lokkorex Posted September 10, 2014 Share Posted September 10, 2014 Fire Golem: looking forward to seeing your tyberos medicae! Grimtalos: Wow, that's a Nice paint job! As for me: Mohahahaha! http://i1216.photobucket.com/albums/dd366/lokkorex/imagejpg1_zpsc43bdbc3.jpg http://i1216.photobucket.com/albums/dd366/lokkorex/imagejpg2_zps91165d25.jpg The post and delivery service gods must have heard my grumbling! Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805713 Share on other sites More sharing options...
Fire Golem Posted September 10, 2014 Share Posted September 10, 2014 Lucky sod! Whatcha got there? Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805720 Share on other sites More sharing options...
Marshal Rohr Posted September 10, 2014 Share Posted September 10, 2014 From my understanding only the big stuff is cast to order, because of the size and larger molds. The infantry upgrades and the like stay in bins read for purchase. Also, if it's got air bubbles or something, that is a miscast. If it's bent or warped, most of the time that is a function of rapid temperature changes in the transportation process (it's really hot in the plane on the ground, and freezing in the air). Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805747 Share on other sites More sharing options...
Fire Golem Posted September 10, 2014 Share Posted September 10, 2014 Well mine won't go on a plane so fingers crossed, but I meant more like air bubbles and stuff, they're quite common in FW models aren't they? Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805754 Share on other sites More sharing options...
Daemon2027 Posted September 10, 2014 Share Posted September 10, 2014 They used to be, not so much any more. You get the odd kit that is a bit crap, but if its to bad they will happily replace. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805777 Share on other sites More sharing options...
Fire Golem Posted September 10, 2014 Share Posted September 10, 2014 Ah okay. I knew they were good at replacing stuff but that's reassuring :) Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805778 Share on other sites More sharing options...
daemonclaw Posted September 10, 2014 Share Posted September 10, 2014 looking good there brothers daismith906 and grimtalos ,looking real good and demon2027 there is alternatives to guitar wire and the tentacle maker that seemed to never be available when i needed it....... gentlemen may i introduce you to window packers ,thats right just chat to your friendly glazier or check out builder stores. these ones i found on site and were a bit bent so i glued them to thick plastic to level them out and those wiggly worms are the result http://i2.photobucket.com/albums/y30/daemonclaw/DSCN0591_zpsfeae3464.jpg hope it helps DC out Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805795 Share on other sites More sharing options...
lokkorex Posted September 10, 2014 Share Posted September 10, 2014 Fire Golem: i've got: -medusan immortals -iron hands mk.3 squad -legion mk.3 armour -legion mk.2 armour -mk.3 command set -legion champion & master of signal -apothecaries -umbra boltguns -chain axes -mk.3 power weapons -boarding assault upgrade set ...and that's about it. Currently it's taking a soapy bath to get rid off that icky sealant or whatever it's called. PS: thanks for the likes, Guys! Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805839 Share on other sites More sharing options...
Daemon2027 Posted September 10, 2014 Share Posted September 10, 2014 Daemonclaw: Well i am off to town tomorrow. Fantastic. I guess you have to well lube it. Nice haul Lokkorex, I want some Immortals. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805846 Share on other sites More sharing options...
daemonclaw Posted September 10, 2014 Share Posted September 10, 2014 i found it worked great with just water ,lightly dampen either side each time you put new greenstuff on and you should be fine .if not a touch of babyoil would be perfect good luck bud Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805865 Share on other sites More sharing options...
Brother Vidius Posted September 10, 2014 Share Posted September 10, 2014 Thanks guys! I have Iron Warriors, Sons of Horus and Word Bearers! I'll be doing the majority of my work on my Iron Warriors so expect some pics at the weekend! Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805873 Share on other sites More sharing options...
Daemon2027 Posted September 10, 2014 Share Posted September 10, 2014 i found it worked great with just water ,lightly dampen either side each time you put new greenstuff on and you should be fine .if not a touch of babyoil would be perfect good luck bud Cool, we have some of the spray baby oil so i could borrow some of that. Save on olive oil. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3805885 Share on other sites More sharing options...
zedmeister Posted September 11, 2014 Share Posted September 11, 2014 Good to see more progress. As for a report, not much to tell. I've finished off 5 bodies of the White Scars, which I'll photograph soon, and made a start on 5 of my Alpha Legion marines with a metallic base coat. Just had a set of Game Air goodies arrive and my next step is to crack open the Air Brush. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806351 Share on other sites More sharing options...
daismith906 Posted September 11, 2014 Share Posted September 11, 2014 Whoohoo my 15 marines have arrived Just cleaning the flash off ready for a soapy bath then it's time to crack on Might be able to complete my vow this month Amazon work by everyone so far - More pics are required Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806377 Share on other sites More sharing options...
Fire Golem Posted September 11, 2014 Share Posted September 11, 2014 Amazon work by everyone so far Absolutely Braziliant ;) ...I'm far too proud of that. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806382 Share on other sites More sharing options...
Daemon2027 Posted September 11, 2014 Share Posted September 11, 2014 I have a little progress on my Iron Farther count as, just need to smooth some bits and add some detail like rivets. However, I have no idea where to place his ranged weapon. I was thinking of giving him a Combi-plasma. Any suggestions: Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806384 Share on other sites More sharing options...
StruManChu Posted September 11, 2014 Share Posted September 11, 2014 He is looking fantastic! I'm ever jealous of people who can use green stuff without it failing spectacularly. In terms of the Combi-weapon, have you considered doing something like Lorenzen did for his Death Guard here? Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806414 Share on other sites More sharing options...
Daemon2027 Posted September 11, 2014 Share Posted September 11, 2014 That is an idea. I am not happy with the chain weapon. Could swap it for the combi bolter, and give him a sheathed sword. May be more Iron Hand like. My gs ability isnt great, its very rough but I am learning and slowly getting better. Its about the right tools and practice. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806423 Share on other sites More sharing options...
Iron Hands Fanatic Posted September 11, 2014 Share Posted September 11, 2014 I'd suggest putting it on a second servo-arm, but it looks like there isn't room. The strap might work though - just use a chain rather than leather, because *dead* flesh is weak. What don't you like about the chainsword? In terms of which is more IH-esque, I'd go for the chainsword over the sword any day - it's just brutal, which always fits the Iron Tenth. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806441 Share on other sites More sharing options...
Daemon2027 Posted September 11, 2014 Share Posted September 11, 2014 I'd suggest putting it on a second servo-arm, but it looks like there isn't room. The strap might work though - just use a chain rather than leather, because *dead* flesh is weak. What don't you like about the chainsword? In terms of which is more IH-esque, I'd go for the chainsword over the sword any day - it's just brutal, which always fits the Iron Tenth. Well its really a chain sabre I would of course use chains. Still not sure. I could stow it under the power pack I suppose. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806445 Share on other sites More sharing options...
chaplain mortis Posted September 11, 2014 Share Posted September 11, 2014 Demon2027....that dude is a bionic BEAST! nice work there mate! regarding the combi/plas...is there room on the inside of the shield for it...facing down, pistol grip outwards on the near edge of the shield...could be "mag-locked" there..failing that..somewhere on the base! Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806646 Share on other sites More sharing options...
Daemon2027 Posted September 11, 2014 Share Posted September 11, 2014 I found a place for it. Pics soon. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806768 Share on other sites More sharing options...
Daemon2027 Posted September 11, 2014 Share Posted September 11, 2014 Here we go, just need to smooth off the rim of the gorget, and we are ready to paint. Combi Plasma is connected by a chain to appease all servants of the Omnissiah. I must admit, having it holstered to the shield would be an awesomely Alpha Legion thing to do... Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806821 Share on other sites More sharing options...
Russ Brother 92 Posted September 11, 2014 Share Posted September 11, 2014 He looks awesome dude :D can't wait to see paint. Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806857 Share on other sites More sharing options...
GhostMalone Posted September 11, 2014 Share Posted September 11, 2014 Holy Efff that IH is amazing brother your skills are superb! Link to comment https://bolterandchainsword.com/topic/295904-casual-30k-hobby-challenge-month-1/page/18/#findComment-3806876 Share on other sites More sharing options...
