Augustus b'Raass Posted January 19, 2015 Share Posted January 19, 2015 Bragging rights, plus you can expect awesome badges and medallions :tu: Noctem Cultor 1 Back to top Link to comment Share on other sites More sharing options...
Noctem Cultor Posted January 20, 2015 Share Posted January 20, 2015 http://i932.photobucket.com/albums/ad165/Liamgregg1988/Night%20Lords%20WIP/temporary_zps796f3590.jpgHey guys, just uploaded pics of the changes I've made to my Praetor Lord. Can I get your opinion on if he needs a cloak/cape to complete the transition to make him look the part. Link to comment Share on other sites More sharing options...
Conn Eremon Posted January 21, 2015 Share Posted January 21, 2015 Well, with the shield/flayed corpse, his visual does lean pretty heavily to his left. A right-flowing cape could do the trick. What if, instead of a true cape, it's shredded rags that cling to his right pauldron, painted up to look like the removed skin? You could still flare it up a bit, maybe to fill in some of the empty space between sword arm and body (but perhaps behind both). Not enough to be a cape, but enough to seem like he overdid it with the purity seals, from far away. And then he gets closer, and the screaming begins. Noctem Cultor 1 Back to top Link to comment Share on other sites More sharing options...
Kol Saresk Posted January 21, 2015 Share Posted January 21, 2015 Well, with the shield/flayed corpse, his visual does lean pretty heavily to his left. A right-flowing cape could do the trick. What if, instead of a true cape, it's shredded rags that cling to his right pauldron, painted up to look like the removed skin? You could still flare it up a bit, maybe to fill in some of the empty space between sword arm and body (but perhaps behind both). Not enough to be a cape, but enough to seem like he overdid it with the purity seals, from far away. And then he gets closer, and the screaming begins. Perhaps something like Boba Fett's shoulder cape? But torn apart as you suggested? Noctem Cultor 1 Back to top Link to comment Share on other sites More sharing options...
Conn Eremon Posted January 21, 2015 Share Posted January 21, 2015 That's actually exactly what I was trying to suggest. Had Boba Fett in my head and everything. I suppose I should have just said it then? Link to comment Share on other sites More sharing options...
Noctem Cultor Posted January 21, 2015 Share Posted January 21, 2015 Thanks guys sounds like a plan. Link to comment Share on other sites More sharing options...
Balthamal Posted January 21, 2015 Share Posted January 21, 2015 Call it what you will; The Murder Duel, Sanguis Extremis, Third Blood, or whatever your legion calls it. This is how disputes are settled and your mettle tested. step into the cage! What you require: Dice, fraternal honesty, the ability to judge your peers justly when called upon The rules: players using the Centurion entry or appropriate consul must choose their arms. basic statline: ws 5, s 4, t 4, w 3, I 5, ld 9 sv 3+ bolt pistol ccw Consul options (if desired): chaplain: power weapon, zealot. Legion champion: one master crafted selected weapon, ws 6. Librarian: up to lvl 2 mastery, force axe sword or stave. Forge Lord: servo arm, artificer armour (2+ save). Primus medicae: narthecium (feel no pain), needle pistol. Vigilator: cameleoline, bolter, may take scout armour (4+ save), may Not take thunder hammer, boarding shield, power fist or lightning claws. Options non terminator: exchange ccw and/or bolt pistol Heavy chainsword charnabal sabre power weapon power fist lightning claw single lightning claw pair thunder hammer swap PA for artificer armour (2+ save) May take One of the following combat shield refractor field boarding shield may take terminator armour (2+ 5++) or cataphractii (2+ 4++) You gain power weapon and combi bolter, which can be swapped for: Power fist thunder hammer chainfist lightning claw (single or pair) Once gear is selected, players roll 1d6. Highest goes first. Psychic phase if librarian selected. Powers chosen from combat applicable options on the relevant tables (up to 2 plus force), warp charge 1d6 + mastery level (1 or 2). Opponent rolls 1d6 for charge if not a librarian for deny the witch. These are successful on a roll of 6. After this phase any legion wargear affecting combat is rolled ( eg trophies of judgement fear test [unmodified ld test taken on 2d6, anything over 9 is a fail]) Combat ensues: player with highest result goes first. Any initiative modified weapons (power fist, power axe, thunder hammer, servo arm etc) strike in order, ie later player turns (10 fastest, 1 slowest). Choosing how many attacks to apply to each weapon a player rolls according to the hit/wound chart, applying modifiers (+1 attack for extra weapon, 2 x special weapons, strength adjustments). Player 2 gets to then roll appropriate saves (1d6 per wound). If iniative is the same as opponent, player 2 gets to roll their attacks (you can be theoretically dead at this point, but for a text based internet game, this is how we have to play for now). Assuming the players havent gloriodly wiped each other out, remaining weapons (i1 weapons for example) can be used, and assuming players have wounds left, the process starts over from the point: combat ensues. Keep going until one or both players lose all 3 wounds. This means the match can end in a draw. Shake hands or start over! Winner gets bragging rights, loser takes hisor her loss on the chin. For now.. right this obviously requires mod approval, some potential revisions but hopefully it enables forumites some fun distraction/ debate settling ability. Not even the option of a chainglaive? Are we not the VIII Legion? Report to Flint's crucible of correction immediately or be judged before the Kyroptera Augustus b'Raass 1 Back to top Link to comment Share on other sites More sharing options...
Kol Saresk Posted January 21, 2015 Share Posted January 21, 2015 Well, it is AP3 and it is supposed uncommon, so if everyone ran around with it, it'd be kind of bleh. Link to comment Share on other sites More sharing options...
helterskelter Posted January 21, 2015 Share Posted January 21, 2015 See this is why i need eyes to proof read. I'll edit in a section on legion specific wargear. Didnt want to explicitly state chainglaive as i'd like everyone in the b+c to have a go, and if i put in chainglaive, the WE for example would have to edit in all their cc gear and so on. Not excluding the use of chainglaives or trophies of judgement. As long as its relevant to hand to hand its a go Link to comment Share on other sites More sharing options...
Xin Ceithan Posted January 21, 2015 Share Posted January 21, 2015 Should get an App for that MurderdueliOS anyone? Link to comment Share on other sites More sharing options...
Flint13 Posted January 21, 2015 Author Share Posted January 21, 2015 There are a couple of virtual dice roller/blogs we could use. http://dicelog.com/dice This one lets you create a blog for just you and assorted buddies so you can keep everything straight and see each others moves/rolls. Could be useful for "official" murder-duelin' Noctem Cultor and Xin Ceithan 2 Back to top Link to comment Share on other sites More sharing options...
Slips Posted January 21, 2015 Share Posted January 21, 2015 We could also use : http://roll20.net/ that has chat functionality and rolling is as easy as /roll 1d6 Mostly used for internet based D&D / TT RPGs but hey, it could work. Link to comment Share on other sites More sharing options...
Flint13 Posted January 21, 2015 Author Share Posted January 21, 2015 Oh yeah, roll20 is *way* more legit. I'm on it! Link to comment Share on other sites More sharing options...
Kol Saresk Posted January 21, 2015 Share Posted January 21, 2015 Sweet Link to comment Share on other sites More sharing options...
Noctem Cultor Posted January 21, 2015 Share Posted January 21, 2015 @Conn And Kol Thanks for your advice guys, im very happy with my Praetor Lord Zaqar now, the small shoulder cloak became swept to the back (magnetised model meant I had to compromise). But he now looks the full part! http://i932.photobucket.com/albums/ad165/Liamgregg1988/Night%20Lords%20WIP/temporary_zps93b8c38b.jpghttp://i932.photobucket.com/albums/ad165/Liamgregg1988/Night%20Lords%20WIP/temporary_zps18759e86.jpg The Huntmaster is now reminded who is the boss helterskelter, Conn Eremon and Xin Ceithan 3 Back to top Link to comment Share on other sites More sharing options...
Slips Posted January 21, 2015 Share Posted January 21, 2015 Oh yeah, roll20 is *way* more legit. I'm on it! Sweet Glad to be an enabler in this Inter-Legion Fratricide Competition Link to comment Share on other sites More sharing options...
helterskelter Posted January 21, 2015 Share Posted January 21, 2015 Slipstream vs flint in a shade of sevatar vs sigismund? :p Slips 1 Back to top Link to comment Share on other sites More sharing options...
Slips Posted January 21, 2015 Share Posted January 21, 2015 Slipstream vs flint in a shade of sevatar vs sigismund? I assume if it were to happen that I'd use Night Lords rule right? Cuz if not I'm abusing the ever loving :cuss: out of our Solarite Power Gauntlets and Vigil Pattern Storm Shields :P Link to comment Share on other sites More sharing options...
Noctem Cultor Posted January 21, 2015 Share Posted January 21, 2015 I'm looking forward to watching my siblings of the 8th and our cousins from the lesser Legions kill each other for sport. In a way it reminds me of home, it reminds me of Nostramo. Link to comment Share on other sites More sharing options...
Flint13 Posted January 21, 2015 Author Share Posted January 21, 2015 Slipstream vs flint in a shade of sevatar vs sigismund? :P I assume if it were to happen that I'd use Night Lords rule right? Cuz if not I'm abusing the ever loving :cuss: out of our Solarite Power Gauntlets and Vigil Pattern Storm Shields :P I'd take a precoged Sevatar or Librarian over the most jazzed up Imperial Fist Praetor you could throw down. Especially in 7th Ed when Sev's Ld.7 doesn't make a big difference for getting that sweet sweet pre-cog off. Sev vs Sigismund is a different story though. He's about the only thing in the general points range that will consistently kill Sevatar. It's all about that damn Eternal Warrior *and* the force re-roll of invulns. ...still gets me that his bolt pistol is master crafted when the Black Sword isn't though :D Link to comment Share on other sites More sharing options...
Kol Saresk Posted January 21, 2015 Share Posted January 21, 2015 Attach Sev to a squad for that beautiful +1W. Link to comment Share on other sites More sharing options...
Slips Posted January 22, 2015 Share Posted January 22, 2015 (edited) Slipstream vs flint in a shade of sevatar vs sigismund? I assume if it were to happen that I'd use Night Lords rule right? Cuz if not I'm abusing the ever loving : out of our Solarite Power Gauntlets and Vigil Pattern Storm Shields I'd take a precoged Sevatar or Librarian over the most jazzed up Imperial Fist Praetor you could throw down. Especially in 7th Ed when Sev's Ld.7 doesn't make a big difference for getting that sweet sweet pre-cog off. Sev vs Sigismund is a different story though. He's about the only thing in the general points range that will consistently kill Sevatar. It's all about that damn Eternal Warrior *and* the force re-roll of invulns. ...still gets me that his bolt pistol is master crafted when the Black Sword isn't though Only reason the Black Sword isnt MC'd is because he gets to Re-roll to wound and to hit due to Legion and Personal Rules in a Challenge. Would be a bit overpowered if he could re-roll almost everything. Also, too bad we cant take book 4 relics. I'd totally get that 3++ Melta Cloak since it confers Eternal Warrior :p Edited January 22, 2015 by Slipstreams Link to comment Share on other sites More sharing options...
Slips Posted January 22, 2015 Share Posted January 22, 2015 (edited) Helter, is there a Points limit we should abide by? And if moi and mme Flint are truly going to duke it out, I'll edit this post with 2 possible Characters; a Night Lord and an Imperial Fists in the event that we keep this...within the Legion for simplicitys sake. Sorry for the Double Post :x Night Lords Primus Medicae -Narthecium -Needle Pistol -Volkite Serpenta -Artificer Armor -Jump Pack -Refractor Field -Thunderhammer -Frag & Krak Grenades Imperial Fists Primus Medicae -Narthecium -Needle Pistol -Tartaros Pattern Terminator Armor -Vigil Pattern Storm Shield -Solarite Power Gauntlet (SO MUCH RE-ROLLING TO HIT WTB RE-ROLLING TO WOUND PLEASE) -DAMNIT HELTER I CAN'T TAKE THE INDOMNITAN MANTLE FOR ETERNAL WARRIOR TO TRUMP FLINTS FORCE WEAPON Edited January 22, 2015 by Slipstreams Link to comment Share on other sites More sharing options...
Flint13 Posted January 22, 2015 Author Share Posted January 22, 2015 (edited) Bring it. I'll murder-duel whatever legion you want to throw at me. Also, I have almost figured out how RollD20 works. Edited January 22, 2015 by Flint13 Link to comment Share on other sites More sharing options...
Slips Posted January 22, 2015 Share Posted January 22, 2015 Bring it. I'll murder-duel whatever legion you want to throw at me. Also, I have almost figured out how RollD20 works. I'm still in the process of kinda-figuring it out myself @_@ I'll keep it within the Legion then. Use the Night Lord. MAY RNGESUS GUIDE MY /ROLL MACROS! Link to comment Share on other sites More sharing options...
