Ovidius Incertus Posted April 15, 2015 Share Posted April 15, 2015 Definitely want to hear these opinions. I'm about the replace my airbrush with either a H&S model or a Badger or some sort before ETL, so I'd like to hear what people think! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4009147 Share on other sites More sharing options...
Akylas Posted April 15, 2015 Share Posted April 15, 2015 Today I got my 5 man death company squad jut about ready for painting once the ETL starts and spent about an hour trimming mold lines off legs for a vanguard vet squad and gluing them to bases. It's not much but a little bit at a time the next few weeks will keep me painting once May starts rather than assembling. Azekellon 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4009413 Share on other sites More sharing options...
LutherMax Posted April 15, 2015 Share Posted April 15, 2015 Yeah, I've tried cleaning it a few times already, no dice so far. I have an Evolution for a few years now and I often have problems with it doing that, but usually a good clean is enough to fix it. And I just replaced the nozzle and needle a month ago. Perhaps it's an issue with H&S brushes, if your Infinity has the same problem? Maybe it's time to look into a different airbrush, what made you buy that Badger? The H&S Infinity can be temperamental but it's good for fine detail work thanks to the handy trigger lock on the back. The Badger is a great workhorse, very reliable, but with no trigger lock it can be a bit heavy handed for detail work. Still I find myself going to the Badger more often than the H&S. I've heard good things about Iwata too - if I get another one it will probably be an Iwata as I think they're the middle ground between Badger and H&S. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4009466 Share on other sites More sharing options...
Father Mapple Posted April 16, 2015 Share Posted April 16, 2015 I use a badger 360, which is like the patriot, but can do gravity or siphon feed. The cup is pretty small, but enough for detail work. It has a trigger lock (if you mean a screw bit on the back that limits how much you can pull the trigger) and while it comes with a big .7mm needle that's good for base coating or tanks, I have bought .2 and a .3 needless for smaller details and effects, and that makes it real precise. Great workhorse. Easy to clean. I just put some thinner in with water into a bottle, or just hot water, then siphon feed until it blows clean. I take it apart some times, but then see it's not necessary. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4010629 Share on other sites More sharing options...
The4thHorseman Posted April 17, 2015 Share Posted April 17, 2015 Technically today, as it was about 1 am. I started painting my 10 man Tacticle Squad, got the legs done. Just started painting again for the first time in forever. http://img.photobucket.com/albums/v74/The4thHorseman/IMAG1102_zpsbhp1olgp.jpg Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4011334 Share on other sites More sharing options...
Jolemai Posted April 17, 2015 Author Share Posted April 17, 2015 These arrived today. I'll be using the graviton gun and lightning guns as grav guns for my two bike squads (with the ETL in mind), while the Breacher Shields will be used on my melta Command Squad (the best part is, I have enough Shields to make two!). I also had this arrive, which will be going into my bitsbox. I'll likely use the sword for my counts-as Cypher (again, with the ETL in mind) but the rest can wait. I know the combi-flamer will end up on a Tactical Sergeant no doubt whilst the power fist may well be on a bike Captain/Chaplain kitbash one day. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4011385 Share on other sites More sharing options...
Azekellon Posted April 17, 2015 Share Posted April 17, 2015 Yeah, I've tried cleaning it a few times already, no dice so far. I have an Evolution for a few years now and I often have problems with it doing that, but usually a good clean is enough to fix it. And I just replaced the nozzle and needle a month ago. Perhaps it's an issue with H&S brushes, if your Infinity has the same problem? Maybe it's time to look into a different airbrush, what made you buy that Badger? Airbrushes have various seals and o-rings to prevent leaks, and it sounds like you've got a blown seal. Dependent on the price of the air brush, it may be worth it to rebuild the internals. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4011414 Share on other sites More sharing options...
LutherMax Posted April 17, 2015 Share Posted April 17, 2015 Yeah, I've tried cleaning it a few times already, no dice so far. I have an Evolution for a few years now and I often have problems with it doing that, but usually a good clean is enough to fix it. And I just replaced the nozzle and needle a month ago. Perhaps it's an issue with H&S brushes, if your Infinity has the same problem? Maybe it's time to look into a different airbrush, what made you buy that Badger? Airbrushes have various seals and o-rings to prevent leaks, and it sounds like you've got a blown seal. Dependent on the price of the air brush, it may be worth it to rebuild the internals. That's a good point - if you contact Harder & Steenbeck they will send you replacement seals for free... Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4011553 Share on other sites More sharing options...
Jolemai Posted April 18, 2015 Author Share Posted April 18, 2015 *** Incoming transmission *** Send reinforcements... Armoured Company ambushed... [static] Eldar raiders... Arrived from nowhere... So fast... Outnumbered... [static] Casualties increasing... [static][static] Sanguinius protect us... *** Transmission ends *** Bukimimaru, LutherMax and Shaezus 3 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4012797 Share on other sites More sharing options...
Dolchiate Remembrancer Posted April 18, 2015 Share Posted April 18, 2015 *** Incoming transmission *** Send reinforcements... Armoured Company ambushed... [static] Eldar raiders... Arrived from nowhere... So fast... Outnumbered... [static] Casualties increasing... [static][static] Sanguinius protect us... *** Transmission ends *** bad loss to new Eldar Jolemai? Shaezus 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4012907 Share on other sites More sharing options...
Jolemai Posted April 19, 2015 Author Share Posted April 19, 2015 *** Incoming transmission *** Send reinforcements... Armoured Company ambushed... [static] Eldar raiders... Arrived from nowhere... So fast... Outnumbered... [static] Casualties increasing... [static][static] Sanguinius protect us... *** Transmission ends *** bad loss to new Eldar Jolemai? Old, and beaten on TO cards! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4013111 Share on other sites More sharing options...
Jolemai Posted April 19, 2015 Author Share Posted April 19, 2015 *** Incoming Message *** Eldar outpost attacked as planned... Servitor hooked up to the Veritas Vitae predicted a 99% victory chance... Element of surprise is with us, Death Company - for Sanguinius!... [static] Where are they coming from?... Are we surrounded?... Throne help us... *** Transmission Lost *** CaptainHelion 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4013124 Share on other sites More sharing options...
Jolemai Posted April 19, 2015 Author Share Posted April 19, 2015 *** Message Log 003456 *** Black Leader, status!... [bL] Approaching site now. It's quiet... Exercise extreme caution; these Xenos are like ghosts... [bL] Contact sighted. Approaching with extreme prejudice... [bL] Enemy fleeing. Where is that Ancient?... Transit delayed. Leave him something to play with!... [bL] Taking heavy fire; we need backup!... [bL] Reinforcements, NOW! Before it's too la... Black Leader: status!... Black Leader, come in. Do you read me?... [static] *** Mission Log Ends *** Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4013554 Share on other sites More sharing options...
LutherMax Posted April 19, 2015 Share Posted April 19, 2015 Won a game against Nurgle Daemons today - two Daemon Princes and two Great Unlean Ones! Go Sanguinius! Grazcruzk 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4013661 Share on other sites More sharing options...
Delfeld Posted April 19, 2015 Share Posted April 19, 2015 I've finished the the Shield of Baal: Deathstorm campaign. Karlaen (thanks to me, naturally) succeded in his mission! Dolchiate Remembrancer, Bukimimaru and LutherMax 3 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4013820 Share on other sites More sharing options...
Ovidius Incertus Posted April 20, 2015 Share Posted April 20, 2015 Finished a Terminator Librarian kitbash of Kaerlan; got Astorath all cleaned and ready for paint; got a jump Librarian underway; finished my Librarian Dread. I suppose it was a good day for the Librarius.... Also got bits laid out for 7 Vanguard Vets and got two bases done on my last unbased squad (10 man tac squad). Akylas 1 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4014031 Share on other sites More sharing options...
Grazcruzk Posted April 20, 2015 Share Posted April 20, 2015 I think I found my red today! http://i6.photobucket.com/albums/y221/loki114/DSC00003_zpsrtmm6aij.jpg http://i6.photobucket.com/albums/y221/loki114/DSC00002_zpsdi7qaore.jpg j-smuv, JamesI, ROBOcaster and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015100 Share on other sites More sharing options...
Ovidius Incertus Posted April 20, 2015 Share Posted April 20, 2015 That flamer is SO FREAKIN' COOL! Is the flame from a Legion of the Damned marine? I got a box of GK yesterday and think I wanna go rip into it! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015109 Share on other sites More sharing options...
Grazcruzk Posted April 20, 2015 Share Posted April 20, 2015 Thanks! The flame is from Inquisitor Karamazov. I bought the metal kit when it was new and have been slowly breaking it down over the years. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015197 Share on other sites More sharing options...
Jolemai Posted April 21, 2015 Author Share Posted April 21, 2015 *** Incoming transmission *** Send reinforcements... Armoured Company ambushed... [static] Eldar raiders... Arrived from nowhere... So fast... Outnumbered... [static] Casualties increasing... [static][static] Sanguinius protect us... *** Transmission ends *** *** Incoming Message *** Eldar outpost attacked as planned... Servitor hooked up to the Veritas Vitae predicted a 99% victory chance... Element of surprise is with us, Death Company - for Sanguinius!... [static] Where are they coming from?... Are we surrounded?... Throne help us... *** Transmission Lost *** *** Message Log 003456 *** Black Leader, status!... [bL] Approaching site now. It's quiet... Exercise extreme caution; these Xenos are like ghosts... [bL] Contact sighted. Approaching with extreme prejudice... [bL] Enemy fleeing. Where is that Ancient?... Transit delayed. Leave him something to play with!... [bL] Taking heavy fire; we need backup!... [bL] Reinforcements, NOW! Before it's too la... Black Leader: status!... Black Leader, come in. Do you read me?... [static] *** Mission Log Ends *** You've probably guessed from these, so I'm not spoiling much to say that I lost three games against Eldar over the weekend. I don't believe in luck/karma/etc. I would suggest that each game was closer than the result appeared and I don't feel I was particularly out-played, but I have been feeling a little flat the past couple of days. What annoys me is the time it takes me to play the game (taking notes for the battle reports doesn't help, but it's neither here nor there really) and the mistakes I make. Basically, I'm not "match fit". As a general, I would hope I'm on the right side of average and thus, I am considerably irked when I read things back and see what I've done wrong and where I've gone wrong. Why couldn't I have seen that during the game? My knowledge of the game is up to scratch but, how would I go about becoming "match fit" without playing more often? Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015604 Share on other sites More sharing options...
Bukimimaru Posted April 21, 2015 Share Posted April 21, 2015 (edited) If I go for some time without playing a match, I like to go on youtube batrep binges. I've picked up loads of do's and don'ts from watching marathons of Miniwargaming, Strikingskorpion, CommisarWarrick, TeamClueless, 40KScribe, etc. Even if its just on in the background when I'm painting / washing up / on the can, i still absorb bits of tactical info here and there. Edited April 21, 2015 by Bukimimaru Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015631 Share on other sites More sharing options...
Ovidius Incertus Posted April 21, 2015 Share Posted April 21, 2015 Jump Librarian is all magnetized and ready to go, except for a bit more basing. Just need to clean up his Gallian's Staff option before wrapping him up. Also started assembling a Fire Raptor. Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015764 Share on other sites More sharing options...
The4thHorseman Posted April 21, 2015 Share Posted April 21, 2015 Making Progress on my 10m tac squad. The other 5 are almost at this point, Arms and Guns are drying and Backpacks are next. Again, apologies for my Potato Phone Pics. http://img.photobucket.com/albums/v74/The4thHorseman/IMAG1109_zpsqgmaiihx.jpg Sans Mercy, DarkMark and Grazcruzk 3 Back to top Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015869 Share on other sites More sharing options...
Dolchiate Remembrancer Posted April 21, 2015 Share Posted April 21, 2015 Really nice shade there horseman! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4015885 Share on other sites More sharing options...
Charlo Posted April 21, 2015 Share Posted April 21, 2015 You see Heresy BA so little, and these look awesome! Link to comment https://bolterandchainsword.com/topic/297201-ba-today/page/25/#findComment-4016279 Share on other sites More sharing options...
