+++Age of Darkness Loyalist Outpost (AoD-L)+++
Just thought I'd post this up. As soon as this dude and the Warsmith are done, that BT Ven dread will be getting vowed in as a fallen warrior of the Templars, complete with some Terminator goodness.
WHAT HERESY IS THIS!?!? AND IN THE LOYALISTS OUTPOST TOO!
Sadly Captain, even Templar Brethren fall in battle. (Plus my interest in a combined 40k BT/SW army waned with news of 8th ed and I need to justify the Templar-looking termies, LR and dreadie)
Ah, that's what you mean... You know for us Dark Angels "Fallen Warrior" has a different meaning... never mind, move on, nothing to see here... :tongue.:
Vow 1 complete. I got these done a lot quicker than I expected, especially as I went into the event with only a vague idea for a colour scheme and spent quote some time experimenting. Talking of experimenting I have used for the first time the Gemstone paints and Agrellan Earth texture and while I need to get a lot better with both I do like how they are turning out so far.
Hope the pictures are ok, parts are out of focus, sorry. Let me know if you want close-ups, more details on anything or any other questions in general.
Hidden Content
Group shot
Malagra close up
Thallax close up
Ursarax close up
Vow 2 will follow shortly.
Excellent result and excellent timing! :thumbsup: Well done sir! Now I wait eagerly for your follow-up vow!
UPDATED TO THIS POINT!
@Trokair, I really like your color choices. That blue pops. And what green did you use on Malagra's blade?
Thank you.
For all the the green I used Waystone Green over a Stormhost Silver. For the Malagra's blade specifically I watered it down a bit so that it flowed quite easily (as it is naturaly a very gloppy paint as per it original design and intended function), filled in the low lying regions, wiped away and over spill and once dry added a even more tinned down waystone green to even the colour out a bit. Then I just used more silver to tidy up.
Those are really tempting me to add some robots.
Then by the grace of the Omnissiah do so in your second vow. Also Thallax and Ursarax are not technically robots, they are more like mini dreadnoughts :wink:
Edit: trying to not double post.
Vow 2
I, Trokair, rise to the challenge of E TENEBRAE LUX on the side of the Loyalist in this Age of Darkness and vow to complete for the all-glory of the Omnissiah one Calleb Decima, one Archmagos Reductor and their attended Thallax and Ursarx Cohorts as detailed below and coming to a total value of 1,185 points as described in Taghmata Red Book on or before August 1st, 2018. Success will bring eternal glory for the Omnissiah and failure will doom me to wear the Badge of the Oathbreaker for as long as the Omnissiah decrees.
Calleb Decima 190p
Cyber-familiar
(235p if the Decima Invictus upgrade is allowed, as it is for games after the Isstvan III campaign and I am not sure how this interacts with the normal rules as I do not have the black books to read up on the specifics of that campaign.)
Archmagos Prime Reductor 305p
Augury scanner, Cyber-familiar, Rad grenades, Archaeochtech pistol, Power fist, Master Crafted Paragon blade, Machinator Array, Abeyant, Djin-skein
Thallax Cohort 145p
3 Thallax, 1 Irad-Clenser
Thallax Cohort 175p
3 Thallax, 1 Photon Thrusters, Destructor
Ursarax Cohort 185p
3 Ursarax, 1 with Power Fists
Ursarax Cohort 185p
I figure I should post an update so you fine people can see how I'm going.
The cataphractii terminators are finished, with the exception of their bases, so now I've started working on the veterans. I'll base everything in the vow together just to make it easier.
The veterans have just had a basecoat of green and I'll try to work through them over the week to get them finished quickly.
Once the vets are finished I'll be able to make a start on the characters. I'm quite looking forward to getting to them.
Great progress guys! And a big follow up there Trokair!
THIS IS THE CUT-OFF FOR THE WEEKLY UPDATE - EVERY VOW OR COMPLETION REPORTED BEYOND THIS POINT WILL COUNT FOR NEXT WEEK'S UPDATE.
Made some pretty good progress on the vets!
Next up will be a big batch of white pads and helmets. I'll get these involved vets done pretty quickly, I should fly though the bog standard tacticals and assault marines!!
http://i66.tinypic.com/afhb35.jpg
Thanks Semper.
Checkmate, what bases are your terminators on? They look small.
Nice colour scheme by the way.
Cheers Trokair :smile.:
The bases are only 25mm, but I only have models that I'm painting on them. I'll transfer the terminators to the 40mm when I've primed and painted the bases.
Looks pretty cool Studio Silvernale, great work on the colour and the decals! :thumbsup: I sure hope your order arrives soon! :smile.:
On an other matter, the AoD-L seems to be running out of steam... You really need to up your recruitment effort here... AoD-T is only two participants behind! :o
The 129th here the war clarion of the Emperor, and we will not be found wanting. I, Vazzy, rise to the challenge of E TENEBRAE LUX on the side of the Loyalist in this Age of Darkness and vow to complete for the glory of the Primarch, The Avenging Son, Roboute Guilliman, and the XIII Legion:
1 Praetor with Terminator armor, Iron halo, and Mastercrafted-Paragon Blade- 180 pts
1 Sicaran Arcus Strike tank- 205 pts
I'll edit in pics this evening Cap!
Going to use a box of reivers as my headhunter squad.
** When I pledged, I had a brain fart and just said 10 headhunters and totally forgot to specify their options.
10x headhunter (5x combi-weapon, 1x heavy bolter; sergeant with power sword and plasma pistol) [390 points] not [300 points]
I, Grand_master85, rise to the challenge of E TENEBRAE LUX on the side of the Age of Darkness Loyalists, and vow to complete the list below which has a total value of 884 points, on or before August 1st, 2018. Success will bring me eternal glory in the name of Ferrus Manus, and failure will doom me to wear the Badge of the Oathbreaker until the year-end.
I had entertained the idea of being a traitor and going Iron Warriors, but I couldn’t bring myself not to be Loyal.
My pledge is as follows:-
Iron Father - Cataphractii Terminator Armour, Paragon Blade, Volkite Charger, Iron Father upgrade, Digital Lasers - 217pts
Legion Terminator Squad - 5x, 2x Chainfist, 3x Power Fist, Plasma Blaster, Combi-Flamer, Grenade Harness - 242pts
Tactical Squad - 10x, Nuncio Vox, Legion Vexilla, Power Axe, Melta Bombs, Artificer Armour - 170pts
Rhino Armoured Carrier - 35pts
Sicaran Venator - Heavy Bolters, Pintle Mounted Heavy Bolter - 220pts
Looking forward to painting again! Next pledge will be Ferrus and friends.
http://i.imgur.com/noyADaV.jpg
Vow 1 complete. So after getting these guys 95% done last Monday I hit a bit of a motivational wall to get those final finishing touches done. Fortunately I managed to sit down and crack on with it today and finally have completed my vow.
The Dreadnoughts
20180520 212205
The Xiphon Interceptors
20180520 212549
