Rider-75 Posted April 6, 2013 Author Share Posted April 6, 2013 Indeed it is - though in future remind me to look at the base model BEFORE I decide to do a conversion! There's a heck of a lot of work done, and a heck of a lot of reworking still to do. The left greave in particular is a challenge - the leering face has been cut away leaving green stuff work to rebuild the shape of the plate and the trim. The head is moulded as part of the body, but it came away easily with lots of small shavings and filing. The fleshy tubes that run from under the back pack to the chest had to be cut away and some re shaping of the torso done to fix that. Most of the damage from around the waist that that left can be covered by adding packs, grenades etc in strategic points. The mk5 chest plate had the belt and abdomen cable removed, and the champions waist was hacked up to allow it to fit. The champion is a bit wider (not to mention A LOT taller) than a standard marine so the shoulders/arm joint surfaces were then filed to meet properly. Arms were fairly simple weapon and hand swaps and after taking the tentacle off the left arm a mk3 pad fitted simply. Lots of other little bits were cleaned off and will require little bits of tidying and hiding as well. Turned out to be more work that expected but it wouldn't be a challenge otherwise! Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3344125 Share on other sites More sharing options...
Rider-75 Posted April 16, 2013 Author Share Posted April 16, 2013 Great Emperor! Over a week since an update? Again? Simply not good enough, I must go chastise myself later..... But first: an update on the chaos champion -> ultramarine conversion. The build is finished which required rather a lot more work than anticipated, but heh ho. Pics first: First up a closer look at the left greave where the demon face was removed. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/5EC758E1-40EC-4DD3-AEAB-B86DCFFE0912-3642-0000070BB1C5C01B_zpsf196fb4a.jpg Repair work to the abdomen using greenstuff to build up a belt and buckle and guitar string cables. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/CC35EEAB-3C71-45D2-A6DE-D95753DDC280-3642-0000070BB98F0EE3_zps213d9022.jpg The skull on the chain replaced by a brass Ultima. Another brass piece added over the belt buckle. Also he was far too big to look good on a normal 25mm base so I up sized to a 40mm. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/8DA15B2A-BBF6-44CD-9014-124FBD9880C3-3642-0000070BC04C496C_zpsc47ae756.jpg After removing the fleshy tubes the rear torso needed re sculpting to smooth it out again. You can also see the use of bits and greenstuff to help meld the model together. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/BDE4AA26-E2A5-4B99-9858-FEBA54CF7358-3642-0000070BC2523A6B_zpsfa14e4d5.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/27E67963-892C-41A0-A83C-D0A63A388D5B-3642-0000070BC4CFCB05_zpsf97675af.jpg Finished assembly: http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/F6841306-13DB-496C-92BD-4E2AC9744F1F-3642-0000070BC70606FE_zps093115bc.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/66B734C2-96C2-4A48-B9B0-A91A40CB2F57-3642-0000070BC92A38FC_zps078ea5b4.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/EABDA4B4-DBC7-4D8D-ABF1-A78DEDDA1093-3642-0000070BCB8766FC_zps88e424d9.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/88F7C1C8-1C50-4025-8198-0F4BF2A6D4B4-3642-0000070BCDC6C079_zps8e30cd78.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/187E4974-1826-4FB1-B3D5-47C950F018CA-3642-0000070BD01A4823_zps08cc1d13.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/A86CD1AE-77D6-4E1F-ABCD-9CDF4078FB80-3642-0000070BD22C6A65_zps27bde397.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/AC908200-C57A-413B-8F2B-1238862621B9-3642-0000070BD45A585E_zpsc07e5bf7.jpg Next task is to actually get some paint on it :) Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3350778 Share on other sites More sharing options...
Dosjetka Posted April 16, 2013 Share Posted April 16, 2013 I look forward to seeing him painted :) Lovely conversion work, by the by! Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3350814 Share on other sites More sharing options...
Rider-75 Posted April 21, 2013 Author Share Posted April 21, 2013 First stages of blue done on this guy. Also shows the difference in size between an standard marine and a chips chosen champion model...... http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/9E09FD36-74AC-4870-93E4-2FCA70CACF66-7911-00000C3A6EC07336_zps747ec92c.jpg Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3354249 Share on other sites More sharing options...
Hyaenidae Posted April 21, 2013 Share Posted April 21, 2013 Clever! I'm going to have to take a second look at those Chaos models, I think. Awesome conversion, man. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3354330 Share on other sites More sharing options...
Febelcrofas Posted April 22, 2013 Share Posted April 22, 2013 Man I live your ultramarines! I really like the darker blue, I did a similar shade on my assault terminators last year. Keep up the outstanding work my friend. For calth! Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3355082 Share on other sites More sharing options...
Rider-75 Posted April 23, 2013 Author Share Posted April 23, 2013 Thanks guys. I've actually just finished this monster but I'm going to try playing around with lights, backgrounds and photoshop to try and get something a little better than my current iPhone snaps ;) Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3355368 Share on other sites More sharing options...
Rider-75 Posted April 27, 2013 Author Share Posted April 27, 2013 Finished. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Horus%20Heresy%20Ultramarines/null_zpse416cb10.jpg Thanks go to The Damned Artificer for the photoshop work :) Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3358417 Share on other sites More sharing options...
Cyrox Posted April 27, 2013 Share Posted April 27, 2013 Awesome! Need to see some more pics of that mini, looks superb. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3358437 Share on other sites More sharing options...
Rider-75 Posted April 27, 2013 Author Share Posted April 27, 2013 Ill put up the alternate angle shots in a bit. They've not received te photoshop treatment though ;) Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3358444 Share on other sites More sharing options...
Rider-75 Posted April 27, 2013 Author Share Posted April 27, 2013 Here are the unadulterated and alternate views: http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps1c8d1c8b.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zpsf2137d0f.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zpsf93b1a75.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps5422085a.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps71a0e8b9.jpg Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3358516 Share on other sites More sharing options...
Hyaenidae Posted May 7, 2013 Share Posted May 7, 2013 Here are the unadulterated and alternate views: http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps1c8d1c8b.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zpsf2137d0f.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zpsf93b1a75.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps5422085a.jpg http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps71a0e8b9.jpg Damn, that is sooo badass. Sorry, brother, but I am stealing this idea. It's far too cool to not try for myself. All credit for the idea will go to you, of course. More mini's. Now. :P Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3365752 Share on other sites More sharing options...
batu Posted May 7, 2013 Share Posted May 7, 2013 He turned out perfect. Great work mate. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3366499 Share on other sites More sharing options...
Rider-75 Posted May 7, 2013 Author Share Posted May 7, 2013 Thanks guys. 1kH - be warned - it was a total pain in the ass of a conversion job. But worth it! There is sn update too. Not much of an update, but managed to get some paint onto the Cataphractii sgt. He's pretty much been a test be for a colour scheme - though I'm still not sure if helmet and pauldron colours for terminators in the XIII during the heresy. I'm inclined to stick with the white for vets. Helmet wise, having cut down the rebreather BA head to fit, I kinda avoided the red for sgt vs red for censure debate..... I'm guessing by the time the UMs have begun to fight back on Calth, after the grid has been sorted and comms restored, the red would have spread.... Or would it? Guilliman states that its ideal for while there's no comms, so how quickly would the practise of switching to red for sgt have spread do you think? Anyway enough wittering, here's the pic... http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Horus%20Heresy%20Ultramarines/null_zpsafa968bb.jpg Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3366518 Share on other sites More sharing options...
Cyrox Posted May 8, 2013 Share Posted May 8, 2013 Gotta love those FW Cataphractii models - nice work Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3366761 Share on other sites More sharing options...
Rider-75 Posted May 9, 2013 Author Share Posted May 9, 2013 Do we remember this guy? http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Horus%20Heresy%20Ultramarines/F380E349-C161-4B7A-AC75-3B13DA107A68-3926-000005FEDDD50589_zps14c32419.jpg Well here I've hit a brick wall..... So to break on through, what I'm looking for is someone to do a little bit of sculpting on commission. It should be a relatively simple and not overly time consuming job. I need someone who can do me a merger on the lion cloak - blending the lion head into a big lion skin cloak with the forelegs draped one in front and one behind the left chest/side of the model. Anyone able to help, or know someone who could? Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3367911 Share on other sites More sharing options...
GooseDaMoose Posted May 10, 2013 Share Posted May 10, 2013 Wouldn't the various shipping costs etc. be a lot more hassle than just finding someone near(ish) by where you are to do it?I mean, I'd gladly do it, but I feel you don't need to spend money on it. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3367947 Share on other sites More sharing options...
Rider-75 Posted May 10, 2013 Author Share Posted May 10, 2013 I'm in the wilds of Aberdeenshire, Scotland... Officially the 2nd back end of nowhere :( Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3368435 Share on other sites More sharing options...
GooseDaMoose Posted May 10, 2013 Share Posted May 10, 2013 PM sent Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3368539 Share on other sites More sharing options...
Veteran Sergeant Posted May 11, 2013 Share Posted May 11, 2013 http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Forge%20of%20Heroes/null_zps1c8d1c8b.jpg That's a great looking miniature right there. Love your blues, and he looks impressively authentic and the posing just screams action and motion. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3369135 Share on other sites More sharing options...
Rider-75 Posted May 19, 2013 Author Share Posted May 19, 2013 Bit of an edit on the Chapter Master / Praetor model. Began to see the big lion head as being a bit OTT, so I've subbed it for the smaller shoulder pad version. The plan is still to add a cloak. http://i92.photobucket.com/albums/l8/rider_in_black/dark%20materials%20miniatures/Horus%20Heresy%20Ultramarines/null_zps2331dec1.jpg Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3375169 Share on other sites More sharing options...
Rider-75 Posted May 21, 2013 Author Share Posted May 21, 2013 I'll put this in here rather than start a new thread elsewhere... Avoiding work yesterday, I knocked this up without knowing anything about what I was doing, using a cheapy video editor on the work PC. Used some of the pics of my stuff from here, plus some other images I had on file. Don't judge too harshly.... As I say, never used video editing for anything along Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3376982 Share on other sites More sharing options...
batu Posted May 22, 2013 Share Posted May 22, 2013 The clip is quite impressiv. Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3377209 Share on other sites More sharing options...
Dosjetka Posted May 22, 2013 Share Posted May 22, 2013 The video is quite well done for a first-timer :tu: Of course, some things could be improved, such as quality of both picture and soundtrack, the cropping of certain pictures, etc... but all in all, I highly doubt that I could do a better job myself, so congrats for trying and managing to produce a nice piece of work :) Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3377366 Share on other sites More sharing options...
Rider-75 Posted May 22, 2013 Author Share Posted May 22, 2013 Thanks guys. I feel it looks more like the work of a 7 year old than a 37 year old.... :P lol Link to comment https://bolterandchainsword.com/topic/192036-riders-wip-thread-deredeo/page/6/#findComment-3377866 Share on other sites More sharing options...
