Zephaniah Adriyen Posted May 19, 2019 Share Posted May 19, 2019 Okay, so. I'm likely going to be able to get an Imperial Knight by Tuesday. That's three days from now. I only have one decision to make: Leviathan or Princeps Astor? I'm running a Nurgle army and an AdMech/Astartes army as it is, and both have Knights sworn to and/or running them in fluff. Both are Questoris-Class Knights. One is Lord Leviathan, a Nurglite Knight with his own personal back garden and small retinue of devout followers. The other is Lady Astor, Princeps of the House Astor, sworn to Forge World Ragnarus. Leviathan was Lady Astor's brother until his betrayal, and I'm building both in the end anyway, but I'm wondering which to attempt for my first Knight. I figure Leviathan's more difficult to pull off (I'd essentially have to base his back for him to match my vision of what he should look like), but, frankly, my Nurgle army needs the boost in strength. My Imperium already has a decent size to it (nearly 2k points) and my Nurgle army is just over 1k. Thoughts? Link to comment https://bolterandchainsword.com/topic/356058-lord-leviathan-or-lady-astor/ Share on other sites More sharing options...
ValourousHeart Posted May 19, 2019 Share Posted May 19, 2019 Well if Astor is going to be generally out of the box, and Leviathan is going to be heavily modified... then I would probably go with Astor first, but take notes while building that one with your thoughts on how best to modify it for when you build Leviathan. You'll also be able to make a clean version of the heraldry and then nurglfy it... which I think will be easier than trying to clean up the nurgle version. Link to comment https://bolterandchainsword.com/topic/356058-lord-leviathan-or-lady-astor/#findComment-5316693 Share on other sites More sharing options...
Gederas Posted May 19, 2019 Share Posted May 19, 2019 Well if Astor is going to be generally out of the box, and Leviathan is going to be heavily modified... then I would probably go with Astor first, but take notes while building that one with your thoughts on how best to modify it for when you build Leviathan. You'll also be able to make a clean version of the heraldry and then nurglfy it... which I think will be easier than trying to clean up the nurgle version. I'm in 100% agreement on this. It makes it easier to do a corrupted heraldry of something if you do the non-corrupted one first :lol: Link to comment https://bolterandchainsword.com/topic/356058-lord-leviathan-or-lady-astor/#findComment-5316707 Share on other sites More sharing options...
DOGGED Posted May 20, 2019 Share Posted May 20, 2019 My two cents: Build Lady Astor first and wait until the chaos knights are released to build Lord Leviathan. You'll have two "out of the box" knights to build, no need to do conversion work except for adding bits to the Nurgle knight which you can get out of the Nurgle minis you have already built. Link to comment https://bolterandchainsword.com/topic/356058-lord-leviathan-or-lady-astor/#findComment-5317302 Share on other sites More sharing options...
Zephaniah Adriyen Posted May 20, 2019 Author Share Posted May 20, 2019 Update: I was able to get a Knight earlier than expected and Lady Astor is well underway as of right now. Just need to build her carapace weapon and add some of those little ladder-rungs on her back. Link to comment https://bolterandchainsword.com/topic/356058-lord-leviathan-or-lady-astor/#findComment-5317446 Share on other sites More sharing options...
