eurieus Posted December 9, 2014 Share Posted December 9, 2014 Amazing work brother !!! Can i ask you how you create such awesome weathering ? My DA successor chapter is mostly black and i have yet to find a nice weathering process for them ... Could you enlighten me ( us ! ) , please !!! Again , brilliant thread full of brilliant minis :D Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3883712 Share on other sites More sharing options...
Flint13 Posted December 9, 2014 Share Posted December 9, 2014 Ooooh, good point. I second that! I just tried weathering on a Ravenguard, and it didn't go so hot on anything that wasn't white, which admittedly was a majority. :D Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3883734 Share on other sites More sharing options...
Dark Rage Posted December 10, 2014 Author Share Posted December 10, 2014 (edited) It really depends what type of base your going for, if you are going for a dried up waste land/desert look I will try to post the steps I use on the next clean model I can finish, probably later today or tomorrow. Paints I use for damage, Leadbelcher, Runefang Steel. For weathering: Agrellan earth, FW Dark earth powder. Bases: Agrellan Earth, Steel Legion Drab, Ushabti Bone. Edited December 10, 2014 by Dark Rage Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3884966 Share on other sites More sharing options...
Dark Rage Posted December 11, 2014 Author Share Posted December 11, 2014 (edited) So tutorial First a scout, ignore the boots I accidently went over them with watered down agrellan earth before I started this. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/1.jpg Add watered down agrellan earth to armour joints and crevices, start at the boots or feet and work your way up as high as you think is appropriate, I tend to still add it to higher areas like the trims on shoulder pads and the vents of space marine backpacks but mainly in patches not completely focused on the entire area. Also sponged on scorched brown onto the bolter, this may only work on red bolters, so if you are using black bolters perhaps better to use the method I use on the black armour. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/2.jpg http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Weapon1.jpg Next I sponged on leadbelcher to the black armour, if I do damage on an chapter mark, I normally use scorched brown as the base instead. If its a red pinstripe I sponge over it with the base colour of the model, in my case that's black. Also you don't have to sponge it, it can be painted on as well if the area is difficult to reach. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/3.jpg Once that was done I went over the damaged areas, including the weapon with runefang steel to lighten some of the damage, some people do this inverted which also looks just as good, so some start with rune fang then do the inner damage with the darker metallic. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/4.jpg http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Weapon2.jpg Sponged on some agrellan earth to the boots and lower trousers, this step isn't always necessary as I dry brush agrellan earth onto the lower area on the model as well. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/5.jpg And after the dry brush to the lower legs and boots. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/6.jpg Last is a watered down wash of dark earth weathering powder which I put pretty much over all the model, when I use pigments on vehicles I normally put it on dry and then use water to streak it but with a small miniature I use it watered down from the start. In the picture you cant really see the effects to much but I find it does make a difference to the finished look, especially on robes and tabards. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/7.jpg That's pretty much what I do to all my units now for weathering, experimenting with gore at the moment but not sure how to go about dried up blood. Will post up a base tutorial if you found this helpful. Edited December 11, 2014 by Dark Rage Chaplain Lucifer, Cactus, O.D. and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3886347 Share on other sites More sharing options...
shabbadoo Posted December 11, 2014 Share Posted December 11, 2014 A good way to do dried blood is to mix red ink with a touch of darker bown ink, as dried blood is a darker reddish-brown color. When you are satisfied with the color of your mix. dab it on a bit at a time where you want it. Don't worry about it being too transparent to begin with, as you should be putting more on as it dries. Doing that will build up the color and make it more opaque. Another thing you will soon figure out is to mess with the drying ink just before it is completely dry, such that you can dab at it to roughen up the texture/vary the color concentration in different areas. Hope that makes sense. Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3886354 Share on other sites More sharing options...
Isiah Posted December 11, 2014 Share Posted December 11, 2014 Nice tutorial :yes: Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3886482 Share on other sites More sharing options...
Flint13 Posted December 11, 2014 Share Posted December 11, 2014 Awesome tutorial! Thanks for turning that out for us. Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3886664 Share on other sites More sharing options...
eurieus Posted December 11, 2014 Share Posted December 11, 2014 Awesome and thanks a lot for the tutorial !!! Will try this ASAP :D Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3886802 Share on other sites More sharing options...
Dark Rage Posted December 14, 2014 Author Share Posted December 14, 2014 (edited) Bases First base in black, here's a base primed with a few glue marks here and there. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b1.jpg After a coat of agrellan earth, the cracks on base tend to always vary, I try to put on a fairly thick coat. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b2.jpg Then I add sand and basing stuff, this could probably have been done before but I tend to always do it after so I can put the sand in areas that didn't crack. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b3.jpg Then go over the sand and rocks with steel legion drab, tends to blend in ok with agrellan earth so you don't need to go over the whole base. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b4.jpg Add a drybrush of ushabti bone to the base, may take a few dry brush coats. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b5.jpg And then I go over the base with a very watered down coat of agrellan earth to blend the colours a bit better. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/b6.jpg The edges I paint with steel legion drab and I also add mordheim turf to a few areas. Thanks for reading. Edited December 14, 2014 by Dark Rage Galthan Ironsturm, Space Truckin, Interrogator Stobz and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889408 Share on other sites More sharing options...
Greenz Posted December 14, 2014 Share Posted December 14, 2014 Awesome tutorial! Question though, how'd you get that cracked effect? Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889512 Share on other sites More sharing options...
Dark Rage Posted December 14, 2014 Author Share Posted December 14, 2014 Awesome tutorial! Question though, how'd you get that cracked effect? That's the result of the Agrellan Earth paint its a GW technical paint designed to crack as it dries Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889545 Share on other sites More sharing options...
Flint13 Posted December 14, 2014 Share Posted December 14, 2014 Thanks for the tutorial, that looks awesome! I've got a total obsession with snow bases at the moment, but I have to admit that's not going to work with HH World Eaters. I think you've just solved my issue there :D Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889600 Share on other sites More sharing options...
Dark Rage Posted December 14, 2014 Author Share Posted December 14, 2014 New base for company master. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/CompanyMaster-1.jpg And finished scout from tutorial, just got round to finishing the icon on his shoulder and adding some turf to the base. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Scout1.jpg So I haven't really updated this thread with any new miniatures in a while, seem to be going back to old or getting distracted with conversions (the amount of half painted stuff I have) so I decided I would try to paint at least two things or more each week and at least get something done, this week it was the scout I showed in the tutorials and this guy. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/VetSrg.jpg I'm still not sure about my method for the green robes, which I may go back to (not this again) but it wont be until I get quite a bit done. Thanks for looking, C&C always appreciated. deathspectersgt7, Cactus, Nomus Sardauk and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889696 Share on other sites More sharing options...
Isiah Posted December 14, 2014 Share Posted December 14, 2014 Love the guy with the mace. Wouldn't want to meet him in a dark alley :p. Looking good on their bases. All beautifully painted as usual. Cheers I Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889749 Share on other sites More sharing options...
SvenONE Posted December 14, 2014 Share Posted December 14, 2014 Love love love love the Seraphicus conversion. Also love the Balthasar conversion, though I must confess he looks like he's the all time leading Test Batsman in the Imperial Cricket League Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3889817 Share on other sites More sharing options...
Interrogator Stobz Posted December 14, 2014 Share Posted December 14, 2014 Great work as usual DR. Nice to see your basing technique, that technical paint is awesome, I need to stop living in the past and go buy some of the new stuff... :D BS Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3890057 Share on other sites More sharing options...
deathspectersgt7 Posted December 15, 2014 Share Posted December 15, 2014 Outstanding but I thought Crickett Paddles were Flat. Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3891079 Share on other sites More sharing options...
Interrogator Stobz Posted December 15, 2014 Share Posted December 15, 2014 (edited) ...and called bats Definitely a Softball/baseball/BDSM implement, "it's just not Cricket ol' Chap". Edited December 15, 2014 by Brother Stobz Space Truckin, Dark Rage and Cactus 3 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3891115 Share on other sites More sharing options...
Bryan Blaire Posted December 16, 2014 Share Posted December 16, 2014 "You gotta know what a crumpet is to understand cricket..." Lovely work, Dark Rage, looks awesome! Really like the tutorial, need to find some place to use that! Tygwyn, Brother Pheidias, Stoic Raptor and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3891172 Share on other sites More sharing options...
Gillyfish Posted December 16, 2014 Share Posted December 16, 2014 Amazing miniatures there. As to your issue with the green robe, I find using a lighter yellow-green mixed with the basecoat in varying shades works well. Then wash the whole thing with green and you should get a richer looking green. You'll want several steps of blending with darker cloth. Interrogator Stobz and Dark Rage 2 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-3891397 Share on other sites More sharing options...
Dark Rage Posted May 2, 2015 Author Share Posted May 2, 2015 Got lost in the warp for a few months, but crawled my way out somehow. Hi all, been a while, hope your all doing well. Seemed to have returned at the same time the ETL is upon us, coincidence or some trick of the warp. Anyway I should really start getting my brushes back out and start painting, so much stuff gathering dust. I was so tempted to buy a Deredeo Dreadnought off FW this weekend but then it was as if I heard the screams of every piece of unfinished plastic telling me no, I never realised how much stuff I got unfinished or not even primed till I looked, this is just the terminators, not so bad I guess. http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/20150502_131003.jpg Then I saw two 10 man assault squads, a 10 man devastator squad, a 10 man veteran squad, a 10 man tactical, a techmarine and servitors, 5 Rhino chassis, a land raider, some bikes I think around 9, a landspeeder and a few independent characters. I'm deciding on something small for the ETL since I really haven't lived up to Dark Angels standards in the last two ETL's I will try to redeem myself. Nice to be back. Captain Semper and Space Truckin 2 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-4027890 Share on other sites More sharing options...
Interrogator Stobz Posted May 2, 2015 Share Posted May 2, 2015 It's great to have you back DR! Just in time too :tu: Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-4028065 Share on other sites More sharing options...
Tygwyn Posted May 5, 2015 Share Posted May 5, 2015 Good luck this year - I've just read this post from start to finish, really hope that some of your awesome painting gets to count towards the Unforgiven total this year. Your weathering/basing tutorials have just made it harder for me though - hope I've got enough time for my planned vows now I need to add those extra processes. For the Lion! Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-4030670 Share on other sites More sharing options...
Captain Semper Posted May 7, 2015 Share Posted May 7, 2015 Dark Rage is the professor of the Consecrators. He's bound to impress! Good luck mate! :tu: Dark Rage 1 Back to top Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-4033979 Share on other sites More sharing options...
Dark Rage Posted May 9, 2015 Author Share Posted May 9, 2015 (edited) Thanks guys, made some progress on the chaplain and land speeder, going to focus on the land speeder for now since I may be entering it in a local GW competition, nothing to serious though just a little local event. WiP always so messy http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/20150509_180241.jpg http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/20150509_180215.jpg Edited May 9, 2015 by Dark Rage Link to comment https://bolterandchainsword.com/topic/274297-drs-consecrators/page/8/#findComment-4035993 Share on other sites More sharing options...
