Beaky Brigade Posted May 21, 2021 Share Posted May 21, 2021 (edited) AKA: How I learned to stop worrying and love the drybrushAKA: Ambitious but rubbishAKA: Lore is more what you call guidelines than actual rulesAKA: Paint it any colour as long as it's blackAKA: An idea isn't a project logDisclaimer:This is a General 40k log. I can't see myself sticking with one project for too long at the moment. This will be strange. I'll try and stay visually friendly to the 40k universe, but I will bend the lore as required for my projects. After 15-16 years in the hobby I think I'm entitled to! Think surreal stuff and mixed IP, mostly using GW models.I favour tabletop standard models with a weathered style, no pro painted eye candy here, sorry! I'm currently working on a Space Hulk Genestealer Kill Team and (non Space Hulk!) Kill Team Board/Terrain.I've been busy over the last couple of months. I wanted to start Kill Team with a friend in time for the UK COVID re-opening this week.Dithering with colour schemes and hay-fever fatigue has made me miss the deadline. I'm nearly there though!Test model and test base:I have to find every way not to paint something before I can decide on a colour scheme. After trying a few things with the unused half of the Genestealers I circled back to my original idea of Xenomorph style Genestealers in a very under highlighted style.It's just Chaos Black liberally sprayed on with an all over dry brush of Scavenblight Dinge followed by an all over wash of Seraphim Sepia, which is my new favourite magic wash (Move over Agrax!)I've never been a big nids fan, but I was worried I would never finish my kill team if I went for my usual default of elaborately kitbashed guard regiments or Inqusition warbands. It also seemed fun to play non Imperial with my 40k newbie friend picking Wolves...I've had the 2014 Space Hulk box for a while (Since 2014) and the Hive Mind Started calling to me. Even I could manage to paint 9 monopose Genstealers right?Being monopose models the main challenge during the build was the basing. A good number of the Space Hulk Genies have amazing bits of er, space hulk moulded onto them. I wanted to retain that, but also make the starship parts seem like a plausible part of the base rather than just stuck on.I have some necromunda/industrial bases but It was hard to make the Space Hulk bits blend in. The largest ones didn't quite fit on 40mm bases so I've obtained some 50mm bases, probably the only innovation from Centurions I approve of . In my day you had 25mm slot bases for troops, 40mm for terminators and 60mm for dreadnoughts (and your kid brother with his WFB had square bases). Now days every man and his dog has a custom base size...In the end I used a mix of sand and chopped up sprue to make fine rubble. After becoming more environmentally concious this year I've decided to stop throwing away used sprues (with no option for recycling them in the UK), and use them for basing or scratch builds.I'm planning to top it with an Ice and Snow wash from precision Ice and Snow. So why haven't I finished 9 models in 2 months?The truth? I spent over a month doing a little bit of de mould lining each evening and not much else. I then decided to start the Kill Team terrain as a parallel project, which is a terrible idea! A great secret I learned from a WHC podcast was that the Kill Team battlefield is a similar size to a standard noticeboard size available in the UK.I already had a cork notice board with only 1cm larger dimensions so I used it to create:Crossroads!I chose to make the road a central feature because thought it would be versatile. Add buildings by the road and you have a small city of death. Add some low rise terrain and the same board becomes a rural battlefield.I got the cork sheet from a cork map of the world I no longer needed and used DIY sharp sand. The areas outside the road are deliberately under detailed so the board is more modular with removable terrain and easier to store.WIP and rather good value laser cut buildings from TC combat:I wanted some more ancient ruins rather than the usual bombed out wasteland, so it was always going to be grass or desert on the board rather than the usual grey or scrapyard vibes you see for 40k.In a bit of a marmite decision I chose a 'Summer Flowers' static grass blend from a model railway provider. My first thought was to use dead grass blends, but to do that realistically would have increased the complexity and time budget.In the end I wanted something that wouldn't depress me to look at in these challenging times and something that's certainly different.The road was painted with art shop greys to save money (which I then wasted by using about Edited May 21, 2021 by Beaky Brigade Azekai, BadgersinHills, Silvereyes and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/ Share on other sites More sharing options...
BadgersinHills Posted May 22, 2021 Share Posted May 22, 2021 Looking good! I like the grass on the board, and the genestealers are very beautiful. For the test model perhaps paint the terminator in a complimentary scheme? Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-5702144 Share on other sites More sharing options...
Commisar Necros Posted May 22, 2021 Share Posted May 22, 2021 Stealers are looking good. I feel you, I'm from around the time terminators moved to 40mm. Those bigger bases give you a lot of opportunity to give the models some volume to em. I really love the board. I keep a pretty basic tabletop with movable stuff, but the idea of some super cool fixed terrain for kill team is interesting. May have to steal that idea. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-5702161 Share on other sites More sharing options...
LameBeard Posted May 22, 2021 Share Posted May 22, 2021 I approve of this thread. Terminators on 40mm still feels like a dangerously new-fangled innovation to me. Commisar Necros and Beaky Brigade 2 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-5702299 Share on other sites More sharing options...
Beaky Brigade Posted June 5, 2021 Author Share Posted June 5, 2021 (edited) I've done some more things. I got the Genestealers done to a tabletop standard. Unfortunately my friend has lost interest in completing his kill team for now but I'm still happy I finished mine to a tabletop standard, and will probably find a different opponent eventually. There are a few more details I want to pick out on a 'second pass' at a later date, but I'm out of motivation for now. It's hard to photograph the black effect but I am happy with them. Next up, some buildings from TT combat. Again, for my kill team game that may not be happening! It's the quite good value Broken Domicilium set, and it wasn't too hard to build with simple PVA glue, though the leaded windows were more like building a heavy duty papercraft kit than a wooden model. I think It's clever how they added depth to what would otherwise be a pretty 2d structure. If there are any niggles with the kit it's that you can only fit models with 25/28mm bases through the doors. I'd half finished them with a coat of textured concrete effect spray paint but I felt they were hanging over me preventing me from finishing other models, so I decided to try and finish them in one sitting last night, that went on quite late. They came out much better than they had any right to. Over the grey textured spray paint I applied prodigious amounts of citadel medium and Seraphim Sepia to paint it with a wash, then I drybrushed screaming skull, followed by white. I was annoyed at how the windows were coming out, so I slapped on Nihilakh Oxide, and I think it turned out really well for the low effort put in. Painting terrain is much more fun/ easy than miniatures! These wooden buildings must have gotten to me because I dreamed I was building a model which was half plastic, half hand carved wood. Next up, tiny buildings for AI! Rejected project idea of the day: Loyalist (non rubricked) 40k Thousand Sons chapterRejected sub project of the day: All Librarian Jedi style Primaris Space Marines Edited June 5, 2021 by Beaky Brigade Dr_Ruminahui, Doghouse, Brother Dallo and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-5707210 Share on other sites More sharing options...
Beaky Brigade Posted April 25, 2025 Author Share Posted April 25, 2025 (edited) I keep boring my friends, co-workers, family, passers by on the street etc. with my stream of consciousness related to my miniature projects. If only there was some medium and format for this unhinged habit of mine? This year I've become much more productive with finishing my miniatures; as a result I've spent a lot less time on here talking about miniatures Time to find a happy medium? I am older, wiser and better prepared to actually finish projects. So far this year I have finished a Khorne Blood Bowl team which I'm very proud of but cant share here... I'm rationalising a lot of the 40k collection around my 'Void Dragoons', unaligned guard and abhuman mercenaries that won't feature explicit chaos or Imperial iconography. I'll be able to run them as Opfor or distasteful allies to the Imperium as I see fit... Effectively they will be a Guard/Militarum army with some spiky models and conversions. Luckily a lot of my backlog is IG/AM :) The force currently planned is based on my existing collection, I am a little tempted by a few new things, but I'll try and finish this backlog first... I am very out of touch with the current rules, so the list / organisation is just based on my impressions of a typical guard list from 3rd edition to the present day, rather than a legal list.HQ: * Command Squad (Void Dragoons) * Rogue Trader + Retinue * Primaris Psyker x 2 (Void Dragoons)Troops: * Void Dragoon Platoon Command Squad * Infantry Squad x 3 (Void Dragoons) * Infantry Squad x 2 (Lizardmen)Elites: * Ogryn Squad (minotaurs!)Transport: * Chimera * Rhimera (converted Rhinos?) x 3 * Valkyrie * Valkyrie Sky TalonFast Attack: * Scout Sentinel x 4 (Elysian Drop sentinel)Heavy Support: * Destroyer Tank HunterLords of War: * Stormblade Superheavy Tank It's actually a pretty neat army, I just wouldn't recommend the decade plus acquisition and procrastination process to get this far... The Void Dragoons are a mix of the Blooded kill team set and the Blackstone Fortress traitor guard models. I ended up doing a lot of surgery on the BSF models to create more riflemen from the pistol and CCW minis and remove Chaos symbols or details that were too eccentric for a non chaos cultist. They are super fun but conceiving the paint scheme was a real challenge, with dozens of stripped and repainted test models and dissatisfaction. Because they are all unique in some way, creating a core colour palette was very challenging. For example, the models with fur need a nice contrasting colour for the fur, which doesn't make them look out of place with the models with no fur. And this great contrasting colour then needs to be reserved just for the fur. In the end the sensible option was painting one of the plainer figures, and adding to that palette when a non standard detail was encountered. I had a lot of ideas for the uniform, but it's hard to get away with how fitting the the black armour and tan uniform is. There aren't a lot of other traitor projects online, but they generally go with the GW schemes in some form, corrupted Cadian, or fully devoted to one of the 4 Chaos powers. I had already undercoated the models in Zandri Dust, so it was a no brainer to keep the fatigues in that colour. The weapons were going to be a desert Tan/Coyote Buff type colour , but didn't present enough visual contrast, and a Vallejo Colour I had called Japan Uniform turned out quite pale yellow. I think it works visually and they will be a bit more distressed by weathering and washes in later stages. I've tried to be ruthlessly limited with the colours used, but it is about 24 paints at the current count, though some of that includes the basing etc... I originally had 25 Void Dragoons to finish, but I picked up another Blooded box this week as I was feeling a little GW FOMO. Edited April 25, 2025 by Beaky Brigade deathspectersgt7, space wolf, Farva Ramathorn and 4 others 4 3 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6106614 Share on other sites More sharing options...
Beaky Brigade Posted July 22, 2025 Author Share Posted July 22, 2025 (edited) Just a little update that these fellas are finally finished. That's 5 (Bull) Ogryns and 16 Guardsmen done :) I do have a nice Galaxy Smartphone but I'm still working out how to do Macro photography with it, my last one was just point and shoot but this one is so high res and optimised for people and landscapes that miniatures don't come out right half the time. I'm currently using 'Food' mode, which I suppose is true if your are a Tyranid or Kroot :D Still thinking about what to start next, I have a few things ready to basecoat, I might want a break from infantry... Edited July 22, 2025 by Beaky Brigade Firedrake Cordova, bloodhound23, deathspectersgt7 and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6123609 Share on other sites More sharing options...
space wolf Posted July 22, 2025 Share Posted July 22, 2025 These are looking very promising! Looking forward to more. I like the idea of a universalist theme, they can be thematically then used as either side....have you considered GS Cults as well? Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6123639 Share on other sites More sharing options...
Beaky Brigade Posted July 22, 2025 Author Share Posted July 22, 2025 4 hours ago, space wolf said: These are looking very promising! Looking forward to more. I like the idea of a universalist theme, they can be thematically then used as either side....have you considered GS Cults as well? Thank you! I have thought about a GS cults force that combined the colonial marines and aliens into one army list, not sure it quite works for what I have in mind here, but maybe! I do have a few Space Hulk Genies laying about. space wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6123682 Share on other sites More sharing options...
Silvereyes Posted July 22, 2025 Share Posted July 22, 2025 I really like your crossroads board. I think you're right, it's great to see 40K battlefields that aren't just wastelands or ruins etc. Some colour and more exotic locales can really liven up a game board. Beaky Brigade and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6123765 Share on other sites More sharing options...
Beaky Brigade Posted October 12, 2025 Author Share Posted October 12, 2025 Hey folks, I've been on a building journey having been a bit burned out on painting. I'm running out of kits to build, so surely must whet the brush again before the end of this year... I built up some classic Elysian Drop Sentinels that I've had for ages. Years ago I purchased a platoon sized Elysian force from Forge World but felt massively intimidated by the fiddly resin infantry and clean up requirements. I subsequently sold the infantry (which I don't regret) but kept the gunships and sentinels. I decided to finally build the sentinels, which required a fair bit of cleanup, though mostly went together in a sane fashion, except for the cockpit dashboard covers, which did not fit, and I almost decided to completely remake, until I realised I could break them into pieces and then fill in the gaps. A minor piece of trivia is the plastic components are from two generations of now OOP plastic sentinel kits: The first two had the original plastic sentinel legs, while the last two I bought had the 2010/11 sentinel kit with the extra leg adjustment, which was nice for variety. I considered painting the sentinels to go with my Void Dragoons; but as I made them I felt they were too unique to simply be used as renegade sentinels, so I started thinking about a Imperial Infantry force that could fill in for the AWOL drop troops. One of my friends is a big 3d printing enthusiast and keen for me to commission him, so after dredging the depths of the STL dark web, I found a re-imagining of the classic Storm Trooper models, from before they became Tempestus Scions: I am really happy with these because the designer has genuinely iterated on the limited number of original metal poses, and added all sorts of extras like heavy weapons teams, officers and snipers. I feel like this is a good use for 3D printing since it is a design language for Storm Troopers / Scions that GW have abandoned. To me it toes the line between copying and making something too original that seems out of place with the 40k style. I have commissioned a scary amount of new minis from my friend, and I have based the first 20! Even though I am a keen builder it was refreshing to have a really straightforward assembly process, my friend being a gentlemen had cut away the majority of the supports for me, so it was just a little clean up of the remnants of these and pinning their feet too deal with. A couple of bits may need some minor repair/resculpting but it was very easy. The main thing I have learned is 3D printing is still not quite as simple as drag and drop a picture of the minis you want. The variety of poses available required me to organise the files for my friend and create a spreadsheet to help me keep track of how many of each I was ordering. The process of cutting off a sprue and organising the pieces is re-imagined as computer admin :D In retrospect I would have asked for a minor mod to the feet to include a flat disk to glue them to the bases without needing pinning or greenstuff, or even integral bases. In terms of the cost, it is a little cheaper than a new GW kit, but the price of resin means they are not pennies or throwaway items. After I did this, I went back to plastic models to finish off the last 10 or so Traitor infantry models for the void dragoons. I think this may be enough for me after this, as I am bored of cleaning up the fiddly details, but should have about 35-40 of them. Perhaps I'll paint something at some point! phandaal, Tallarn Commander, MoriyaSchism and 5 others 6 2 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6136305 Share on other sites More sharing options...
Tallarn Commander Posted October 12, 2025 Share Posted October 12, 2025 Your army is coming along nicely. The trooper who is carrying their comrade is a particularly well-done and dramatic sculpt. I do like the old 2000 sculpts of Storm Troopers. From time to time I use them to support my Tallarns. Firedrake Cordova and Beaky Brigade 2 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6136361 Share on other sites More sharing options...
Beaky Brigade Posted December 6, 2025 Author Share Posted December 6, 2025 (edited) Omnissiah! Omnissiah! Omnissiah! Glory to Mars! In November I FINALLY finished building this Stormblade which has been WIP for a scary amount of time. In fact I have a long defunct thread where I started this project. The model was in the 2/3 finished state for a few years, all the resin pieces required significant cleaup and work to fit together, and my dislike of the extra PPE and precautions for resin work and the fiddly nature of the the fitting process had put me off finishing it. It was also hard to justify the time when I had projects with more playable miniatures I could work on. In my original thread, I thought the Stormblade would take the name 'Imperial Sun', but since then, names such as 'Thunderchild', 'Final Victory' or 'Final Liberation' have been growing on me. Why did I decide to finish this after so long? Well, the truth is there is still some gap filling to do, and I'm thinking such a mighty project deserves a diorama base... so it's not finished finished per se, but it's built enough not to feel bad about it any more. I pushed through to finish it off because I took on ANOTHER super-heavy project as a favour for a friend, and I thought it would be stupid to start that without finishing my own tank first. Behold, the magnetized glory of the Imperium! Even though I have a huge backlog, I took on this building project because my friend is painting an AM army for someone who cannot build and paint models because they are partially sighted. My friend is a great painter but was intimidated by the Baneblade box. As an armour nut I was happy to accept this mighty challenge. I watched a few guides on how others had approached the magnetization. I'm personally much happier to have models without interchangeability, I like to have a unique story in mind for each mini, but I can see how people who play regularly want to try different weapons or variants without buying the same kit multiple times. For £120.00 a pop who can blame them? The results have been pretty good, so my stance on magnets may be softening. It is somewhat of an art, and there is not always a single correct way to achieve the desired result, as long as the pieces stick together and come apart. Because the brief was very limited, building just the Baneblade and Shadowsword would have been enough, but I wanted to give a decent outcome. Ambitious magnetization efforts have removable sponsons and take the approach of having lots of smaller magnetized pieces to squeeze every penny out of the sprues. I decided to only magnetize the weapon options and to have fixed sponsons for my own sanity. This approach meant it was going to be tricky to build the Shadowsword / Stormlord hull variants, because it is the same pieces in different places. I got around this by buying another Shadowsword hull and weapons sprue on ebay, which I think was worth it over the extra stress of making the hull transformation work nicely. I did not build the Banehammer or Doomhammer variants. I'm not sure how often they would be picked over the others, and seem very similar in concept to the Stormsword to me :D I'm almost ready to hand the mini over for painting, I am adding some re-enforcement to the underside of the upper hull pieces because they will be potentially fragile when removed from the main hull. Overall the hull swap was easier to achieve than I imagined, only requiring the removal of two tabs on the front glacis plates. The sponsons and sponson turrets ended up being a bit more close to disaster than I prefer but I think they are good enough! The downside of my fixed sponsons is there isn't room to place the troop compartment machine guns on the Stormlord, but I am happy with it. I'm excited to see how it looks when my friend paints it, and how the end client finds the magnetization. It was not my intention to ask for anything in return for this project, but I have been gifted a load of AM sprues to add to my pile of shame! Edited December 6, 2025 by Beaky Brigade Firedrake Cordova, Valkia the Bloody, Dr_Ruminahui and 5 others 6 2 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6145657 Share on other sites More sharing options...
Firedrake Cordova Posted December 8, 2025 Share Posted December 8, 2025 Nice work! On 12/6/2025 at 11:35 AM, Beaky Brigade said: It was not my intention to ask for anything in return for this project, but I have been gifted a load of AM sprues to add to my pile of shame! Are you sure they're not a member here and trying to undermine your Beat the Backlog efforts? Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6145885 Share on other sites More sharing options...
Beaky Brigade Posted December 26, 2025 Author Share Posted December 26, 2025 (edited) On 12/8/2025 at 7:40 AM, Firedrake Cordova said: Nice work! Are you sure they're not a member here and trying to undermine your Beat the Backlog efforts? They could well be! They have always feigned ignorance of this board when I ask them about it, in spite of their many years in the hobby, and time as a GW redshirt... I have been busy on my endless build quest, I was really lucky to get this limited edition model as one of the rewards, which was surprisingly fun to build. I added some extra ruins to a 60mm base as the stock model implies you should attach it to a 40mm to make it gameplay legal, but the relationship between the model and the base is somewhat abstract, either implying it is on a taller platform than is possible for a playable model, or the statue was only over a bust, or partially collapsed. Oddly the Vindicare is part of the platform, but you can assemble the statue facade as a sub assembly for painting... I thought the end result was kind of planet of the apes Edited December 26, 2025 by Beaky Brigade Firedrake Cordova, Tallarn Commander and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/370362-peacehammerhow-not-to-paint-citadel-miniatureswaking-dream/#findComment-6148412 Share on other sites More sharing options...
