Trokair Posted September 8, 2022 Share Posted September 8, 2022 4 minutes ago, A.T. said: Though if it's a keycode we can just try 0451, that usually works :p Or Swordfish 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5864994 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2022 Author Share Posted September 8, 2022 There is a 451, but it's not the code.... Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865038 Share on other sites More sharing options...
Lysimachus Posted September 8, 2022 Share Posted September 8, 2022 (edited) So, if I understand right, the first Security Test will be to try and remove up to 6 wrong answers? Then, we will have 3 chances to pick the right answer. Each time we input an answer we also need to make another successful Security Test. If we get it wrong, the next attempt gets an extra -10 to the Security Test. Is that right? Edit: or is it 3 attempts, and with each attempt we can make a Security Test to try and remove up to 6 wrong answers...? Can we keep using the same Character to make the Tests, or is it one go each? (Up to the 3 guesses, of course) Edited September 8, 2022 by Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865039 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2022 Author Share Posted September 8, 2022 (edited) I apologise for confusion, but it has to be a catch-all to allow everyone to have a try if they want to, however you want to do it (plus I'm doing stuff in between :p ): Anyone can try Can be the same person each time, or a different person each time First test is (+0) (no matter who does it). DoS removes 1 wrong answer, to a max of 5. Attempt required. Second test is (-10) (no matter who does it). DoS removes wrong answers to a max of 4. Attempt required. Third test is (-20) (no matter who does it). DoS removes wrong answers to a max of 3. Attempt required Further: If the person doing the test has Security, they test as normal. If they achieve any DoS (at all), they get + 1, and an extra wrong answer removed. (So, max of 6, 5, 4 etc) A maximum of 1 assist can be given An assist can ONLY be given by a PC with Security Only 1 hand on the panel at any one time! (So no extra assists for canny players who like patty-cake!) Players should narrate their 'hacking' work, subroutine commands etc. (without actually using real terms - that's what jargon is for!) Don't machine gun all your attempts into one post. One Attempt per post, then I will reply, then it goes round again. Does that clear it up a bit? Edited September 8, 2022 by Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865046 Share on other sites More sharing options...
Lysimachus Posted September 8, 2022 Share Posted September 8, 2022 (edited) Very much so, cheers! So, assuming Falk can use his multi-key, he's in the best position to make the Security Tests to remove wrong answers? Restal also has Security so he could provide the Assists? I think, looking at Chargen sheets, that would give Falk targets for his rolls of 72, then 62 then 52? That gives us the best chances of getting rid of the most wrong answers, then we can all offer our thoughts about which answer we want to give for each of the 3 Attempts? (before Falk makes the next roll, if needed) Edited September 8, 2022 by Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865047 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2022 Author Share Posted September 8, 2022 27 minutes ago, Lysimachus said: So, assuming Falk can use his multi-key... It's not a lock, mate, nice try! Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865057 Share on other sites More sharing options...
Lysimachus Posted September 8, 2022 Share Posted September 8, 2022 (edited) 4 hours ago, Mazer Rackham said: It's not a lock, mate, nice try! Seriously though, I'd argue the Multi-key description doesn't specify what form it takes (ie like a literal skeleton key as opposed to a handheld electronic device with a plug-in) and even today there are plenty of locks that don't use keys at all... magnetic locks, electronic locks, code locks, etc, etc. Is it a door? Is it locked? It has to have a lock. ...any of this working...? Edit: imagining the lock in question as something like this (but more grimdark/clunky/big): https://www.amazon.co.uk/Fingerprint-Password-Waterproof-Digital-Controller/dp/B08PD1XMJ6/?_encoding=UTF8&pf_rd_p=130990a8-15b6-435f-b3b3-746d0202a980&pd_rd_wg=qOMqR&pf_rd_r=76SEVX5V6NMKZ6YTHY5T&content-id=amzn1.sym.130990a8-15b6-435f-b3b3-746d0202a980&pd_rd_w=LtRY2&pd_rd_r=6353b709-df5f-4c80-9080-7b0c3ae16681&ref_=pd_gwm_ci_mcx_mr_hp_atf_m Edited September 8, 2022 by Lysimachus Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865086 Share on other sites More sharing options...
A.T. Posted September 8, 2022 Share Posted September 8, 2022 Falks first security attempt up. For efficiency of fate-point usage it's probably a good idea to rotate around anyone with good INT (assuming that is the stat we are using) starting with those that have the security skill for the extra +1 success. The last roll in particular is going to be a stretch even with a reroll. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865092 Share on other sites More sharing options...
A.T. Posted September 8, 2022 Share Posted September 8, 2022 (edited) 19 minutes ago, Lysimachus said: Seriously though, I'd argue the Multi-key description doesn't specify what form it takes (ie like a literal skeleton key as opposed to a handheld electronic device with a plug-in) and even today there are plenty of locks that don't use keys at all... magnetic locks, electronic locks, code locks, etc, etc. All the books I have looked in have reused the same equally vague piece of text. However the online fandom page did have:"A multikey is a device available in the Imperium of Man that is designed to digitally circumvent most forms of electronic security mechanisms." https://warhammer40k.fandom.com/wiki/Multikey Which may save Falk a fate point and make this test relatively easy, or may just be fandom. I guess it kind of makes sense in that almost nothing in 40k is actually locked with a key-lock in the mechanical sense, it's all keypds and ident-wafers, and authorisation cants, and the like. Edited September 8, 2022 by A.T. 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865093 Share on other sites More sharing options...
Mazer Rackham Posted September 8, 2022 Author Share Posted September 8, 2022 (edited) I'm reading the forums, rules and every other thing to get a better handle on it. I am partially convinced that a multikey does what has been suggested, but I am also aware that such an interpretation begins to impinge on Tech-Use. I'm sure that tumbler-designed locks do exist in 40k - especially on backwater planets, or in places where a good, solid lock is economical. (It does not need power, it can be missed in a search etc). It's also my argument for fighter-craft in space, but that's a whole other diatribe... I'm going to make it a special case here, and say that a Multikey would open (run a bypass!/Slice/Rip) electronic locks, or fingerprint readers etc as Lysi/AT state, but here we are dealing with a terminal, with its own innate access structure. It is a secured, non-networked, isolated terminal on a closed circuit. That does provide an option, though. Technical attack could be available with a logic bypass, but the terminal would have to be opened. That would certainly be a Tech Use test, allowing assistance as usual for anyone who has Tech Use, followed by your mulitkey attempt. However - it would be safe (lol) to assume that this being an Inquisition facility, there would be "Surprises" for any failures, and you would only get ONE chance. The first Attempt is already up, so I will let it stand, IF you choose to go that way, but you need to decide as a group how you want to procced, (Password Attempt, or Technical Attack) and I will then be able to present alternative challenges. Because of the nature of the thing, it's either one or the other. If you choose to wait one hour (you know Stitches is coming) he will arrive with you, and you will be in vox range for Bardas, who will inform you he is on the way. An hour after that (so 2 Hours total), he will arrive. Up to you. Edited September 8, 2022 by Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865108 Share on other sites More sharing options...
Lysimachus Posted September 9, 2022 Share Posted September 9, 2022 (edited) Fair enough, boss! 2 hours is a long time to hang around... and OOC I'm quite up for trying to figure out which answer it is? AT has done well to knock out 4 (5 if he spends the FP) wrong answers with his roll, shall we see what they are and then have a guess? Edited September 9, 2022 by Lysimachus Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865167 Share on other sites More sharing options...
Trokair Posted September 9, 2022 Share Posted September 9, 2022 Have we considered trying to explore the accessible part of the complex further and see if that provides any clues, the store room, further down the corridor (if it doesn’t just dead end) and similar? 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865179 Share on other sites More sharing options...
Lysimachus Posted September 9, 2022 Share Posted September 9, 2022 (edited) Another idea that just popped into my head: Ask our GM to remove the first 5 wrong answers, then take our first guess. (Even if we don't get it right, we've knocked out 6 wrong answers out of 15?) Roll Security again (maybe have Restal do it this time and Falk Assist, so it shares out FP spends?) and input a second guess. If still not right, do the third Security roll and see how much further we can narrow it down? But at that point, if we still aren't confident of our third guess, as long as we don't input anything, will anything bad happen? Could we just pause there and wait for Bardas to try the technical attack instead? Just gives us a bit of a safety net to have a go at it, but not then completely stuck if rolls go horribly wrong? Edited September 9, 2022 by Lysimachus 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865188 Share on other sites More sharing options...
Mazer Rackham Posted September 9, 2022 Author Share Posted September 9, 2022 GM: "Ah-ha! My devilish quandary has ensnared the players! So, choose wisely, each path before you has many perils!" Players: "What are our options?" GM: "Option A is difficult, but safer, or Option B is dangerous, but easier! Which shall it be?" Players: "Yes." GM: I did say it was one or the other, gents, but if you want to leverage both, be my guest... 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865249 Share on other sites More sharing options...
Trokair Posted September 9, 2022 Share Posted September 9, 2022 "Burn it, burn it all!" Oops, wrong game, continue :P 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865253 Share on other sites More sharing options...
Lysimachus Posted September 9, 2022 Share Posted September 9, 2022 41 minutes ago, Mazer Rackham said: I did say it was one or the other, gents Oops. Fair enough again, then! Right, in that case, I say let's go with trying to get inside the GM's head and work out the password? Once we take off Falk's 5 wrong answers, it's down to a 1 in 10 on the first guess... then see what happens after that? 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865261 Share on other sites More sharing options...
Lord_Ikka Posted September 9, 2022 Share Posted September 9, 2022 We're all gonna die... 3 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865319 Share on other sites More sharing options...
Lysimachus Posted September 9, 2022 Share Posted September 9, 2022 (edited) Hmm, with MG's successful roll it may not be too bad... If my maths is right: Falk's roll takes out 5 wrong, plus 1 guess makes 6, leaving us at 9 possibles left. Restal's roll just now takes out another 5 wrong, plus his guess makes 6, leaving us at 3 possibles left. If whoever does the last roll can just get a Success, having Security will mean 2 more wrong answers revealed, leaving only the correct answer left! Edited September 9, 2022 by Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865333 Share on other sites More sharing options...
Mazer Rackham Posted September 9, 2022 Author Share Posted September 9, 2022 MG's roll doesn't take into account the Difficulty step of -10 (therefore dropping a DoS) (so 4)...unless you want to use an FP to offset it @Machine God? 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865343 Share on other sites More sharing options...
Trokair Posted September 9, 2022 Share Posted September 9, 2022 As mentioned the other day I’ll be away for two or so week from tomorrow, as such Mazer (or anybody else if you feel so inclined) please pilot Bardas. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865352 Share on other sites More sharing options...
A.T. Posted September 9, 2022 Share Posted September 9, 2022 (edited) MG's original roll was five DoS: 02 vs a target of 23(1), 13(2), 03(3), +2 extra for security and assist = 5 Next up - whoever has high INT and a reroll given that we are at -20, though we could potentially be down to a 50/50 coinflip. Edited September 9, 2022 by A.T. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865365 Share on other sites More sharing options...
Lord_Ikka Posted September 10, 2022 Share Posted September 10, 2022 Nicios is at 38, which would be 48 with assistance but 28 with the negative put in I believe. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865374 Share on other sites More sharing options...
Machine God Posted September 10, 2022 Share Posted September 10, 2022 (edited) I'd already thought about using a Fate Point, but ended up with 6DoS. I forgot about increasing difficulty. I edited my post to spend a Fate Point. https://bolterandchainsword.com/topic/375260-dh1e-the-damocles-contingency-rpg-ic/?do=findComment&comment=5865322 Edited September 10, 2022 by Machine God linky 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865418 Share on other sites More sharing options...
Mazer Rackham Posted September 10, 2022 Author Share Posted September 10, 2022 (edited) I've updated with the extra DoS. Since things are getting sweaty, I'm going to say that Stitches turns up now - but he's been puffing and blowing to get to you. As this is a medical terminal, (as per Ikka/Nicios' suggestion) I will allow Beren to use his full Medicae training to make the test, in place of Security. Edited September 10, 2022 by Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865436 Share on other sites More sharing options...
Lysimachus Posted September 10, 2022 Share Posted September 10, 2022 (edited) Does that mean we're just waiting for Stitches to do it? If we're taking turns, I'm happy to have a go at the last Security Test, but Reynard doesn't have Security Skill so I'll need a roll of 27 to remove 1 wrong answer, or 17 (or 27 plus spend a FP) to knock out both wrong answers? Edited September 10, 2022 by Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/17/#findComment-5865516 Share on other sites More sharing options...
