Knightsword Posted December 2, 2025 Author Share Posted December 2, 2025 3 hours ago, space wolf said: Oooh, this has a lot of promise. Looking forward to seeing your progress. I always thought the lion's head looked like Charles Dance (the actor who played Tywin Lanester on Game of Thrones). Which by the way is perfect for a grizzled knight. I'd always thought he looked like what would happen if you put Liam Cunningham's facial hair as Davos Seaworth on Charles Dance's face. I'm really not looking forward to doing the cape. Sculpting fabric is frustrating. I may have to ditch it and do something like get a drink can and cut and shape a cape from that and then put a thin layer of green stuff over that instead. 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145002 Share on other sites More sharing options...
Knightsword Posted December 3, 2025 Author Share Posted December 3, 2025 Test fit of the cape. This phase 1 of doing the cape. Sanded most of the obvious lumps down first and will be building up the folds and blending the joints with the plastic on the underside where needed next. 6 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145152 Share on other sites More sharing options...
W.A.Rorie Posted December 3, 2025 Share Posted December 3, 2025 Very nice! Looks great 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145190 Share on other sites More sharing options...
space wolf Posted December 4, 2025 Share Posted December 4, 2025 (edited) On 12/2/2025 at 9:18 AM, Knightsword said: I'd always thought he looked like what would happen if you put Liam Cunningham's facial hair as Davos Seaworth on Charles Dance's face. I'm really not looking forward to doing the cape. Sculpting fabric is frustrating. I may have to ditch it and do something like get a drink can and cut and shape a cape from that and then put a thin layer of green stuff over that instead. I have done this! The 50/50 miliput/GS mix is perfect for this. You slap it on there, and usa a wet brush to smooth out all the wrinkles...much easier than sanding afterward, but its an option l, if you dont get everything smooth initially. The trick to GS Capes is to let it sit for like 45 minutes. Then roll it out, and cut to shape. Should be not very sticky any more, and if youre gentle, you wont put fingerprints in it. Then just attach it and use some sticky tack to keep it in place where you know it will droop....or just find a way to angle the model so that the flow of the cape is going with gravity as it cures. Hope that helps. Edited December 4, 2025 by space wolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145441 Share on other sites More sharing options...
Knightsword Posted December 5, 2025 Author Share Posted December 5, 2025 15 hours ago, space wolf said: I have done this! The 50/50 miliput/GS mix is perfect for this. You slap it on there, and usa a wet brush to smooth out all the wrinkles...much easier than sanding afterward, but its an option l, if you dont get everything smooth initially. The trick to GS Capes is to let it sit for like 45 minutes. Then roll it out, and cut to shape. Should be not very sticky any more, and if youre gentle, you wont put fingerprints in it. Then just attach it and use some sticky tack to keep it in place where you know it will droop....or just find a way to angle the model so that the flow of the cape is going with gravity as it cures. Hope that helps. This will definitely help for when I pluck up the courage to do a full cape from scratch. Luckily this was just gap filling so the plastic of the existing cape kept the putty in place. Cape now attached to model, but may still do a bit more sanding down. Added some purity seals for good measure. And now to ask for some opinions. The first ever iteration of this model had a lion pelt on top of its cape (see below). The model was in Cataphractii Armorur so it didn't have the vents to worry about covering. I'm tempted to alter this and do the same, but it would mean covering the vents which I've always viewed as a no-no for Indomitus. That was until new Grimnar was released who conveniently has his wolf pelt covering his vents! So now I can't decide whether leave him as is or pay tribute to his first iteration and add a lion pelt which would cover the vents. Thoughts? I suppose there is also the option to explain away with a bit of lore on how his suit is custom built due to being larger than a normal Astartes and is frankensteined from available Indomitus and Cataphractii parts and say it doesn't have vents. 4 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145545 Share on other sites More sharing options...
Firedrake Cordova Posted December 5, 2025 Share Posted December 5, 2025 I'd say rule of cool trumps any functional concerns. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145564 Share on other sites More sharing options...
space wolf Posted December 5, 2025 Share Posted December 5, 2025 Agreed, rule of cool always wins. Go with the pelt. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145569 Share on other sites More sharing options...
kabaakaba Posted December 5, 2025 Share Posted December 5, 2025 Idk, MY rule of cool said me leave vents open. I don't really like huge pelts all over model. It's maybe cool for someone, though I like open went. 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145622 Share on other sites More sharing options...
Alby the Slayer Posted December 6, 2025 Share Posted December 6, 2025 (edited) Leave his as is, I think you have just the right amount of "cool" in that area. Love it, btw, great conversion. Edited December 6, 2025 by Alby the Slayer 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145644 Share on other sites More sharing options...
Knightsword Posted December 6, 2025 Author Share Posted December 6, 2025 Ah no a 50/50 split Thanks for the input all. After looking at the model I think I'm going to try and get the best of both worlds. By that I mean take the cape off, trim back where the fur comes over the shoulder so there's enough room for the pelt's head and sculpt on paws similar to Lion El'Jonsons cape. The pelt will only be over the one shoulder and leaves the vents open. If it doesn't look right then I'll just reinstate everything as it currently is and stick with that. Wish me luck. 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145670 Share on other sites More sharing options...
Knightsword Posted December 8, 2025 Author Share Posted December 8, 2025 So I spent so long looking at this model that my partner actually asked if I was alright First attempt at my plan. I feel like I need to extend the limbs for the paws further up the sides of the pelt and make look they gradually "wrap under" the pelt towards the top sides if that makes sense to anyone. I managed to cheat a bit and make blue stuff molds of the paws and tail from El'Jonson's cape and then a blue stuff mold of the fur texture from the plastic part of the cape to try and better blend the green stuff. I unfortunately got impatient whilst sculpting and started trying to do more whilst the first bits were still malleable and flattened some of the initial detail. Managed to rescue it to a decent degree and then waited before carrying on. 3 5 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145901 Share on other sites More sharing options...
Rusted Boltgun Posted December 8, 2025 Share Posted December 8, 2025 Looking really good! I sympathise on the green stuff travails. I recently put a lovely thumbprint over a piece whilst rushing to finish. 3 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6145961 Share on other sites More sharing options...
Vairocanum Posted December 10, 2025 Share Posted December 10, 2025 The fur pelt is looking great! The temptation to keep sculpting instead of waiting is always so strong when I've still got leftover greenstuff on the table 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6146271 Share on other sites More sharing options...
Knightsword Posted December 13, 2025 Author Share Posted December 13, 2025 I will stop tinkering with this model at some point. The paws and limbs on the pelt have been extended to the top with an attempt to make them look like they're folding under. I also found some bits from a Lions of Chrace kit that had little lion icons on it so made a cast of those and used them as heraldic icons on the tilt shield and gauntlet shields. 7 3 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6146938 Share on other sites More sharing options...
Firedrake Cordova Posted December 15, 2025 Share Posted December 15, 2025 Looks good to me 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147085 Share on other sites More sharing options...
space wolf Posted December 18, 2025 Share Posted December 18, 2025 (edited) I think it lookz great. Once you prime an paint it, you wont be able to see any imperfections, that you as the creator may notice. Especially if you paont on a texture. I do it all the time, "got a smooth area that isnt smooth enough?" "Well, just paint some scales, or small fur lines on it, and it breaks it all up, and noone is the wiser." If your mindful about how you paint it, you can hide all manner of "sins." All that being said, i think youve done an outstanding job here Edited December 18, 2025 by space wolf Typo 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147541 Share on other sites More sharing options...
Knightsword Posted December 19, 2025 Author Share Posted December 19, 2025 Making some good progress on painting. 1 13 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147641 Share on other sites More sharing options...
space wolf Posted December 19, 2025 Share Posted December 19, 2025 Yep this is coming along nicely! 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147646 Share on other sites More sharing options...
Knightsword Posted December 23, 2025 Author Share Posted December 23, 2025 Base is done. Just deciding on a few finishing touches now. Also trying some decoration on the cape which just needs some shading to match the rest of the the colours. 4 9 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147917 Share on other sites More sharing options...
The Pounder Posted December 23, 2025 Share Posted December 23, 2025 Absolutely outstanding! I love the scheme, the sculpting skills and well, everything about this bloke! What’s coming next? 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6147969 Share on other sites More sharing options...
Boc Posted December 28, 2025 Share Posted December 28, 2025 That cloak is awesome. How long did it take you? 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6148695 Share on other sites More sharing options...
Knightsword Posted January 5 Author Share Posted January 5 (edited) On 12/23/2025 at 7:16 PM, The Pounder said: Absolutely outstanding! I love the scheme, the sculpting skills and well, everything about this bloke! What’s coming next? @The Pounder Much appreciated. I'm hoping one day my sculpting skills will get to the same level as Anpharius on Insta. I do have a rough to-do list somewhere on a previous page but really I need to finish off my Proxy Headtakers. I was going to get the Deathwatch shoulder icons from PopGoesTheMonkey to use as heraldic symbols on their shoulders, but with Shapeways going into administration last year they no longer have a printing facility in Europe so the shipping costs for the shoulder icons now exceed the price of the shoulder icons themselves. I may try sculpting but I'm not great at things that small yet. I may skip them for now and work on an update to my proxy Ragnar. On 12/28/2025 at 9:57 PM, Boc said: That cloak is awesome. How long did it take you? @Boc Thanks. A few days I think, had to wait a while for the gap filling on the original cloak to cure and then the pelt took a couple more, especially because I got impatient and ruined the fur texture on it. Having a short pause on hobbying. Our 16 month old bypassed the fire guard on our log burner in a way that would make Alpharius and Corax proud and got 2nd degree burns all over both his hands, so no free time whilst we try to keep him occupied and prevent him taking his bandages off Edited January 5 by Knightsword add more 5 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6150045 Share on other sites More sharing options...
Rusted Boltgun Posted January 5 Share Posted January 5 Hope your little one recovers well, that sounds a challenge! Anpharius' work is amazing. I went on his HH beginner's course last year and had a blast despite being the worst in the room. Hadn't written so many lecture notes since uni! 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6150066 Share on other sites More sharing options...
Firedrake Cordova Posted January 5 Share Posted January 5 Oof! Hopefully your Raven Guard in training recovers soon. 1 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6150096 Share on other sites More sharing options...
Knightsword Posted March 2 Author Share Posted March 2 The tiny man is fully healed and so I am back on with hobbying Version 2 of my proxy Ragnar, Lord Calen Belmont of the Ardent Swords 2nd Company, Master of the Knights Errant, Master of the Watch. The moment GW revealed the Execrator I knew I had to use it to make this guy. The only problem was finding a suitably dynamic cape. I mulled over re-using Mephiston's cape from the previous version but I've decided that I'll keep it as-is and use it as a Battle Leader. I nearly settled on Castellan Crowe's cape but couldn't find it at any bits sellers. I then stubbled across Suboden Khan's cape for sale and took a chance on it after looking at the 3D view on GW's site. I had also wanted to use a Sword Brethren style shoulder pad topper but couldn't get my hands on one. Overall it's turning out pretty well. Parts used: Black Templar Execrator body Black Templar Sword Brethren shoulder pads Dark Angels Inner Circle Companion arms White Scars Suboden Khan's cape Leviathan Terminator Captain's head Lion El'Jonson's sword Random Primaris backpack 6 4 Back to top Link to comment https://bolterandchainsword.com/topic/342619-knightswords-wip-thread/page/14/#findComment-6159052 Share on other sites More sharing options...
