Canadian_F_H Posted September 12, 2022 Author Share Posted September 12, 2022 So... I was working on a conversion project to build "The Tormentor" because in HH1 it didn't count towards the LOW 25% points limit. Now it's much more expensive in points and it is counted against LOW+Primarch limit... so it is now basically restricted to Apocalypse sized games. So I'll finish it as an Octoblade for my IW with much less urgency... I will eventually make the Tormentor. But It seams it will be a bit more involved since it's now a shadowsword with a turret instead of a central axis gunmount. Anybody have any ideas? Link to comment https://bolterandchainsword.com/topic/331677-iron-warriors-lay-seige-to-acadiana/page/4/#findComment-5865891 Share on other sites More sharing options...
Canadian_F_H Posted October 12, 2023 Author Share Posted October 12, 2023 (edited) Finally had time to work on hobby. started these an embarrassingly long time ago. for Horus Heresy Era: Iron Warriors Dominator Cohort Terminators. (for 40k, just Chaos Terminators with whatever. i guess accursed weapons or powerfists, and the MM can be a Heavy flamer) Conversion materials: Tortuga Bay's Primarisized Cataphractii bodies and shoulder plates (I trimmed the shoulder plates down because frankly they were WAY too big). Model railroad scale chain from "Builders-in-Scale" http://www.builders-in-scale.com/bis/parts-chain.html Combi-Bolters and right arms +1 right arm from Tartaros Terminator kit Remaining leftaArms and all Thunderhammers are from Assault Intercessor kit multimelta + it's hoses + backpack from Eradicators + the arm and part of the weapon is from the Tartaros Heavy Flamer arm Heads are from the Forgeworld Iron Warriors set. Guitar strings for power cables to thunderhammers. Still some things i will likely do to them eventually but this is where I am stopping at for now. Group shots Spoiler Individual shots Spoiler Edited October 12, 2023 by Canadian_F_H Updated materials used. Brother Tyler, Kythnos, Wind Whistler and 4 others 1 6 Back to top Link to comment https://bolterandchainsword.com/topic/331677-iron-warriors-lay-seige-to-acadiana/page/4/#findComment-5994444 Share on other sites More sharing options...
Dr_Ruminahui Posted October 12, 2023 Share Posted October 12, 2023 Heh, you're still around! Great to see you escape from the Eye of Terror. Your terminators look really good - their flat shoulders make a great pallet to show off the hazard stripes. Canadian_F_H 1 Back to top Link to comment https://bolterandchainsword.com/topic/331677-iron-warriors-lay-seige-to-acadiana/page/4/#findComment-5994487 Share on other sites More sharing options...
madlibrarian Posted October 14, 2023 Share Posted October 14, 2023 Dude that multi Melta conversion is absolutely inspired! Great job! Canadian_F_H 1 Back to top Link to comment https://bolterandchainsword.com/topic/331677-iron-warriors-lay-seige-to-acadiana/page/4/#findComment-5995098 Share on other sites More sharing options...
Canadian_F_H Posted October 15, 2023 Author Share Posted October 15, 2023 10 hours ago, madlibrarian said: Dude that multi Melta conversion is absolutely inspired! Great job! Thanks! I'm very pleased with how the Multimelta worked out. The hoses were a bit annoying. I had to heat them up in boiling water and reshape them a bit, and ended up pinning them at every join with brass wire... but otherwise i was surprised it was not to difficult of a conversion. All the chains were the most tedious part of the whole build. madlibrarian and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/331677-iron-warriors-lay-seige-to-acadiana/page/4/#findComment-5995172 Share on other sites More sharing options...
