Lorenzen's Abyss: Heresy, Necro & a load of other stuff
Lorenzen
Your minis are getting better and better, and considering the amount of talent you already had, it's a thing :). I've already said it, but your yellow is awesome.
I would really appreciate an updated tutorial on your skin tones. They're perfect and it's always been a week point of mine.
The more I see Sigismund, the more I think he would do a great White Scars praetor (pose, etc...) !
1) Tutorial. Yes. Awesome. :tu:
2) Those studs look good, with the exception of the gold blending in with the yellow somewhat. Short of a silver highlight akin to what Kizzdoug does, I'm not sure what else would be worth suggesting.
Ok, i'll do 2 heads for a tutorial.. 1 with my brush method and one with the airbrush.
The gold photographs badly.. but i think defining the edge a bit better could help.. its highlighted with s75 peridot alchemy so the highlight has a light green hue Rather than just pure silver.
Cheers for compliments One-eye im trying to improve my painting as id like to get somewhere in the demons one day. (hence all the wierd single models and colour)
OK tutorial 1 Airbrush Faces.
Equipment & paints:
Badger Sotar 20-20 (any reasonable airbrush will do)
Winsor & Newton Series 7 size 0
Vallejo Airbrush thinner
Scale 75 Indian shadow
Scale 75 Basic skin
Scale 75 Light skin
Games Workshop Reikland fleshshade
Games Workshop Druchii violet
Halfords Grey primer
Vallejo model colour White
Vallejo model air Black
Vallejo model air Cam. black brown
11239698_10152907673466406_8457536524487
I primed the model with halfords grey as i prefer working off a light colour for skin out of habit.
11391732_10152907673656406_2338911302860
A flat coat of Indian shadow was airbrushed over the entire face.
11246472_10152907673726406_171417745673311377186_10152907673901406_5020123507680
from about a 30 degree angle i airbrushed basic skin onto the face, the higher the angle you spray from the more indian shadow will show through in the lower areas if you want more contrast in the face. I also sprayed the model from directly above just to make sure the top of the head, cheek bones etc had a little more coverage.
11391647_10152907676481406_177814638736811200817_10152907678201406_5949417628979
I then sprayed the model from roughly 85 degrees with light skin to add the final gradient to the skin.
10489662_10152907678411406_570859649335111391212_10152907681546406_7194443406071
The head was the washed with reikland flesh shade with a little water.. this wah washed over the entire head and manipulated with a brush with a little water on it to make sure it sat evenly over most of the skin and settled into the recesses nicely
11229281_10152907686636406_4827128351303
once the flesh shade had dried (with help from a hairdryer) i added a basic skin highlight to the raised areas, focussing on the brow, nose, cheekbones and the top of the chin and the raised edge on the left of his jaw.
11351388_10152907697866406_623976856001211391617_10152907693161406_3535668019638
I then added a light skin highlight to the raised areas trying to focus on defining the earlier highlights and adding in the frown lines on the forehead to give a bit of interest.
11351458_10152907698616406_457266108723511052392_10152907698671406_3003953458743
The head was then glazed with diluted druchii violet, I find that the hint of purple helps to make the face look a little more realistic rather than the slightly orangey tone the flesh shade has. This stage can be done before the light skin highlights if you want a little more contrast to them rather than toning them into the rest of the skin (ill show the results of that in my other skin method)
11054480_10152907698761406_1284106689248
The area around the eyes and the mouth were then washed with a thinned down cam. black brown, this helps define the area, increases the shadow around the eye, looks more natural than black and will help later with any mistakes doing the eyes. you can use a blue wash around the eyes if you want to try something a little different (A good example of this is the Fulgrim model on FW's website)
11391488_10152907698846406_336363045615911391375_10152907698981406_409517458091611147870_10152907698881406_2637170241319
the eyes were then very carefully painted in, the paint needs to flow off the brush with very little pressure without flooding the area and when doing them i draw the brush from the inside to the outer edge.. if you get any white around the socket that you dont want, touch it up with cam. black brown again, after the eyes were done i painted the teeth in white too.
The pupils were then painted in with black. I tend to do the left hand pupil first with the head facing me as normal and drawing down the eye, then turning it all upside down and doing the right hand one upside down.. it helps me but is probably all psychological..
10644804_10152907699266406_6292965217828
The hair was just given a quick coat of cam. black brown and the soft armour was painted black for the final shot.. Hopefully that is comprehensive enough.. if anyone has any questions feel free to ask. :smile.:
Right.. I'm now very close to finishing Sigismund, mainly working on fixing a few bits (random bits of yellow on his shoulders fist as an example) and adding some light weathering to his armour.. the scroll on his backpack will read ZEAL when i get round to it.. don't think im going to write anything on the leg ones they'll just get squiggly lines.
10304438_10152917379796406_4632162701916
11377214_10152917379846406_6333278206391
11150895_10152917379876406_7340993377156
10387536_10152917379916406_7017238851825
1560637_10152917379986406_70022474005994
11351436_10152917380031406_5035010200337
1979511_10152917380101406_69563535533774
11393126_10152917380156406_6690217466227
Thank you for the informative face tutorial Lorenzen.  I actually just ordered the scale 75 skin tone set the other day, so knowing a good face painting process ahead of time saves a lot of trial and effort.   You're right, the purple wash makes a considerable difference.  Can I ask what was the dilution ratio in parts ink/water or ink/thinner?
Ok, I'm classing Sigismund as being finished now (until i notice some glaring mistake..) I've switched to a black backdrop for the photos as i think it shows the model off a bit better.. i've done one with white for comparisons sake though.. I wish my writing was neater for freehand stuff but then i have handwriting like a serial killer at the best of times.. front reads fury, back reads zeal.. Anyway I hope you all like him, he's been great fun to paint.
11150905_10152920702666406_5998984930374
11393104_10152920702766406_7251528591948
11407267_10152920703031406_4500680684019
11407157_10152920703381406_2929197191555
10153129_10152920703651406_1189470944235
11418917_10152920703696406_3171553223780
11350487_10152920704016406_1382613056621
11391191_10152920704056406_5270492485404
11148716_10152920704091406_7758116226393
A little of both really.. I have a huge backlog of death guard (and makabius) to get through. . Need to finish vulkan and sevatar and am planning a fist army.. :S Atm its just a matter of getting a plan to tackle it all sorted
Cheers Olis :) He'll be coming with me to the Forge World Open Day if anyone wants to see him in person.
BrotherJim.. Thats a huge amount of praise considering the sheer amount of awesome on the B&C and out in the hobby as a whole so to quote ADB when I got him to sign Soul Hunter "thanks for your kind lies" :)
Haha nice sounds like something he would say :)
Seriously though, great job on Sigismund and I've been following your work since your Fire Angels (it's not stalking) and I'm still digging great ideas out of that thread. It's great to see you flex your muscles as the saying goes...
keep at em!
