Nusquams 30k WIP Thread 6/14/17 - Finished Atrapos
Nusquam
I love my Dark Furies. They always end up doing serious work ha.
The battle damage I use foam from my transport case. Take a darker and lighter color and dab it over the area, then take a metallic color and do the same.
The dots on the Furies is actually the blood technical I flicked on.
Some Mor Deythan WIP updates:
http://4.bp.blogspot.com/-OtkwBDMsp6k/VPjpyO-nidI/AAAAAAAABc4/dRd-hVXRMPA/s1600/20150305_183525%2B(800x600).jpghttp://4.bp.blogspot.com/-do6Iv0cVOCI/VPjpyEbbYHI/AAAAAAAABdA/uMlgh2dpbDg/s1600/20150305_183534%2B(800x600).jpghttp://4.bp.blogspot.com/-m2JRuFQVdzQ/VPjpyRqr4WI/AAAAAAAABdk/Gjs6V4yVaV0/s1600/20150305_183559%2B(800x600).jpghttp://4.bp.blogspot.com/-AnDBYbG8a24/VPjpyu56imI/AAAAAAAABdY/IW57ycLCtbk/s1600/20150305_183616%2B(800x600).jpghttp://1.bp.blogspot.com/-rS7tBqTGw0w/VPjpy3qD47I/AAAAAAAABdU/4ISRo1yGBX4/s1600/20150305_183700%2B(800x600).jpg
And the future of their bases:
http://1.bp.blogspot.com/-wMCStQKEe4U/VPjpy7Kh4tI/AAAAAAAABdg/ou3Cpg2fnDs/s1600/20150305_183801%2B(800x600).jpg
I'm kinda looking forward to that medicae. I love the mix of parts on him.
For the furies, the camera is prolly focus struggling. Try putting them on a white background and having the camera auto focus on the head.
Tactical Sarge with his trophy axe:
gallery_72456_10525_192577.jpggallery_72456_10525_127426.jpggallery_72456_10525_148321.jpg
Chooser of the Slain for the Dark Furies:
gallery_72456_10525_81558.jpggallery_72456_10525_43486.jpggallery_72456_10525_170271.jpg
For the Primus Medicae I'm debating his final loadout. My one consul slot is usually spent on a Chaplain. It's hard for me to make a list that doesn't use Decapitation Strike.
I have to admit, if I was going to steal one thing from you it would be the patterning on the Mor Deythan. I may even do just that and title it Nusquam-pattern decoration or something. It works really, really well. Continuing it on the bare skin of the Shade was inspired.
I generally avoid greenstuff and focus on hack and slash conversions and creative posing to make my models stand out, so your Chooser of the Slain really speaks to me.  You've posed him beautifully, in a way that tells a story.  I was immediately able to picture him running alone through the smoke-covered Isstvan dropsite, frantically scanning for targets amidst the burned out wrecks and trying to regroup with his brothers, still reeling from the shock of betrayal.
I picked up a rigger brush (not quite as long as your liner, but similar) to make a Nusquam-Pattern Freehander (henceforth to be referred to as a Nusquamder or NPF--your choice). You mentioned the ratio of paint-to-water being tricky, yeah? Any tips? I know I'll want it a bit thinner than regular, but I'm not sure quite how thin. And you're just thinning with water, not Lahmian Medium or anything, right? Anyway, I've got some freehand work calling my name and I want to give this a shot so any advice would be stellar.
Thanks for the idea! You've been using the NPF to powerful effect on these guys and they're looking excellent.
I practiced on some pieces of paper first. It'll be different for each brush, it just takes some test runs to find the right ratios. Also use 'base' paints, they're more opaque and forgiving when thinned down with water. And yeah, just using water. Medium might not be a bad idea, but water being thinner it was my first choice, but it might be worth a test. I'm just low on mine.
Practice practice! It took me a few tries to get it right, but it was fun and worth it.
  • 8 months later...
It's been a while but I'm finally able to get some work done on my XIX.
I grabbed two of those Calth boxes and I am in love with them. Here is a WIP blast. I jsut got the transfers and volkites today so now I'm about to go nuts with them. The unpainted contemptors arms are swap-able so he can be anything I need.
20151127 204054
20151127 203513
20151127 202803
20151127 202239
20151127 144543
20151126 192134
20151126 191456
20151126 191442
20151126 191429
20151121 002314
20151119 161903
20151118 204346
  • 2 weeks later...
The Viper... I mean Xiphon looks really good in Raven colours. Alot of great kitbashes and the OSL for the Tactical's plasma guns is impressive. The only thing that's niggling me would be the mold lines on the Tactical's arms (although I assume those will be dealt with at some point).
Thanks!
I couldn't even see the line until the blown up pic. I have terrible lighting in my new place as I slowly acquire furniture and lights ha. I had only just found my painting lamp a few days ago. Glad you pointed it out.
Looking great. How do you rate the RG transfer sheet? Worth getting?
I'm divided on it.
Pros:
  • Gorgeous decorative transfers (banners, raven skulls etc)
  • Wide variety of unit types
  • Cool lines of RG themed mottos (Victorus Aut Mortis, Umbra, etc)
  • Variety of command and veteran symbols
Cons:
  • Unit designations come in groups of 4, not 5, per color; So you can't even have a minimum number unit with matching designations.
  • Theres some weird bronze color I'm not really a fan of. I can't tell if it's growing on me or I'm just accepting it
  • Not enough plain raven symbols. So if you have a lot of bodies you'll need to get more or make your own dedicated to the plain raven symbol.
  • they are really thick and its much harder to get them to appear 'painted-on' and not show the edges
If there was an easy way to do white decals I would do it myself. I think its great if you want some bling transfers, but to fill out numbers beyond 20 tacticals its not going to go far.
To clarify i mean unit markings without the reticle and XIX underneath; those are special designations
  • 1 month later...
I applaud your sensible decision to put a helmet on Mr. Corax there. It should have been standard for all the Primarchs to come with the option of a suitably ornate helmet.
Thank ye, I agree. I also plan to paint designs on it like the ones on his gorget.
Wow I love the viper xiphon! Also that helmet looks fantastic on Corax! I'm very surprised a normal helmet would fit, I assumed it would look too small but it looks pretty good!
The Xiper was a lot of fun. His head is actually pretty small, it's the size of the dark fury bare head with respirator; it's all that hair that makes it look bigger haha.
