Has cracking the password shut off the autoclave? If not, I guess our first order is to shut it down? Then secondly, is there a way to vent the already superheated atmosphere and bring the room air temperature down to normal?
Once that process is started, we can decide who to send in via the cleanroom and who should stay out to operate the terminal? Presumably more than 1 can go in, either in a group or 1 at a time depending on the size of the cleanroom? So is it more a case of deciding which 1 of us won't come in?
Edited by Lysimachus
I'd definitely say Stitches should go in, his medical skills are invaluable in trying to figure out what happened? I'd probably also send Falk in, as an investigator, and Nicios to see if he can pick up more psychically than what he got from the corridor?
Reynard might be able to spot stuff that doesn't seem right, too?
I'd probably have Restal wait outside, though once Bardas gets there he might be able to get more info from the terminal? (Is there any security picter footage, for example?)
Yes, you've unlocked the terminal only. The controls for the doors, autoclave and life support will be up to your discretion.
With Bardas and Scourge being on autopilot, you can assume they can operate the terminal and keep each other honest.
Plus Bardas may delve further, but there won't be much. He will quickly discover (by simply looking at the network structure) that it's an isolated network, with only enough info on it to do small tasks.
It would be simple to send in the rest of you as a group. I'll pop up a better map soon. Players are free to post their thoughts, reactions etc in the meantime.
Ooh, very interesting! If Bardas is staying outside, does anyone else have Tech-Use to investigate the desk terminal?
As a Hiver, Reynard treats Tech-Use as a Basic skill, so he can actually still try it, though only at half Int 37 = 18... so not great odds, but I'm not sure if anyone else has a better shot at it?
Though, as its narrative time, can he just keep trying it until he gets it? Or is there a limit to it?
Edit: oh, and could he get an Assist from Bardas using the hardwired comm to the security terminal?
If you fluff it, you'll time out for 1D5 mins +5 mins per DoF, but that's it. Passing will open the safe, but the research stuff in there is completely beyond you.
I like your moxie! I regret not... ;)
Might be a good idea for the team to coordinate and decide who would be best suited to which task...
Machine God is suspicious of the  killing jar , er medicae facility...
Edited by Mazer Rackham
Cool. So, Scourge, Restal and Bardas are staying outside, so we've got 4 of us going in?
Things to look at:
Search the storage (maybe Falk, as he has Search skill and good Per?)
Look at examination table and organic remains on the floor (maybe Stitches, assuming that's a Medicae Test?)
If the stuff in the safe is beyond us anyway, and there's nothing of worth on the desk terminal except popping the safe open, I'm not sure it's the best use of time... maybe Reynard should look at the metallic remains instead? Would that require any particular skill, or will basic Awareness do the trick?
What about Nicios? Can he psy-scan the room again now he's in it? Maybe that might give us a clearer idea of what we're looking for?
Any other ideas?
True, but that's more another task for Falk (the multikey is his and he has Security skill...)
I guess if Falk wants to use his key on the safe, Reynard could rifle through the storage lockers... again though, if the Search skill is required I'm down to half Per =14 to actually find anything useful (whereas Falk has Search and Per47)
Basically, without Search, Security, Tech-Use or Medicae Skills, I'm at a slight loss as to how to use Reynard here... maybe he would be better just staying outside on guard?
Edit: well, safe is open, excellent! I guess I'll just start opening the storage cupboards and have a look through...?
Edit edit: yup, that went much as I thought! Assuming Reynard didn't just knock the cupboards over and smash everything within, he might have... eventually... found something useful...?
Standard awareness to scope out the room is always useful
That quick scurrying thing that you can just see out of the corner of your eye...
That jumping thing
Reynard has just moved to look at the blue triangle.
I think Mazer said the only use of the terminal would be as an alternative way to open the safe, so we don't have anything else to do there?
The inner terminal will open the safe (as an alternative to low Security if it fluffed or became a problem, you know, like one of you having their arm savaged by a pit worm) but it also contains medical information. It can be surmised that this was Dreyfuss' desk, and therefore would contain working files.
Like with the terminal outside, it's a Medical setup, so anyone with that kind of training will know what to look for. I'll let Stitches use his Medicae skill + his Electoo, in place of Tech-Use. (You can assume the electoo would contain your job specs, and the system would be expecting Dr Dreyfuss).
Ah ok, i misunderstood your previous comments, so we definitely want to see those files then? (Maybe they will explain more about what is in the vial in the safe?)
In that case, Reynard will continue to wait before pulling the catch, to give Stitches a chance to open the desk terminal.:thumbsup:
And the blobs on the floor are Dreyfuss and his gun, then? :laugh:
Another thought that just popped into my head: the terminal has a hard-wired commlink, which I'm assuming is like a land line through/across the Hive? Once we're into the terminal, can we use the comm to contact Verdict (or whichever V) to provide them with an update and ask if they have uncovered any more information on their end?
...and come to think of it, to ask if they know what the hinge catch is and what it does! :sweat:
Could be anything on that terminal...maybe even a folder full of 40k memes...:ph34r:
Yes, an outside line can be had and patch through to Voyager sitting on his flight throne reading Pilot's Weekly.
As for that catch, it's like a finger - pull it and find out...!
Nice!
Another question: is the commlink tied into the rest of the terminal?
(ie, can we start contacting Voyager/Verdict now, or do we need to wait for the entire terminal to be unlocked by Stitches' Medicae Test?)
