lhg033 Posted January 19, 2021 Share Posted January 19, 2021 The shape reminds me of the rooftops in Paris (best example I can quickly google: https://www.etsy.com/uk/listing/192835277/paris-photography-paris-rooftops) Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5655787 Share on other sites More sharing options...
Mud Duck Posted January 20, 2021 Share Posted January 20, 2021 That looks good, but aren't the angles a wee bit - or a bit - off. Your recreation is far more rounded than the gothic-like angles of the roof in the still. That's called "Artistic License." Actually the angular roof would have been far more simple to reproduce. Never let it be said the Blackadder opts for the easier way to do something. Oh, so this isn't just the inner vault to which your going to reproduce the Sistine Chapel, the Apotheosis of Washington (hum, yeah, ok the Emperor), and Leonardo da Vinci's Man? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5655910 Share on other sites More sharing options...
Blackadder Posted January 22, 2021 Author Share Posted January 22, 2021 Central Dome: The Central Dome will occupy the middle of the superstructure in this model seen here in a top view image https://i.imgur.com/0GHdunT.jpg And in the rough placement on the upper deck: https://i.imgur.com/KDpqBJS.jpg Now I need to find the Aquila template from my old Warlord work???? Dr_Ruminahui and Captain Caine 24th 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5657224 Share on other sites More sharing options...
Brother Carpenter Posted January 23, 2021 Share Posted January 23, 2021 And youll stick a big gun out of that stucture? Would fit nice under the stairs Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5657904 Share on other sites More sharing options...
Blackadder Posted January 24, 2021 Author Share Posted January 24, 2021 (edited) And youll stick a big gun out of that stucture? Would fit nice under the stairs A humongous Volcano Cannon will be housed in the central Keep but right now I'm going to indulge myself with some fine detail. First on the agenda will be an Aquila for the dome. Edited January 24, 2021 by Blackadder Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5658330 Share on other sites More sharing options...
Lord_Mephistopheles Posted January 25, 2021 Share Posted January 25, 2021 And youll stick a big gun out of that stucture? Would fit nice under the stairs A humongous Volcano Cannon will be housed in the central Keep but right now I'm going to indulge myself with some fine detail. First on the agenda will be an Aquila for the dome. It's an aside in a lot of ways, but the only "official" Imperator model from the old Epic days was armed with a Quake Cannon in the carapace, which also had a "planetary defence laser" mounted atop the central tower. The surrounding towers were then armed with what were described as "secondary carapace weapons". The datasheets i've seen for using Imperators in other systems, be it fan-made 40k datasheets, or for Titanicus, suggest that an Imperator carapace can mount any 4No. Warlord-class weapons. Obviously up to you as it's your grand design, but hope the input is enlightening at the very least. Also - a new titan class has just been released by the artisans at GW - the Warmaster Heavy Battle Titan. Bigger than a Warlord, presumably smaller than an Imperator. There might be some inspiration there as well perhaps? Other than that, epic as always! Blackadder 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5658856 Share on other sites More sharing options...
Blackadder Posted January 29, 2021 Author Share Posted January 29, 2021 "Armed with a Quake Cannon in the carapace." "Planetary Defense laser mounted atop the central tower." "The surrounding towers were then armed with what were described as "secondary carapace weapons." "The datasheetsIi've seen for using Imperators in other systems, be it fan-made 40k datasheets, or for Titanicus, suggest that an Imperator carapace can mount any 4No. Warlord-class weapons." Obviously up to you as it's your grand design, but hope the input is enlightening at the very least. Also - a new titan class has just been released by the artisans at GW - the Warmaster Heavy Battle Titan. Bigger than a Warlord, presumably smaller than an Imperator. There might be some inspiration there as well perhaps? Many thanks for this information and the new Warmaster Heavy Battle Titan. I did a bit of research and found this: Another undersized disappointment from the FW group and I'm not a fan of the Alpha designs at all. It's just a larger version of the "Imperial Knights" IMHO. ;) Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5661246 Share on other sites More sharing options...
Blackadder Posted January 31, 2021 Author Share Posted January 31, 2021 Here come the eagles.... No not the 'Lords of the Ring' eagles but the 40K Imperial eagles. It took me the better part of this week to make 4 of these plus a paper and plastic template for future use. https://i.imgur.com/Frac3Yr.jpg https://i.imgur.com/1TwZD4w.jpg It hardly looks like a week's production but it's most gratifying to get these done. https://i.imgur.com/rL798Pc.jpg Now it remains to glue the pieces to a sheet of 0.010 styrene (seen below with the bodies already glued in place. And trim to size for the Dome structure previously shown. Mechanist, Zebulon and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5662140 Share on other sites More sharing options...
Indefragable Posted January 31, 2021 Share Posted January 31, 2021 Just a thumbs up to say this is a fun thread to stop in every now and then and check in on. Keep up the good work and focus! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5662148 Share on other sites More sharing options...
Lord_Mephistopheles Posted February 2, 2021 Share Posted February 2, 2021 "Armed with a Quake Cannon in the carapace." "Planetary Defense laser mounted atop the central tower." "The surrounding towers were then armed with what were described as "secondary carapace weapons." "The datasheetsIi've seen for using Imperators in other systems, be it fan-made 40k datasheets, or for Titanicus, suggest that an Imperator carapace can mount any 4No. Warlord-class weapons." Obviously up to you as it's your grand design, but hope the input is enlightening at the very least. Also - a new titan class has just been released by the artisans at GW - the Warmaster Heavy Battle Titan. Bigger than a Warlord, presumably smaller than an Imperator. There might be some inspiration there as well perhaps? Many thanks for this information and the new Warmaster Heavy Battle Titan. I did a bit of research and found this: Another undersized disappointment from the FW group and I'm not a fan of the Alpha designs at all. It's just a larger version of the "Imperial Knights" IMHO. I tend to agree. Neither this not the Warbringer Nemesis model really "work" - the aesthetic is wrong and does match upto the venerable Reaver and Warlord at all. Too top heavy. Like they've just emptied the weapons bin onto the carapace and then put armour around it. Just thought it might be inspiration for weapon ideas is all. The aquilas look good. Might i suggest a few of the Collegia Titanicus logos as well? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663025 Share on other sites More sharing options...
Blackadder Posted February 3, 2021 Author Share Posted February 3, 2021 All in good time. The Aquila are the hardest to make therefore I make them first. These will be especially ornate just as I made for my Warlord only larger. https://i.imgur.com/KeBAr.jpg CaptainFrederickson 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663200 Share on other sites More sharing options...
grailkeeper Posted February 3, 2021 Share Posted February 3, 2021 Wow! What's your plan for this thing once its finished? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663474 Share on other sites More sharing options...
Blackadder Posted February 4, 2021 Author Share Posted February 4, 2021 Wow! What's your plan for this thing once its finished? Put it on a shelf (Figuratively speaking; it's too big for a shelf.) and let it gather dust. A game involving pieces a big as this would require a gymnasium floor. :D I just like building them for the fun of it. Thanks for the query. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663756 Share on other sites More sharing options...
Quixus Posted February 4, 2021 Share Posted February 4, 2021 I wonder if you could use it as a terrain piece for Killteam. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663855 Share on other sites More sharing options...
lhg033 Posted February 4, 2021 Share Posted February 4, 2021 I wonder if you could use it as a terrain piece for Killteam. You just might need a step ladder to reach everything on the top deck Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663858 Share on other sites More sharing options...
Brother Carpenter Posted February 4, 2021 Share Posted February 4, 2021 Wow! What's your plan for this thing once its finished? Put it on a shelf (Figuratively speaking; it's too big for a shelf.) and let it gather dust. A game involving pieces a big as this would require a gymnasium floor. I just like building them for the fun of it. Thanks for the query. You could just build about 10-20 more and play a game of titannicus in 40K scale with them? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5663914 Share on other sites More sharing options...
Blackadder Posted February 5, 2021 Author Share Posted February 5, 2021 Two Weeks in the Making: At this rate it's going to take decades to finish this thing. Hardly the project for someone who's reluctant to purchase green bananas. But Hey; the fun is in the building and I did have fun creating these eagles.... Not! It was an arduous task principally because I hate repetition. So here's the result and I'm pretty pleased with it. https://i.imgur.com/HxySykF.jpg All four sides have the same Aquila but each is an individual and I had to chose which one looked best on each side https://i.imgur.com/lRliuPl.jpg but for all my angst they all look pretty much the same. https://i.imgur.com/TJVj8Jb.jpg The bird's eye view(groan) shows them off the best. Martini time, Skoal. Majkhel, Augustus b'Raass, LameBeard and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5664279 Share on other sites More sharing options...
ThePenitentOne Posted February 6, 2021 Share Posted February 6, 2021 Just amazing. This is a great Kill team board for jump units- I'd love to play in that game! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5664330 Share on other sites More sharing options...
Brother Carpenter Posted February 6, 2021 Share Posted February 6, 2021 Looking very nice! Chapeau Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5664590 Share on other sites More sharing options...
lhg033 Posted February 8, 2021 Share Posted February 8, 2021 Really impressive! Are you planning on fixing these in place permanently on the upper deck or will you make them removable so you can get in/around them and/or use them as terrain in games if you play? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5665196 Share on other sites More sharing options...
Mechanist Posted February 12, 2021 Share Posted February 12, 2021 If you finish that beast in a decade I'd say you where flying the level of detail you go to and the scale of it is so amazing. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5666650 Share on other sites More sharing options...
Blackadder Posted February 12, 2021 Author Share Posted February 12, 2021 Eohippus: A horse is a horse of course, of course.... Yesterday my better half said this looked like a dinosaur. Today she said it looked like an Eohippus.... Huh! What do women know. I think it looks like a stylized Aquila and I like it. https://i.imgur.com/ca4jaQZ.jpg And birds descended from Dinosaurs so I'm on the right track anyway. You wouldn't believe how much work went into this decoration: https://i.imgur.com/x2PKJsi.jpg Of course I also had to deal with a foot of snow in three separate storms this past week which is a lot for my area anyway. So I tacked the work temporarily to the center edifice and it looks pretty good. https://i.imgur.com/Dm2bIaj.jpg I'm going with it. Grotsmasha, Bryan Blaire, Sagentus and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5666837 Share on other sites More sharing options...
Brother Carpenter Posted February 12, 2021 Share Posted February 12, 2021 Wow you had me there. At first I thought you had a massive building splurge and finised the topside. That's a nice reconstruction for the decoration. Nice! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5666916 Share on other sites More sharing options...
Majkhel Posted February 13, 2021 Share Posted February 13, 2021 Magnificent! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5667094 Share on other sites More sharing options...
Augustus b'Raass Posted February 14, 2021 Share Posted February 14, 2021 The aquilas look great!It's pretty hard to see from the pictures - but do they have the one eye or two? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/37/#findComment-5667247 Share on other sites More sharing options...
