miniaturepainter Posted December 19, 2015 Share Posted December 19, 2015 I feel humble - thank you for the praise I did the blades one at a time with the sword one being first which naturally followed on to the remaining wing section on the second blade but the last blade with the angel on initially caused problems as only the tip of the mural would be shown, hence the addition of the text and Angel which happened to fill the space nicely. The dozer blade was first painted green and highlighted then the mural was outlined using a soft pencil as this allows you to correct errors without damaging the base colour. I did not use a template. Once I was happy with the outline I then filled it in using watered down white paint (ended up with 7 coats to get good coverage) then weathered. The only advice I can give is to choose a simple mural which is wide enough to fill the 3 blades and also as the advantage of being able to stand alone on one blade. The 2 examples you have shown would not really work as they are not wide enough. Thinking out loud how about the feather turning into ravens on the left hand blade turning into small ravens in flight in the centre then reforming into a raven on the right?? Add a few Blood Raven icons and it may work.... You will have to try a few sketches till you are happy. To make it easier you could try to print your own decals of different sized bird silhouettes instead of painting them on. Do you have a link to your WIP thread as it would make more sense discussing this there as it is not really DA relevant Yes sir. http://www.bolterandchainsword.com/topic/317178-miniaturepainters-blood-raven-blog/ I'm working on 35 marines for the demi company, then I'll start working on their transports. But once I'm in the saddle I knock them out kinda quick. Since I'm not working at the moment, I have all day to model and paint. I was thinking of doing the Blood Raven icon but it would mimic your style, but then again, I could center the icon on the middle tank and then flush it out to the other sides. Also was thinking about using the feathers on the sides of rhino's. Thanks for the inspiration :) MP elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4256321 Share on other sites More sharing options...
Dark Rage Posted December 19, 2015 Share Posted December 19, 2015 very nice job on those units really like the knee pads and freehand on the contemptor and the terminators. elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4256333 Share on other sites More sharing options...
elmo Posted March 19, 2016 Author Share Posted March 19, 2016 After a short (3 month :( ) break I will be returning to the Calth set after Easter and the first job will be completing the Cataphractii Terminators. My 2 old style Rhinos have had a simple green bath and the 2 Predators are now soaking so these should be making an appearance sometime this year along with a bucket full of Ravenwing and a Demi Company to go along with the 4th. It is all Stobs fault as his Ravenwing are bringing me back to The Rock just in time for the ETL. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4340609 Share on other sites More sharing options...
Interrogator Stobz Posted March 20, 2016 Share Posted March 20, 2016 I'll take that blame. Welcome back Brother Elmo, I can't wait to see what the meatsacks forum has taught you. elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4340914 Share on other sites More sharing options...
Galthan Ironsturm Posted March 20, 2016 Share Posted March 20, 2016 Welcome back Bro' !! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4341085 Share on other sites More sharing options...
Punk possum Posted March 21, 2016 Share Posted March 21, 2016 Woop woop, A "bucket full" of ravenwing and another demi company along with more armour? Sounds like its going to be a good year! Welcome back. elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4341457 Share on other sites More sharing options...
elmo Posted March 26, 2016 Author Share Posted March 26, 2016 Just before I make the grand return to The Rock here is a current update on the state of the "painted" collection which includes some poor photos of my Deathwing, Ravenwing, 4th Company, 10th Company and Armoury plus the Horus Heresy DA - there is also a small appearance by the next company on the list but I have not fully committed to which one it will be, 3rd or 5th? Next up the completion of the Cataphractii Terminators then I may go for some more Ravenwing ;) Raztalin, Dark Rage, Space Truckin and 15 others 18 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4346415 Share on other sites More sharing options...
Interrogator Stobz Posted March 26, 2016 Share Posted March 26, 2016 How much is too much? This is a good starting point for your obsession Elmo, only the rest of the Chapter to go :P :D bs elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4346439 Share on other sites More sharing options...
JJD Posted March 26, 2016 Share Posted March 26, 2016 (edited) It's wrong that I can only like it once. I know it was quite some time ago but when you did your librarian on the bike conversion how much did you cut away from the mid section. Did you keep the Deamon skull belt or the book. Did you have to cut anything away from the waist attached to the bike. Edited March 26, 2016 by JJD elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4346864 Share on other sites More sharing options...
elmo Posted March 26, 2016 Author Share Posted March 26, 2016 It was a long time ago and my memory is not what it was ;) I have had a look at the model and it looks like I had to trim all the fancy bits from the Librarian and trim back the Sgts ammo pouch to get it to fit. Here are a couple of close ups - hope this helps you out :) JJD 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4346891 Share on other sites More sharing options...
JJD Posted March 26, 2016 Share Posted March 26, 2016 That's a big help thanks. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4346900 Share on other sites More sharing options...
elmo Posted March 28, 2016 Author Share Posted March 28, 2016 (edited) I am now committed! Although I did say I had enough to paint I just had to buy some DA decals and one thing led to another and I now have a Dark Angels Battleforce on the way. Nearly a complete 2nd Company to paint now I just can't walk past that shiny plastic stuff.... but who needs to eat anyway? Edited March 29, 2016 by elmo Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4348254 Share on other sites More sharing options...
Master Avoghai Posted March 28, 2016 Share Posted March 28, 2016 *Please note that elmo's magnets are on the way we are just shipping his last order http://i2.photobucket.com/albums/y50/Masteravoghai/Miscelleanous/6c6c5ffbb1c1cdfa3b699ba91c42a9d8.jpg :rolleyes: Spaced Hulk, Brother dean, Punk possum and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4348525 Share on other sites More sharing options...
elmo Posted March 29, 2016 Author Share Posted March 29, 2016 Funny you should mention it but there are a thousand on the way Anyone with a pacemaker please keep clear of this thread Space Truckin 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4348788 Share on other sites More sharing options...
jbaeza94 Posted March 29, 2016 Share Posted March 29, 2016 Where do you buy you're magnets from elmo? I recently bought 300 for about 20 bucks, in curious if I missed out on a great deal Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4348790 Share on other sites More sharing options...
elmo Posted March 29, 2016 Author Share Posted March 29, 2016 I get mine from spider magnets. They have an eBay shop and do freepost to the UK. I have always found them fast and reliable and they do a great bulk discount which is just what I need :) Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4348848 Share on other sites More sharing options...
elmo Posted March 29, 2016 Author Share Posted March 29, 2016 First night back on The Rock and have been using large amounts of Agrax to darken the red casings of the weapons but have mainly been working on the lightning claws and power sword effects. I decided to try something new rather than my previous lightning effect - what do you think? Sorry for the poor photo but it is the best I can do till the weekend and by then the Termies should be complete. Othniel's Blade, Galthan Ironsturm, Space Truckin and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4349482 Share on other sites More sharing options...
elmo Posted March 30, 2016 Author Share Posted March 30, 2016 The Cataphractii Terminators are done but I will save the photos for when I get back to the photobooth on the weekend as the phone camera will just depress me so have a little patience Brothers. Next up will be a Chaplain using the Dark Apostle model - nothing exciting. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4350274 Share on other sites More sharing options...
Lostrael Posted March 30, 2016 Share Posted March 30, 2016 Next up will be a Chaplain using the Dark Apostle model - nothing exciting. just a bit heretical Interrogator Stobz and Punk possum 2 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4350306 Share on other sites More sharing options...
Punk possum Posted March 30, 2016 Share Posted March 30, 2016 First night back on The Rock and have been using large amounts of Agrax to darken the red casings of the weapons but have mainly been working on the lightning claws and power sword effects. I decided to try something new rather than my previous lightning effect - what do you think? Sorry for the poor photo but it is the best I can do till the weekend and by then the Termies should be complete. I think the claws look fantastic and dangerous, which seems right for lightning claws! The power sword I'm less sold on at the moment to be honest to me it looks a bit eldar-ish as is. Now to be fair I like power swords to have a crackling power field look to them so it could just be me. But I think just a little restrained lightning effect on it would help it look a little less crystalline. Feel free to ignore this as it does look nice. Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4350322 Share on other sites More sharing options...
Cypher 102 Posted April 2, 2016 Share Posted April 2, 2016 Something to add to your magnet fetish . . . http://www.belloflostsouls.net/2016/03/geekery-3d-printed-magic-magnets.html elmo and Tygwyn 2 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4352428 Share on other sites More sharing options...
elmo Posted April 2, 2016 Author Share Posted April 2, 2016 Here we go with the first newly completed DA models for ages :( Dark Angels Horus Heresy Cataphractii Terminators Magnetised for all weapons Armless Combi bolters, Chain fists and power sword Combi bolters, Power fists and Power sword Combi bolters, Chain fists, Power sword and Heavy flamer Lightning claws Terminator Sgt Plus the WIP of my HH DA Chaplain About another 2 evenings and he will be done :) Galthan Ironsturm, egon1six, Punk possum and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4352661 Share on other sites More sharing options...
Punk possum Posted April 2, 2016 Share Posted April 2, 2016 Fantastic stuff I love all the little scribble script on the tassets, greeves and pauldrons. The Chaplain is well on the way to awesome too! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4352952 Share on other sites More sharing options...
Interrogator Stobz Posted April 3, 2016 Share Posted April 3, 2016 Yeah, those little green bits are a fantastic touch. Awesome work as usual Brother Elmo! elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4353087 Share on other sites More sharing options...
elmo Posted April 8, 2016 Author Share Posted April 8, 2016 Yay... Chaplain is done :) Now to start building and priming Tacticals for the 3rd Company and the glory of The Lion (and the ETL of course ;) ) Epher, Bryan Blaire, Interrogator Stobz and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/260687-elmos-seemingly-constant-wip/page/26/#findComment-4358641 Share on other sites More sharing options...
