Honda Posted June 7, 2014 Share Posted June 7, 2014 I'm sorry, I just can't type right now..<passes out> Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3711017 Share on other sites More sharing options...
Krikey Posted June 7, 2014 Author Share Posted June 7, 2014 On 6/6/2014 at 10:00 PM, Reinhard said: It's Bootifull! *sniff* You seriously gotta do a tank tutorial at some point. Seriously. And weathering. And the physical wear and battle damge. Just a the shields alone are humbling. Can I get a close up? *saves pictures in inspiration folder* Thank you (and everyone else!) for the kind words. I'll try to do a tutorial sometime reasonably soon, but with my schedule, that may or may not actually happen. I had to postpone my Step 1 exam to the end of June and start an 8-week surgery rotation in the beginning of July, so that puts a damper on a lot of the things I would like to do. However, I do have three Sicarans and various other tanks and flyers assembled and primed, and would really like to get at least a couple done in that small window between Step 1 and the rotation that may very well cause my mind to produce such a vast outpouring of negative emotion that I will be personally responsible for the spawning of a new chaos god. If I can, I'll do the tutorial along with one or two of them. If I don't do it then, I'll be in hiding from forum members screaming "Purge the Unclean!" after they find out I wasn't joking about that new warp god. ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3711056 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 7, 2014 Share Posted June 7, 2014 Worry not brother, hold off the tutorial, you just keep pushing out those gorgeous tanks, your Brothers will hunt you down and slay you like a crazy WITCH help you out, if it comes to you creating a new Chaos God and going wibble . Anything for a Brother. We are Templars, It's what we do. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3711097 Share on other sites More sharing options...
Marshal Reinhard Posted June 7, 2014 Share Posted June 7, 2014 My petty request can certainly wait until more reasonable times. I'm a patient man... most of the time. Good luck to you Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3711117 Share on other sites More sharing options...
Honda Posted June 7, 2014 Share Posted June 7, 2014 "A wise and patient student will observe his teacher and learn." Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3711204 Share on other sites More sharing options...
Krikey Posted June 21, 2014 Author Share Posted June 21, 2014 Mors Ultima Ratio was found in the depths of a machine bunker on one of the outlying planets of the Phall system. On Phall VIII, the crusade discovered a long-abandoned outpost of the Imperial Fists 1st company. Our tech adepts hypothesized that the base was created in haste during a great battle between the Imperial Fist fleet and some unknown enemy. The remnants of a crashed Imperial Fist vessel were found relatively close to the base, and all signs were that the surviving crew created the hidden base to keep war materiel out of the enemy's hands. This particular war machine was discovered on the lowest level of the base -- a great and rusted hulk filling the dark and soundless space. Heraldry and other identifying markers were all but unrecognizable, though a portion of its flank bore the peeling remnants of white and blue. It was thought upon discovery that this flanking plate had been salvaged from another legion during the Horus Heresy, but after more recent events there are whispers to the contrary. The restoration proceeded as normal during the first weeks, but retrofitting of the turret lenses resulted in the unexpected awakening of the Fellblade. The machine spirit was enraged upon activation and its subsequent actions nearly resulted in the loss of Strike Cruiser Nemhain as well as nearly threescore tech servitors. Brother Molifand valiantly struck the deactivation runes within the Fellblade, losing his right arm when security measures attempted to block his actions. Further restoration proceeded only under the vigil of Forge Lord Ulysses, and even then resulted in the loss of fourscore further servitors. The machine spirit has been somewhat tamed, but upon command of Lord Mkallan, the beast may only be unleashed with brother Ulysses in attendance. Images taken from a safe distance follow: Reveal hidden contents ~K edit: Brother Secutanus (the gunner) is wearing an unrepainted suit of ancient power armour during Mors Ultima Ratio's first action with the crusade. This suit's particular machine interfaces are necessary to control the turret. Use of another suit was attempted, but the result was somewhat unfavorable. (It took the servitors several hours to clean the remains of Brother Mkarren's lower body from the gunnery pit.) The suit will be repainted with Brother Secutanus's personal heraldry soon. (In other words, this is my IF Horus Heresy gunner. I have a BT gunner, but he is not yet painted.) Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3725519 Share on other sites More sharing options...
Golf33 Posted June 22, 2014 Share Posted June 22, 2014 Wow. Amazing work, especially the weathering and the lettering. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3725764 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 22, 2014 Share Posted June 22, 2014 Simply stunning, I am in awe of your skills. Again. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726014 Share on other sites More sharing options...
General Disarray Posted June 22, 2014 Share Posted June 22, 2014 Clearly that Fell Blade is super heavy because of all of the awesome you've layered on top of it. Seeing work like this makes me want to do a small HH army whenever Sigismund finally gets a model. The synergy of the BT/IF combo is great and inspiring. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726022 Share on other sites More sharing options...
Marshal Reinhard Posted June 22, 2014 Share Posted June 22, 2014 I fear any words of praise I might offer would offend the mighty beast due to their inevitable inadequacy. Words simply cannot describe it justly. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726024 Share on other sites More sharing options...
Krikey Posted June 22, 2014 Author Share Posted June 22, 2014 Thanks, guys. I really appreciate your kindness. There are a few small details I need to take care of (like the machinery plates on the flank and rear of the turret). I'll post those eventually. ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726130 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 22, 2014 Share Posted June 22, 2014 It's not finished? You Brother have the spark of the Mechanicus in you. It's the only explanation. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726133 Share on other sites More sharing options...
tvih Posted June 23, 2014 Share Posted June 23, 2014 That's certainly one awesome tank! The yellow section works quite well, and the weathering on it looks excellent indeed. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3726838 Share on other sites More sharing options...
Krikey Posted June 30, 2014 Author Share Posted June 30, 2014 Progress report: work proceeds at a slow, but steady pace. Much better than a slow and sporadic pace, I suppose, but I still wish I was a bit faster. I'd like to squeeze in one more vow when this is done. ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733397 Share on other sites More sharing options...
Marshal Reinhard Posted June 30, 2014 Share Posted June 30, 2014 Awesome. I love the half and half IF/Templar thing you got going Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733550 Share on other sites More sharing options...
Krikey Posted June 30, 2014 Author Share Posted June 30, 2014 On 6/30/2014 at 5:47 PM, Reinhard said: Awesome. I love the half and half IF/Templar thing you got going Thanks! I'm working on a 30K Imperial Fists army, and 1st company and veterans will be using the templar iconography, so I feel comfortable using them with my BT force as well. If I had time to play. ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733718 Share on other sites More sharing options...
ValkyrieUndead Posted June 30, 2014 Share Posted June 30, 2014 just wow, read through the whole lot and very inspirational. Hope to get this good at conversions and painting one day! Keep it up Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733723 Share on other sites More sharing options...
HLVW Posted June 30, 2014 Share Posted June 30, 2014 That is a awesome idea using the power cable mount for the heavy bolter as a pintail mount. I may need to try this with my leftovers. To echo the above comments, I really enjoy the imp fist and BT theme and think it will look awesome for 30k. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733731 Share on other sites More sharing options...
Honda Posted July 1, 2014 Share Posted July 1, 2014 Quote If I had time to play. In time brother, in time. Given the alternative, I would rather be able to paint as you do, in preparation of a future of gaming vs. the opposite. The dice will come in their own time. :) Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733827 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 1, 2014 Share Posted July 1, 2014 I share your pain Brother, I have not played for nearly a year, but I have faith. And ZEAL. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733839 Share on other sites More sharing options...
Krikey Posted July 1, 2014 Author Share Posted July 1, 2014 On 6/30/2014 at 10:00 PM, HLVW said: That is a awesome idea using the power cable mount for the heavy bolter as a pintail mount. I may need to try this with my leftovers. To echo the above comments, I really enjoy the imp fist and BT theme and think it will look awesome for 30k.Yeah, I just drilled out a hole and used a short piece of brass rod as a pin to temporarily mount the weapon. That way I can build the other pintle weapon options later on and swap them as needed. The sponson weapons are also magnetized. You can't see in this photo, but the spartan on the right is armed with laser destroyers. The sponsons on my fellblade, glaive, falchion, and spartans all have magnets aligned for interchangeability. ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3733863 Share on other sites More sharing options...
Krikey Posted July 30, 2014 Author Share Posted July 30, 2014 Here is my ETL III 2nd vow, finally finished. Standard disclaimer: I'm never really finished. I have yet to do any but the very beginning of weathering on any of the models. Eventually, the bronze will all have the same patina as is found on the beakie headed model. Also, I'm not yet decided how heavily I'll be weathering the spartans. I don't think I will go as extreme as on the Fellblade, but I'm not sure, so I'm stuck for now. Here they are: "Cypher" -- see the last pic as well. I just realized the beakie-headed fellow is out of focus. And the tabard on the right-side miniature is pretty rough-looking. I'll have to fix it. I've yet to scrawl any text on the crusade and purity seals -- I'll do that later, I hope. I think I need to sharpen up the banner painting a bit. Saddest of all, I haven't written any text on the tanks. MUST. HAVE. TEXT. Maybe after surgery. Staring at these pics of tanks without text makes me feel like they're naked. Anyway, there they are. I hate calling the tanks "finished", but the ETL deadline won't wait. And I'm afraid of getting a private text from Honda -- I'm scared of the red text. I also felt a bit like I was cheating by painting up a gunslinger chaplain and calling it Cypher in disguise, so to diminish that sense of unfairness, I started the following (I still have a lot of work to do, but won't be able to finish him until later): I based the miniature upon this painting (unfortunately, I don't know the artist, so I can't give proper credit): ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3760230 Share on other sites More sharing options...
Firepower Posted July 30, 2014 Share Posted July 30, 2014 And to think I've gone this long without remembering how much I hate you. Good reminder, right here. Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3760234 Share on other sites More sharing options...
Krikey Posted July 30, 2014 Author Share Posted July 30, 2014 On 7/30/2014 at 4:40 PM, Firepower said: And to think I've gone this long without remembering how much I hate you. Good reminder, right here. But ... I haven't even done the plaid yet! ~K Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3760241 Share on other sites More sharing options...
greggles Posted July 30, 2014 Share Posted July 30, 2014 Your work is very inspirational. It makes me work even harder when I paint! Such fantastic work! Link to comment https://bolterandchainsword.com/topic/256175-the-exeter-crusade-foulest-heresy-1mar2016/page/10/#findComment-3760245 Share on other sites More sharing options...
