Vairocanum Posted August 23, 2017 Share Posted August 23, 2017 Great work! I think the legs look better than they did before! Just an idea, but maybe you could put a corpse between his legs? Like he's leaping over his disemboweled victim? The cape for the Dark Apostle is looking great too, nice work making it look more ragged! Sort of off topic but if you're looking to continue doing more complex conversions I'd highly recommend getting a dremel cause it's much faster than filing something plus you can usually fix any mistakes with GS pretty easily (especially since you have the silicone brushes). So things like smoothing out work on the cape and making damage would be a lot quicker. Looking forward to seeing more! Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4865761 Share on other sites More sharing options...
The_Stray_Idea Posted August 23, 2017 Share Posted August 23, 2017 Fanatastic work on the Dark Apostle. Looking forward to how all the green stuff experiments turn out. The last bezerker you posted made me think classic Wolverine not a bad thing in my books. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4865789 Share on other sites More sharing options...
Sagentus Posted August 23, 2017 Author Share Posted August 23, 2017 Cheers Vair! I have some old SM part lying around somewhere and ill mock that up tonight. I was quite happy with how the cape is looking, little more to do on it though. defo tempted for a Dremel, especially if it speeds things up. Do you have any suggestions as to which one to get? The new silicone brushes really help get a smooth finish i have found, defo see what you mean when you said to get the harder nibs though, you have to put quite a bit of pressure on with the soft nibbed ones. @The_Stray_Idea - Thank you, got a lot more work to do on the DA, but hopefully get plenty done tonight whilst i wait for my undercoat to dry on the bezerkers. I thought that too, its hard not to think of wolverene when looking at dual LC. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4865801 Share on other sites More sharing options...
Aasfresser Posted August 23, 2017 Share Posted August 23, 2017 Ha! I think I ordered the exact same wax carving tools from amazon a few weeks ago. And some silicone brushes, but not the same. I used some of the warptalon LCs on some minis and after painting them, I wouldn't do it again without getting rid of the extra lightning like trim on the claws back. It just looks strange esp. if the miniature over all is a bit older and not as detailed, like those old zerkers. But that might just be my personal taste and not worth anything. Also, that cape is coming along very nicely! Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4866244 Share on other sites More sharing options...
Biohazard Posted August 23, 2017 Share Posted August 23, 2017 Wolvey Zerker looks good mate. The cape on the DA is looking great as well, I will also chime in on the dremel thing as well. I bought a cheap rotary tool last year and for drilling to add pins or for smoothing/hollowing out bits it's perfect, mine still spins a bit fast and tends to melt the plastic a little if I'm not careful but it makes a lot of jobs a lot easier. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4866420 Share on other sites More sharing options...
Sagentus Posted August 23, 2017 Author Share Posted August 23, 2017 @vair - for how cheap they were they are perfect. Kinda wishing I got the harder nibbed brushes, but I'll get them some point soon. Dam, I saw your post to late about the lcs and have already undercoated and Base coated them :-( I think you are right though and I'll do that next time @Bio - cheers mate! Quite happy with how he's coming on, but I think vair was right about the back of the lcs, will have to live and learn with that one. Defo going to get a dremel, it's payday soon and you can get cheapish one that should do the trick like you say. I did some more work on my DA tonight as I was waiting for my bezerkers to dry, managed to undercoat then and the Base spray them mephiston red (yes it's cheating but I don't have an airbrush). Firstly with the front I changed bits out that various people mentioned, belt, spikes on the end of the tastles, made the robe look ragged and got some khorne symbols on each shoulder I was trying to get a good lean on him as if he was charging. I also changed out both the hands for standard csm ones. Finally I did more work on the robe to get rid of the dark angles insignia. I'm pretty happy with how he's turned out, but as always I'm open to c&c and suggestions to make him look better :-) Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4866531 Share on other sites More sharing options...
Vairocanum Posted August 26, 2017 Share Posted August 26, 2017 First off the comment you replied to was Aafresser's comment not mine . As for the Dark Apostle, he's looking a lot more chaos now! Fantastic work, he's definitely going to look epic when painted up! My only gripe is that the combi plasma looks a bit top heavy. Looking forward to seeing more stuff painted up! And for which dremels are good: I have an old one which is the dremel 275. The current version of mine is the dremel 100 which is supposed to be better. It's basically the cheapest version you can get but for modelling it's enough I'd say cause I can work with the old metal models just fine. I bit that I get the most use out of looks like this, but it doesn't come with the dremel and you'd need to get an extra pack of bits like this or buy one separately. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4868598 Share on other sites More sharing options...
Sagentus Posted August 26, 2017 Author Share Posted August 26, 2017 Whoops sorry vair and Aafresser Cheers vairocanum, I'm really happy with how he's coming on too. I agree with the combi plasma think I might just give him a plasma pistol. As for painting him, he's going to have to wait until my bezerkers are finished, got the final highlight or red to do on them, then it's onto painting the gold and silver ;) Cheers for the advice on the dremel. Will get one asap Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4868650 Share on other sites More sharing options...
ElDuderino Posted August 26, 2017 Share Posted August 26, 2017 Your apostle is coming along great, I imagine shaving off the DA logo of the cape must've been a hassle though:) Small suggestion, is it possible to shave down the left shoulder bit? His shoulder pad seems to stick out a bit too much. The berzerkers are looking cool too, and looking at your earlier paintworks I'm sure they'll look awesome finished. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4868677 Share on other sites More sharing options...
Sagentus Posted August 26, 2017 Author Share Posted August 26, 2017 Cheers ElD. Yeh the dark angels symbol was a pain. I think it looks like that due to the white tac. I'll have a look at it later. Thanks again, I'll try and get a wipe pick of the up later today ;) Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4868712 Share on other sites More sharing options...
Sagentus Posted September 18, 2017 Author Share Posted September 18, 2017 Been a while, but life has kicked me in the ass. The miss' insisted i went for a blue cloak/robes, which look good but contrast like mad with the red armour. But i think i'm going to keep going with it and see what the end result looks like Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889063 Share on other sites More sharing options...
hushrong Posted September 18, 2017 Share Posted September 18, 2017 I think it looks good. The clash of the two colors is nice and it will attract the eye and favor of Khorne! Looking forward to more. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889230 Share on other sites More sharing options...
Vairocanum Posted September 19, 2017 Share Posted September 19, 2017 That looks great so far! Maybe the Dark Apostle is more biased towards tzeentch rather than chaos undivided! Looking forward to seeing more! Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889709 Share on other sites More sharing options...
The Traitor Posted September 19, 2017 Share Posted September 19, 2017 The blue looks good, it will make him pop out more in your army. However for it not to be too excessive maybe you could paint the interior of the cape in a darker colour, like grey or black? Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889886 Share on other sites More sharing options...
rednekkboss Posted September 19, 2017 Share Posted September 19, 2017 Yeah, I echo the others on the blue. Great accent color! Great looking stuff. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889889 Share on other sites More sharing options...
Sagentus Posted September 19, 2017 Author Share Posted September 19, 2017 Thanks all! With regards to what the traitor said, is it worth me toning down the robes/repainting them grey or repaint the inside of the cloak grey? Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889909 Share on other sites More sharing options...
rednekkboss Posted September 19, 2017 Share Posted September 19, 2017 A deep gray or even black with deep blue highlight. I do like the blue as an accent color. One thought: You could hit the robes with a shade (GW Drakenhof Nightshade is a blue/black..great stuff , very useful for all sorts of stuff) that would tone them down a bit. That would even shade nicely over greys and give you toned down blue. If you go with a lighter grey, however, it'll look like faded blue jeans- that's how I do my Ork pants. :) Not sure I'd go with a straight black shade. If you wanted to try that I'd say water it down and try it on the inside before you repaint it to see how it looks. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889932 Share on other sites More sharing options...
Sagentus Posted September 19, 2017 Author Share Posted September 19, 2017 Cheers Red! I will see if i have that shade then redo the robes grey with a blue accent, hopefully that way they will look darker. Then keep the inside of the cloak the same colour with a wash of Drakenhof Nightshade on it. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4889951 Share on other sites More sharing options...
Sagentus Posted September 22, 2017 Author Share Posted September 22, 2017 Managed to get more done on the DA, really liking how the front is coming on, still plenty to do on the silver, gold and bone but I’m happy with how the cloak and robes have turned out. Not to sure on the back atm, needs more work on the recesses but it is getting there :) Also I have been working on my bez, keep forgetting to take pics, will upload some soon :) Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4892798 Share on other sites More sharing options...
hushrong Posted September 22, 2017 Share Posted September 22, 2017 I liked the blue but the new colors on the tabbard and the outer portion of the cloak look great! Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4892826 Share on other sites More sharing options...
Sagentus Posted September 22, 2017 Author Share Posted September 22, 2017 Cheers Husrong! - I'm defo happier with the grey tabbard/cloak being the main focus. The blue inside to the cloak looks better in person imo, but ill get a better pic of it once its done :) Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4892869 Share on other sites More sharing options...
Pearson73 Posted September 22, 2017 Share Posted September 22, 2017 The robes are looking good, the new grey at the front helps reduce the red-blue contrast to a decent level, I think before it might have been a bit too much, but that break of grey has worked well. Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4893102 Share on other sites More sharing options...
chaplain cy Posted September 22, 2017 Share Posted September 22, 2017 that blue really pops, I like it! Definitely subbing to this thread :D Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4893129 Share on other sites More sharing options...
The Traitor Posted September 23, 2017 Share Posted September 23, 2017 I like the grey better too, more khornate! Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4893497 Share on other sites More sharing options...
ElDuderino Posted September 23, 2017 Share Posted September 23, 2017 Yeah the blue certainly looks good, no question about it, but it's a bit too cheery for a follower of khorne imo Link to comment https://bolterandchainsword.com/topic/329556-sagentuss-khorne-army-contemptor-dread-and-da/page/5/#findComment-4893528 Share on other sites More sharing options...
