Gederas Posted August 18, 2020 Author Share Posted August 18, 2020 awesome stuff! That justicare head is perfection! Thank you! Also, my First just got some reinforcements.... The Caestus is going to be fun to fix though.... I've already built 10 of the Mark II marines: Got another 10 to go, and then there's the 20 Mark II Assault Marines. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5587539 Share on other sites More sharing options...
shabbadoo Posted August 18, 2020 Share Posted August 18, 2020 Wow, but is that some kind of warpage on the Cestus. Careful application of a heat gun + 2 steel rulers + clamps could do the trick. Best of luck with it. WrathOfTheLion and Gederas 2 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5587579 Share on other sites More sharing options...
Gederas Posted August 18, 2020 Author Share Posted August 18, 2020 Wow, but is that some kind of warpage on the Cestus. Careful application of a heat gun + 2 steel rulers + clamps could do the trick. Best of luck with it. I've already started working on getting the warping out. Hairdryer did most of the work, some hot water from the Keurig did the rest. Cleaning up the mould slippage... Now that I can see taking a while :lol: Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5587802 Share on other sites More sharing options...
Aeri Posted August 19, 2020 Share Posted August 19, 2020 That's why I don't like forgeworld. The models can be awesome (some, not all imho) bit resin is just a pain in the backside... Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5588269 Share on other sites More sharing options...
G8Keeper Posted August 21, 2020 Share Posted August 21, 2020 That's why I don't like forgeworld. The models can be awesome (some, not all imho) bit resin is just a pain in the backside... I think you have to approach forgeworld kits knowing you're going to potentially be getting into something major modelling wise, anything less and you're possibly going to shelve it for a good while. It's sad as it's such a huge monetary investment that the models should not require so much intervention, but it's been like this for over a decade and I can't see it changing. Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5589478 Share on other sites More sharing options...
WrathOfTheLion Posted August 21, 2020 Share Posted August 21, 2020 (edited) Most of the time, I've had the Forgeworld kits be quite alright, depending.The old hand sculpted ones are the worst however. Things like MK IV assault marines, MK IV destroyers, etc. require quite a bit of cleanup. The molds are getting a bit ratty over the years, slippage can be bad, etc.Newer vehicles like the Sabre tank were quite nice, and fit together really well. I really liked that kit. Newer infantry like the dreadwing interemptors are nice as well. Edited August 21, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5589479 Share on other sites More sharing options...
Gederas Posted August 21, 2020 Author Share Posted August 21, 2020 That's why I don't like forgeworld. The models can be awesome (some, not all imho) bit resin is just a pain in the backside... I think you have to approach forgeworld kits knowing you're going to potentially be getting into something major modelling wise, anything less and you're possibly going to shelve it for a good while. It's sad as it's such a huge monetary investment that the models should not require so much intervention, but it's been like this for over a decade and I can't see it changing. Most of the time, I've had the Forgeworld kits be quite alright, depending. The old hand sculpted ones are the worst however. Things like MK IV assault marines, MK IV destroyers, etc. require quite a bit of cleanup. The molds are getting a bit ratty over the years, slippage can be bad, etc. Newer vehicles like the Sabre tank were quite nice, and fit together really well. I really liked that kit. Newer infantry like the dreadwing interemptors are nice as well. Pretty much :yes: The Caestus took some effort, but as soon as I saw it in the bags I knew it was going to be warped simply because it's sides are long thin pieces. Resin, when heated to a certain temperature, gets malleable and can bend. Resin curing, produces said heat :lol: But, I have done some work on the Caestus. And it's coming along faster than I thought. It's definitely going to be a long-term project though :lol: You can really see the wonky fitting on the right (first image's left) Crew Bay in the second two pictures. Thankfully though, I think some use of the dremel on the inside fittings and more heat applications should fix it. Interrogator Stobz and G8Keeper 2 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5589498 Share on other sites More sharing options...
bevulf Posted August 22, 2020 Share Posted August 22, 2020 These guys rock ! That is exactly the same idea i had for bladeguards! Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5590401 Share on other sites More sharing options...
Gederas Posted August 23, 2020 Author Share Posted August 23, 2020 [snipped] These guys rock ! That is exactly the same idea i had for bladeguards! Thanks! And yeah, that's really all that was needed to make the Bladeguard right and proper Dark Angels. In other news, Caestus is ready for the final stretch! :D Just need to use some milliput to fill in the gaps/clean up mould slips and then it's final assembly. Painting sometime in the next four months or so :lol: Dread, Grotsmasha and Interrogator Stobz 3 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5590805 Share on other sites More sharing options...
Gederas Posted August 27, 2020 Author Share Posted August 27, 2020 Finished the Eradicators! Aeri, Lostrael, ShibeKing and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5592588 Share on other sites More sharing options...
shabbadoo Posted August 27, 2020 Share Posted August 27, 2020 Looking good! Working on cleaning up those guys right now myself. And I see you carved off and replaced the left shoulder pads. Good man! Sorry to see the Cestus is the usual Forgeworld "Requires a full can of BONDO for patch work." quality. Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5592649 Share on other sites More sharing options...
Gederas Posted August 31, 2020 Author Share Posted August 31, 2020 Looking good! Working on cleaning up those guys right now myself. And I see you carved off and replaced the left shoulder pads. Good man! Sorry to see the Cestus is the usual Forgeworld "Requires a full can of BONDO for patch work." quality. Ehh.... The Caestus isn't as bad as it looks. The worst part is the nacelles need some milliput work of gap-filling. In other news, My results of the month of August: G8Keeper, Lostrael, Spaced Hulk and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5594480 Share on other sites More sharing options...
zacret Posted September 7, 2020 Share Posted September 7, 2020 well done brother! Amazing productivity and really nice paint jobs. You nailed the colors of the justicar! Dark and grimdark Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5597459 Share on other sites More sharing options...
Gederas Posted September 14, 2020 Author Share Posted September 14, 2020 (edited) well done brother! Amazing productivity and really nice paint jobs. You nailed the colors of the justicar! Dark and grimdark Thanks a lot! No new painted models (working on the rest of Indomitus this month). Buuuuuuuuuuut..... Something showed up on Sunday! :wub: (yes, that's two boxes of the Lion you see there) So, I got to building him yesterday after I did the scrubbing. And I have to say, he's a tall'un: I also magnetized not just Lion El'Jonson's weapons, but ALSO the scabbards for said weapons! Lion Sword: Wolf Blade: Edited September 14, 2020 by Gederas Interrogator Stobz, ShibeKing, bevulf and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5601722 Share on other sites More sharing options...
Spaced Hulk Posted September 16, 2020 Share Posted September 16, 2020 (edited) Nice work mate Edited September 16, 2020 by Spaced Hulk Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5602577 Share on other sites More sharing options...
Gederas Posted September 28, 2020 Author Share Posted September 28, 2020 Nice work mate , and kudos for drilling/converting such an expensive forgeworld model. Are you going to magnetise the bare head and helmet as well? Nah, going with the helmeted head for the gaming model :yes: In other news, finished the Indomitus Master: zacret, Skywrath and Interrogator Stobz 3 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5608182 Share on other sites More sharing options...
Gederas Posted October 1, 2020 Author Share Posted October 1, 2020 Seems you can get a lot of painting done in two days if you call out of work because you're not feeling well. Whoda thunk? As I managed to finished the Outriders and the Bladeguard this morning (as in, 1AM this morning before I went to bed): Though, looking at them now, I realize there's still some cleanup required on them, but hey ho. LameBeard, painting.for.my.sanity, Interrogator Stobz and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5609648 Share on other sites More sharing options...
bigtrouble Posted October 1, 2020 Share Posted October 1, 2020 What shoulder pads did you use for your bladeguard? Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5609671 Share on other sites More sharing options...
Gederas Posted October 1, 2020 Author Share Posted October 1, 2020 What shoulder pads did you use for your bladeguard? Our own Ezr91aeL's Grievous ptrn Shoulder Pads: DW Death Angels pads. Very excellent quality, and nearly no print lines. Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5609699 Share on other sites More sharing options...
WrathOfTheLion Posted October 1, 2020 Share Posted October 1, 2020 (edited) Bladeguard look great, they are probably my favorite model out of this new round, along with assault intercessors. I'm going to stick to the decals though for mine, I'm not the biggest fan of molded shoulderpads, but that's personal tastes. The beaky helmets on the bikers look good, I think I'm going to cut the helmet off the belt of the sergeant and do that as well. Are you doing the Lieutenant from the box as deathwing as well? Nevermind - see he's already done above. Edited October 1, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5609711 Share on other sites More sharing options...
Gederas Posted February 27, 2021 Author Share Posted February 27, 2021 Blowing the dust off the thread: I've finished 10 more Assault Intercessors (sans bases, I'll finish them some other time :lol:) for Lazarus' company (to make the 10 from Indomitus into two 10-man squads) I also finished Lion El'Jonson (gaming version, yes I bought two): Galloway, bigtrouble, lucien and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5671947 Share on other sites More sharing options...
Gederas Posted August 6, 2021 Author Share Posted August 6, 2021 (edited) Soon...... For context: That's 79 Mark III and Mark IV Tactical Marines, 5 Mark III Plasma gunner, 5 Mark III Meltagunners, 5 Mark IV Missile Launchers, 1 Mark IV Flamer Sergeant (for an eventual Zone Mortalis 5-man flamer squad), the BaC Cataphractii Praetor, Mark II Banner-bearer, Mark II Praetor and a Contemptor-Mortis Edited August 6, 2021 by Gederas ShibeKing and Interrogator Stobz 2 Back to top Link to comment https://bolterandchainsword.com/topic/354278-gederas-dark-angels-paint-it-black/page/8/#findComment-5727102 Share on other sites More sharing options...
