Fluff Competition
goggen
No problem B)
Welcome to Imperial Dating 101, I'm Mr Trader, your teacher for today. Pay attention, there may be a quiz later. ;)
A typical dating code is written 0555969.M02 or 0555969/M02. The M02 means it's a second millennium date. The other numbers give the year and fraction of the year.
0 (check number) 555 (year fraction number) 969 (year number) M02 (millennium)
The check number is present due to the temporal distortions which affect ships in warp-space as well as worlds which are remote, or isolated, from Earth. In this case, a '0' is Earth standard date, typically referring to an event that occured with the Terran Solar system.
The year digits specify which year within the millennium running from 001-000 (one thousand). For example 0280964/M39 is the year 964 of the thirty ninth millennium. In our terms, the year 38,964.
The year fraction is for 'administrative purposes' (ie. to make it sound cooler and so that non-geeks can't work out what is means ;) ). The year is divided into 1000 equal segments; 001-000.
To work out the equivalent Gregorian day, simply divide the fraction number by 1000 and multiply by 365. ie:
555
1000 = 0.555 x 365 = 202.575 (or the 202nd day of the year, and just after midday)
The 202nd day of the year in July 21st. Put that together with 1969, and as every schoolboy knows, you get Neil Armstrong walking on the moon (or in a TV studio in somewhere america, depending on whether you believe the conspiracy theorists or not :eek )
Class dismissed.
++edit++
Beaten to it! Not at all below the belt though - a knowledge of the dating system should be an integral part of basic fluff knowledge :P Look at 0555969/M02 and you should instantly know it's 1969. It's simplicity itself to carry out a a few seconds of mental arithmatic and you have day 202. Not difficult at all
Umm...shot in the dark, wasnt it a uprising in the 9th century of the 41st millenium or something? Im probably completley wrong, but it was worth a shot! Hmm...just dfound the CA I was after, but goggen got there first damn him! It was called the Badab Uprising though, Im pretty sure of that.
