Kelborn Posted December 22, 2016 Share Posted December 22, 2016 (edited) How do you name your chapters / companies again? So I can use Captain Gelen and his chapter like I would like to? Any specifications I need to bear in mind while writing about him / your Legion in Tohos fluff? Would it be ok if I name him Arjac Gelen? A giant, even for an Astartes, Arjac was a veteran of countless skirmishes and he had seen more battlefields than he could remember. Deriving from Terra itself and accompanied by a cadre of battle-hardened veterans since the first days of the Great Crusade, Arjacs was tasked to bring the southern regions of the Domain of Storms into compliance. While the northern Domain was secured by the Predators Legion, the southern still bear threats and never before seen races. Edited December 22, 2016 by Kelborn Link to comment Share on other sites More sharing options...
bluntblade Posted December 22, 2016 Share Posted December 22, 2016 *Galen. Chapters/Battalions are ad hoc, we haven't discussed names for them at all. Companies are simply numbered. Link to comment Share on other sites More sharing options...
Slips Posted December 23, 2016 Author Share Posted December 23, 2016 (edited) I have a very strong disdain and dislike for the Space Wolves so I'm not for having a character having the same name as one of their special Characters Ajax could work becuase its suitably Greek-ish. The size thing is also potentially an issue since ALL the Iron Bears (iirc) are larger-than-normal size Astartes. I dunno, I'm not really a fan of "Hes a Captain who stands out especially because hes lerger than normal!" Possibilities ie Alexis Polux of the Imperial Fists; its his only feature that I dislike. Also, if you can find the excel sheet someone oosted a while back with Company/Battalion/Chapter/etc. Names in it, the Scions section is filled out. I dont remember who originally posted it and where though! Edited December 23, 2016 by Slipstreams Link to comment Share on other sites More sharing options...
Kelborn Posted December 23, 2016 Share Posted December 23, 2016 My intention was that Galen could be resembling the Greek Ajax. Instead of using his name, I though an aberration like Ajac or Arjacs would be ok. If Ajax is ok nevertheless, I'll use it. Same with his size. As its your Legion and if you don't want that, I'll adapt, of course. Maybe he'll be clad in Terminator armor instead of making him bigger than normal marines. If I remember it correctly, you prefer Tartaros pattern because of its streamlined and modern form, correct? Link to comment Share on other sites More sharing options...
Slips Posted December 23, 2016 Author Share Posted December 23, 2016 (edited) TDA should be fine enough for me; we only have one actual character in TDA anyways. For which pattern, Ill leave that to you since you can streamline any pattern (look at the Cataphractii Primus FW is selling. Fix the shoulders and legs and BAM perfect). Edited December 23, 2016 by Slipstreams Link to comment Share on other sites More sharing options...
Kelborn Posted December 23, 2016 Share Posted December 23, 2016 What does TDA stand for by the way? Link to comment Share on other sites More sharing options...
bluntblade Posted December 23, 2016 Share Posted December 23, 2016 Tactical Dreadnought Armour. Btw, are all Scions Terminators Depthstriders? Link to comment Share on other sites More sharing options...
Slips Posted December 23, 2016 Author Share Posted December 23, 2016 No, not all Terminators would be Depthstriders. Link to comment Share on other sites More sharing options...
simison Posted December 24, 2016 Share Posted December 24, 2016 [it took three tries, but I'm finally here.] The Phantoms Comparison Base: Dark Fury Assault Squad (175 pts) Attributes +1 UNIT WS: 10 points +1 SGT WS: 5 points Total: 15 points Wargear No SGT Artificer Armour: (-10) Points Obscura-Pattern JP: 5 points * 5 = 25 points Shroud Bombs: 20 points Hooknet & Lancea (Hinder) vs. Raven's Talons (Rending & Master-Crafted): -15 points * 5 = (-60) points Total: (-25) points Special Rules Furious Charge vs Sudden Strike: (-5) points Total: (-5) points Total cost: 160 points Notes: For the Obscura JP, I subtracted the cost from a normal JP and removed an additional 5 points since Fateful Descent has the same bonus as Shrouded when Deep Striking. Why does the unit have Shroud Bombs? Note to self: be wary of Raven's Talons. They really swung the calculations. Overall, I think I'm satisfied with the results. Link to comment Share on other sites More sharing options...
Slips Posted December 25, 2016 Author Share Posted December 25, 2016 (edited) Shroud bombs are defensive grenades that you can use to gain shrouded for a full game turn (iirc). So something they can use to give them a defensive buff after theyve used their jump packs effect. Edited December 25, 2016 by Slipstreams Link to comment Share on other sites More sharing options...
simison Posted December 25, 2016 Share Posted December 25, 2016 I know what they are, my question was what was the fluff reason for having them? Link to comment Share on other sites More sharing options...
Slips Posted December 25, 2016 Author Share Posted December 25, 2016 I honestly just went "well they have no real shooting to speak of and are likely to be down range ASAP so might as well give them something to help them survive longer." Or, they use them to confuse the enemy when "SUDDENLY SMOKE GRENADES!" Happens and they just charge through it and skewer their targets and/or provide cover on their approach. Also makes charges difficult terrain (-2"), iirc, which they themselves mostly ignore but can use to their advantage when faced with other CC punchers. Link to comment Share on other sites More sharing options...
Slips Posted December 26, 2016 Author Share Posted December 26, 2016 Note to self: go through all the scions rules/wargear/characters and either reduce or eliminate the amount of redundancy, overlap or overcomplication present therein. Why? Because I read the book 1 pdf and went "damn slips you went legit overboard with a LOT of this stuff" now that hindsight is in effect. Link to comment Share on other sites More sharing options...
bluntblade Posted December 26, 2016 Share Posted December 26, 2016 Best to start big and trim down, I reckon Link to comment Share on other sites More sharing options...
Slips Posted December 27, 2016 Author Share Posted December 27, 2016 Thats almost always how I make stuff hahaha Link to comment Share on other sites More sharing options...
simison Posted December 27, 2016 Share Posted December 27, 2016 There's a reason why I always ask if you want to revise anything before I go through it. Link to comment Share on other sites More sharing options...
Slips Posted December 27, 2016 Author Share Posted December 27, 2016 I mean the revision is part of that process anyways so it comes out to roughly the same result. Mostly its just wording issues with how clunky Ive made stuff sound. Link to comment Share on other sites More sharing options...
simison Posted December 29, 2016 Share Posted December 29, 2016 I honestly just went "well they have no real shooting to speak of and are likely to be down range ASAP so might as well give them something to help them survive longer." Or, they use them to confuse the enemy when "SUDDENLY SMOKE GRENADES!" Happens and they just charge through it and skewer their targets and/or provide cover on their approach. Also makes charges difficult terrain (-2"), iirc, which they themselves mostly ignore but can use to their advantage when faced with other CC punchers. Alright, something practical given their role. Do you approve of the price tag? Link to comment Share on other sites More sharing options...
Slips Posted December 29, 2016 Author Share Posted December 29, 2016 I'd honestly go for 175 as a safe bet but 160 is fine. Link to comment Share on other sites More sharing options...
simison Posted December 30, 2016 Share Posted December 30, 2016 Then I'll tone it down to 165 points as a compromise. Link to comment Share on other sites More sharing options...
Slips Posted December 30, 2016 Author Share Posted December 30, 2016 Sounds fair! Link to comment Share on other sites More sharing options...
simison Posted January 2, 2017 Share Posted January 2, 2017 (edited) The Depthstriders Comparison Base: Red Butchers (275 pts) Attributes +1 UNIT LD: 10 pointsTotal: 10 points Wargear Volkite Charger vs. Combi-bolter: 7 Points * 5 = 35 points Wave Blade vs. Power Axe: 30 points Total: 65 points Special Rules Fearless = Fearless Night Vision vs. Hatred (Everything): (-5) points Monster Hunter vs. FNP (6+): 5 points Chosen of Pionus: 5 points Ravening Madmen/Unstoppable Charge = 10 points Total: 20 points Total cost: 95 points Recommend overall cost: 370 Notes: That Wave Blade is responsible for a third of the boost, while the chargers are a responsible for the other third. Otherwise, the units are relatively close together. Edited January 8, 2017 by simison Link to comment Share on other sites More sharing options...
Slips Posted January 3, 2017 Author Share Posted January 3, 2017 The Wave Blades for the Depthstriders should be an Upgrade Option and not standard issue. They should have Power Weapons instead. That said, IIRC, the upgrade option is pretty cheap (10-15 points) so I'd boost that to 20-25 points. Link to comment Share on other sites More sharing options...
simison Posted January 3, 2017 Share Posted January 3, 2017 What does IIRC mean? Removing the Wave Blade on the Divemaster brings the unit down to 340 points. How is that? And we'll bump up the Wave Blade to 20 points per blade. A power weapon costs 15, while the Wave Blade costs 45 points. So, while the standard difference would be 30 points, I'll knock off an extra 10 points to show that the Depthstriders are regularly supplied with Wave Blades and to offset the high cost for the unit. Link to comment Share on other sites More sharing options...
Slips Posted January 3, 2017 Author Share Posted January 3, 2017 If I Recall Correctly. All that sounds fine to me. Link to comment Share on other sites More sharing options...
