I got this one https://www.amazon.com/tool-home-Precision-Model-Drill-Twist/dp/B010BV7190/ref=sr_1_4?ie=UTF8&qid=1515455232&sr=8-4&keywords=pin+vise
for christmas this year, has quite a few different size bits.  I don't know if there's a bit big enough for the largest magnets but should be good.
I just buy drill bits at the DIY store, and use a hand drill with a locking chuck. If they'll go through metal or wood, plastic is no problem, and for the bits to go through metal, well... There's some to go though concrete, so something will be tough enough. The hand drill makes sure I don't go too far. Edited by Father Mapple
  On 1/9/2018 at 2:40 PM, Jolemai said:
Then I simply need a pin vice(?) that can hold larger drill bits.
I have a pin vice but also a hand drill which is useful if you have a hobby vice or the model you are working on is large, like drilling out rhino exhausts. Unsure what the uk has but they are in Bunnings here
Yep - something like this... https://www.bunnings.com.au/stanley-8mm-handyman-hand-drill_p5611844
Although I'm sure they can be found for much cheaper in the US/UK. Bunnings (as do most things) get a markup for shipping to Oz...
Having said that - for magnets I usually just use the GW sizes up to the biggest in their pin vice and then work up through 3-6mm drill bits just held with a bit of masking tape at the back end. Generally 3mm is what I use for shoulders or jump packs, so the 3mm bit is just to widen the pin vice hold out. Also makes it far more accurate to have a 1mm hole first.
*Slightly ashamed to admit I got the GW drill - I had a bunch of ancient metal GK models that needed intense pinning and the grip helped to work into tin.
It has been a workhorse for putting pins into resin bases, bolter barrels etc since. So despite giving them moar monies... I have come to quite like it.
Hey guys, I have a rules question that probably belongs in another thread... but I like you guys more than anyone else on the inter webs
If I have a two units of terminators drop down and then drop down another unit right behind them, can my opponent shoot through the termies and target the other unit? I thought that the unit in the back would be safe, but others are saying you can just shoot through any unit (friendly or foe) unless it's a completely LOS blocking tank or something.
My opponent was using tau in my last game. He put a big unit of drones and a big unit of kroot in front of some fire warriors to the point where you really couldn't see much of the fire warriors through the other units, but he said I could still target the fire warriors with my infantry and shoot through the kroot and drones and he could shoot me with his fire warriors as well.
Is this correct? This just seems silly to me for some reason... also I was planning on hiding some VVs behind shooty termies for one of my lists!
Sure he can. Only Characters with less than 10 wounds are safe from getting shot at when another unit is closer. ;)
Darn, I was thinking a wall of terminators was more than enough to block LOS to other, smaller infantry behind them, but I guess not!
Now I have to wonder why shooting into combats is considered too dangerous to do while fire warriors are shooting through blobs of thirty kroot that are touching base to base lol
Edit: just to clarify, I'm talking about shooting through friendly or enemy units that are blocking over 50% of the view of another infantry unit behind them as if the first unit didn't exist.. Not just having one unit close and another non character unit further away unobscured
Edited by Brother Lemartes
Because it's a game of abstraction. In melee your target and friendly soldiers are VERY close together and in constant movement while a unit simply walking behind another is a MUCH easier target to shoot at.
Register a new account
Sign in
