Rogue Crusader Posted July 25, 2020 Share Posted July 25, 2020 (edited) Templar-izing my Outriders I already have a pretty large bike force for my Black Templars so I've been waiting excitedly for the Outriders. I added some of my existing bike conversion parts to the mix along with the heavy guardbrace on the shoulder pads. For the exhausts, I removed the thinner segment of the exhaust pipe filed it smooth then attached my resin upgrades rather than just drilling out the tube. Because they are so small they can be a bit fiddly but IMO it's worth the effort. It helps to add them before attaching the side pieces to the bikes, while you can still do it at any point it's just easier while it's still separate. I use a jewelry saw to remove the tube tips on the exhaust since it makes a nice clean & controlled cut, then filed everything smooth before attaching the resin tips. I use the tip of my hobby knife or a sewing needle carefully touched between the vents and help pick it up so I can eyeball that everything is straight before pressing it in place. The guardbrace was heated in very hot water for about 15 seconds then bent around the shoulder pad. (Hot enough to make tea) If you mess up they can be reheated and they'll flatten back out. Just make sure they aren't too cold when you go to bend them or they could crack. If's it's heated correctly it'll be very pliable. I used one of the Templar vehicle crosses on the hood and the shrine on the rear is a press molded copy of the top of the buttress piece from the Imperial Sector city fight terrain. Link for where to find the conversion parts: https://www.reddogminis.com/human-scaled-infantry.html Edited August 7, 2022 by Rogue Crusader Mmmmm Napalm, Marshal Mattias, Champion Rawne and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/ Share on other sites More sharing options...
Gederas Posted July 25, 2020 Share Posted July 25, 2020 How'd you make the exhaust tips? I must find this out for my own :yes: Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5571118 Share on other sites More sharing options...
Rogue Crusader Posted July 25, 2020 Author Share Posted July 25, 2020 I 3D printed them, there’s a link to my website in the post & my sig line. Gederas 1 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5571147 Share on other sites More sharing options...
Rogue Crusader Posted July 26, 2020 Author Share Posted July 26, 2020 So here's more of the Indomitus stuff with the heavy guardbraces. There's a couple really simple tricks that help when working with them. Do all your cleaning on the part first. Have a coffee mug of really hot water like you're making tea and a toothbrush. You can stick the guardbrace in the bristles of the tooth brush then submerge it in the water. That way you're not scalding your finger tips trying to hold it with tweezers or dropping it and having to fish it out. (Make sure to reheat the water periodically to keep it hot if you're doing multiple sets). Leave it in 15-20 seconds and it should be really pliable take it out and quickly bend it around the handle of your exacto knife. They're almost the perfect size and curvature to match the shoulder pads. Let it sit and cool so it holds it shape then you can glue it on, once it has the curve set in place the resin has enough spring and bend to it that you should be able to fit it snugly against the shoulder pad without too much of a gap. I had already pre-assembled most of the models so I had to pop the backpacks off a couple to get the pads on, fortunately I use super glue for everything and not plastic cement. Later when I have more time I'll be grinding down the right shoulder pads on the HQ models to give them each a second pad and the standard bearer will have the bionic hand bit replaced with a more Templar-ish holy orb hanging from his chain or possibly a censer. I have a bit of a fetish for Chaplain models and it's by far my favorite model in the box. I have a second copy coming from ebay so I decided to modify this one and give him a skully head which I'd recast. I also can't wait for the upcoming bike Chaplain. The sergeants in each squad are going to get SB pads to denote their veteran status. IMO the pads help them look big and chonky and helps them stand out vs the other marines in their squad. Champion Rawne, Marshal Laeroth, The Ergonomic Enginseer and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5571215 Share on other sites More sharing options...
TheOneTrueZon Posted August 9, 2020 Share Posted August 9, 2020 Thank you once again for the quick pack and ship, always outstanding quality! I've got 3x Outriders and 6x Bikes on deck for the painting bench after I finally finish my Angry Marines. Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5581213 Share on other sites More sharing options...
Sword Brother Adelard Posted August 9, 2020 Share Posted August 9, 2020 I WANT MINE! Damn international post... Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5581221 Share on other sites More sharing options...
SWORD BROTHER RYAN Posted August 9, 2020 Share Posted August 9, 2020 Wonderfully done Brother! You make great use of the add-ons, and I can't wait to see them done up in color! Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5581251 Share on other sites More sharing options...
Wulf Vengis Posted August 11, 2020 Share Posted August 11, 2020 Gorgeous... Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5582898 Share on other sites More sharing options...
BLACK BLŒ FLY Posted August 12, 2020 Share Posted August 12, 2020 Excellent work ! /thumbs up Thanks for sharing. Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5582984 Share on other sites More sharing options...
Sword Brother Adelard Posted August 12, 2020 Share Posted August 12, 2020 MINE ARRIVED! PRAISE BE! Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5583085 Share on other sites More sharing options...
atropos_priest Posted August 12, 2020 Share Posted August 12, 2020 Excellent work, brother! Where did you source the chaplain skull helm? I'm trying to scratch build one, but I feel I could find a better looking option. Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5583349 Share on other sites More sharing options...
Marshal Reinhard Posted August 12, 2020 Share Posted August 12, 2020 That's the space marine heroes (not the blind buy series) chaplains head https://www.games-workshop.com/en-GB/Space-Marines-Heroes?_requestid=459484 Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5583380 Share on other sites More sharing options...
Rogue Crusader Posted August 15, 2021 Author Share Posted August 15, 2021 It's been a while, but with new crusade material on the horizon it was time to get started on a new model. I like the previewed EC but not totally in love with it, so I wanted to take a stab at a custom Emperor's Champion. Parts: Indomitus chaplain, arm and head from power sword lieutenant, stern guard shoulder pads, and an old metal black sword from the first born EC.It needs a bit of clean up work and is currently being held together by stick tack while I finalize the pose and do some greenstuff work. BitsHammer, JAG Templar, Shovellovin and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730647 Share on other sites More sharing options...
Marshal Reinhard Posted August 15, 2021 Share Posted August 15, 2021 (edited) Simple, but effective. I'd personally be a bit picky about swapping that left arm holding the absolvor bolt pistol out Edited August 15, 2021 by Reinhard Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730649 Share on other sites More sharing options...
Ishagu Posted August 15, 2021 Share Posted August 15, 2021 (edited) This is great work, I'm looking forward to seeing these painted up. Edited August 15, 2021 by Ishagu Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730704 Share on other sites More sharing options...
Albinoboy Posted August 15, 2021 Share Posted August 15, 2021 Those models look ace Rogue Crusader! Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730710 Share on other sites More sharing options...
TheOneTrueZon Posted August 15, 2021 Share Posted August 15, 2021 Any plans for new bits from the Reg Dog banner to accompany the new release? I've been rocking the guardbraces since you started selling them, one of the best Templar bits out there! Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730728 Share on other sites More sharing options...
Rogue Crusader Posted August 15, 2021 Author Share Posted August 15, 2021 I have a couple ideas for new items. It’ll depend on if I can get prints done in time. At the very least I’ll be able to release a hem digital files. I have some power weapons and shields planned. Gederas 1 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730744 Share on other sites More sharing options...
Bjorn Firewalker Posted August 15, 2021 Share Posted August 15, 2021 He looks most promising. Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730815 Share on other sites More sharing options...
Medjugorje Posted August 15, 2021 Share Posted August 15, 2021 I prefer the knightly helmet. Not Mark X styled. Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5730818 Share on other sites More sharing options...
Rogue Crusader Posted August 17, 2021 Author Share Posted August 17, 2021 (edited) Converted Marshal Parts, Primaris Captain body, Riever gun arm, Sternguard head, Indomitus Chaplain backpack, 3D printed shoulder pads and Axe.Shoulder pads are available on shapeways: https://www.shapeways.com/shops/red-dog I will be making the pad and axe STL files available shortly. (I'll post info when finalized) Edited August 17, 2021 by Rogue Crusader Marshal Mattias, Brother Captain Vakarian, Brother Kraskor and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5731870 Share on other sites More sharing options...
Rogue Crusader Posted August 18, 2021 Author Share Posted August 18, 2021 Converted Gravis Captainkitbashed from Tor Garadon, easy to build Gravis Captain, Black Templars bits and resin shoulder pad and gun barrel from Red Dog Minis. (link in sig)Needs a bit of final clean up work and it'll be ready fro priming. BitsHammer, Marshal Mittens and Brother Kraskor 3 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5731900 Share on other sites More sharing options...
Rogue Crusader Posted October 21, 2021 Author Share Posted October 21, 2021 (edited) I have additional stuff underway that I'm adding the final touches to. Weapons like the axe shown on my Marshal along with a sword, hammer and shoulder pads. I'll be adding them to shapeways and I've also started up a Patreon for people who are interested in files to print their own. http://patreon.com/reddog3d Resin versions will be on my regular website soon-ish. (which is linked in my sig). Edited October 21, 2021 by Rogue Crusader BitsHammer and Brother Kraskor 2 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5755933 Share on other sites More sharing options...
Marshal Mattias Posted October 21, 2021 Share Posted October 21, 2021 These are looking awesome; I'm such a fan of those classic swordbrethren shoulder-guards. Might need set of them to sprinkle through my planned primaris reinforcements... Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5755985 Share on other sites More sharing options...
Khornestar Posted October 21, 2021 Share Posted October 21, 2021 Is there any way to just buy the STLs we want from you, and not this whole subscription thing? These are tremendous. Well done! T14 1 Back to top Link to comment https://bolterandchainsword.com/topic/365438-primaris-templars-3d-created-bits/#findComment-5755996 Share on other sites More sharing options...
