Mazer Rackham Posted January 15, 2023 Author Share Posted January 15, 2023 Finding clothes at short notice in the hive is fairly simple, it's just down to how pricy you want it. Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5900261 Share on other sites More sharing options...
Trokair Posted January 22, 2023 Share Posted January 22, 2023 @A.T., split up or stick together? If we do split I would sugest it makes sense for Bardas to take Sector B as we can continue to use the Auspex to help in his search after giving Falk all he can on the Sector A locations Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902104 Share on other sites More sharing options...
A.T. Posted January 22, 2023 Share Posted January 22, 2023 13 hours ago, Trokair said: If we do split I would sugest it makes sense for Bardas to take Sector B as we can continue to use the Auspex to help in his search IIRC there was the possibility that the location of this warehouse might also hide access below sector B so that will be something best left to Bardas to scan for initially. Trokair and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902241 Share on other sites More sharing options...
Mazer Rackham Posted January 22, 2023 Author Share Posted January 22, 2023 Yes, that's correct. As the auspex sweeps, it will discover a chamber below Sector B. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902251 Share on other sites More sharing options...
Trokair Posted January 22, 2023 Share Posted January 22, 2023 I am getting rather worried for our colleagues up in the spire. Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902273 Share on other sites More sharing options...
Mazer Rackham Posted January 22, 2023 Author Share Posted January 22, 2023 I'm sure they'll be fine. So, chargen, fellas? Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902275 Share on other sites More sharing options...
Trokair Posted January 22, 2023 Share Posted January 22, 2023 Where is the cavlary we were expecting? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902277 Share on other sites More sharing options...
Mazer Rackham Posted January 22, 2023 Author Share Posted January 22, 2023 The proposed players are otherwise busy or tied up, so for now it will have to play out. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902283 Share on other sites More sharing options...
Trokair Posted January 22, 2023 Share Posted January 22, 2023 1 hour ago, Mazer Rackham said: The Upper House: Great drops of sweat fall from Valkyrie's brow, and her body rocks unsteadily as she powers up from her knees, bracing herself with a wide stance, her palm slaps onto the bolter and she struggles to pull it, hair suddenly lifting, all her movements give the appearance she is deep underwater. "Leave!" she growls through clenched teeth. The bolter cracks. Her target, the noble Magda Aldario, so porcelain and so delightful lifts from the ground, hair trailing behind her, caught in a storm. Everything slows down. Light glints from the bolt shell, the colours suddenly vivid and bright. Beads of Valkyrie's perspiration turn to glimmering diamonds. "Vermin! Just more Rats!" Magda calls, swimming out of the way of the bolt shell, lunging for the Battle Sister. With a slow hand, Valkyrie picks Restal up from the floor and hurls him at Reynard and Nicios. The order, no a plea, becomes long and drawn out as darkness spills over the throne room, eclipsing even Valkyrie's holy nimbus of faith. "Go!" The doors are locked. Kraevus Aldario exhorts the guards, whose stupefied faces rasp into snarls as they launch for the three Agents, staves and blades coming. Gentlemen. Initiatives. There wasen't quite the righ Reaction avilable, good luck you all. Spoiler Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902314 Share on other sites More sharing options...
Lysimachus Posted January 22, 2023 Share Posted January 22, 2023 @MG: Did you roll 100 twice in a row? Fear Test, target 29, Roll 100 would indeed be 7DoF Then you roll a second d100 for the Shock Table and add +70 for the DoF? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902357 Share on other sites More sharing options...
Machine God Posted January 22, 2023 Share Posted January 22, 2023 19 minutes ago, Lysimachus said: @MG: Did you roll 100 twice in a row? Fear Test, target 29, Roll 100 would indeed be 7DoF Then you roll a second d100 for the Shock Table and add +70 for the DoF? Yes two consecutive rolls of Treble 0 on Percentage Dice. It's a good job that Kerr Restal has WP 39 and not WP 29 or it could've been a Lot Worse. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902366 Share on other sites More sharing options...
Mazer Rackham Posted January 23, 2023 Author Share Posted January 23, 2023 Last IC post has been updated. Restal has been left out of the Initiative order as per the results of his fear test. Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902621 Share on other sites More sharing options...
Trokair Posted January 23, 2023 Share Posted January 23, 2023 (edited) 19 hours ago, Machine God said: Yes two consecutive rolls of Treble 0 on Percentage Dice. It's a good job that Kerr Restal has WP 39 and not WP 29 or it could've been a Lot Worse. So that's where my dice ended up. I am confident the others can save you. Edited January 23, 2023 by Trokair Mazer Rackham and Machine God 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902638 Share on other sites More sharing options...
Lysimachus Posted January 23, 2023 Share Posted January 23, 2023 I'm out for another couple of hours, it's been too long since I've been in a fight scene and I need to go home and check my book... I'm thinking Autogun, though - either FAB or maybe Suppressing Fire to pin the bad guys until Nicios can fry them all... any suggestions, anyone? Machine God and Mazer Rackham 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902650 Share on other sites More sharing options...
A.T. Posted January 24, 2023 Share Posted January 24, 2023 (edited) On 1/22/2023 at 11:56 PM, Machine God said: Yes two consecutive rolls of Treble 0 on Percentage Dice. Stash those dice away for your next character creation :p DM / Bardas: 01000111 01101100 01100001 01100100 01101001 01110101 01110011 00100000 01000100 01100101 01101001 00100000 01010011 01100001 01101110 01100011 01110100 01110101 01110011 00101110# 47 6C 61 64 69 75 73 20 44 65 69 20 53 61 6E 63 74 75 73 2E- G - L - A - D - O - S -- B - A - C - K -- U - P -- C - O - R - E - . - :p Edited January 24, 2023 by A.T. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5902792 Share on other sites More sharing options...
Mazer Rackham Posted January 24, 2023 Author Share Posted January 24, 2023 Just a suggestion for @Machine God, your character is down and out, but you could still do character RP, maybe a fever dream, or a memory from before. Perhaps even deepen Restal's background - why he became a killer, what motivates him, etc. It will break up some of the combat and keep you posting if you wanted to do that. Being catatonic, I don't think you can self-revive, at least for another hour, you'll need help, so might as well dream... Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903002 Share on other sites More sharing options...
Lord_Ikka Posted January 25, 2023 Share Posted January 25, 2023 I'd try to help Restal, but I don't think that any of my powers actually can... Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903062 Share on other sites More sharing options...
Lysimachus Posted January 25, 2023 Share Posted January 25, 2023 (edited) Hey boss, just to check, you've written Guard 6 charged Reynard, but in the pic he's charged (and was closer to) Nicios, which was it? If it wasn't Reynard that got charged, is he free to take whatever action as Guard 4 is down? Also, did 1, 2 and 3 escape from being Pinned at the end of Round 1? Edit: rereading the Pinning rules, I'm assuming they are still Pinned at the start of Round 2, and therefore will only be able to do Half Actions and can't move towards Reynard this turn, right? Then they get to test again at the end of this Round with a +30 if we haven't shot at them again? Edited January 25, 2023 by Lysimachus Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903120 Share on other sites More sharing options...
Mazer Rackham Posted January 25, 2023 Author Share Posted January 25, 2023 (edited) 1 hour ago, Lysimachus said: Hey boss, just to check, you've written Guard 6 charged Reynard, but in the pic he's charged (and was closer to) Nicios, which was it? If it wasn't Reynard that got charged, is he free to take whatever action as Guard 4 is down. Also, did 1, 2 and 3 escape from being Pinned at the end of Round 1? Edit: rereading the Pinning rules, I'm assuming they are still Pinned at the start of Round 2, and therefore will only be able to do Half Actions and can't move towards Reynard this turn, right? Then they get to test again at the end of this Round with a +30 if we haven't shot at them again? Yep, that's all correct - they can't test again until the end of this Turn. I apologise for the PC mixup, G6 charged Nicios. You have it exactly, I'll tidy it up in a bit. EDIT: Yep, that's fixed now. Just as an aside, the charging rules state that you need a clear run up to charge, and can only pass over intervening terrain/chars if you can fly (jump pack for example). To be fair, Restal's sandbagging just saved you. Maybe work the irony into your next post? Edited January 25, 2023 by Mazer Rackham Update Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903153 Share on other sites More sharing options...
Lord_Ikka Posted January 25, 2023 Share Posted January 25, 2023 I'm getting worried about Nicios' good rolls. Last time he had a good string it ended with everyone flying towards the ceiling... Mazer Rackham and Lysimachus 2 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903358 Share on other sites More sharing options...
Lysimachus Posted January 25, 2023 Share Posted January 25, 2023 (edited) As long as the next closest target for the Overbleed is Magda herself rather than Reynard, I'm happy...! (I'm pretty sure she is? Hopefully, even if she passes the Wp test, it might be enough for Valkyrie to clobber her!!! ) Edited January 25, 2023 by Lysimachus Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903373 Share on other sites More sharing options...
Mazer Rackham Posted January 25, 2023 Author Share Posted January 25, 2023 Guard 5 is nearer, sorry, but I am wondering if Ikka's 'bad feeling about this' is about to manifest.... Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903380 Share on other sites More sharing options...
Lord_Ikka Posted January 26, 2023 Share Posted January 26, 2023 Did Nicios just psyker someone into shooting him? Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903407 Share on other sites More sharing options...
Mazer Rackham Posted January 26, 2023 Author Share Posted January 26, 2023 Noooo, Nicios is quite safe. The guards are also convinced Reynard is the bigger threat as he has a machinegun (ho-ho-ho), and they don't know where the cramps are coming from. Magda can feel you, though, so be careful. Machine God 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903415 Share on other sites More sharing options...
Lord_Ikka Posted January 26, 2023 Share Posted January 26, 2023 10 hours ago, Mazer Rackham said: Noooo, Nicios is quite safe. Good, I think? 10 hours ago, Mazer Rackham said: Magda can feel you, though, so be careful. Very much not good. Need to get away from the scary psychic vampire lady. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/375214-dh1e-the-damocles-contingency-ooc/page/43/#findComment-5903489 Share on other sites More sharing options...
