++ Excessive Perfection - An Emperor's Children Community ++
Forté
Doom Sirens go in all my 10 man squads. It's simply too cool to have a doom siren, a sonic blaster and a chainsword on the same champion! :D (I still believe that you can swap the bolter for a blaster and STILL swap the pistol for something on the champs equipment list) Four attacks from the same model always surprise the opponent.
I just can't help building the sonic terminators as obliterators now, since I believe that the Slaanesh release is further out than the Khorne one is. :)
My deathshrouds are getting their armour repaired(holes filled and missing bolts replaced) and a bunch of cloth/pelts and gemstones. Furthermore I have three of the large EC chaos lord backpack for them, and the old dirge casters as loudspeakers on the end of bulked heavy flamers.
At least that's the plan before I encounter any problems! ;)
Doom Sirens go in all my 10 man squads. It's simply too cool to have a doom siren, a sonic blaster and a chainsword on the same champion! :biggrin.: (I still believe that you can swap the bolter for a blaster and STILL swap the pistol for something on the champs equipment list) Four attacks from the same model always surprise the opponent.
That's definitely possible. I used to give my Champions a Power Axe (because it's fun to imagine them using the Sonic Blaster Guitars for melee as well :D ) but the -1 to-hit prevents rolling 6s for the DttfE ability and halfs the chance to trigger it with an Icon so I'm thinking about either Power Sword or Chainsword now. ^^
Fact of the day: 6 minimum size noise marine squads each with a blastmaster and 4 sonic blasters clock in at 666 points, praise Slaanesh!
Now, start making those brigade detachments count. ;)
I'm looking at a bunch of noise marines and obliterators to serve as 'sonic terminators'. Do you guys have any ideas for base models to make Slaanesh obliterators from? I'm making the first three out of blinged-up deathshrouds with sonic weapons.
I plan to make my sonic terminator/obliterators from Chaos Terminators with sonic weapon bits and a fair bit of GS (and my tentacle roller...they are ‘flesh weapons’, after all...).
Where do you get the -1 to hit on power axes? Is it from a FAQ I missed?
Sorry I :cussed up the quote
I'm going with the fleshmaster path, and converting up some Stormfiend rat ogres as obliterators/mutilators.
That's definitely possible. I used to give my Champions a Power Axe (because it's fun to imagine them using the Sonic Blaster Guitars for melee as well :biggrin.: ) but the -1 to-hit prevents rolling 6s for the DttfE ability and halfs the chance to trigger it with an Icon so I'm thinking about either Power Sword or Chainsword now. ^^
Sorry I :censored: up the quote
Look at that! Only the Daemon Prince Axe gets a -1 to-hit modifier but the regular Power Axe doesn't! The more you know! :biggrin.:
Thanks for pointing that out. I guess I can keep my Power Axes after all. :wink:
I need your opinions on this. So I was thinking about making cultists out of Gors, to make some satyrs. And while shopping for Gors I stumbled upon centigors and thought to myself "these would make some nice fiends with a bit of conversion work". I was thinking about giving them whips and making them look like slave masters. What do you guys use for fiends?
I can recommend Gors for (Slaangor) cultists :tu: I think photos of mine are a page or two back.
For Fiends I used daemonettes and Goblin Spider Rider’s spiders:
I’d love to see some centigor versions :tu:
Has anyone thought about using the dark eldar wracks as a cultist base?
On the 33th page of this thread you should find my vision of Cultist : Dark elf witch with Wrack Mask.
I like them, interesting take. I might try and get hold of a box and see what I can do with them. But as Slave to Darkness suggested. The cost would rack up (no pun intended) when you look at getting 40 of them.
 "Unbearable, isn't it? The suffering of strangers, the agony of friends. There is a secret song at the center of the cosmos, and its sound is like razors through flesh. It can not be explained. There is no language for such abysms of shrieking and immemorial lunacy - such contradictions of cosmic order. There is a world out there waiting to yield to us. I am offering you a place at my right hand - flesh, power, dominion." - Daemon Prince Cynaes the Peerless
Hmmm, I am sure I have heard that quote somewhere before! ;)
Thx you sfPanzer for bringing a little NOISE in this topic.
With this new cost Noise Dread are even more amesowe now..
And look what i found from FW : (bottom left) https://lh3.googleusercontent.com/-Qwvzx_ZkkSI/WhlEJDZb2cI/AAAAAAAAMq8/IMI-rV0JLr8r3PPjpqXepF4-DH3ekglRACHMYCw/s5000/%255BUNSET%255D
