MikhalLeNoir Posted August 21, 2016 Share Posted August 21, 2016 You forget that Alexos is a scientist as well. A year back, I think the foundation of his cloning attempts was quarith tech and xenos tech improved later from the cognis with daemonic powers. So a totally different situation. And, if we go with the corax cloning, then I can't see how the hidden clone troopers can blast away the loyalists eagles and a warden fleet. This is not space invaders. The whole construct with the clones surprise attack is then flawed and we need to return to only Alexos opens fire on the wardens. No loyalists, no clones. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474210 Share on other sites More sharing options...
bluntblade Posted August 21, 2016 Share Posted August 21, 2016 (edited) Damnit, we really are dealing with too much stuff for me to hold in my head. I'm leaving all this stuff on hold and delving back into Book 1. We never said it'd be only clones. It'd be those original Eagle Warriors Alexos has swayed, those recruited in secret by the outrider fleets and the clones. Edited August 21, 2016 by bluntblade Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474216 Share on other sites More sharing options...
~Drakzilla~ Posted August 21, 2016 Share Posted August 21, 2016 If you guys are going to make rules for these clones, keep in mind that the Warriors of Peace have their own corps of less-trained, easy-to-produce space marines. Not clones per se, but similar enough concept that we should avoid overlap. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474219 Share on other sites More sharing options...
Sigismund229 Posted August 21, 2016 Share Posted August 21, 2016 @Mikhal: I thought it was Poseko who was the scientist? AO, clarification is needed. They were designed using Qarith organs found within their warriors(some EW were implanted with them as well but not nearly so many). And I could easily see them being made with deamonified tech. Deamonculba/Deamonic Vitae womb anyone? And I mean, when they're only really intended as cannon fodder who cares about quality? Just augment them with bionics and combat drugs and hurl them at the enemy. I'm not gonna comment on the clone's numbers, although I think 400k is too high. But "true" Eagle Warriors shouldn't number above 150k in the whole legion at Terra and even that is bit iffy. It all depends on what the EW are doing during the Insurrection, seeing as we know they fight in the Blood Crusade but have no idea how many(personally I think they should be present in almost full strength) or what else they do. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474222 Share on other sites More sharing options...
bluntblade Posted August 21, 2016 Share Posted August 21, 2016 To clarify, Alexos was always going to have the bulk of his true Astartes on his side against the Loyalist EWs. The clones I intended mostly to serve as easily replaced soldiers for the outriders while they built up their numbers. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474223 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 21, 2016 Share Posted August 21, 2016 @Mikhal: I thought it was Poseko who was the scientist? AO, clarification is needed. Alexos has been one of the main scientists even before poseko was added to this project. He learned it in his early years and honed it during his 60 years of normal leading, he became even better during the insurection, its almost his main trade To clarify, Alexos was always going to have the bulk of his true Astartes on his side against the Loyalist EWs. The clones I intended mostly to serve as easily replaced soldiers for the outriders while they built up their numbers. most loyalist EW's became the base organ donors for the new clones, they were not killed, they were sacrificed, and proceededly used to supply base organs and the likes for the clones. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474228 Share on other sites More sharing options...
Sigismund229 Posted August 21, 2016 Share Posted August 21, 2016 Hmm. So he is both a scientist and a preacher? Seems a bit strange but then he does have two different personalities... Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474233 Share on other sites More sharing options...
MikhalLeNoir Posted August 21, 2016 Share Posted August 21, 2016 (edited) To clarify, Alexos was always going to have the bulk of his true Astartes on his side against the Loyalist EWs. The clones I intended mostly to serve as easily replaced soldiers for the outriders while they built up their numbers.Using standard tech they are not easily produced. I think AO will answer and clarify things when he has time. I bet he is atm cloning enough marines with paint to show us that we all are false amd he has a couple of million eagles on reserve. @Drak: yep, if there ever will be rules, it should ne avoided that they are to close to the peons. Maybe adding a simple rule: unstable. Every round after round x has to be made a test. For every squadmember throw a dice. For every dice showing a 1 remove a member from the unit amd instead place a large blast over them. Every enemy unit who is touches it jas to make an ld test. If failed they are slipping on the remnants , are vommiting because of the disgusting scenes or cleaning their visors amd weapons because of the gore spread over them. They can't move, shoot or take cover this round. Except for berserkers of uran, they rejoice and get +1A. BLOOD FOR THE BLOODGOD Damn AO108 you ninjaed me. And yes the one personality seeks god as answer the other wants to get answers.with science. Makes sense Edited August 21, 2016 by MikhalLeNoir Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474235 Share on other sites More sharing options...
Grifftofer Posted August 21, 2016 Share Posted August 21, 2016 If you guys are going to make rules for these clones, keep in mind that the Warriors of Peace have their own corps of less-trained, easy-to-produce space marines. Not clones per se, but similar enough concept that we should avoid overlap. I can't remember if I mentioned it before or not. But my suggestion for having clone armies would be to use the Militia army list with the Gene-crafted and Survivors of the Dark Age Provenances. That way you can get troops (Grenadiers) with WS3, BS4, S4, T3, W1, I4, A1, Ld7, Sv3+ for really cheap, which to my minds fits quite well with a clone army. If you were willing to not have 3+ armour you could take either Warrior Elite or Feral Warriors for either +1Ld or +1WS Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474239 Share on other sites More sharing options...
bluntblade Posted August 21, 2016 Share Posted August 21, 2016 Mikhal, I only meant easily compared to Astartes (and quickly produced). Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474244 Share on other sites More sharing options...
Sigismund229 Posted August 21, 2016 Share Posted August 21, 2016 For the Blood Crusade, how many maries will tge Eagle Warriors committ? 150k? It should be a relatively large force seeing as, while Alexos is there to secure Raktra's allegiance to Khorne, the strategic reasoning for it is that Icarion wants to remove the Lions from the playing field and the 'serkers wouldn't be enough to do that on their own. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474255 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 21, 2016 Share Posted August 21, 2016 around 100k of wich 40k clones. The eagles want to have raktra do the main work, as they are well suited for that, the eagle warriors are there to support, and call in HUGE swathes of cognis armies Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474261 Share on other sites More sharing options...
bluntblade Posted August 21, 2016 Share Posted August 21, 2016 And you don't want to break Khorne's favoured Legion in the process. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474263 Share on other sites More sharing options...
bluntblade Posted August 21, 2016 Share Posted August 21, 2016 most loyalist EW's became the base organ donors for the new clones, they were not killed, they were sacrificed, and proceededly used to supply base organs and the likes for the clones. That would have to be done carefully and in the utmost secrecy. How many companies are left under Takar for PR/smokescreen purposes? Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4474619 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 22, 2016 Share Posted August 22, 2016 about one spear, wich is 10k men, enough to quickly conquer alot of worlds with the help of the cognis, making it look like a huge force, but actually not that big. Most of those become black shields after the insurection and during Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475136 Share on other sites More sharing options...
bluntblade Posted August 22, 2016 Share Posted August 22, 2016 We've established the Blackshields bit. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475146 Share on other sites More sharing options...
simison Posted August 22, 2016 Author Share Posted August 22, 2016 Slips, we have a suggestion to ask that the Special Projects sub-forum be able to participate in ETL as it's own participant. I thought that the request might have a better chance if either you or I made the request since I'm kind of a half-breed Moderator, while you're a full one. Which one of us would have the better chance? Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475641 Share on other sites More sharing options...
MikhalLeNoir Posted August 22, 2016 Share Posted August 22, 2016 Whoooo. An own etl entry. Finally incould paint my minis amd it has sense. Beeing kinda homeless is awful. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475653 Share on other sites More sharing options...
Slips Posted August 22, 2016 Share Posted August 22, 2016 Slips, we have a suggestion to ask that the Special Projects sub-forum be able to participate in ETL as it's own participant. I thought that the request might have a better chance if either you or I made the request since I'm kind of a half-breed Moderator, while you're a full one. Which one of us would have the better chance? Probably you since you're the project lead. Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475663 Share on other sites More sharing options...
simison Posted August 22, 2016 Author Share Posted August 22, 2016 Got it, it's Semper who I ask, right? AlphariusOmegon108 1 Back to top Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475673 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 22, 2016 Share Posted August 22, 2016 Got it, it's Semper who I ask, right? yeah Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475674 Share on other sites More sharing options...
MikhalLeNoir Posted August 22, 2016 Share Posted August 22, 2016 AO alone will win us the cup. He is a daemonengine with integrated airbrush and detail brush. We will be unbeatable so long as he is around. ~Drakzilla~, AlphariusOmegon108, bluntblade and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475678 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 22, 2016 Share Posted August 22, 2016 AO alone will win us the cup. He is a daemonengine with integrated airbrush and detail brush. We will be unbeatable so long as he is around. I hope to do about 10k points Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475684 Share on other sites More sharing options...
MikhalLeNoir Posted August 22, 2016 Share Posted August 22, 2016 Per day!!!! AlphariusOmegon108 1 Back to top Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475686 Share on other sites More sharing options...
Doctor Perils Posted August 22, 2016 Share Posted August 22, 2016 Wouldn't it be possible to count them separately, in the same way as the Liber vows? Link to comment https://bolterandchainsword.com/topic/311978-general-discussion/page/128/#findComment-4475763 Share on other sites More sharing options...
