Dosjetka Posted December 13, 2017 Share Posted December 13, 2017 Don't have any excuses left not to get a Glaive soon! Cheers for doing this, mate. Excellent work. :tu: Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4958664 Share on other sites More sharing options...
Cadmus Tyro Posted December 13, 2017 Author Share Posted December 13, 2017 Lovely armies - is the alpha legion serpent on your vehicles free handed? Very impressive regardless!Thanks mate, I wish my freehand was that good! They are just the alpha decals cut down to fit. The Glaive is probably my single favorite FW model, and I've restrained myself from getting one until this point. I am eagerly looking forward to your build log for the day when I have my own to tackle!Cheers. It’s a beautiful model and a well designed kit. I hope this blog inspires you to build your own! Don't have any excuses left not to get a Glaive soon! Cheers for doing this, mate. Excellent work. :tu:Do it! Which legion would you go for? Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4959014 Share on other sites More sharing options...
Dosjetka Posted December 13, 2017 Share Posted December 13, 2017 Don't have any excuses left not to get a Glaive soon! Cheers for doing this, mate. Excellent work. Do it! Which legion would you go for? http://www.bolterandchainsword.com/topic/341876-1500-points-iron-hands-head-of-the-gorgon/ It's mostly definitely your fault. ;) Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4959039 Share on other sites More sharing options...
Cadmus Tyro Posted December 13, 2017 Author Share Posted December 13, 2017 Ha ha! For the Iron Xth! Will you be attempting the metallic FW scheme? Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4959055 Share on other sites More sharing options...
Cadmus Tyro Posted December 16, 2017 Author Share Posted December 16, 2017 Evening all, I’ve finished the next phase of the Glaive, the tracks. This phase of the build really shows the limitations of working with resin. Step 8: Before you start laying the track, pay attention to the piece of plastic on the side of the baneblade hull. The tracks have cut away sections and are designed to sit on top of this piece of plastic. However, unless you have lined up the hull pieces perfectly, they won’t sit flat. I learned this the hard way and had to take the track section off to rectify the problem. Simply remove the piece of plastic, this will help the tracks to sit straight. Step 9: All the pieces of track are labelled L+R 1-7. I would suggest building the top tracks (pieces 1-3) first to try and get them symmetrical before you move on to the bottom of the tank. Lay the first piece of track labelled L/R 1, it slots under the upper hull plate. Then you need to glue this piece: to the front of the hull. It will require a little bit of work to make it fit. The piece houses the front wheel (L/R 3), I would suggest you fit the front wheel (without glueing it in place) before you glue the above piece to the hull. You will end up with this: The front wheel is free to move, making it easier to get things lined up. Just line up the second track piece. When you are happy with the position glue it in place. Then move the front wheel/track into position, apply some glue to the track and when you’re sure the position is correct, apply some more glue to the axel. Repeat the above process on the opposite side. Before you move onto the underside of the tank I would observe the model from the front. If the front wheel isn’t quite straight, you can use a little hot water to straighten the wheel on its thin axel. Step 10: Turn the tank over, you need to apply the plastic bane blade wheels to the resin hull. It’s fairly obvious where they go. Before you fit them, remove the plastic pegs. Once they are in position I would also suggest you remove the pegs on the inside edge of each wheel. The foremost wheels on the above picture still have the plastic pegs in place, the others have been removed. The kit is designed to work around this but I found they limit the track positioning. Which isn’t helpful. Step 11: Lay both track pieces 4+5. Track piece 6 may need a little work to let it sit flat (even then it will protrude a little above the rest, just take a look at the forgeworld Legion Glaive). Finally, glue the rear wheel in position so it sits true with the hull. I had a few issues at this stage getting the rear wheel square on with the hull. Well, that’s the tracks done! I only glued my finger to the tank once during the process! Good luck ;) Cadmus Khornestar, robofish7591, Dosjetka and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4961414 Share on other sites More sharing options...
Dosjetka Posted December 16, 2017 Share Posted December 16, 2017 Ha ha! For the Iron Xth! Will you be attempting the metallic FW scheme? No, I'll most probably be going with a solid black or the one they used on Ferrus' armour. Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4961418 Share on other sites More sharing options...
Cadmus Tyro Posted December 16, 2017 Author Share Posted December 16, 2017 Ha ha! For the Iron Xth! Will you be attempting the metallic FW scheme? No, I'll most probably be going with a solid black or the one they used on Ferrus' armour. I’m sure it will look awesome! Any ideas which clan? Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4961420 Share on other sites More sharing options...
Cadmus Tyro Posted December 17, 2017 Author Share Posted December 17, 2017 So, quick community poll if you don’t mind everyone. I’m busy adding all the hull detailing to the Glaive and I need to make a decision. The hull mounted twin heavy bolters can be swapped out for a twin heavy flamer. Now I have the heavy flamers left over from the leviathan kit and I’ve seen a Glaive online and it looks great with heavy flamers instead, it’s just a subtle difference but I like it! (Just google Glaive heavy flamers and you will find a beautiful IF Glaive equipped with them) The issue I have is why, from a gaming perspective, you would ever want to swap out the heavy bolters? Neither option is likely to contribute much to the game, but the heavy bolter seems a more practical choice. Should I apply rule of cool here? Your opinion please ladies and gentlemen! Cadmus Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4961844 Share on other sites More sharing options...
binary Posted December 17, 2017 Share Posted December 17, 2017 Rule of cool definitely, and I’ve always though flamers were a better close in point defence weapon than heavy bolters Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4962035 Share on other sites More sharing options...
ephrael Posted December 17, 2017 Share Posted December 17, 2017 I would definitely go for the heavy flamers. They look better than the heavy bolters, it will be fun to surprise someone by cooking s unit with them and you’ll have the opportunity to add some cool scorching effects to the front of the hull. Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4962078 Share on other sites More sharing options...
Dosjetka Posted December 17, 2017 Share Posted December 17, 2017 Heavy flamers. :tu: Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4962221 Share on other sites More sharing options...
Cadmus Tyro Posted December 18, 2017 Author Share Posted December 18, 2017 Cheers folks, looks like it’s heavy flamers by unanimous decision. The polls not closed until the hobby saw comes out tonight though! Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4962549 Share on other sites More sharing options...
Cadmus Tyro Posted December 19, 2017 Author Share Posted December 19, 2017 Flame on! It think the leviathan heavy flamers work, what do you think? Cadmus Dosjetka, Kizzdougs, Ovidius Incertus and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4963904 Share on other sites More sharing options...
ephrael Posted December 20, 2017 Share Posted December 20, 2017 They look perfect in there! Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4964031 Share on other sites More sharing options...
hushrong Posted December 20, 2017 Share Posted December 20, 2017 Oh boy does that look good! Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4964111 Share on other sites More sharing options...
Bjorn Firewalker Posted December 20, 2017 Share Posted December 20, 2017 You demonstrate good imagination in mounting a twin-heavy flamer in the Glaive's hull. Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4964132 Share on other sites More sharing options...
Cadmus Tyro Posted December 20, 2017 Author Share Posted December 20, 2017 (edited) Thanks guys, your feedback/comments are much appreciated.The rest of the build is fairly simple. Only a couple of points to take note of. I will post a few pics of the build when I’ve finished the hull! Cadmus Edited December 20, 2017 by Cadmus Tyro Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4964430 Share on other sites More sharing options...
Brother Pheidias Posted December 20, 2017 Share Posted December 20, 2017 I am eyeing up a glaive, think I'll have to get me some of them flamers as well.Am I the only one saddened by the fact that we can't mount a twinlinked Culverin in the hull? Think I might do it still. Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4964806 Share on other sites More sharing options...
Cadmus Tyro Posted December 21, 2017 Author Share Posted December 21, 2017 I am eyeing up a glaive, think I'll have to get me some of them flamers as well. Am I the only one saddened by the fact that we can't mount a twinlinked Culverin in the hull? Think I might do it still. A white Scars glaive would look awesome! Do it! Culverins might be too big for the space, but the twin linked calivers from the leviathan kit would work really well ;) Brother Pheidias 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4965546 Share on other sites More sharing options...
Cadmus Tyro Posted December 23, 2017 Author Share Posted December 23, 2017 Evening all, I’m up to the hull detailing and turret work with the Glaive. First up the hull. There’s no point in offering up a step by step guide here, it’s fairly straight forward. But there are a couple of small things to be aware of. 1 - the rear track guard should be placed with the rivets facing out. 2 - there is a slight flaw in the design of the barrels. The injection mould will be on the top of the barrel, therefore clearly visible. Mine were really poorly cast, I just removed the feet and turned it around. This way the mould line is no as visible. 3 - there are three different sized plates that join the top plate to the sponson armour. Make sure you get them the right way round! This is my second attempt: There you have it! The hull is complete, I’ll add the turret pics tomorrow and then it’s just the sponsons! Cadmus Kizzdougs, hushrong and Dosjetka 3 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4966937 Share on other sites More sharing options...
Cadmus Tyro Posted December 27, 2017 Author Share Posted December 27, 2017 Evening all, So the turret is done, it needed a lot more work than I originally thought. It’s an obvious build, in terms of pieces, but I ran into a few issues: 1 - The first thing I struggled to fathom was whether the Carronade was meant to move. The Carronade sits in the turret and can, if you want it to, move up and down. But the top plate prevents any movement when glued in place... Also, if the Carronade isn’t glued in position, gravity means the gun will not fall level with the hull of the tank. My advice, glue it! 2 - The next issue was that of the turret sitting level on the hull, both the left and right sides sit slightly proud of the hull creating large gap. It needed a lot of sanding. 3 - the main issue for me was turret clearance. The Carronade hits the front hull sensor (the one above the hatch) as it rotates left. To solve this I placed a small piece of plasticard under the Carronade before gluing the gun in position. Secondly, I filed the base of the Carronade and the first coil. The coil was then partially rebuilt with green stuff. The sensor was also filed down as much as possible without losing detail. Now you can (just about) see the turret clearing the hull sensor. Almost there guys! Is it worth adding a quick sponson tutorial? C&C welcome! Cadmus Dosjetka, hushrong and Dantay VI 3 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4969102 Share on other sites More sharing options...
Dosjetka Posted December 28, 2017 Share Posted December 28, 2017 Fantastic. Thank you for taking the time to do this! A sponson tutorial would be great if you've got the time. :tu: Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4969316 Share on other sites More sharing options...
Dantay VI Posted December 28, 2017 Share Posted December 28, 2017 Awesome tutorial on building a Glaive, and really nice work on your Alphas and Iron Hands Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4969416 Share on other sites More sharing options...
hushrong Posted December 28, 2017 Share Posted December 28, 2017 Happy to see progress on that beast! It's also very awesome you posted those pictures with tips. There have been a fair few times where I would be building something, hit a wall, and struggle to look up how someone else did it. And for some reason I want a glaive too... Cadmus Tyro 1 Back to top Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4969430 Share on other sites More sharing options...
Cadmus Tyro Posted December 28, 2017 Author Share Posted December 28, 2017 Fantastic. Thank you for taking the time to do this! A sponson tutorial would be great if you've got the time. :tu: No problem mate, sponson tutorial coming up! Awesome tutorial on building a Glaive, and really nice work on your Alphas and Iron Hands Thanks for stopping by Dantay, and thanks for the encouragement! Can’t wait to get some paint on the Glaive. Happy to see progress on that beast! It's also very awesome you posted those pictures with tips. There have been a fair few times where I would be building something, hit a wall, and struggle to look up how someone else did it. And for some reason I want a glaive too... Cheers mate, hope someone finds it useful! Have you made any progress with your alphas recently? Link to comment https://bolterandchainsword.com/topic/317342-cadmus-tyro-xth-and-xxth-blog-terror-squad/page/19/#findComment-4969778 Share on other sites More sharing options...
