Burias-Drak'shal Posted February 9, 2021 Share Posted February 9, 2021 Stunning work Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5665622 Share on other sites More sharing options...
Almagor Posted February 9, 2021 Author Share Posted February 9, 2021 FW MKIV Siege Dreadnought. Only a matter of time till it becomes a legend... Kind of surprised it isn't one yet. khorneslegion, Chaplain Raeven, lucien and 13 others 16 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5665852 Share on other sites More sharing options...
jbaeza94 Posted February 9, 2021 Share Posted February 9, 2021 That boy is sweet! Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5665884 Share on other sites More sharing options...
Almagor Posted February 25, 2021 Author Share Posted February 25, 2021 Another dreadnought for my 5th company! Galloway, bigtrouble, SteveAntilles and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5671150 Share on other sites More sharing options...
Burias-Drak'shal Posted February 27, 2021 Share Posted February 27, 2021 Those dreads look great ! Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672181 Share on other sites More sharing options...
Almagor Posted February 27, 2021 Author Share Posted February 27, 2021 Those dreads look great ! Â Thank you! Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672186 Share on other sites More sharing options...
Gederas Posted February 27, 2021 Share Posted February 27, 2021 I'm in agreement, the Dreadnoughts look awesome. Â My only comment is that iId make the barrels of the multi-melta bigger on the second one as it's.... Kind of tiny and not close to how large melta barrels are usually shown? Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672243 Share on other sites More sharing options...
jbaeza94 Posted February 28, 2021 Share Posted February 28, 2021 How do you get the barrel so centered ? When I try it’s always slightly offset Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672280 Share on other sites More sharing options...
Almagor Posted February 28, 2021 Author Share Posted February 28, 2021 I'm in agreement, the Dreadnoughts look awesome. Â My only comment is that iId make the barrels of the multi-melta bigger on the second one as it's.... Kind of tiny and not close to how large melta barrels are usually shown? Â Thank you! Â Purely aesthetically speaking, you are probably right. A slightly larger hole might look better. The art and models of meltas and multi-meltas are quite inconsistent. Some have large bores and some small. My reasoning is that the only reason to have a large bore on a barrel is if you are firing a large caliber projectile. Energy based weapons, weather las, flame, melta or plasma have no need for a large bore on the barrel. Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672415 Share on other sites More sharing options...
Almagor Posted February 28, 2021 Author Share Posted February 28, 2021 How do you get the barrel so centered ? When I try it’s always slightly offset  1. I make a tiny indentation with a pin tack. If it's not dead center, I make another one, till I'm happy with it. 2. I make a pilot hole with a very small diameter drill bit 3. I expand the hole with progressively larger drill bits till I reach the desired diameter. Could take 2 stages for a small diameter like 1mm or up to 4 stages for a large one, like 3mm  Practice makes perfect. Also, don't always succeed... Look carefully through this thread, you'll see quite a few of my blunders. Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672416 Share on other sites More sharing options...
Gederas Posted February 28, 2021 Share Posted February 28, 2021 (edited) I'm in agreement, the Dreadnoughts look awesome. Â My only comment is that iId make the barrels of the multi-melta bigger on the second one as it's.... Kind of tiny and not close to how large melta barrels are usually shown? Thank you! Â Purely aesthetically speaking, you are probably right. A slightly larger hole might look better. The art and models of meltas and multi-meltas are quite inconsistent. Some have large bores and some small. My reasoning is that the only reason to have a large bore on a barrel is if you are firing a large caliber projectile. Energy based weapons, weather las, flame, melta or plasma have no need for a large bore on the barrel. That makes sense, yeah. I personally like the depiction in the Space Marine 3rd-person shooter game where the melta's wide barrel was so that a "cone" of thermal energy was projected from it. Which also fits the description I get from a lot of the Black Library novels (in that Melta weapons shoot out a cone of thermal energy) Edited February 28, 2021 by Gederas Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672494 Share on other sites More sharing options...
jbaeza94 Posted February 28, 2021 Share Posted February 28, 2021   How do you get the barrel so centered ? When I try it’s always slightly offset 1. I make a tiny indentation with a pin tack. If it's not dead center, I make another one, till I'm happy with it. 2. I make a pilot hole with a very small diameter drill bit 3. I expand the hole with progressively larger drill bits till I reach the desired diameter. Could take 2 stages for a small diameter like 1mm or up to 4 stages for a large one, like 3mm  Practice makes perfect. Also, don't always succeed... Look carefully through this thread, you'll see quite a few of my blunders. Ah, the tiny indent with a pin is what I wasn’t doing. I would try to use my exacto blade to make the initial hole and I could never get it centered enough. I’ll try the pin now and hopefully it’ll be better Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5672536 Share on other sites More sharing options...
Almagor Posted March 28, 2021 Author Share Posted March 28, 2021 Three more Ravenwing Bikers, made from eBay scrap and spare bits. bevulf, bigtrouble, Interrogator Stobz and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5683942 Share on other sites More sharing options...
Almagor Posted April 20, 2021 Author Share Posted April 20, 2021 Another terminator squad, this one made from AoBR terminators with a few extra bits to make them look more like Deatwing. Also, 5 tactical marines made from ebay scrap I got in lot purchases and leftover bits. Skywrath, ranulf the revenant, Chaplain Raeven and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5690913 Share on other sites More sharing options...
Interrogator Stobz Posted April 21, 2021 Share Posted April 21, 2021 Fabulous Work Brother! Â Keep doing the Lion Proud. Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5691211 Share on other sites More sharing options...
Almagor Posted April 22, 2021 Author Share Posted April 22, 2021 Fabulous Work Brother! Â Keep doing the Lion Proud. Â Thank you! Will do! Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5691366 Share on other sites More sharing options...
Almagor Posted May 5, 2021 Author Share Posted May 5, 2021 3 Ravenwing Black Knights converted from Dark Vengeance bike squad. Galloway, Chaplain Raeven, Brother Christopher and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5695281 Share on other sites More sharing options...
Galthan Ironsturm Posted May 12, 2021 Share Posted May 12, 2021 Really beautifull paints! You dont put corvus hammer on your black knights ? Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5698587 Share on other sites More sharing options...
Almagor Posted May 13, 2021 Author Share Posted May 13, 2021 Really beautifull paints! You dont put corvus hammer on your black knights ? Â Thank you! Â Usually I do give them corvus hammers but as this is my third batch of converted Black Knights I had no spare bits and decided against buying more from ebay. Galthan Ironsturm 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5699143 Share on other sites More sharing options...
Almagor Posted May 19, 2021 Author Share Posted May 19, 2021 Three more bikers. That's enough Ravenwing for now... bigtrouble, Wrath of Bruinen, ranulf the revenant and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5701236 Share on other sites More sharing options...
Almagor Posted July 6, 2021 Author Share Posted July 6, 2021 Wow it sure took me a long time to paint this one... So much effort for just 55 pts. Great model though. bigtrouble, Cpt. Bannockburn, Wrath of Bruinen and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5717245 Share on other sites More sharing options...
Wrath of Bruinen Posted July 7, 2021 Share Posted July 7, 2021 Very nice! Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5717335 Share on other sites More sharing options...
Galthan Ironsturm Posted July 7, 2021 Share Posted July 7, 2021 Beautifull Speeder ! Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5717387 Share on other sites More sharing options...
Almagor Posted July 10, 2021 Author Share Posted July 10, 2021 Stormraven gunship. Because who needs aerodynamics and clear firing arcs when you have faith in the emperor?! Brother Christopher, Galloway and Skywrath 3 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5718126 Share on other sites More sharing options...
Wrath of Bruinen Posted July 10, 2021 Share Posted July 10, 2021 Superb blending on the green, looks really great! Almagor 1 Back to top Link to comment https://bolterandchainsword.com/topic/331876-almagors-dark-angels/page/12/#findComment-5718299 Share on other sites More sharing options...
