Looks like there's an issue with Alpha Legion banestrike rounds. Currently, the centurion can take a bolter with banestrike rounds for 5 points, but the cost should be 7 (2 for the bolter and 5 for the banestrike). Also, they should be available for the combi bolter for +5 as well. (The praetor doesn't seem to have an option for them at all unless this is a mobile version issue.)
Thanks again for all the work!
~K
This isn't strictly true the Vigilator doesn't have to pay for the bolter upgrade. So the cost to him should still only be +5pts
~K
Yes, the others have been fixed, but my suggested fix messed up the vigilator for Alpha Legion. Good catch.
~K
Hi, one minor suggestion I spotted while making a list.
In emperors children legion I selected legion terminators, it lists one of their upgrades as a Phoenix spear
unfortunately they aren't allowed to take this instead of a power fist, as only characters are permitted this. The sgt could do though.
Other wise if choose them over Phoenix guard any day of the week!!!
Hi there.
Phoenix Terminators missing their champion.
In SA each section without transport can have Aegis, not just 1 per tercio.
Good luck and thanks for great job.
Whoops for some reason I read that as only one Aegis per Tercio.  Corrected.  As far as the Phoenix Terminators - I don't have a dedicated entry because there's only one option...
I think X Legion using the Head of the Gorgon RoW should have access to Vorax maniples as Elite choices in addition to Castellax...
Thanks for all the work you've done with the lists, btw!
Unfortunately the Rite of War states pretty clearly "Legio Cybernetica" battle-automata maniples.  The way I read it, that doesn't include Taghmata Omnissia battle-automata.
You're welcome, though!
Minor tweak, auxilia magos from SA list cannot take meltabombs, though he should.
Thallaxi cannot take heavy chainblades in SA list.
Thanks!
Corrected!  Nice catches, thank you.  I got a little lazy with my copy/paste from other catalogues...
Oh man, I totally goofed on this one.  I did the same thing for Power Scythes.  Corrected - great catch!  Thanks!
Any time frame on the deredeo?
Unfortunately I'm not planning on adding it until the full rules are released in the next book.
Lastly - I think the whole Alpha Legion banestrike ammo issue is worked out now.  Is that correct?  Or is there still a problem there?
Thanks for all the feedback, guys!  I really appreciate it - this would be a very different product without all your help.
Actually page 202 of Extermination says Legio Cybernetica can select Thanatar and Vorax
This will be a question I'll ask at the Weekender. I'd like to know just what automata are available for this selection. Not that the Castellax is bad though. Just seeking clarity.
Ah the vigilator with banestrike rounds. I'll fix that, I didn't even touch the special consuls.
As far as the taghmata/cybernetica thing, I'll reread a bit and get back to you. I'm all about the spirit vs the letter of the law so we'll adjust accordingly.
Has that changed in LACAL? If so then extermination is superseded by the red book.
The LACAL is a poorly edited mess among poorly edited messes, consisting of out of context basic copy pasting errors as FW rushed to release a more accessible version of the rules and should be taken in accordance. Hence why it took the FAQ to finally sway me that the Command Tank rule no longer granted Interceptor as a result of 'spirit of the rule' and FW's notorious poor rules writing (even among GW publications)
All I was doing was making a valid point about how they cannot properly copy paste rules. The information contained within said book should be treated as circumspect in many aspects, especially where they contradict the rules in earlier books (and aren't directly answered by the FAQ).
Hope you're having a good time Milicant!
Just found a wee glitch while trying to make a SoH PotL list. If you have a squad of 10 Legion terminators chosen and try to go above 5 extra in another squad all the choices for adding more terminators and weapon options vanish, not sure why?
Ha! I am not, it's not a vacation, I'm on a det with my squadron and away from my books/computer.
That's interesting. I will investigate a bit. I'm unable to replicate on the mobile version, but I will try some more once I return. The more specific you can be, the better.
