Interrogator Stobz Posted May 25, 2014 Share Posted May 25, 2014 Nice project you have there Mr Belmo :tu: Looking forward to the resulting excellence. elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3696202 Share on other sites More sharing options...
elmo Posted June 3, 2014 Author Share Posted June 3, 2014 Thanks Bobz :) The vow is moving along slowly. Greenstuffing has been continuing, some base spraying (19 out of 25 models are now bleached bone) but there are a few final bits of converting/tidying up to do before I can spray the remainder and then the detail painting will start next week. I am hoping to crack out 5 a week with characters taking a little longer but we shall see. I am not expecting to have enough time to do a second vow at the moment, but "hope springs eternal Baldrick". Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3706256 Share on other sites More sharing options...
elmo Posted June 3, 2014 Author Share Posted June 3, 2014 I am having to alter the Sgt models as our FAQ means they can only have the sword and stormbolter but I will be using magnets just in case we get another update allowing them to use hammers/shields or claws ;) Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3706650 Share on other sites More sharing options...
elmo Posted June 4, 2014 Author Share Posted June 4, 2014 The DA FAQ does not allow the Deathwing Sgt to take any other weapons than a Stormbolter and Powersword so I have had to play with my initial models which I was planning on having with Thunder Hammers/Storm Shields and Lightning Claws. All the arms will be magnetised so if the FAQ is changed to allow other weapon load-outs I will just be able to swap them over. http://fc01.deviantart.net/fs70/f/2014/155/6/f/deathwing_sgt_1_by_elmo9141-d7kzlm8.jpg This conversion uses the Deathwing Sgt from the Dark Vengeance box set combined with parts from the Deathwing command box. http://fc06.deviantart.net/fs70/f/2014/155/7/0/deathwing_sgt_2_by_elmo9141-d7kzm5j.jpg This conversion uses the Deathwing Sgt from the Dark Vengeance box set but with the sword arm removed and repositioned and the bunny ears have been chopped off along with the feathers behind the skull icon. http://fc01.deviantart.net/fs70/f/2014/155/b/9/deathwing_sgt_3_by_elmo9141-d7kzmfx.jpg This conversion uses the Deathwing Sgt from the Dark Vengeance box with the sword hand repositioned slightly. http://fc05.deviantart.net/fs71/f/2014/155/a/f/deathwing_sgt_4_by_elmo9141-d7kzmkb.jpg This is the standard Dark Vengeance model for those that have not seen it before. http://fc05.deviantart.net/fs71/f/2014/155/4/5/deathwing_hammer_and_shield_by_elmo9141-d7kzmnk.jpg This conversion uses the Deathwing Sgt from the Dark Vengeance box set combined with parts from the Terminator box and a shield from Scibor Work continues Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3707902 Share on other sites More sharing options...
Larhendiel Posted June 4, 2014 Share Posted June 4, 2014 this is a nice shield brother :)I look forard to see even more of your awesome project. But looking through your all blog you must have soo much stuff I do not know where you keep it all! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3707992 Share on other sites More sharing options...
elmo Posted June 4, 2014 Author Share Posted June 4, 2014 The painted models are in two display cabinets and the WIP/unpainted stuff takes up half of another one :( http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0287_zps504ef3bd.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0289_zps56df19d4.jpg Top left: Ravenwing, Deathwing, 4th, 10th and start of 6th Companies, Bottom left: Orcs and Goblins, Bastions, Skyshield, Aegis Top right: Tau Empire Bottom right: Imperial Guard, Magnetised arms and vehicle bits, Spray cans Kierdale, Interrogator Stobz, Prot and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3708110 Share on other sites More sharing options...
Bryan Blaire Posted June 4, 2014 Share Posted June 4, 2014 My Deathwalkers Company Master says to give him his sword grip and position back from your first sergeant posted. :p :D Xenos. :sick: Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3708516 Share on other sites More sharing options...
elmo Posted June 5, 2014 Author Share Posted June 5, 2014 I could not resist borrowing your idea ;) Bryan Blaire 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3708682 Share on other sites More sharing options...
Larhendiel Posted June 5, 2014 Share Posted June 5, 2014 Whaaaaa......... I want one too, wish I had more space in my flat..... Man this is awesome! For a moment I thought I was looking at GW cabinets from Nottingham Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3708816 Share on other sites More sharing options...
elmo Posted June 5, 2014 Author Share Posted June 5, 2014 (edited) I just wish I could have taken a sharper photo The display cabinets are from a well known Swedish furniture company... Update on the DV terminator Sgt #4 I changed my mind. The standard DV pose needed converting! The sword arm has been carefully removed and the joint repaired with greenstuff The bolter arm connection has been filled with greenstuff ready for magnetisation The arm joints on the torso rear have been trimmed and repaired with greenstuff The torso front has the feathers and skull icon removed and the robe will be continued in their place using greenstuff and the bunny ears have been rotated through 90° http://fc02.deviantart.net/fs71/f/2014/156/0/a/deathwing_sgt_4_revisited_by_elmo9141-d7l3htr.jpg Edited June 5, 2014 by Elmo9141 Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3708942 Share on other sites More sharing options...
Isiah Posted June 5, 2014 Share Posted June 5, 2014 Nice cabinets :tu: Looking forwards to seeing those subtle pose tweaks on the final model. ~ I elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3709134 Share on other sites More sharing options...
elmo Posted June 6, 2014 Author Share Posted June 6, 2014 Thanks I. Work has been progressing and the greenstuff and base spray is now complete. I have also pre-drilled a 3mm hole in the torso and 2.5mm (initial) hole in the arms ready for the magnets. I now realise just how much work I have ahead of me :( http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0293_zpsc1d41b5a.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0296_zps4f6db668.jpg The red storm bolters are earlier ones I started but never finished so I will use the ETL as motivation to get them done along with a heavy flamer and plasma cannon for arm swapping later. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3710404 Share on other sites More sharing options...
Bryan Blaire Posted June 8, 2014 Share Posted June 8, 2014 Wow, Elmo, I think you are definitely more obsessive than I am. Also looking forward to seeing how your sword turns out, I altered my pose some so that the sword is being held out away from the body a little more. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3712332 Share on other sites More sharing options...
elmo Posted June 10, 2014 Author Share Posted June 10, 2014 Thanks Bryan. Here is the progress so far... 5 terminator bodies just about done and I am hoping to have their bases and about 10 arms done by the weekend http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0298_zpsccaf347f.jpg JeffJedi, Prot and Larhendiel 3 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3714816 Share on other sites More sharing options...
Bryan Blaire Posted June 10, 2014 Share Posted June 10, 2014 One of these things is not like the other... One of these things doesn't belong... :D Awwww, look, how cute, identical quadruplets and one odd one. Guess which will be Momma's favorite... ;) They look great, Elmo, really like the knee pads' freehand markings, lenses and targeters look awesome, but the parchment looks a tad dark (but it's very hard to distinguish parchment from bone already, dark might be the only way to go). Smashing job! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3714825 Share on other sites More sharing options...
elmo Posted June 10, 2014 Author Share Posted June 10, 2014 They where just the first 5 I picked from the pile, just typical that 4 where clones ;) I normally paint parchment bone so I had to go for another colour with these and it was 50:50 whether it was going to be lighter or darker - I went darker... Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3714836 Share on other sites More sharing options...
Hexagon Sun Posted June 10, 2014 Share Posted June 10, 2014 Haven't popped in here to say hello much recently but thought it high time I did. Your painting discipline never fails to impress me, I know for a fact I'd be ruined after doing about 10 of those terminators never mind 25. Brilliant work so far and your cabinets look amazing. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3714941 Share on other sites More sharing options...
elmo Posted June 11, 2014 Author Share Posted June 11, 2014 Thanks hex :) I have just realised I have cocked up - the holes I drilled in the arms are 2.5mm and the magnets are 2mm. Buggr! I will have to pack them out with greenstuff or loads of superglue. That will teach me to check first :( Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3715339 Share on other sites More sharing options...
elmo Posted June 11, 2014 Author Share Posted June 11, 2014 As I screwed up the arms I decided to start on some more bodies instead. Here are the 4 Sgts after the first evening. I hope to have them done by tomorrow night. http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0300_zps1f4595f6.jpg Larhendiel 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3716069 Share on other sites More sharing options...
Interrogator Stobz Posted June 12, 2014 Share Posted June 12, 2014 Epic work rate Belmo! not a bad standard either ;) Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3717203 Share on other sites More sharing options...
elmo Posted June 12, 2014 Author Share Posted June 12, 2014 Well thank'e kindly Master Bobz :) They are done now but I can only get poor camera phone shots so I will wait till tomorrow night and take a photo of the 9 together. Rather than greenstuffing all the holes in the arms then redrilling them to 2mm I have decided to go the easy way and drill them to 3mm and use the same magnets I used in the torsos so that should save a little time ;) I am planning to paint all the bodies first then all the arms. It will be my own little painting production line and just to paraphrase Henry Ford "You can have any colour as long as it's bone." Alright he said black but RW will be later... Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3717221 Share on other sites More sharing options...
elmo Posted June 13, 2014 Author Share Posted June 13, 2014 (edited) The bodies are painted (less a couple of things I noticed taking the photo) and magnetised with 2 3mm N52 magnets, one for each missing arm/hand. Here are some better pictures however some of the lighter highlighting has been washed out - need to play with the camera settings again. The red chest sword needs a wash in the 4 clones and general tidying up. One of the sgts (Champion) needs his cloak. http://fc02.deviantart.net/fs71/f/2014/164/9/3/wip___deathwing_end_of_1st_painting_week_by_elmo9141-d7m6zrb.jpg Edited June 13, 2014 by Elmo9141 Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3717815 Share on other sites More sharing options...
elmo Posted June 20, 2014 Author Share Posted June 20, 2014 Just to prove that there is progress being made here are the next batch of bodies about 50% done. These should be ready by mid next week then I will start on the last 5 DV DW before the Knights and a big bag of arms :( http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P6200001_zps8f71781c.jpg Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3724701 Share on other sites More sharing options...
elmo Posted June 24, 2014 Author Share Posted June 24, 2014 Next batch of bodies is complete http://th06.deviantart.net/fs70/PRE/f/2014/175/7/5/wip___deathwing_by_elmo9141-d7ns7cz.jpg And here are all the so far completed bodies, only another 5 DV and 5 Knights to do :( http://th03.deviantart.net/fs71/PRE/f/2014/175/6/4/wip___deathwing_by_elmo9141-d7ns7ic.jpg Spaced Hulk 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3728347 Share on other sites More sharing options...
Interrogator Stobz Posted June 24, 2014 Share Posted June 24, 2014 Brilliant work Belmo mate, that is going to be an epic DW force! bobz elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/18/#findComment-3728386 Share on other sites More sharing options...
