The Unseen Posted May 20, 2023 Share Posted May 20, 2023 1 minute ago, Sorceress said: dose it say anywhere that a guided unit can't be selected to observe when there unit is activated to shoot? we still activate one unit at a time in the shooting phase so if you activate unit 1 choose it to observe and unit 2 to be guided, do unit 1s shooting, is there anything stopping you from picking unit 2 and having it observe for unit 3 and so on and so on in a daisy chain of murder? Yes, the steps for picking an observer requires it to not be either an observer or guided unit. So no daisy chaining Sea Creature 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949496 Share on other sites More sharing options...
Dark Legionnare Posted May 20, 2023 Share Posted May 20, 2023 3 hours ago, Tokugawa said: Up to 2+. +1 BS is not limited by "max +1 hit on total" right? Current 9th ed rules support that. BS being modified doesn't modify the "to hit roll", its modifying a characteristic of the attack. We'll have to see if that's the case in 10. I haven't looked at the core rules leaks yet, but I'm sure somebody could vet if the logic there in 10 is the same as 9 if they've taken the time to. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949499 Share on other sites More sharing options...
spessmarine Posted May 20, 2023 Share Posted May 20, 2023 (edited) 10 hours ago, MagicHat said: My left eye have started twitching. I can't confirm if this is related to Pathfinders getting 4+ save while my cogboys were dropped to 5+, but I can't rule it out either. Isn't drones purchased by the team leader for infantry currently? I imagine the team leader will be the one that gets the +1 w for shield drones. Votann and Admech dropped to BS4+, the latter also apparently became a Sv5+ faction as you said. Tau had their squishier guys bumped to Sv4+ while staying BS4+. The other neat thing is, Markerlight 2.0 boosts BS characteristic, not hit rolls, therefore stacks. A stationary Hammerhead then hits on a 2+. Critical unchanged from being only 6s. (though, the 1/6 change to get sustained 3 hits with the railgun will definitely be burned in memories) Funny stuff for the blue men. The Tau will be probably be hitting on a 2+ fairly regularly! Edited May 20, 2023 by spessmarine Burni 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949505 Share on other sites More sharing options...
Isual Posted May 20, 2023 Share Posted May 20, 2023 (edited) 16 hours ago, Indy Techwisp said: I think it specifies that both units need to see the target for the Spotting to work. Edit: Was too fast. Damn, I red it again and you are right. Edited May 20, 2023 by Isual Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949510 Share on other sites More sharing options...
AenarIT Posted May 20, 2023 Share Posted May 20, 2023 1 hour ago, spessmarine said: Funny stuff for the blue men. The Tau will be probably be hitting on a 2+ fairly regularly! That depends on how many [HEAVY] weapons we have access to, most of the regular battlesuit guns have been assault weapons for many editions now. Without the +1 to hit if stationary from heavy, the +1BS from the army rule seems the only buff available. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949515 Share on other sites More sharing options...
Madao Posted May 20, 2023 Share Posted May 20, 2023 First of the previewed armies that AdMech bombardment will be good against, as being battleshocked prevents you from using markerlights. Similarly - Tyranids shadow over the warp might bring a lot of pain to the Tau players, disabling their faction ability for one turn (at least for the part of the army) Sea Creature 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949521 Share on other sites More sharing options...
VanDutch Posted May 20, 2023 Share Posted May 20, 2023 (edited) 18 minutes ago, Madao said: First of the previewed armies that AdMech bombardment will be good against, as being battleshocked prevents you from using markerlights. Similarly - Tyranids shadow over the warp might bring a lot of pain to the Tau players, disabling their faction ability for one turn (at least for the part of the army) Battleshock prevents the use of stratagems. Markerlights will be an army rule. So I don’t see how rad bombardment is any worse for Tau, except that we’re likely to have more units sat in the deployment zone shooting at range. Edited May 20, 2023 by VanDutch Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949525 Share on other sites More sharing options...
Madao Posted May 20, 2023 Share Posted May 20, 2023 Battleshocked units cannot be guided VanDutch 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949528 Share on other sites More sharing options...
VanDutch Posted May 20, 2023 Share Posted May 20, 2023 20 minutes ago, Madao said: Battleshocked units cannot be guided Ah my bad, I missed the exceptions bit in the rule. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949537 Share on other sites More sharing options...
AenarIT Posted May 20, 2023 Share Posted May 20, 2023 24 minutes ago, Madao said: Battleshocked units cannot be guided No, battleshocked units can be guided but cannot guide others. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949539 Share on other sites More sharing options...
Madao Posted May 20, 2023 Share Posted May 20, 2023 8 minutes ago, AenarIT said: No, battleshocked units can be guided but cannot guide others. Hmm, you are right. The rule is too overcomplicated for me. But to be honest - it does not change anything in the end, as if whole army is battleshocked, then no one can be an Observer - > no one will be Guided mel_danes, Emperor Ming and Tymell 3 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949542 Share on other sites More sharing options...
Emperor Ming Posted May 20, 2023 Share Posted May 20, 2023 What a complicated system compared to the previous Drones better be free, going from wound blockers to tokens is a huge change CrusaderXIII, Oxydo, tzeentch9 and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949561 Share on other sites More sharing options...
MagicHat Posted May 20, 2023 Share Posted May 20, 2023 5 hours ago, Madao said: Hmm, you are right. The rule is too overcomplicated for me. But to be honest - it does not change anything in the end, as if whole army is battleshocked, then no one can be an Observer - > no one will be Guided Would pathfinders be able to scout out of their deployment zone and dodge the bombardment altogether? Madao 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949621 Share on other sites More sharing options...
Madao Posted May 20, 2023 Share Posted May 20, 2023 (edited) Yes, they can. Ghostkeel and Stealthsuits can as well if they keep forward deployment (infiltrators in 10?). And everything, that can start in Manta and deepstrike later on in the game. With tailored list, I guess that you can secure the whole army from it. It seems that Rad bombardment is awful here as well... My poor robo-cowboys from space... EDIT: Hmm... It depends whose abilities are resolved first - both 'scouts' and rad-bombardment are at the beginning of the first battle round Edited May 20, 2023 by Madao Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949622 Share on other sites More sharing options...
tzeentch9 Posted May 20, 2023 Share Posted May 20, 2023 Doesn’t matter if they do decide to be battleshocked, on the first turn that tau get to shoot, they will have a battleshock step and be back to normal by the shooting phase anyway Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949631 Share on other sites More sharing options...
Oxydo Posted May 20, 2023 Share Posted May 20, 2023 10 minutes ago, tzeentch9 said: Doesn’t matter if they do decide to be battleshocked, on the first turn that tau get to shoot, they will have a battleshock step and be back to normal by the shooting phase anyway No, because the Battleshock from Rad-Bombardment lasts until the end of the first round. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949633 Share on other sites More sharing options...
Sorceress Posted May 20, 2023 Share Posted May 20, 2023 12 hours ago, The Unseen said: Yes, the steps for picking an observer requires it to not be either an observer or guided unit. So no daisy chaining the step for picking a observer only requires it not be a observer, it says nothing about guided units. I mean I agree they seemed to intend it to not be done this way, I just see a day one errata in the future for it. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949635 Share on other sites More sharing options...
Oxydo Posted May 20, 2023 Share Posted May 20, 2023 22 minutes ago, Sorceress said: the step for picking a observer only requires it not be a observer, it says nothing about guided units. I mean I agree they seemed to intend it to not be done this way, I just see a day one errata in the future for it. You can only pick units that are eligable to shoot as Observer units. If they are a Guided unit they have already shot, hence aren't eligable to shoot anymore. Khornestar and Arkhanist 2 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949643 Share on other sites More sharing options...
Arkhanist Posted May 20, 2023 Share Posted May 20, 2023 A unit that has already acted as an observer cannot itself be guided. 3 Tau units, A, B, C, Target T. A is picked to shoot. It is not an observer and is eligible to shoot, so it picks B to be it's Observer (both can see T, making it Spotted). A is now Guided, shoots with +1BS at T; if B has markerlights, A also ignores T's cover. (Shooting at anything else than T, A is -1BS and doesn't benefit from B's markerlights). So far so good. If B is picked to shoot, it is already an Observer so cannot use from "For the Greater Good" per the rule. Therefore it cannot make e.g. C its observer unit to make B Guided. But B can shoot normally. If C is picked to shoot it can take advantage of FTGG, but cannot pick B as its observer since B already has observer status and is thus excluded. It cannot pick A as A is no longer eligible to shoot having already done so this phase, so is also excluded from being an Observer. So C can only shoot normally also. If there was a unit D, C could do another Guided/Observer pairing and gain +1BS, assuming D is not battleshocked, has already shot, or is an observer already. Mr. Oddity, ZeroWolf, Dumah and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949646 Share on other sites More sharing options...
tzeentch9 Posted May 20, 2023 Share Posted May 20, 2023 1 hour ago, Oxydo said: No, because the Battleshock from Rad-Bombardment lasts until the end of the first round. Fair enough :) Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949655 Share on other sites More sharing options...
Sorceress Posted May 20, 2023 Share Posted May 20, 2023 ok sorry my brain was reversing the observer/ guided roles,I thought it was the the observer who was active and gave a bonus to the guided unit, but instead it's the guided unit that forces another unit to observer for it. which seems all sorts backwards when you think of how actual spotters tend to work. but ya no daisy chain. still one of the most wordy rules we have seen so far. mel_danes 1 Back to top Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949664 Share on other sites More sharing options...
spessmarine Posted May 20, 2023 Share Posted May 20, 2023 11 hours ago, AenarIT said: That depends on how many [HEAVY] weapons we have access to, most of the regular battlesuit guns have been assault weapons for many editions now. Without the +1 to hit if stationary from heavy, the +1BS from the army rule seems the only buff available. I was thinking that Markerlight 2.0 being worded specially as a modification to BS indicated the army would have sufficient access to +1 to hit. Otherwise, why bother modifying characteristic? Modifying enables stacking with +1. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949675 Share on other sites More sharing options...
Mithrilforge Posted May 20, 2023 Share Posted May 20, 2023 I can dig out my small pathfinder army for 10th Ed , I’m happy to see T’AU come out sort of ok , apologies to Ad Mech ..but not DG ..boo hiss (bad guys) Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949756 Share on other sites More sharing options...
marspeople Posted May 21, 2023 Share Posted May 21, 2023 Pathfinders seem like they are going to be worth their weight in gold in 10th. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949773 Share on other sites More sharing options...
mel_danes Posted May 21, 2023 Share Posted May 21, 2023 1 hour ago, marspeople said: Pathfinders seem like they are going to be worth their weight in gold in 10th. And thus targeted with extreme prejudice, and they're soft targets. I'm still not sold on this implementation being simplified. Compare to the mess that was Crossfire for GSC, which we've yet to see what they do with them. Link to comment https://bolterandchainsword.com/topic/378693-faction-focus-tau-empire/page/3/#findComment-5949782 Share on other sites More sharing options...
