TheWarmaster Posted June 4, 2023 Share Posted June 4, 2023 What would you say is the best loadout and role for two squads of Sons of Horus Cataphractii Terminators? One squad will be with Maloghurst in a Landraider and the other will be with a Master of Signals in a Landraider.. Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/ Share on other sites More sharing options...
MichaelCarmine Posted June 4, 2023 Share Posted June 4, 2023 Power-/Chainfists or Thunderhammers. SoH have the freedom of not worrying too much about enemy Str.8 Attacks on the first round of Combat. For budget Terminators, i'd try the new breaching 4+ Tabars =] I think, Justaerin might make most out of 'em, thanks to 3 Attacks and str.6 on the charge. TheWarmaster and Starlight_Wolf 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955044 Share on other sites More sharing options...
Lord Krungharr Posted June 4, 2023 Share Posted June 4, 2023 Whoa where are these Breaching 4+ tabars?! Just for Sons of Horus or other Legions as well? My Space Wolves' Command Squad only had 5+ which failed miserably my last game. Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955199 Share on other sites More sharing options...
MichaelCarmine Posted June 4, 2023 Share Posted June 4, 2023 52 minutes ago, Lord Krungharr said: Whoa where are these Breaching 4+ tabars?! Just for Sons of Horus or other Legions as well? My Space Wolves' Command Squad only had 5+ which failed miserably my last game. Carsoran Power Tabars from the new Siege book. Only for SoH, any model, exchange a Powerweapon for no additional cost. S+1, AP3, Breaching (4+), Twohanded. Starlight_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955215 Share on other sites More sharing options...
The Scorpion Posted June 5, 2023 Share Posted June 5, 2023 Doesn't it have to be a character? Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955534 Share on other sites More sharing options...
MichaelCarmine Posted June 5, 2023 Share Posted June 5, 2023 1 hour ago, The Scorpion said: Doesn't it have to be a character? Nooooope =] TheWarmaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955576 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted June 5, 2023 Share Posted June 5, 2023 What type of Land Raider? Phobos or Spartan?. In my opinion, is always good a mixture of lighting claws and fists/thunder hammers. And, if you can, change combi-bolters for volkite chargers or combi- Volkites. Is quite curious, at least for me, see a front-line MoS. Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5955627 Share on other sites More sharing options...
Starlight_Wolf Posted June 7, 2023 Share Posted June 7, 2023 Load out would depend heavily on intended target, my rule of thumb so far has been: Standard Cata squad into mainline infantry (WS4 or less) Lightning Claws Justaerin squad in to other terminators/WS5 targets Thunder Hammers/Power Fists (Leaning more heavily to Hammers for brutal) For the heavy weapon I tend to lean into Heavy Flamers just for charge shenagins, as you can charge whatever you shoot at, so set up for a cheeky charge into another target by clipping it with the flamer template ;), the others just seem a little too pricey/less effective depending on role in the army. Off the top of my head Maloghurst gives the unit he joins line, so I'd lean towards the new Tabars if going cheap (or 2nd wave), or hammers if you're wanting to go in as a 1st wave force and potentially facing dreadnoughts (avoid them if you're using standard catas, as WS4 vs WS5 really doesn't go well in that scenario) MoS unit I'd suggest again keeping the combi bolters and following the same as above to make the most of the augury scanner (also one of the few instances I'd consider the other two weapons, likely moving to the Reaper autocannon, unless you want to go tank hunting). Also as Agramar queried, would also depend which Raider variant you're taking, as standard I'd go for the Phobos or Proteus unless you're taking Justaerin (as they are locked to Spartans for DTs) or a bigger squad (in which case fill your boots and your Raider :) ) Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5956206 Share on other sites More sharing options...
General Zodd Posted June 8, 2023 Share Posted June 8, 2023 20 hours ago, Starlight_Wolf said: Load out would depend heavily on intended target, my rule of thumb so far has been: Standard Cata squad into mainline infantry (WS4 or less) Lightning Claws Justaerin squad in to other terminators/WS5 targets Thunder Hammers/Power Fists (Leaning more heavily to Hammers for brutal) For the heavy weapon I tend to lean into Heavy Flamers just for charge shenagins, as you can charge whatever you shoot at, so set up for a cheeky charge into another target by clipping it with the flamer template ;), the others just seem a little too pricey/less effective depending on role in the army. Off the top of my head Maloghurst gives the unit he joins line, so I'd lean towards the new Tabars if going cheap (or 2nd wave), or hammers if you're wanting to go in as a 1st wave force and potentially facing dreadnoughts (avoid them if you're using standard catas, as WS4 vs WS5 really doesn't go well in that scenario) MoS unit I'd suggest again keeping the combi bolters and following the same as above to make the most of the augury scanner (also one of the few instances I'd consider the other two weapons, likely moving to the Reaper autocannon, unless you want to go tank hunting). Also as Agramar queried, would also depend which Raider variant you're taking, as standard I'd go for the Phobos or Proteus unless you're taking Justaerin (as they are locked to Spartans for DTs) or a bigger squad (in which case fill your boots and your Raider :) ) Justaerin aren’t able to take Spartans as a Dedicated Transport, they’re limited to LR Proteus or Dreadclaw Drop Pods. Doesn’t stop you giving them a Spartan from the Heavy Support, but I always thought that was very odd! Alternatively there are a couple of ways of giving them Deep Strike… Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5956520 Share on other sites More sharing options...
Starlight_Wolf Posted June 8, 2023 Share Posted June 8, 2023 3 hours ago, General Zodd said: Justaerin aren’t able to take Spartans as a Dedicated Transport, they’re limited to LR Proteus or Dreadclaw Drop Pods. Doesn’t stop you giving them a Spartan from the Heavy Support, but I always thought that was very odd! Alternatively there are a couple of ways of giving them Deep Strike… My bad, I knew it was one or the other, but couldn't remember which way round it was :P Off the top of my head, Deep Strike options would be Horus, Abaddon, a Warmonger Consul or the Black Reaving Row iirc? General Zodd 1 Back to top Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5956584 Share on other sites More sharing options...
TheWarmaster Posted June 16, 2023 Author Share Posted June 16, 2023 (edited) On 6/7/2023 at 11:28 AM, Starlight_Wolf said: Load out would depend heavily on intended target, my rule of thumb so far has been: Standard Cata squad into mainline infantry (WS4 or less) Lightning Claws Justaerin squad in to other terminators/WS5 targets Thunder Hammers/Power Fists (Leaning more heavily to Hammers for brutal) For the heavy weapon I tend to lean into Heavy Flamers just for charge shenagins, as you can charge whatever you shoot at, so set up for a cheeky charge into another target by clipping it with the flamer template ;), the others just seem a little too pricey/less effective depending on role in the army. Off the top of my head Maloghurst gives the unit he joins line, so I'd lean towards the new Tabars if going cheap (or 2nd wave), or hammers if you're wanting to go in as a 1st wave force and potentially facing dreadnoughts (avoid them if you're using standard catas, as WS4 vs WS5 really doesn't go well in that scenario) MoS unit I'd suggest again keeping the combi bolters and following the same as above to make the most of the augury scanner (also one of the few instances I'd consider the other two weapons, likely moving to the Reaper autocannon, unless you want to go tank hunting). Also as Agramar queried, would also depend which Raider variant you're taking, as standard I'd go for the Phobos or Proteus unless you're taking Justaerin (as they are locked to Spartans for DTs) or a bigger squad (in which case fill your boots and your Raider :) ) Doesn't Mal only give Line to a unit IF he is the Warlord though? Edited June 16, 2023 by TheWarmaster Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5960771 Share on other sites More sharing options...
NemoVonUtopia Posted June 16, 2023 Share Posted June 16, 2023 7 hours ago, TheWarmaster said: Doesn't Mal only give Line to a unit IF he is the Warlord though? He has a legion standard that gives line too. Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-5961157 Share on other sites More sharing options...
The Scorpion Posted March 25, 2024 Share Posted March 25, 2024 On 6/8/2023 at 1:14 AM, General Zodd said: Justaerin aren’t able to take Spartans as a Dedicated Transport, they’re limited to LR Proteus or Dreadclaw Drop Pods. Doesn’t stop you giving them a Spartan from the Heavy Support, but I always thought that was very odd! Alternatively there are a couple of ways of giving them Deep Strike… In my opinion this is a non-issue, but only because a Justaerin deathstar is so goddamn expensive that you will struggle to fill your HS slots even after purchasing the Spartan. On 6/7/2023 at 4:28 AM, Starlight_Wolf said: Load out would depend heavily on intended target, my rule of thumb so far has been: Standard Cata squad into mainline infantry (WS4 or less) Lightning Claws Justaerin squad in to other terminators/WS5 targets Thunder Hammers/Power Fists (Leaning more heavily to Hammers for brutal) For the heavy weapon I tend to lean into Heavy Flamers just for charge shenagins, as you can charge whatever you shoot at, so set up for a cheeky charge into another target by clipping it with the flamer template ;), the others just seem a little too pricey/less effective depending on role in the army. Off the top of my head Maloghurst gives the unit he joins line, so I'd lean towards the new Tabars if going cheap (or 2nd wave), or hammers if you're wanting to go in as a 1st wave force and potentially facing dreadnoughts (avoid them if you're using standard catas, as WS4 vs WS5 really doesn't go well in that scenario) MoS unit I'd suggest again keeping the combi bolters and following the same as above to make the most of the augury scanner (also one of the few instances I'd consider the other two weapons, likely moving to the Reaper autocannon, unless you want to go tank hunting). Also as Agramar queried, would also depend which Raider variant you're taking, as standard I'd go for the Phobos or Proteus unless you're taking Justaerin (as they are locked to Spartans for DTs) or a bigger squad (in which case fill your boots and your Raider :) ) What is better in your opinion? Forking out the points to attach a chaplain to regular catas, or upgrading to Justaerin? Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-6030376 Share on other sites More sharing options...
General Zodd Posted March 26, 2024 Share Posted March 26, 2024 22 hours ago, The Scorpion said: In my opinion this is a non-issue, but only because a Justaerin deathstar is so goddamn expensive that you will struggle to fill your HS slots even after purchasing the Spartan. What is better in your opinion? Forking out the points to attach a chaplain to regular catas, or upgrading to Justaerin? I didn’t raise it as an issue, simply pointing out the fact it’s not allowed. Where it might become an issue is in a Black Reaving army, where your Heavy Support options are limited to one fewer than your Fast Attack slots. But then you get Deep Strike on your Justaerin, which I hinted at as a very credible alternative to giving them a dedicated transport in the first place. As for the question about buffing regular Cataphractii vs upgrading to Justaerin, I’d always choose to go for Justaerin. I know it’s 30 points for a termie with power weapon and combibolter vs 50 for a Justy with Carsoran axes and Banestrike bolters and that extra 20 points will really add up, but the WS5 and extra attack, plus potential for Deep Strike I think makes them really solid. Plus their Justaerin, they’re just cool. Link to comment https://bolterandchainsword.com/topic/378847-sons-of-horus-cataphractii-terminator-builds/#findComment-6030525 Share on other sites More sharing options...
