OD_Templar Posted August 9, 2022 Share Posted August 9, 2022 Just getting back into the hobby after being gone for about 9 years. Making my own chapter that was founded after the first Terran Crusade by the Black Templars and Imperial Fists. Think World War stormtrooper types. Use BT rules. C&C welcome. Plan on adding some fluff as I go also Doghouse, Marshal Reinhard, Kurgan the Lurker and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/ Share on other sites More sharing options...
OD_Templar Posted August 9, 2022 Author Share Posted August 9, 2022 Neophytes gonna redo their tabards and drybrush details eventually Dr_Ruminahui, Warden-Paints, phandaal and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5855144 Share on other sites More sharing options...
OD_Templar Posted August 9, 2022 Author Share Posted August 9, 2022 Incursor Squad "the Fen Jackals" seen as somewhat devious but highly effective Phobos armor is approved for Doom Warden use as it allows them to get close enough to strike foes they may otherwise have to shoot. Eradicators fire support Squad for "opening" enemy armor and fortifications Brothers of the 1st Crusader Squad stationed at the Cape Fear Chapter Keep. phandaal, sitnam, Doghouse and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5855146 Share on other sites More sharing options...
Raziel-TX Posted August 10, 2022 Share Posted August 10, 2022 Neat color scheme. The green really “pops” against gray and black. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5855419 Share on other sites More sharing options...
OD_Templar Posted August 10, 2022 Author Share Posted August 10, 2022 Thank you I originally had a more subdued green but I tried the warpstone glow and ended up liking the contrast more than the muted colors. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5855430 Share on other sites More sharing options...
OD_Templar Posted August 12, 2022 Author Share Posted August 12, 2022 Making some relic terminators and I want options. Nothing a drill can't handle. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5856191 Share on other sites More sharing options...
Doghouse Posted August 12, 2022 Share Posted August 12, 2022 I really like these, the green stands out really well and breaks up the metallic areas nicely. OD_Templar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5856423 Share on other sites More sharing options...
OD_Templar Posted August 19, 2022 Author Share Posted August 19, 2022 On 8/12/2022 at 4:45 PM, Doghouse said: I really like these, the green stands out really well and breaks up the metallic areas nicely. Thank you. I started out with Caliban but there wasn't enough contrast to make the model look good IMO. I then thought about doing castellan green and doing an almost metal and camo blend. This is warpstone with a moot green highlight and I really like the contrast it created. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5858465 Share on other sites More sharing options...
OD_Templar Posted August 19, 2022 Author Share Posted August 19, 2022 Some intercessors from 2nd squad phandaal and Doghouse 2 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5858467 Share on other sites More sharing options...
Raziel-TX Posted August 19, 2022 Share Posted August 19, 2022 Nicely done. Given any thoughts to panel lining the armor and weapons? I find doing so helps add depth to the gear and the model has a whole. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5858553 Share on other sites More sharing options...
OD_Templar Posted August 21, 2022 Author Share Posted August 21, 2022 On 8/19/2022 at 8:39 AM, Raziel-TX said: Nicely done. Given any thoughts to panel lining the armor and weapons? I find doing so helps add depth to the gear and the model has a whole. I have been meaning to I'm a newer painter and I'm not super confident to try. Does drybrushing work? Or do you mean edge highlighting? Brother Chaplain Vallon Doom Wardens 6th company. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5858974 Share on other sites More sharing options...
Raziel-TX Posted August 21, 2022 Share Posted August 21, 2022 Dry bushing will allow you to hit the raised areas somewhat similar in scope to edge highlighting. Panel lining, pin washing and such is were the paint (usually oil because it’s flows much better than water bases) flows into the cracks and crevices. I’m fairly new at pin washing myself but this video helped me out. Video Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5859078 Share on other sites More sharing options...
OD_Templar Posted August 21, 2022 Author Share Posted August 21, 2022 7 hours ago, Raziel-TX said: Dry bushing will allow you to hit the raised areas somewhat similar in scope to edge highlighting. Panel lining, pin washing and such is were the paint (usually oil because it’s flows much better than water bases) flows into the cracks and crevices. I’m fairly new at pin washing myself but this video helped me out. Video Ok I'm gonna try it out on my next batch any suggestions on brands? Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5859197 Share on other sites More sharing options...
Raziel-TX Posted August 24, 2022 Share Posted August 24, 2022 Sorry for the delay. Work has been bananas. I used tamya (spelling?) for the black panel lining. They also make brown, gray, and green as well. If you get some paint thinner, you can clean up any excess/spill over once it drys (which takes a while since it’s oil based). if you want to avoid messing with oils, you can just you a water based wash which does something very similar; they don’t flow as well and stains the layers below if you allow the wash to pool. Hope that helps. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5860153 Share on other sites More sharing options...
OD_Templar Posted February 27, 2023 Author Share Posted February 27, 2023 Finished up my eliminators. phandaal 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5914261 Share on other sites More sharing options...
OD_Templar Posted February 27, 2023 Author Share Posted February 27, 2023 Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5914262 Share on other sites More sharing options...
OD_Templar Posted March 10, 2023 Author Share Posted March 10, 2023 Happy with how my Relic terminators the "Headsmen" turned out. Firedrake Cordova and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5918301 Share on other sites More sharing options...
Mr. Oddity Posted March 11, 2023 Share Posted March 11, 2023 You should be! The squad looks great, your colorscheme works well on the larger Terminator frames. I also really like how they each have a different weapon as their heraldry. Gives them a nice subtle individuality. OD_Templar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5918580 Share on other sites More sharing options...
OD_Templar Posted March 12, 2023 Author Share Posted March 12, 2023 21 hours ago, Mr. Oddity said: You should be! The squad looks great, your colorscheme works well on the larger Terminator frames. I also really like how they each have a different weapon as their heraldry. Gives them a nice subtle individuality. Thank exactly what I was trying to do. Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5918780 Share on other sites More sharing options...
OD_Templar Posted April 24, 2023 Author Share Posted April 24, 2023 Finished up some van vets. Magnets have been very helpful. ranulf the revenant, Grotsmasha, Dr_Ruminahui and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5938832 Share on other sites More sharing options...
ZeroWolf Posted April 24, 2023 Share Posted April 24, 2023 I like the colour scheme you're using here, good work! OD_Templar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5938910 Share on other sites More sharing options...
OD_Templar Posted April 30, 2023 Author Share Posted April 30, 2023 Prepare for orbital drop. New jumplain done Raziel-TX 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5941411 Share on other sites More sharing options...
OD_Templar Posted May 14, 2023 Author Share Posted May 14, 2023 Aggressors WIP ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5947620 Share on other sites More sharing options...
OD_Templar Posted June 2, 2023 Author Share Posted June 2, 2023 Some new infiltrators Boc, Raziel-TX and phandaal 3 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5953896 Share on other sites More sharing options...
Boc Posted June 2, 2023 Share Posted June 2, 2023 Looking really good! Edge highlighting looks very clean and precise This could be because I'm pretty colorblind, but the silver of the body is a little hard to differentiate from the black (more so on the vanguard vets) with it's light edging. Maybe a deeper black with bluer highlights could make it stand out more? Could just be the light source for the photos is just washing it out though OD_Templar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375414-joint-ifbt-successor-doom-wardens/#findComment-5953919 Share on other sites More sharing options...
