2022 This still an amazing product with incredible amounts of work and craftsmanship going into it. Black Adder you truly are a mad master of what you do. Always looking forward to the next step. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5870755 Share on other sites More sharing options...
Blackadder Posted October 13, 2022 Author Share Posted October 13, 2022 Corner Bastions,  In the past few weeks I've managed to complete hundreds of components out of thousands of bits on plastic.  I have far outstripped my budget and my original ambition for this project.  Seen below is my first trial assembly of the corner Bastion with its corner pylons each of with consumed days of tedious assembly.  The trim bound by gum bands on the left  contains 98 assembled strips each containing 8 bits of meticulously crafted styrene plastic.   On the  right of the image is another bound bundle of trim 32 assembled strips each containing 6 bits of styrene.   I rebuilt the corner upper bastions to be more compact and began the upper gun mounts flanking the pylons.  I decided to take a break from the frantic pace and post an update while I regroup and begin completing the other 7 pylons and mounting them on the upper bastions. LameBeard, firestorm40k, Loquille and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5875235 Share on other sites More sharing options...
Mud Duck Posted October 14, 2022 Share Posted October 14, 2022 Mad, I say! Mad! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5875509 Share on other sites More sharing options...
Grotsmasha Posted October 17, 2022 Share Posted October 17, 2022 The best type of mad though.... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5876126 Share on other sites More sharing options...
Rusted Boltgun Posted October 17, 2022 Share Posted October 17, 2022 To maintain the vision and output on a project of this magnitude is fantastic. I hope to maintain my hobby focus long enough to see it brought to conclusion. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5876376 Share on other sites More sharing options...
Blackadder Posted October 25, 2022 Author Share Posted October 25, 2022 (edited) Thanks for the replies,  Whew; well it took the better part of a month but I finally finished the corner obelisks. Literally thousands of pieces   But I think it was worth it.   I can't wait until they're painted gold and graphite and installed on the Titan's super structure.   The beauty of these modular constructions is that I can begin painting as soon as the sub-structures are completed....  To my satisfaction that is so there are the discrepancies to be dealt with.  But these are sufficiently done so I can begin working on the gun mountings on these units. it will be a release from the tedium as I only need eight gun emplacements. Piece o' cake. :D  Edited October 25, 2022 by Blackadder CaptainFrederickson, Kythnos, Dr_Ruminahui and 11 others 14 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5878927 Share on other sites More sharing options...
Blackadder Posted November 29, 2022 Author Share Posted November 29, 2022 Yeah, I've been totally remiss in posting new work but in spite of the tedium of adding all these bits and the time consumed it does not seem very much to report... So we'll take it from where I installed the spikes on the corona. This actually is a chaos feature but it looked so d@mned good I couldn't resist. Â Then I had to adjust the cannon emplacements to fit the new design otherwise all the new detail wouldn't fit. There's a months worth of revamping to post but here's some tidbits to nosh on whilst I get some pictures together. Â Â Zebulon, Loquille, Focslain and 15 others 18 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5888249 Share on other sites More sharing options...
Brother Carpenter Posted November 30, 2022 Share Posted November 30, 2022 Â Wonderfull. Looking very nice. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5888380 Share on other sites More sharing options...
dieusurterre Posted December 27, 2022 Share Posted December 27, 2022 I was visiting Malta during Christmas holidays, the St John's Cathedral hit me like a good source of inspiration for you! Wulf Vengis, Majkhel and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5895290 Share on other sites More sharing options...
dieusurterre Posted December 27, 2022 Share Posted December 27, 2022 The floor is made of the tombstones of the knight templars Valkia the Bloody, Majkhel, Brother Carpenter and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5895291 Share on other sites More sharing options...
Brother Carpenter Posted December 28, 2022 Share Posted December 28, 2022 Thanks. It is suitable zeal inspiring for a bt player as well. Interesting to see that most of the depicted stones are dated in the 18th century. Depicting deaths between 1708 and i believe 1768. ( I know ex archaeologist speaking) Â Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5895550 Share on other sites More sharing options...
dieusurterre Posted January 10, 2023 Share Posted January 10, 2023 They were many more, but that's all I took... :/ Valkia the Bloody 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5898917 Share on other sites More sharing options...
dieusurterre Posted March 30, 2023 Share Posted March 30, 2023 I hope (once again) BA is all right! It's been a while since his last update Brother Carpenter 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5927458 Share on other sites More sharing options...
Blackadder Posted April 9, 2023 Author Share Posted April 9, 2023 We're back ( I hope for good ) To tell the truth I've been busy with local politics and have not had time to work on this project for the past four months. I'll scrounge around for some update images. Last week I totally disassembled the model to make ready to work on the upper deck. I also removed the upper legs to work on the thigh and knee armour regions. ' I've also been teaching myself "Pirates of the Caribbean" on the piano. It's a tough piece to learn and my old hands and fingers aren't up to the god awful repetition in the base clef. https://www.youtube.com/results?search_query=pirates+of+the+caribbean+piano+impossible I'll post something in a day or two Brother Christopher, Firedrake Cordova, Focslain and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5931602 Share on other sites More sharing options...
AlexCrute Posted April 10, 2023 Share Posted April 10, 2023 Sir we appreciate the proof of life. This creature of yours is teaching us patience, it's a public service really. Zebulon 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/45/#findComment-5932400 Share on other sites More sharing options...
