Necronaut Posted July 7, 2022 Share Posted July 7, 2022 It must be "gene-stealer hybrid"! What an oddly specific password! (Why are the walls still closing in??) Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843093 Share on other sites More sharing options...
Necronaut Posted July 7, 2022 Share Posted July 7, 2022 (edited) Assuming Luthais and/or Arcturion are nominated/volun-told to go batter down the door, do we need to make an attack roll vs the stationary object, or do we go straight to damage? And is there an advantage to charging the door (i.e. bonus damage on charge via Blood Angels chapter trapping)? Edited July 7, 2022 by Necronaut Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843108 Share on other sites More sharing options...
Machine God Posted July 7, 2022 Share Posted July 7, 2022 (edited) 12 minutes ago, Necronaut said: Assuming Luthais and/or Arcturion are nominated/volun-told to go batter down the door, do we need to make an attack roll vs the stationary object, or do we go straight to damage? And is there an advantage to charging the door (i.e. bonus damage on charge via Blood Angels chapter trapping)? I think MR said to Lysimachus that you Had to roll To Hit, it isn't automatic. Like you can hit it but not damage it MR said: @Lysimachus The simple answer is (+0) as it's not a target, it's an object, but it's so large it's like a wall if that makes sense. You can't fail to hit it, it's so big, but likewise you get no benefit, because it's so big. (Any failed attack roll will be the natural robustness of the door, the angle of the attack was off etc). There is a way out... If you want to use The Ladder... Edited July 7, 2022 by Machine God MR's answer & remembered the Ladder. Necronaut and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843111 Share on other sites More sharing options...
Necronaut Posted July 7, 2022 Share Posted July 7, 2022 Got it, cheers. Missed that post. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843114 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 (edited) 28 minutes ago, Machine God said: If you want to use The Ladder... Ladder is too small. You could cut a hole to open it up, but it's going to be tougher to do than the door. This is one of my "I don't want to say no, because you're thinking laterally, but it's not that great an alternative" type posts. Edited July 7, 2022 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843124 Share on other sites More sharing options...
Necronaut Posted July 7, 2022 Share Posted July 7, 2022 10 minutes ago, Mazer Rackham said: Ladder is too small. You could cut a hole to open it up, but it's going to be tougher to do than the door. This is one of my "I don't want to say no, because you're thinking laterally, but it's not that great an alternative" type posts. Somehow I suspect we would have to continue cutting down the entire length of the ladder assuming it's built into a narrow shaft (we're talking serious material removal), plus we would almost certainly have to contend with some hilarious fall damage depending upon where (if?) the ladder terminates. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843131 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 Just now, Necronaut said: Somehow I suspect we would have to continue cutting down the entire length of the ladder assuming it's built into a narrow shaft (we're talking serious material removal), plus we would almost certainly have to contend with some hilarious fall damage depending upon where (if?) the ladder terminates. Fall damage no, but we're talking deck thickness, down to the underdeck. Excavation is the operative word, I suppose. Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843133 Share on other sites More sharing options...
Machine God Posted July 7, 2022 Share Posted July 7, 2022 12 minutes ago, Mazer Rackham said: Ladder is too small. You could cut a hole to open it up, but it's going to be tougher to do than the door. This is one of my "I don't want to say no, because you're thinking laterally, but it's not that great an alternative" type posts. How about this one? Arcturion sliced Hybrid#2 into two halves. We take the two halves of the Hybrid to the door, We put the two halves together to make a whole and then we climb through the hole. Mazer Rackham, Trokair, Lysimachus and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843135 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 I like it. It's like a portable hole, but it's so wrong, that doesn't make it right. ;) Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843140 Share on other sites More sharing options...
Trokair Posted July 7, 2022 Share Posted July 7, 2022 (edited) If only one of us can go through the door per turn (after we attacked it) and there are five of us, and there are four turns till squish one of us mathematically is already dead?  Edit: what would I need to do in assiting to search for the braclet thingy. Edited July 7, 2022 by Trokair Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843164 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 (edited) Oops! Copypasta error? EDIT: No, it's ok - just need to put the door into Critical wounds (so anything from -1 to -10) to make a big enough hole for you go out two at a time. Like Noah's Ark. Edited July 7, 2022 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843168 Share on other sites More sharing options...
Lysimachus Posted July 7, 2022 Share Posted July 7, 2022 Question: we only need to make 1 hole don't we? It's not that each attacker needs to get 30 SI on their own, is it? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843174 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 (edited) Correct, only one opening is required. Anything more than that, and you boys are either showing off, making modern art, or going to funny Slanneshi clubs... Edited July 7, 2022 by Mazer Rackham Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843178 Share on other sites More sharing options...
Necronaut Posted July 7, 2022 Share Posted July 7, 2022 Let me at 'em! Let me at 'em! Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843182 Share on other sites More sharing options...
Mazer Rackham Posted July 7, 2022 Author Share Posted July 7, 2022 (edited) 37 minutes ago, Trokair said: Edit: what would I need to do in assiting to search for the braclet thingy. @Trokair A search action, Challenging (+0) Perception Test (due to the corpse's condition. You don't need the map, you can handle that narratively ("I crouch by the body, search it etc") It will take your Full Action (turn). There are three bodies. You may search Hybrid 4, Hybrid 2, or Hybrid 3. I will randomly determine which one has the bracelet, until by elimination or luck it is discovered. DO NOT SPOIL - posted for transparency. Spoiler You didn't peek did you? Spoiler Are you sure you didn't peek? Spoiler Really? Spoiler Hybrid 4    A simple pass is required to determine if the body does, or does not have the bracelet. Is everyone ok with that? Edited July 7, 2022 by Mazer Rackham Trokair, Machine God and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843188 Share on other sites More sharing options...
A.T. Posted July 7, 2022 Share Posted July 7, 2022 Luthais has a shot at door-wrecking. Lightning claws are +2 damage for every DoS - so they can stack up. Mazer Rackham and Necronaut 2 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843193 Share on other sites More sharing options...
Trokair Posted July 7, 2022 Share Posted July 7, 2022 (edited) Post updated: http://bolterandchainsword.com/topic/374425-dw-the-desolation-of-innocence-rpg-ic-thread/?do=findComment&comment=5842801 Not much of one, still trying to find the voice and style of NergüI. Edited July 7, 2022 by Trokair Machine God and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843213 Share on other sites More sharing options...
Machine God Posted July 7, 2022 Share Posted July 7, 2022 Post edited: http://bolterandchainsword.com/topic/374425-dw-the-desolation-of-innocence-rpg-ic-thread/?do=findComment&comment=5843157 Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843217 Share on other sites More sharing options...
Necronaut Posted July 8, 2022 Share Posted July 8, 2022 @A.T. not to pry, and purely for my understanding, how did you double the pen on your lightning claws from 8 to 16? Is this another Storm Warden talent, or maybe an assault marine talent that I have missed? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843248 Share on other sites More sharing options...
A.T. Posted July 8, 2022 Share Posted July 8, 2022 (edited) 1 hour ago, Necronaut said: @A.T. not to pry, and purely for my understanding, how did you double the pen on your lightning claws from 8 to 16? Is this another Storm Warden talent, or maybe an assault marine talent that I have missed? Hammer Blow - regular assault marine talent but Storm Wardens get it cheap. It adds half the characters Strength bonus to penetration during all out attacks. Edited July 8, 2022 by A.T. Mazer Rackham and Necronaut 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843292 Share on other sites More sharing options...
Necronaut Posted July 8, 2022 Share Posted July 8, 2022 Oh of course thank you. I knew there was something I was missing.  Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843308 Share on other sites More sharing options...
Mazer Rackham Posted July 8, 2022 Author Share Posted July 8, 2022 Congratulations KT Regent, you have escaped the PULVERISER and the mission continues! We shall take a breath there whilst I sort out the next juncture of the adventure/mission and would like and encourage any feedback you have about the game thus far. Cheers! Â Necronaut, Lysimachus and Machine God 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843356 Share on other sites More sharing options...
Lysimachus Posted July 8, 2022 Share Posted July 8, 2022 Going great so far, boss! Enjoying the setting and everyone's writing, scary how nasty all the PCs are at this level! Mazer Rackham, Machine God and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5843564 Share on other sites More sharing options...
Trokair Posted July 10, 2022 Share Posted July 10, 2022 On 7/7/2022 at 11:13 PM, Mazer Rackham said: @Trokair A search action, Challenging (+0) Perception Test (due to the corpse's condition. You don't need the map, you can handle that narratively ("I crouch by the body, search it etc") It will take your Full Action (turn). There are three bodies. You may search Hybrid 4, Hybrid 2, or Hybrid 3. I will randomly determine which one has the bracelet, until by elimination or luck it is discovered. DO NOT SPOIL - posted for transparency.  Reveal hidden contents You didn't peek did you?  Reveal hidden contents Are you sure you didn't peek?  Reveal hidden contents Really?  Reveal hidden contents Hybrid 4    A simple pass is required to determine if the body does, or does not have the bracelet. Is everyone ok with that? Now that we are past the door I had a look, layers much? I just picked 4 as it was the closest fully expecting to have to move on to the others, and also for the door to last longer. Not so much TPK potential as it first appeared. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5844202 Share on other sites More sharing options...
Mazer Rackham Posted July 10, 2022 Author Share Posted July 10, 2022 The layers are to protect players who like to delve! To be honest, the setup for the first encounter was really just a bit of a taster session for us all. Never having run a game for higher level Deathwatchers, I wanted to give you guys a bit of pressure to get you thinking, deciding, rolling dice. It was also good for me to see how the mechanics worked in function, not just on paper. Success all round, I think Trokair, Machine God and Necronaut 3 Back to top Link to comment https://bolterandchainsword.com/topic/374403-dw-the-desolation-of-innocence-rpg-ooc-thread/page/10/#findComment-5844211 Share on other sites More sharing options...
