LutherMax Posted January 6, 2016 Author Share Posted January 6, 2016 Finally got some pics of the finished Stormraven. The lighting is a bit harsh as the model wouldn't fit in my lightbox on its stand. I tried to go fairly realistic with the weathering and used bright metallic chips to act as edge highlights rather than highlighting the red itself. Hope you all like! http://www.themightybrush.com/wp-content/uploads/2016/01/Blood-Angels-Stormraven-01.jpg http://www.themightybrush.com/wp-content/uploads/2016/01/Blood-Angels-Stormraven-02.jpg http://www.themightybrush.com/wp-content/uploads/2016/01/Blood-Angels-Stormraven-03.jpg http://www.themightybrush.com/wp-content/uploads/2016/01/Blood-Angels-Stormraven-04.jpg Blindhamster, DimDim, rossjk and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4270146 Share on other sites More sharing options...
Firepower Posted January 6, 2016 Share Posted January 6, 2016 Someone spilled toxic goop all over that poor pastry :( Excellent work, as per the norm. Is the green cockpit glass just a single coat of the Tamiya on the interior? How easy/hard is it to mess that up? And did you still have to paint the guys inside for the effect to work? Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4270180 Share on other sites More sharing options...
Dosjetka Posted January 6, 2016 Share Posted January 6, 2016 Not at all keen on the base, but that's quite a bird you have there. What's next? Firepower 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4270313 Share on other sites More sharing options...
RedemptionNL Posted January 6, 2016 Share Posted January 6, 2016 (edited) That Stormraven looks absolutely mint! The only thing I'd add is to copy the heat stain you did on the assault cannon barrels on the multi-melta and side thrusters as well, as they look a little clean compared to the rest of the craft. Although I must echo the others in that I'm not a big fan of the base. If I were to improve upon the it, I wouldn't have made the edges of the cork (both inner and outer) so uniform and smooth - that just makes it a look like a giant letter O. I'd add more height variation as well. For added effect, you could also stick some bits in the green gloop to add context. Is it a Tyranid digestion pool? Toxic waste spill? Things like half-dissolved corpses, floating oil barrels or Tyranid bits add a narrative and make it look less clean overall. Out of curiosity, how do you do the edge weathering? Just sponge on layers of paint, drybrushing or do you go for weathering powders or something? I use a similar effect by sponging on Rhinox Hide followed by Leadbelcher, but I find the effect isn't always as easy to control as I want. Especially on reflex angles (like the sides of the assault cannons), where you logically want less but because the angle is so flat, it's easy to get more paint on it because it's harder to hit the exact edge. Any hints and tips are always appreciated. Edited January 6, 2016 by RedemptionNL Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4270343 Share on other sites More sharing options...
LutherMax Posted January 7, 2016 Author Share Posted January 7, 2016 Thanks for the comments and Likes! A lot of people aren't keen on the base and I must admit on reflection I agree... I think the idea was good but the execution could have been much better. Luckily it's not glued on so I think this bird will be getting a new base at some point! @ Firepower, for the cockpit I sprayed the inside of the cockpit black, masked it off and gave the controls and pilot a blast from in front / below with white. Then I gave the inside of the canopy a heavy coat of Tamiya Clear Green. It created a kind of gradient where it's almost opaque around the edges. I quite like the effect but if I were doing it again I might try airbrushing it for more control. So the pilot is painted, but just in greyscale. @ Dosjetka – as for what comes next I'm spoiled for choice! I have loads of stuff basecoated waiting to be finished... I think it might be my Deredeo or Sicaran. @ RedemptionNL, the paint chips are just sponged on – black followed by Vallejo Model Air 'Steel'. I always make sure there is hardly any paint on the sponge so I can build it up gradually for more control (just like with drybrushing). I also try to make sure the sponge is folded and use the rounded side – this allows you control by varying the pressure to hit smaller or larger areas. I find this works fine even for reflex angles. Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4270646 Share on other sites More sharing options...
DeathbyWes Posted January 17, 2016 Share Posted January 17, 2016 What an ace Stormraven, Luther! The chipping highlights look really fantastic. Very inspiring stuff as always. -W LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4277320 Share on other sites More sharing options...
LutherMax Posted January 17, 2016 Author Share Posted January 17, 2016 Thanks Wes! I think I will revise the base as I agree with the feedback I've had, then try to take some pics under less harsh lighting... Watch this space! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4277483 Share on other sites More sharing options...
helterskelter Posted January 17, 2016 Share Posted January 17, 2016 Such exquisite reds and yellows! And some awesome conversions. Then the storm ravens canopy! Awesome awesome awesome LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4277545 Share on other sites More sharing options...
Xenith Posted March 19, 2016 Share Posted March 19, 2016 Continually awesome work, Luther. I just used your drop pod from the first page as a reference for where to put the metallics on mine! Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4340602 Share on other sites More sharing options...
DistroyA Posted March 19, 2016 Share Posted March 19, 2016 (edited) Loving the Stormraven. I'm glad one of my favourite threads has been updated. Looking forward to the next update, and maybe will post a thread for my own Blood Angels. :) Edited March 19, 2016 by DistroyA Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4340765 Share on other sites More sharing options...
LutherMax Posted April 2, 2016 Author Share Posted April 2, 2016 Thanks guys! Sorry for the lack of updates. I've been really busy with work and also a planning a month-long trip away which I'm on now! But I when I get back I will be chomping at the bit to get back into the hobby :) Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4352672 Share on other sites More sharing options...
Midnightmare Posted April 2, 2016 Share Posted April 2, 2016 When you do I am chomping at the bit to see this Deredeo!! Your Stormraven is gorgeous mate, fair do's :tu: Enjoy your trip B) Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4352831 Share on other sites More sharing options...
LutherMax Posted May 15, 2016 Author Share Posted May 15, 2016 Thanks MR, however the Deredeo will have to wait as it's time for the ETL and he is too far along to pledge... Instead, I'll be doing Dante: http://www.themightybrush.com/wp-content/uploads/2016/05/01-Dante-01.jpg In other news, I went to Warhammer Fest yesterday and took loads of pics – check 'em out here: http://www.themightybrush.com/warhammer-fest-2016/ Cheers! Ovidius Incertus, DaBoiKyknos, marine7312000 and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4395295 Share on other sites More sharing options...
CaptainHelion Posted May 16, 2016 Share Posted May 16, 2016 Nice bits selection for Dante there! Looking good. Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4395720 Share on other sites More sharing options...
LutherMax Posted May 16, 2016 Author Share Posted May 16, 2016 Cheers CaptainHelion! Just a kit bash but should do the job as a proxy for the aging 'official' model... Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4396107 Share on other sites More sharing options...
LutherMax Posted June 18, 2016 Author Share Posted June 18, 2016 Work in progress... http://www.themightybrush.com/wp-content/uploads/2016/06/Dante-WIP-02.jpg Pearson73, sockwithaticket, Aqui and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423211 Share on other sites More sharing options...
marine7312000 Posted June 18, 2016 Share Posted June 18, 2016 Work in progress... http://www.themightybrush.com/wp-content/uploads/2016/06/Dante-WIP-02.jpg You sure he's not done?!? Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423409 Share on other sites More sharing options...
LutherMax Posted June 18, 2016 Author Share Posted June 18, 2016 Almost! Needs some airbrush effects on his axe blade and jump pack thrusters, scribbles on his oath parchments, heat stain on his Infernus and the gems need finishing. Oh and the base ;) Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423411 Share on other sites More sharing options...
LutherMax Posted June 19, 2016 Author Share Posted June 19, 2016 Dante done! http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-01.jpg http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-02.jpg http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-03.jpg http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-04.jpg http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-05.jpg http://www.themightybrush.com/wp-content/uploads/2016/06/Blood-Angels-Commander-Dante-06.jpg CaptainHelion, Aubéron, BrokenRecord and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423870 Share on other sites More sharing options...
Quixus Posted June 19, 2016 Share Posted June 19, 2016 Impressive. That kitbash looks more like Dante than the proper model. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423874 Share on other sites More sharing options...
Pearson73 Posted June 19, 2016 Share Posted June 19, 2016 Ace work on the axe head and gold. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4423875 Share on other sites More sharing options...
LutherMax Posted June 19, 2016 Author Share Posted June 19, 2016 Thanks guys, glad you like him :) Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4424009 Share on other sites More sharing options...
batu Posted June 20, 2016 Share Posted June 20, 2016 He turned out wonderful mate. Especially the axe and the golden power armour. LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4424087 Share on other sites More sharing options...
Midnightmare Posted June 20, 2016 Share Posted June 20, 2016 Glorious gold :tu: and is that freehand writing on the back of his jump pack???!! LutherMax 1 Back to top Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4424498 Share on other sites More sharing options...
LutherMax Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks both! @ Midnight Runner – I wish! It's a transfer from the Forge World Blood Angels sheet :) Link to comment https://bolterandchainsword.com/topic/282574-luthers-wosp-works-of-slow-progress/page/12/#findComment-4424598 Share on other sites More sharing options...
