Emperor Ming Posted May 10, 2023 Share Posted May 10, 2023 Triumph got nerfed It was never even a good pick Maschinenpriester and W.A.Rorie 2 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946228 Share on other sites More sharing options...
Emperor Ming Posted May 10, 2023 Share Posted May 10, 2023 Wow, so exorcists only s10 and mm only9, sisters are gonna struggle to kill anything tougher than a rhino Unless I'm missing something? Maschinenpriester and Toxichobbit 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946233 Share on other sites More sharing options...
Emperor Ming Posted May 10, 2023 Share Posted May 10, 2023 Sisters anti tank looks appallingly bad The humble MM, no longer one of the best anti vehicle weapons, its been relegated to wounding rhinos on 4s Khornestar, Cruor Vault, Vanger and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946235 Share on other sites More sharing options...
Bonzi Posted May 10, 2023 Share Posted May 10, 2023 The big change is a large uptick in miracle dice generation and refund opportunities. Also, it's now allowed for each unit to use a single miracle dice per phase. That's a big jump compared to only allowing a single miracle dice to be used per phase in total. It seems like their want miracle dice to be a more central gimmick of the army. Downside is that with the changes to battleshock...a roll of a 1 on a miracle dice has zero use in 10th. I suspect characters like the dogmata will have an expanded roll in modifying dice for that reason. Exorcist got a slightly more even shot output on the Krak missiles and didn't lose a pip of AP like most weapons are seeming to this edition (though the antipersonell missiles did lose their AP). Indirect fire is back to a built in feature instead of a strat which is nice. Hopefully it gets a big bump in toughness and reasonable points cost. Article mentioned the Castigators becoming tougher but showed no profile. Hopefully both the exorcist and Castigator are now tougher than Rhino profiles. The detatchment bonus is decent. Giving +1 to hit for being wounded and +1 to wound for being below half strength gives sisters a good mechanic to become more dangerous as their units get damaged. RolandTHTG, W.A.Rorie and Emperor Ming 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946237 Share on other sites More sharing options...
Frogian Posted May 10, 2023 Share Posted May 10, 2023 it always seemed a bit odd they just didn't let them take the rhino based SM tanks. Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946242 Share on other sites More sharing options...
tzeentch9 Posted May 10, 2023 Share Posted May 10, 2023 25 minutes ago, Emperor Ming said: Sisters anti tank looks appallingly bad The humble MM, no longer one of the best anti vehicle weapons, its been relegated to wounding rhinos on 4s 3s if you’re at half strength or below. And there is miracle dice for wounding. I don’t think sisters need to worry Hellex_The_Thanatar, phandaal, Kallas and 6 others 6 3 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946245 Share on other sites More sharing options...
Dark Shepherd Posted May 10, 2023 Share Posted May 10, 2023 The one situation I can think of youd want low rolls for is Deadly Demise, but thats excluded Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946271 Share on other sites More sharing options...
Arikel Posted May 10, 2023 Share Posted May 10, 2023 53 minutes ago, Dark Shepherd said: The one situation I can think of youd want low rolls for is Deadly Demise, but thats excluded Maybe use low rolls to fail some armour saves and start getting bonuses? Plays into the martyrdom theme anyways. phandaal, Maschinenpriester, Mithrilforge and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946286 Share on other sites More sharing options...
Arikel Posted May 10, 2023 Share Posted May 10, 2023 2 hours ago, Bonzi said: The big change is a large uptick in miracle dice generation and refund opportunities. Also, it's now allowed for each unit to use a single miracle dice per phase. That's a big jump compared to only allowing a single miracle dice to be used per phase in total. It seems like their want miracle dice to be a more central gimmick of the army. Downside is that with the changes to battleshock...a roll of a 1 on a miracle dice has zero use in 10th. I suspect characters like the dogmata will have an expanded roll in modifying dice for that reason. Thought I would pop this in here too, but you could use a bad miracle dice to auto fail a save and start getting bonuses perhaps? Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946288 Share on other sites More sharing options...
MadEdric Posted May 10, 2023 Share Posted May 10, 2023 Perhaps Sisters will have a strat, like before that allows you to discard MD for better effect. Maschinenpriester 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946293 Share on other sites More sharing options...
tzeentch9 Posted May 10, 2023 Share Posted May 10, 2023 2 hours ago, Dark Shepherd said: The one situation I can think of youd want low rolls for is Deadly Demise, but thats excluded Overcharge plasma, use a one miracle dice for the hit, give the rest of the unit plus one to hit for the rest of the game Maschinenpriester, Dark Shepherd, Urauloth and 5 others 3 5 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946301 Share on other sites More sharing options...
Montford Posted May 10, 2023 Share Posted May 10, 2023 Some of these previews have gotten me speculating on which 5 or 6 stratagems the Sisters will be keeping, or if some might be entirely new. Like the Space Marines the Sisters will probably have more than just the one Our Martyred Lady style of play when they publish the rules when the new edition drops. Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946334 Share on other sites More sharing options...
Urauloth Posted May 10, 2023 Share Posted May 10, 2023 Looks fun to play and to play against. I really like boltguns being rapid fire for humans and flat two-shot weapons for astartes. That's a great mesh of narrative flavour and rules design. DemonGSides, Montford, Lazarine and 6 others 4 5 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946347 Share on other sites More sharing options...
BitsHammer Posted May 11, 2023 Share Posted May 11, 2023 10 hours ago, Subtleknife said: I still don't think that means they should be more accurate than a genetically engineered post human. It is janky and not fluffy imo. I don't like plus 1 to wound or hit in general imo. It wouldn't be so bad if GW used a more granular system but on a D6 system it isn't a good look for me. Maybe if the Transhumans had more faith it'd be different. Raven1, VengefulJan and Mithrilforge 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946358 Share on other sites More sharing options...
BitsHammer Posted May 11, 2023 Share Posted May 11, 2023 9 hours ago, ThePenitentOne said: Simulacra no longer allow a unit to use an additional AoF per phase, which sucks. We didn't need another tool to GENERATE MD, we need tools to let us USE MD. And we lost that in the simulacra. Poor decision making on GW's part. Not as bad as what I had been prepared for mind you, but it was certainly my biggest disappointment in this preview. Each unit from your army can do a single AoF per phase. How many more do we need exactly? RolandTHTG, VengefulJan, Oxydo and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946359 Share on other sites More sharing options...
BitsHammer Posted May 11, 2023 Share Posted May 11, 2023 9 hours ago, Bradeh said: Sisters having a better Storm Bolter than a 1st Company Captain is a choice! That's not new. painting.for.my.sanity, MoshJason and VengefulJan 3 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946360 Share on other sites More sharing options...
spessmarine Posted May 11, 2023 Share Posted May 11, 2023 11 hours ago, BitsHammer said: Uh, have you not seen how Order of Our Martyered Lady works right now? Being inspired by martyrs and hitting better is a thing they do now. They just traded out extra Miracle Dice for the ability to wound better as the unit gets more wounded. 20 minutes ago, BitsHammer said: That's not new. Noticed this a bunch too the other day for the Volcano Cannon, not just here. People who have no clue about how things already are weighing in to complain about things staying the same. painting.for.my.sanity, Wugo_Heaving, VengefulJan and 6 others 4 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946367 Share on other sites More sharing options...
Urauloth Posted May 11, 2023 Share Posted May 11, 2023 1 hour ago, BitsHammer said: That's not new. What's the deal with it anyway? I'm not super familiar with Sisters lore, why's it so much beefier than regular stormbolters? Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946382 Share on other sites More sharing options...
ThePenitentOne Posted May 11, 2023 Share Posted May 11, 2023 The strat they need to keep is Moment of Grace. After a roll to hit, to wound or to save, you can discard up to 2 MD which each confer a +1 to the roll, regardless of the value of the MD. It's a get mechanic to deal with ones. The problem is that this is a strat that ALL detachments require, and strats are determined by detachment. Maybe they keep the ability, but make it a unit ability for a Leader or an Aura ability. Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946383 Share on other sites More sharing options...
Bradeh Posted May 11, 2023 Share Posted May 11, 2023 (edited) 1 hour ago, spessmarine said: Noticed this a bunch too the other day for the Volcano Cannon, not just here. People who have no clue about how things already are weighing in to complain about things staying the same. I know what the rules were, my point is that it shouldn't be the case. Sisters shouldn't have better Storm Bolters than Terminators, especially the Captain. Edited May 11, 2023 by Bradeh Lemondish, BitsHammer, Oxydo and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946386 Share on other sites More sharing options...
Cryptix Posted May 11, 2023 Share Posted May 11, 2023 18 minutes ago, Urauloth said: What's the deal with it anyway? I'm not super familiar with Sisters lore, why's it so much beefier than regular stormbolters? Says it right in the name, it's master-crafted, just like how marines get +1D on their master crafted weapons. BitsHammer and Oxydo 2 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946392 Share on other sites More sharing options...
ThePenitentOne Posted May 11, 2023 Share Posted May 11, 2023 Wow, okay bad brain! Somehow I forgot that the 9th ed. rule was that only one unit could do an AoF per phase unless they had a simulacrum. So yeah, new AoF WAY better, and though I'd still love for a single unit to be able to use two MD every now and again, the MD generation probably is the better bargain now because of the issue with ones. BitsHammer and phandaal 2 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946395 Share on other sites More sharing options...
BitsHammer Posted May 11, 2023 Share Posted May 11, 2023 1 hour ago, Urauloth said: What's the deal with it anyway? I'm not super familiar with Sisters lore, why's it so much beefier than regular stormbolters? It's Artificer crafted. Basically it's like a Master-crafted Stormbolter would be for the Marines: the best example of that gun you can find. Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946400 Share on other sites More sharing options...
BitsHammer Posted May 11, 2023 Share Posted May 11, 2023 1 hour ago, Bradeh said: I know what the rules were, my point is that it shouldn't be the case. Sisters shouldn't have better Storm Bolters than Terminators, especially the Captain. Then he should be using a Master-Crafted Stormbolter. Captains have a Master-Crafted Bolter option (d2 and all), seems they trade that for more shots though. Oxydo, VengefulJan and HolyPestilience 3 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946401 Share on other sites More sharing options...
spessmarine Posted May 11, 2023 Share Posted May 11, 2023 Gotta say, big gulf in rules complexity for SoBs from 9th -> 10th (good thing!) Also, guess this also confirms that detachments is where subfactions will continue to exist, provided you have subfactions of significance? So things like first founding chapters and probably Farsight Enclaves. Wonder how many detachments to a codex. DA/BA/etc overwrite OoM with their faction ability. Their detachments will be interesting, DA ones are easier to guess, one per Wing. But now I am getting off-topic. VengefulJan 1 Back to top Link to comment https://bolterandchainsword.com/topic/378600-10th-edition-warhammer-faction-focus-adepta-sororitas/page/3/#findComment-5946410 Share on other sites More sharing options...
