Sons of Mortarion - Pre Heresy Death Guard
Some really sweet stuff you got here Midian!
I really like your Grave Wardens, and I also have a small question about them.
How do you do the chipping?
Sponge, chipping fluid or brush?
Because I can't get the results I am looking for with my chipping fluid and your is more or less the ideal chipping. :D
Thanks Packe ;)
The chipping is done with a torn piece of sponge and Charadon Granite. It's as simple as that. Given the amount of figures i'd end up doing I thought using a brush or chipping fluid would be too labour intensive and probably kill any momentum i'd build up painting them.
This is my favorite interpretation of pre-heresy Death Guard I have seen. Absolutely incredible work with the details and choice of colors.
Thanks Marshal, always nice to get comments like that. ;)
I've edited the first page to include the text below covering how I paint and weather the armour.
How I paint and weather the armour
  • The whole figure is given two undercoats - firstly with grey all over, followed by white sprayed on at a rough 45 degree angle.
  • Once the base colours are on, I use a piece of torn sponge to stipple the armour with Charadon Granite.
  • The figure then gets a coat of gloss varnish.
  • Once the varnish is dry, I make a 2:1 mix of brown and black oil paints, then heavily thin them with white spirit. This wash is applied to the entire figure.
  • After an hour or so drying time, I use a cotton bud to wipe away the wash from the upper surfaces of the armour, leaving the wash in the recesses, and giving a dirty, streaky finish to the white armour.
Cheers guys ;)
Well, I was going to work on another set of Cataphractii but seeing as they decided not to turn up before the postal service ground to it's usual Easter halt, I figured i'd carry on with the Breacher unit. Got the fun ones to do this time instead of the usual bolter fodder so it might be a bit more fun than last time.
Not the most exciting update this evening, just the usual procrastination and thinking about other projects. I have managed to get the transfers on the Breachers and ready for chipping.
  • 2 weeks later...
Finally finished up the Breachers today and im glad to see the back of them to be honest. I've never liked painting anything with shields, let alone a marine carrying one. On the plus side, that gives me my two compulsory troop units when im not using Terminators. I'll probably add another Tac Squad down the road but for now i'll be expanding the Terminator unit before adding a Contemptor and a couple of characters.
  • 3 weeks later...
There's lots of great Heresy/Crusade era DG armies out there, but Yours are hands down the best I've seen. The Grave Wardens are mouthwatering and very inspiring.
Thanks!
Im back today from a trip to London with the wife for our wedding anniversary and found some time to finish up the next 5 Cataphractii. These chaps are added to the 5 done previously to make a mess of anything they roll over.
Also figured it was time to add a HQ choice and had Typhon sat in a box so though it was about time. Had a little accident that sheared off the tiny pipes on the top of his armour, not impressed with that. No survivors from it so nothing left to pin back on.
Not 100% sure on what is coming next after Typhon, though I have got a trio of Primarchs to paint - Mortarion for myself, and Horus and Mortarion for a commission job.
