lokkorex Posted February 18, 2016 Share Posted February 18, 2016 (edited) Nicely done! I like your painting abilities! I also take it your grinding through the contents of two betrayal at calth boxes to build the basis of your army? Edited February 18, 2016 by lokkorex Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4310522 Share on other sites More sharing options...
Monstra Sumus Posted February 19, 2016 Author Share Posted February 19, 2016 Nicely done! I like your painting abilities! I also take it your grinding through the contents of two betrayal at calth boxes to build the basis of your army? Thankyou for the kind words, Iokkorex! Actually, it's just the one box and a bit of resourcefulness! Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4311279 Share on other sites More sharing options...
Monstra Sumus Posted February 19, 2016 Author Share Posted February 19, 2016 (edited) Khanat slammed down into the courtyard, his eyes narrowing behind his visor, bis breath coming in short and sharp growls. The Primarch moved on the capital, bringing their might against the bastion walls of the Palace; yet here he was, out on the flank of the main thrust, tasked with subduing outlying fortresses so that their guns could be turned against the walls of the Emperors defence. The work suited him because that is what he saw it as. Butchering fellow Astartes wasn't glorious war or righteous vengeance like some of the other Legions preached, it was simply work. His chainblade sputtered to a halt, flicks of meat and bone splashing away onto the cracked flagstones. A pall of smoke drifted across the interior of the bastion and he took two steps forward before his men thudded down onto the hardpan behind him. Fanning out into a vee, he strode cautiously forward, his helmet flicking left and right. It was merely a second before the gun fire started that his helmets sense alerted him. The chattering boom of a heavy bolter spat streaks of hot white in their direction, sawing one of his Astartes in half at the waist. The soldier crashed to the ground, torso and legs coming down in different directions. To the warriors credit, he began to return fire while his life blood pumped out of his ruined body. Khanat threw himself forward, skidding across the concrete floor to seek cover behind crumpled barricades. His squad spread out, finding cover where they could. His helmet pinged responses back to him, one heavy weapon and two support weapons. It seemed the Fists wouldn't let their approach go unanswered. Good, he thought. Mass reactive rounds punched chunks out of the wall section he crouched behind, peppering his upper body with a rain of stone. Touching his vox he sent a support request to the second element of the 126th that had been assigned to his task force. Khanat risked a glance over the ruined wall to survey the enemy position. A round smashed through the command crest upon his helm. His head snapped back and he sought refuge behind cover once more. The ringing in his ears balanced out just in time to hear the thunderous impacts against the bastion wall. Cresting the battlements behind the enemy position came a terrifying sight to behold. Rising up from the fog of war came a behemoth of burnished iron and savage intent. Warhorns blared a shout which distorted into vicious machine shriek, one gigantic wrecking claw crumpled the top of the wall as the Contemptor hauled itself over and down into the courtyard. Slamming down with enough force to knock one of the enemy legionnaires off their feet, the dreadnought rose to his full imposing height with a squeal of pistons. Thrusting his combat claw forward his blasted one warrior with the built in bolter weapon, his multi barreled assault cannon splitting the air with its scream as he flexed his gun arm back and forth. Khanat stood up from his defensive position and watched with mounting impatience as the dreadnought, Falx, cleared the way to the inner bunker entrance. Falx was screeching throughout the ordeal, a terrible wail of static. The sergeant watched as the war machine marched on, the heavy bolter chipping away his torso armour, trying to breach the up-armoured helmet. With a sound like a mountain splitting he saw Falx kick the heavy weapons away; his torso spun and he punched his battle claw through the upper body of a second Imperial Fist. The third came forward, clutching the red tube of a krak grenade, but Falx stove his head in with the reinforced bar underneath his assault cannon. Khanat came out from behind his cover, signalling his squad to form up as the lumbering form of Falx began to pound at the bunker door. Economical, piston driven, thundering punches hammered into the heavy blast door until it crumpled under the assault. Tearing it away the dreadnought roared again, unleashing a hail of bullets from his assault cannon into the bunkers interior. The massive machine then began smashing its bulk through the doorway, widening the entrance enough to advance. Khanat locked his bolter to the magnetic strip on his thigh and began to pick coagulated chunks from between the teeth of his blade. It would be a while before Falx had cleared the interior and he was in no rush. There would be no reinforcements coming for the Imperial Fists. So, for a giggle I figured I'd turn this into a proper "To the Gates of Terra" force and do a small allied force of Emperor's Children. That being said, this army isn't for competitive play at all, it's for fun and for fluff. So I think Iron Warriors will be my main army with allied Traitor Legion detachments I can bolt onto it to simulate different era's or battles. So my (wish)list I'm gearing towards for the moment is as follows: +Iron Warriors+ Barban Falk/Siegebreaker in Cataphractii armour with combi melta and chain fist. Kharnasus/Praetor in Artificer with Paragon Blade and Plasma Pistol. - Command Squad with Combi-Plasma and Power Swords. Tactical Squad with Vexilla, Nuncio-Vox (10 men, bare bones.) Tactical Squad with Vexilla, Nuncio-Vox (10 men, bare bones.) Contemptor Dreadnought with Kheres Assault Cannon and DCCW. Tyrant Siege Terminators with Chain Fists (5 men to accompany Siegebreaker for tank hunter goodness). Iron Havoc Squad with Missile Launchers (5 men, K/F/AA for some back field flanking cover). +Emperor's Children+ Julius Kaesoron/Praetor in Terminator Armour with MC Paragon Blade, Sonic Shrieker, Iron Halo, Digital Lasers and a Volkite Charger. Tactical Support Squad with Plasma Guns (5 men). Phoenix Terminators with Sonic Shriekers. Kakaphoni (bare bones for psycho-dakka, 5 men). They'll all be given transports and the like once I've got them all done, I'll probably throw foot sloggers in rhinos and stick Kaesoron + PT in a Dreadclaw for facepunchy 2nd turn assault. Then I'll expand the Iron Warriors along with their strange allies. Might even try for Iron Warriors plus 1k points of each Traitor Legion present at Terra. Who knows. Edited February 19, 2016 by Brother Tyrax Gorgoff and Hydriatus 2 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4311470 Share on other sites More sharing options...
Monstra Sumus Posted February 24, 2016 Author Share Posted February 24, 2016 So I flew back from America yesterday and I'm having trouble readjusting, spent the night rummaging through my hobby boxes and decided what I was going to re-purpose for the 126th. A few hours later... Pearson73, Gorgoff, Brofist and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4317492 Share on other sites More sharing options...
Gorgoff Posted February 25, 2016 Share Posted February 25, 2016 Nice Story. You gonna need a compulsory Troop Choice because TSS cannot be taken as such. Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4318084 Share on other sites More sharing options...
The Pounder Posted February 25, 2016 Share Posted February 25, 2016 Looking good so far! Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4318089 Share on other sites More sharing options...
Monstra Sumus Posted February 25, 2016 Author Share Posted February 25, 2016 Nice Story. You gonna need a compulsory Troop Choice because TSS cannot be taken as such. Gonna run PotL so got a chunk of Tacticals and Terminators in there. Looking good so far! Thank you Judd, now comes the long war against my painting table! Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4318209 Share on other sites More sharing options...
Gorgoff Posted February 25, 2016 Share Posted February 25, 2016 For your allied detachment you need at least on compulsory Troop Choice. Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4318413 Share on other sites More sharing options...
Monstra Sumus Posted February 26, 2016 Author Share Posted February 26, 2016 For your allied detachment you need at least on compulsory Troop Choice. Ah! Yes, now I see. I had planned for an Assault Squad but obviously didn't write it down. Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4319862 Share on other sites More sharing options...
Gorgoff Posted February 27, 2016 Share Posted February 27, 2016 For your allied detachment you need at least on compulsory Troop Choice. Ah! Yes, now I see. I had planned for an Assault Squad but obviously didn't write it down. That'll work. :) Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4320627 Share on other sites More sharing options...
Monstra Sumus Posted March 2, 2016 Author Share Posted March 2, 2016 BREACH! So I wanted some breachers, so I made some breachers. Lots of clipping, cutting and replacing went on but now each Marine has a shield, bolter, bolt pistol and melta bomb. The sarg is armed with a power fist, bolt pistol, shield and breaching charge. They have dual flamers for some wall of death goodness. Going to expand to a 20 man squad with 4 flamers as I have another 10 shields, just need another 10 men. Marqol, Grim Dog Studios, Brother-Chaplain Kage and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4324201 Share on other sites More sharing options...
Monstra Sumus Posted March 4, 2016 Author Share Posted March 4, 2016 Bit of work on the IV over the last few days. More Terminators, a Siege Breaker, a Vigilator, his Seeker squad and the start of Barban Falk. Marqol and Pearson73 2 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326123 Share on other sites More sharing options...
Dantay VI Posted March 4, 2016 Share Posted March 4, 2016 Very nice, although the IW need to be careful... Looks like a Salamander has infiltrated their ranks disguised as a Siege Breaker ;) Monstra Sumus 1 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326158 Share on other sites More sharing options...
Monstra Sumus Posted March 4, 2016 Author Share Posted March 4, 2016 Very nice, although the IW need to be careful... Looks like a Salamander has infiltrated their ranks disguised as a Siege Breaker Haha, he used to be a lonely old, dust covered, Son of Medusa. He used to be. Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326167 Share on other sites More sharing options...
Pearson73 Posted March 4, 2016 Share Posted March 4, 2016 Nice conversion with the 40k terminators. Are those shields Anvil? Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326305 Share on other sites More sharing options...
Monstra Sumus Posted March 4, 2016 Author Share Posted March 4, 2016 Nice conversion with the 40k terminators. Are those shields Anvil? That they are Pearson. Just don't do what I did and spend a whole night converting arms to use the shields, only to find out the website do arms for those shields once you'd finished. Pearson73 1 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326494 Share on other sites More sharing options...
Brother Pheidias Posted March 4, 2016 Share Posted March 4, 2016 great reinforcements there, liking the Vigilator a lot! Monstra Sumus 1 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4326499 Share on other sites More sharing options...
Calas Typhon Posted March 5, 2016 Share Posted March 5, 2016 Quite like this fella! Hydriatus and Monstra Sumus 2 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4327048 Share on other sites More sharing options...
Monstra Sumus Posted March 5, 2016 Author Share Posted March 5, 2016 great reinforcements there, liking the Vigilator a lot! Thank you Pheidias, he used to see life as a never used Techmarine. Figured he'd be better applied as spec ops! Quite like this fella! Thank you Cthonia. I'm very eager to paint him, just need to give him a bath first. Got round to a few little bits, some Rhinos, two Whirlwinds (don't know if I can get away with them as Scorpius) and an Assault Squad. Pearson73 and Calas Typhon 2 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4327061 Share on other sites More sharing options...
Doctor Perils Posted March 6, 2016 Share Posted March 6, 2016 Those yellow bits must be repainted in the righteous Steel and Iron of the true sons of Perturabo as soon as possible :P! The tanks look nice, and I think those missile launchers could easily be passed off as Mars pattern Scorpius Launchers (on a side note, where are they from ? I want a Scorpius or three and I prefer Mars pattern tanks to Deimos :) ) Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4327834 Share on other sites More sharing options...
Doctor Perils Posted April 3, 2016 Share Posted April 3, 2016 (edited) snip Oooh, very nice ! EDIT: snipped the images for space ^^ Edited April 3, 2016 by Lord Thørn Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4353344 Share on other sites More sharing options...
Charlo Posted April 3, 2016 Share Posted April 3, 2016 I like the Cataphracti arms on the indomitus body. Look very unique and especially brutal with the IW heads Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4353604 Share on other sites More sharing options...
Monstra Sumus Posted July 8, 2016 Author Share Posted July 8, 2016 Got Barban Falk and Contemptor Falx finished and set aside for proper photos. Working on a Terminator squad but need my order of shoulder pads to show up. Also have the Leviathan Ardakas to start on. Cheers for looking! BT hushrong, Pearson73, Reyner and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4438063 Share on other sites More sharing options...
Pearson73 Posted July 9, 2016 Share Posted July 9, 2016 Nice posing with the Leviathan. Link to comment https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4438870 Share on other sites More sharing options...
https://bolterandchainsword.com/topic/319105-126th-grand-company-iron-warriors/page/2/#findComment-4353178Share on other sites
