Rabenga Posted February 1, 2020 Share Posted February 1, 2020 I picked up a reaper warecrocodile for a Molech beast, and it works pretty good... Fajita Fan 1 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5470960 Share on other sites More sharing options...
Fajita Fan Posted February 2, 2020 Share Posted February 2, 2020 Warehouses are basically done, all I need is rust on the doors and metal but I have to glue the roofs. malika666 and Mendi Warrior 2 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5471044 Share on other sites More sharing options...
Fajita Fan Posted February 5, 2020 Share Posted February 5, 2020 Tried assembling my first actual AT buildings and I've discovered the little buttresses are actually required to hold the wall together. It would've been nice to have an angled piece that can glue in behind the little notches and act as internal support but oh well. My biggest mistake was trying to be cheap and use 3d printed 3x2 sections to build a roof in one shot, superglue ain't curing fast enough and my fingers are COVERED in glue right now. I can't feel my own fingertips. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472512 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Share Posted February 5, 2020 Tried assembling my first actual AT buildings and I've discovered the little buttresses are actually required to hold the wall together. It would've been nice to have an angled piece that can glue in behind the little notches and act as internal support but oh well. My biggest mistake was trying to be cheap and use 3d printed 3x2 sections to build a roof in one shot, superglue ain't curing fast enough and my fingers are COVERED in glue right now. I can't feel my own fingertips. A little trick that works quite well, at least for me, is to add 1mm thick plasticard on the back of the panels, then align them perfectly, preferably using something straight (e.g. a straight wooden plank) and a ruler so as to measure precisely the width of the wall you are building (remember 1 panel is 29mm wide, so 2 will be 58mm, 3 will be 87mm, and so on), and then add another piece of plasticard so as to join the x panels you are gluing together. Think of leaving some space at the extremities if you want to add more panels later. This also works with rigid cardboard, coffee stirrers, … 1mm plasticard gives this but you can also use something thicker, just be consistent for all the panels you are gluing together Straight wooden plank to align the upper part, ruler to measure the precise width After that, it is much easier to add the buttresses. It works also with elements having a face that is less flat, it is just a bit trickier. Fajita Fan 1 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472585 Share on other sites More sharing options...
Fajita Fan Posted February 5, 2020 Share Posted February 5, 2020 I now see why you’re doing that. Also I post from my phone throughout the day, that’s why you see a lot of funky errors in my post as my iPhone’s highly aggressive autocorrect does it’s best to confuse my words. My fingers are covered in glue right now so expect a lot of errors today >_< Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472685 Share on other sites More sharing options...
Black Knight Posted February 5, 2020 Author Share Posted February 5, 2020 Mendi Warrior what sized squares do you use with regards to the textured plexi in your photos, the only stuff I have access to is either 2, 3 or 4mm sizes. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472826 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Share Posted February 5, 2020 Mendi Warrior what sized squares do you use with regards to the textured plexi in your photos, the only stuff I have access to is either 2, 3 or 4mm sizes. Â The one you see at the top of the first picture is 2mm, I have already used quite a bit of it. I also have some 4mm but I haven't used it yet. Black Knight 1 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472845 Share on other sites More sharing options...
Black Knight Posted February 5, 2020 Author Share Posted February 5, 2020 Thanks for the info, looks like 2 is good for stairs and 4 maybe for open floors or walkways. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472852 Share on other sites More sharing options...
Mendi Warrior Posted February 5, 2020 Share Posted February 5, 2020 You are welcome! Â 2 is perfect for stairs, it also has my preference for walkways, both are great for open floors. Also, I currently have a "larger" stock of 2mm and I am planning to use the 4mm for something a bit different. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5472943 Share on other sites More sharing options...
Mendi Warrior Posted February 7, 2020 Share Posted February 7, 2020 New article focusing on the warbringer nemesis https://www.warhammer-community.com/2020/02/07/engine-kill-initial-engagementgw-homepage-post-4fw-homepage-post-3/ Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5473703 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020 I have six more chemical tanks printed and ready for priming as scatter terrain when it’s not cold and rainy. Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5473729 Share on other sites More sharing options...
Guest Posted February 7, 2020 Share Posted February 7, 2020 I have six more chemical tanks printed and ready for priming as scatter terrain when it’s not cold and rainy. You might have said but I am old and forgetful what printer you got? Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5473730 Share on other sites More sharing options...
Emicus Posted February 7, 2020 Share Posted February 7, 2020 Local shop had a bargain bin with a box of reavers and a box of warhounds in it... Â Suffice to say they are on my titanicus pile now :) Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5473760 Share on other sites More sharing options...
Fajita Fan Posted February 7, 2020 Share Posted February 7, 2020   I have six more chemical tanks printed and ready for priming as scatter terrain when it’s not cold and rainy. You might have said but I am old and forgetful what printer you got?It’s a Jellybox 2 kit that we built here. It’s a pretty simple printer made for classrooms but it can do smaller objects okay. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5473854 Share on other sites More sharing options...
Emicus Posted February 10, 2020 Share Posted February 10, 2020 Ordered the new starter and book, had my finger on the nemesis but managed to hold off. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475277 Share on other sites More sharing options...
Guest Posted February 11, 2020 Share Posted February 11, 2020 Got the next 3 Knights primed... Ordered my Starter set and 2 Warbringers.... Â I am really enjoying painting AT as a whoie. Â Will pick my book up soon. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475334 Share on other sites More sharing options...
Fajita Fan Posted February 11, 2020 Share Posted February 11, 2020 I’m really enjoying all the activity in this forum! This is great seeing new posts throughout the day. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475345 Share on other sites More sharing options...
prime-alber Posted February 11, 2020 Share Posted February 11, 2020 Today in titanicus I magnetised three questoris, and I will try to paint them, and some weapons for my warlords Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475451 Share on other sites More sharing options...
schoon Posted February 11, 2020 Share Posted February 11, 2020 Yeah, I was not able to resist, and ordered the Warlord-Sinister in addition to a Warbringer-Nemesis and the new book. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475595 Share on other sites More sharing options...
Mandragola Posted February 11, 2020 Share Posted February 11, 2020 Today I caved and ordered two Warbringers from Dark Sphere. I found that the Astorum transfer sheet is out of stock online, to my great irritation, and I managed to hold off from ordering the starter set on the basis that I really don't need it. But let's be honest, it's just a matter of time. I probably need one more Warhound for my Mortis and the logical choice is to get it with the starter set. That's just maths. Â I'll probably do one Warbringer each for my Mortis and Astorum, and maybe get a Bellicosa one for Astorum if and when it comes out. These two guys and the Psi-Titan I've ordered are already plenty of work for me to do. Gore Crow 1 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475611 Share on other sites More sharing options...
Fajita Fan Posted February 11, 2020 Share Posted February 11, 2020 Yeah, I was not able to resist, and ordered the Warlord-Sinister in addition to a Warbringer-Nemesis and the new book. Â Â Today I caved and ordered two Warbringers from Dark Sphere. I found that the Astorum transfer sheet is out of stock online, to my great irritation, and I managed to hold off from ordering the starter set on the basis that I really don't need it. But let's be honest, it's just a matter of time. I probably need one more Warhound for my Mortis and the logical choice is to get it with the starter set. That's just maths. Â I'll probably do one Warbringer each for my Mortis and Astorum, and maybe get a Bellicosa one for Astorum if and when it comes out. These two guys and the Psi-Titan I've ordered are already plenty of work for me to do. LOL @ both of you, some of you guys are closing in on having as many titans as I do. Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475713 Share on other sites More sharing options...
Dulahan Posted February 11, 2020 Share Posted February 11, 2020 Got my first three Titanicus Models put together - a trio of Questoris Knights I picked up when I pre-ordered the new boxed set from the LGS. Â So it begins. Fajita Fan and wildweasel 2 Back to top Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475714 Share on other sites More sharing options...
Guest Posted February 11, 2020 Share Posted February 11, 2020 LOL @ both of you, some of you guys are closing in on having as many titans as I do. Â Â Am I close? 5 warlords, 2 Warbringers, 7 Reavers and 8 Warhounds? :P Â Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475715 Share on other sites More sharing options...
Sherrypie Posted February 12, 2020 Share Posted February 12, 2020 Â Â Â LOL @ both of you, some of you guys are closing in on having as many titans as I do. Â Am I close? 5 warlords, 2 Warbringers, 7 Reavers and 8 Warhounds? :P Blimey I'm behind y'all with only 4 lords, 3 bringers, 4 reavers and 6 hounds. Most aren't even painted yet :P Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475763 Share on other sites More sharing options...
wildweasel Posted February 12, 2020 Share Posted February 12, 2020 Refreshed tracking on my FW weapons order and told my partner all the different maniples they can use Warhounds in (they really like Warhounds). Link to comment https://bolterandchainsword.com/topic/357462-today-in-titanicus-i/page/22/#findComment-5475764 Share on other sites More sharing options...
