Zopha Posted January 17, 2017 Share Posted January 17, 2017 I noticed just today that the legion command squad should be 75 pts base instead 100pts base and 15 pts for additional bodies instead of 20pts Thanks, I've logged that here https://github.com/BSData/horus-heresy/issues/662 will be fixed for the next release. Hi Zopha, I just noticed that Cor'Bax and Samus are not available as LoW in the WB list and cant be chosen as HQ in the Demon Catalog Just thought i Let you know if no one has pointed it out yet. Is that the 40k catalogue? As far as I know we haven't integrated codex demon units or their own catalogue yet. It's on the list but one of the larger projects as the 40k file would need to be updated to use the main 30k Battlescribe file. We can set up something to add in Cor'Bax and Samus for the WB though.Can Demons be used as a stand alone army in HH or are they allies/summoned only at the moment? Yes from what I read Demons are a stand alone army in HH and can only be taken as Allies by the WB Below is Cor'bak discretion of how he can be used Samus is the same I hope this helps Lord of the Ruinstorm 9 Cor’bax Utterblight is a Lords of War choice for a Codex: Chaos Daemons army. If Cor’bax Utterblight is selected in an army which uses Codex: Chaos Daemons as its Primary Detachment in Age of Darkness games, Cor’bax Utterblight may be counted as a HQ choice rather than as a Lords of War choice. If this is the case, then Cor’bax Utterblight must be the army’s Warlord and has the following Warlord trait rather than rolling to determine a trait. Cor’bax Utterblight, Daemon Prince of the Ruinstorm, may be chosen as a Lords of War choice for the following armies in Age of Darkness games: Word Bearers Legiones Astartes and Codex: Chaos Daemons (see also the Lord of the Ruinstorm special rule). Will see what can be done to add Cor'bax and Samus as a LoW. The Demon's codex is going to be a much larger addition so that one will take a while, more than likely after we have most of the other issues ironed out. LoW logged here - https://github.com/BSData/horus-heresy/issues/663 Are the most current rules for them the ones on the FW site? Just noticed Today that the Legion Tarantula Sentry Gun has all the Gun Options its suppose to have, but they are all listed as No Cost. I know this worked like a week or two ago. I don't know if this is due to you working on the Fast Attack Choices. Yeap, that's usually my fault although I had a look on my phone and the costs look correct. Only two of the choices have a cost, TL las and MM with searchlight. Can you clear out your catalogue data and see if that fixes it? You can delete data from the menu in Manage Data. Take a look at this: https://battlescribe.net/?faq=refreshData I think I'll need to revisit that entry at a later stage. I wasn't completely sure how to handle the complete replacement for the Hyperios so the entry comes with no weapons selected, you have to add them on to make them appear on the profile. Just did that and it seems to have fixed it. However, when Selecting Blood Angels Legion, which grants Access to Assault Cannons as upgrades from Heavy Flamers the Point cost remains at No Cost. It should be 5 points as Listed in Book 6 Under BA Rules. I've updated the points for that. I'll get a closer look at it when we get around to looking at each legion options and their rites. For other vehicles do you have to buy the Heavy Flamer first (if it has a cost) and then buy the cannon on top of it? The Rhino for example, would the assault cannon work out to be 15 points? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4626125 Share on other sites More sharing options...
The4thHorseman Posted January 17, 2017 Share Posted January 17, 2017 Just noticed Today that the Legion Tarantula Sentry Gun has all the Gun Options its suppose to have, but they are all listed as No Cost. I know this worked like a week or two ago. I don't know if this is due to you working on the Fast Attack Choices. Yeap, that's usually my fault although I had a look on my phone and the costs look correct. Only two of the choices have a cost, TL las and MM with searchlight. Can you clear out your catalogue data and see if that fixes it? You can delete data from the menu in Manage Data. Take a look at this: https://battlescribe.net/?faq=refreshData I think I'll need to revisit that entry at a later stage. I wasn't completely sure how to handle the complete replacement for the Hyperios so the entry comes with no weapons selected, you have to add them on to make them appear on the profile. Just did that and it seems to have fixed it. However, when Selecting Blood Angels Legion, which grants Access to Assault Cannons as upgrades from Heavy Flamers the Point cost remains at No Cost. It should be 5 points as Listed in Book 6 Under BA Rules. I've updated the points for that. I'll get a closer look at it when we get around to looking at each legion options and their rites. For other vehicles do you have to buy the Heavy Flamer first (if it has a cost) and then buy the cannon on top of it? The Rhino for example, would the assault cannon work out to be 15 points? As is my understanding and how it worked in the previous incarnation of Battlescribe. First you purchase the Heavy Flamer, then Upgrade to Assault Cannons. So you could just do a Flat Upgrade cost of Heavy Flamer +5 points for the Cost of an Assault Cannon. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4626283 Share on other sites More sharing options...
Plaguecaster Posted January 17, 2017 Share Posted January 17, 2017 How does one add Fortifications to an age of darkness list, I think I may be an idiot as I can't work it out Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4626438 Share on other sites More sharing options...
ezeefisch Posted January 17, 2017 Share Posted January 17, 2017 How does one add Fortifications to an age of darkness list, I think I may be an idiot as I can't work it outI've had the same problem, if I remember correctly Millicant said it was due to the Fortification list not being compatible with BS 2.0 yet Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4626454 Share on other sites More sharing options...
Zopha Posted January 18, 2017 Share Posted January 18, 2017 How does one add Fortifications to an age of darkness list, I think I may be an idiot as I can't work it out How does one add Fortifications to an age of darkness list, I think I may be an idiot as I can't work it outI've had the same problem, if I remember correctly Millicant said it was due to the Fortification list not being compatible with BS 2.0 yet Yeap, they're not in the datafiles yet except for the two from the Legion army book. If you want to add those it's the same process as a Lord of war. Add in a second force using the legion catalogue Add a new Force Org selection in the second force Touch it for options Touch the Force Org Chart selection (the text, not the radio button!) Change to Fortification Go back to the main roster Add in your Forification The rest of the fortifications are on the todo list along with a better implementation for them. No ETA on it but it'll be after the standard Astarte units are sorted out (HQ and Elites are left atm) and probably done along side the Lord of War units. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4627047 Share on other sites More sharing options...
Zopha Posted January 19, 2017 Share Posted January 19, 2017 I've two questions I've been having trouble with if anyone can help. Questoris Knights Does anyone know how Household ranks work with their lord of war units? (not counting titans) Not 100% sure but it looks like you buy a knight pilot in a force org slot and then that knight pilot can use any knight armour (unless something restricts them), what I'm not sure about is how their two Lord of War units (Atrapos and Porphyrion) work with this and if they're limited by being lords of war or that slot restriction gets replaced by the pilot. For example, if a Scion Martial is chosen can it take a Porphyrion and still count as a troop selection? I think yes but I'm not confident that's the correct answer. Rules Does anyone know where I can find the Agile and Missile rules? I couldn't find them in the red book or the BRB, so maybe another FW book? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4628263 Share on other sites More sharing options...
fedratsailor Posted January 19, 2017 Share Posted January 19, 2017 Atropos and Porphyrion both can use the Knightly ranks as normal. your example is correct. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4628537 Share on other sites More sharing options...
Nusquam Posted January 20, 2017 Share Posted January 20, 2017 I've two questions I've been having trouble with if anyone can help. Questoris Knights Does anyone know how Household ranks work with their lord of war units? (not counting titans) Not 100% sure but it looks like you buy a knight pilot in a force org slot and then that knight pilot can use any knight armour (unless something restricts them), what I'm not sure about is how their two Lord of War units (Atrapos and Porphyrion) work with this and if they're limited by being lords of war or that slot restriction gets replaced by the pilot. For example, if a Scion Martial is chosen can it take a Porphyrion and still count as a troop selection? I think yes but I'm not confident that's the correct answer. Rules Does anyone know where I can find the Agile and Missile rules? I couldn't find them in the red book or the BRB, so maybe another FW book? Yes, they use Household ranks normally. Agile is +1 to jink. Missile Barrage, quite literally, does nothing. It's an ancient rule before flyers were flyers and could fire four weapons by default. It allows you to fire 4 missiles in one turn. I think they're both in Book 1. Can't remember. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4628843 Share on other sites More sharing options...
Zopha Posted January 20, 2017 Share Posted January 20, 2017 7.1.6 has been tagged and released. I've put a fix in place so a Primarch in a sepearte LoW detachment will cause the Rite of War selections to show. If anyone has the time can they test this please? I want to make sure it's working for everyone. If it's not then please clear out your catalogue data and see if that helps. You can delete data from the menu in Manage Data. The instructions for this can be found here: https://battlescribe.net/?faq=refreshData ----------- 7.1.6 patch notes Updated following profiles for Battlescribe 2 standards Legions:Legion Mortis DreadnoughtContemtpor Mortis DreadnoughtContemtpor DreadnoughtLegion DreadnoughtContemptor-Cortus DreadnoughtLegion FalchionHeavy Support SergeantDamocles Solar Auxillia: Valdor Tank HunterAuxillia Malcador tank More work is being carried out with each release. Please bear with us as we make this transition and improvements to the catalogues. Fixed: LegionsLegion command squad costs for Centurion and Preator.Assault Cannon cost on TarantulaPoints cost too high on Tactical Support Squad weaponsRite of War not showing when a Primarch is selected in a seperate LoW detachmentFalchion missing Neutron Wave Capacitor upgrade.Optional Searchlight on vehicles is automatically selected.World Eaters - Cannot exchange two power axes without a validation errorSons of Horus - Limitation on Justaerin squads, was limited to 1 per forceUltramarines RoW - The Logos Lectora - Too many HQ choices and not checking to see if a MoS or Damocles was selected. Mechanicum/GeneralCastellax - Could still selected 2 bolters when using a Siege Wrecker.Vorax - Squad size was 5, should be 6. Questoris KnightsAdded Acastus Knight Porphyrion to Questoris Knights list. More work to be done to allow it to be take in a LoW detachment for MechanicumFixed Force Org validation, this matches the Questoris Knight custom force org. Solar AuxilliaSolar Aux - Valdor Tank Hunter sponson options updated Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4629009 Share on other sites More sharing options...
Trydragon Posted January 20, 2017 Share Posted January 20, 2017 I've two questions I've been having trouble with if anyone can help. Questoris Knights Does anyone know how Household ranks work with their lord of war units? (not counting titans) Not 100% sure but it looks like you buy a knight pilot in a force org slot and then that knight pilot can use any knight armour (unless something restricts them), what I'm not sure about is how their two Lord of War units (Atrapos and Porphyrion) work with this and if they're limited by being lords of war or that slot restriction gets replaced by the pilot. For example, if a Scion Martial is chosen can it take a Porphyrion and still count as a troop selection? I think yes but I'm not confident that's the correct answer. Rules Does anyone know where I can find the Agile and Missile rules? I couldn't find them in the red book or the BRB, so maybe another FW book? Yes both use Knight Ranks but the Porphyrion cannont be taken as a Scion Aspirant or Scion Uhlan And off the top of my head as i don't have the rules In front of me I believe the Aptrpos is a 0-1 for every 2000 points I.E in a 2000pts list you can only have 1 Aptrpos but in a 2001pts list you could have 2. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4629021 Share on other sites More sharing options...
fedratsailor Posted January 21, 2017 Share Posted January 21, 2017 Nothing major, just that the point cost for a Porphyrion is not showing up. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4630540 Share on other sites More sharing options...
Zopha Posted January 21, 2017 Share Posted January 21, 2017 Nothing major, just that the point cost for a Porphyrion is not showing up. I had this feeling I had forgotten something... Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4630548 Share on other sites More sharing options...
Balthamal Posted January 23, 2017 Share Posted January 23, 2017 Quick heads up the RoW are absent again from the android/windows versions. Have the instructions to select it but not the option itself Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4632438 Share on other sites More sharing options...
jedimasterwiggy Posted January 23, 2017 Share Posted January 23, 2017 On my Android version it seems that for seeker squads when I go at add combi weapons I can add one by ticking the box but only one. No options for more. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4632476 Share on other sites More sharing options...
Zopha Posted January 24, 2017 Share Posted January 24, 2017 Quick heads up the RoW are absent again from the android/windows versions. Have the instructions to select it but not the option itself I added in a No Force Org section as a quick fix to get instructions and PSA's in to the data files and it only contains instructions. The Rite of War selection is in the "Legoin" slot instead. Having three separate non-unit slots is not the clearest and needs to be cleaned up. If I misunderstood you and you are looking in the legion section then try clearing out and refreshing your data files. Instructions to refresh them can be found here - https://battlescribe.net/?faq=refreshData On my Android version it seems that for seeker squads when I go at add combi weapons I can add one by ticking the box but only one. No options for more. Thanks! I pushed a release and just seen this :( I've tested it and found the problem so the fix will be in the next release in a day or so. ------------- A release has been tagged and will be available soon. Nothing major, Added cost to Acastus knight Fixed optional pintle mount requirement on Auxilla Valdor and Malcador Reverted Centurion and Praetor Legion command squad as they couldn't take jump packs or bike. Added text to lighting blows rule for Custodes. Updated some Legion Terminator weapons with linked entries. Some of their weapons will have profiles now. This is part of the on-going project to get the files up to Battlescribe 2 standards. It's going to be mostly small bug fixes until late next week. I'm off to the HH doubles event this weekend and I'm getting sleep deprived, the kids are taking turns making sure we only get 4 hours sleep a night for the last two weeks. If I make any major changes I'm bound to make more mistakes. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4632977 Share on other sites More sharing options...
+Grimdark Prince Adam+ Posted January 24, 2017 Share Posted January 24, 2017 I looked for it, bu couldn't find it - how do you activate the Armoured Spreahead RoW (the one where preedators become troops)? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633004 Share on other sites More sharing options...
Zopha Posted January 24, 2017 Share Posted January 24, 2017 I looked for it, bu couldn't find it - how do you activate the Armoured Spreahead RoW (the one where preedators become troops)? Add in any unit that is a Master of the Legion. Go to the Legion section on the Roster Add Rites of War and go back out to the Roster Select Rites of War and you'll have the option for Armoured Spearhead (and other RoW's) It's on my to-test list so I'm not sure if it's 100%. If you find any problems with it or it's doing/not doing something it should please let me know. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633017 Share on other sites More sharing options...
IronDrake28 Posted January 24, 2017 Share Posted January 24, 2017 I looked for it, bu couldn't find it - how do you activate the Armoured Spreahead RoW (the one where preedators become troops)? Armoured Breakthrough* :p Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633021 Share on other sites More sharing options...
+Grimdark Prince Adam+ Posted January 24, 2017 Share Posted January 24, 2017 Thanks, it worked! So i was able to add the 2 predators as troops, however, I did not find a way to add either a predator or sicaran tank as the possible compulsory HQ unit. Anything I'm missing? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633038 Share on other sites More sharing options...
BLACK BLŒ FLY Posted January 24, 2017 Share Posted January 24, 2017 Can't select jump packs for my command squad (iPad). Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633043 Share on other sites More sharing options...
Zopha Posted January 24, 2017 Share Posted January 24, 2017 Thanks, it worked! So i was able to add the 2 predators as troops, however, I did not find a way to add either a predator or sicaran tank as the possible compulsory HQ unit. Anything I'm missing? No, your not. I just looked over the rite and it enables you to add one of those tanks as a Company Command Vehicle, which grants it the Master of the Legion rule JUST for this rite of war. That's not implemented yet and nether tank is setup for the HQ slot so it's going to need work to implement. I'll check the old files a little later and see if it was setup before the BS2 transition. I've logged the issue here - https://github.com/BSData/horus-heresy/issues/683 to keep track of it. I might be able to get the basics working but it'll be at least a week and a half before I can get back to normal-ish battlescribe updates so this make take sometime to get right :( Can't select jump packs for my command squad (iPad). Thanks. Your Legion file should be 209 that was released earlier today, I broke that option in 208. Update your files if you can, it should be available for download now. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633057 Share on other sites More sharing options...
BLACK BLŒ FLY Posted January 24, 2017 Share Posted January 24, 2017 How do you manually update your version (iPad) ? Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633070 Share on other sites More sharing options...
IronDrake28 Posted January 24, 2017 Share Posted January 24, 2017 How do you manually update your version (iPad) ? Delete your data and re-downloading it works for me. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633071 Share on other sites More sharing options...
Zopha Posted January 24, 2017 Share Posted January 24, 2017 How do you manually update your version (iPad) ? It should be the same on ipad/iphone and android. There's a guide on the battlescribe site - https://battlescribe.net/?faq=refreshData You don't have to delete data first but it can be good to do as it can clear out other issues. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633076 Share on other sites More sharing options...
BLACK BLŒ FLY Posted January 24, 2017 Share Posted January 24, 2017 Thanks Zopha. Link to comment https://bolterandchainsword.com/topic/326330-30k-battlecribe-repository/page/42/#findComment-4633088 Share on other sites More sharing options...
